Building a Long-Form SMS Concatenator for NICE CXone with Java
- A Java service that splits long SMS text into 3GPP-compliant segments, constructs explicit concatenation payloads with message ID references, and sends them via atomic POST operations to the NICE CXone SMS API.
- The implementation uses the CXone
/api/v2/sms/outboundMessagesendpoint with explicit segmentation matrix logic, UDH header directives, and encoding validation. - The tutorial covers Java 11+, Jackson JSON binding, and the CXone OAuth 2.0 client credentials flow.
- OAuth Client Type: Machine-to-Machine (Client Credentials Grant)
- Required Scopes:
sms:outbound:write,sms:status:read - API Version: CXone REST API v2
- Language/Runtime: Java 11 or higher
- External Dependencies:
com.fasterxml.jackson.core:jackson-databind:2.15.2,java.net.http.HttpClient(built-in)
NICE CXone uses OAuth 2.0 for all API access. You must request a bearer token using your organization ID, client ID, and client secret. The token expires after thirty minutes, so production systems require caching and automatic refresh.
import java.net.URI;
import java.nio.charset.StandardCharsets;
import java.util.Base64;
public class CxoneAuth {
private static final String TOKEN_URL = "https://api.myniceone.com/oauth/token";
private static final ObjectMapper mapper = new ObjectMapper();
public static String fetchAccessToken(String orgId, String clientId, String clientSecret) throws Exception {
String authHeader = Base64.getEncoder().encodeToString((clientId + ":" + clientSecret).getBytes(StandardCharsets.UTF_8));
String body = "grant_type=client_credentials&scope=sms:outbound:write+sms:status:read";
.uri(URI.create(TOKEN_URL))
.header("Authorization", "Basic " + authHeader)
.header("Content-Type", "application/x-www-form-urlencoded")
.header("X-Organization", orgId)
.POST(HttpRequest.BodyPublishers.ofString(body))
.build();
HttpResponse<String> response = HttpClient.newHttpClient().send(request, HttpResponse.BodyHandlers.ofString());
throw new RuntimeException("OAuth token request failed with status: " + response.statusCode());
JsonNode json = mapper.readTree(response.body());
return json.get("access_token").asText();
Expected Response:
"expires_in": 1800,
"token_type": "Bearer"
The X-Organization header is mandatory for CXone routing. Store the token in memory with an expiration timer and refresh it before the thirty-minute window closes to prevent 401 interruptions.
Step 1: Encoding Validation and Segmentation Matrix
SMS concatenation depends entirely on character encoding. GSM-7 supports 160 characters per segment. UCS-2 (UTF-16) supports 70 characters. When concatenation is enabled, the 3GPP specification reserves 7 bytes for the UDH header, reducing GSM-7 to 153 characters and UCS-2 to 67 characters per segment. The CXone gateway enforces a maximum of 10 segments per concatenated message.
This function validates the input string, determines the encoding, and calculates the segmentation matrix.
import java.util.ArrayList;
import java.util.List;
import java.util.regex.Pattern;
public class SmsSegmenter {
private static final Pattern GSM7_PATTERN = Pattern.compile("^[\\x00-\\x7F]*$");
private static final int MAX_SEGMENTS = 10;
private static final int GSM7_CONCAT_LEN = 153;
private static final int UCS2_CONCAT_LEN = 67;
public static record SegmentResult(String encoding, int totalParts, List<String> parts) {}
public static SegmentResult calculateSegments(String message) {
if (message == null || message.isEmpty()) {
throw new IllegalArgumentException("Message content cannot be null or empty");
boolean isGsm7 = GSM7_PATTERN.matcher(message).matches();
String encoding = isGsm7 ? "GSM-7" : "UCS-2";
int segmentLength = isGsm7 ? GSM7_CONCAT_LEN : UCS2_CONCAT_LEN;
int totalParts = (int) Math.ceil((double) message.length() / segmentLength);
if (totalParts > MAX_SEGMENTS) {
"Message exceeds maximum 3GPP concatenation limit. Requested: " + totalParts + ", Maximum: " + MAX_SEGMENTS
List<String> parts = new ArrayList<>();
for (int i = 0; i < totalParts; i++) {
int start = i * segmentLength;
int end = Math.min(start + segmentLength, message.length());
parts.add(message.substring(start, end));
return new SegmentResult(encoding, totalParts, parts);
Why this matters: The CXone SMS engine rejects payloads that exceed 10 segments. Calculating the matrix upfront prevents runtime 400 errors. The 7-byte UDH reduction is handled by the carrier gateway, but your application must account for it during splitting to avoid truncation.
Step 2: Concatenation Payload Construction with UDH Directives
The CXone API expects explicit concatenation metadata. When you provide concatenationId, totalParts, and partIndex, the platform automatically generates the UDH header and routes the segments to the correct carrier gateway. You must include a webhook URL to receive reassembly status events.
import com.fasterxml.jackson.databind.node.ObjectNode;
import java.util.UUID;
public class SmsPayloadBuilder {
public static String buildConcatenationPayload(
String toNumber,
String fromNumber,
String messagePart,
String concatenationId,
int totalParts,
int partIndex,
String encoding,
String webhookUrl) throws Exception {
ObjectNode payload = mapper.createObjectNode();
payload.put("to", toNumber);
payload.put("from", fromNumber);
payload.put("message", messagePart);
payload.put("concatenationId", concatenationId);
payload.put("totalParts", totalParts);
payload.put("partIndex", partIndex + 1); // CXone uses 1-based indexing
payload.put("encoding", encoding);
payload.put("webhookUrl", webhookUrl);
return mapper.writerWithDefaultPrettyPrinter().writeValueAsString(payload);
HTTP Request Example:
POST /api/v2/sms/outboundMessages HTTP/1.1
Host: api.myniceone.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
X-Organization: 1234567890
"to": "+14155552671",
"from": "+14155559876",
"message": "This is segment 1 of the long form message...",
"concatenationId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"totalParts": 3,
"partIndex": 1,
"encoding": "GSM-7",
"webhookUrl": "https://your-server.com/cxone/sms/webhook"
Expected Response:
"id": "9876543210abcdef",
"totalParts": 3,
"partIndex": 1,
"status": "queued",
"createdDate": "2024-01-15T10:30:00.000Z"
The partIndex is 1-based in CXone. The gateway returns a unique message id for each segment. You must store these IDs to track individual segment delivery and final reassembly status.
Step 3: Atomic POST Operations with Rate Limit Handling
Sending segments requires atomic POST operations. The CXone API enforces strict rate limits. A 429 response requires exponential backoff. This implementation handles retries and validates the HTTP response before proceeding.
import java.time.Duration;
public class SmsSender {
private static final String BASE_URL = "https://api.myniceone.com/api/v2/sms/outboundMessages";
private static final int MAX_RETRIES = 3;
private static final HttpClient httpClient = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(10))
.build();
public static String sendSegment(String token, String orgId, String payload) throws Exception {
.uri(URI.create(BASE_URL))
.POST(HttpRequest.BodyPublishers.ofString(payload))
.build();
int attempt = 0;
Exception lastException = null;
while (attempt < MAX_RETRIES) {
int status = response.statusCode();
if (status == 201 || status == 200) {
return response.body();
if (status == 429) {
long retryAfter = Long.parseLong(response.headers().firstValue("Retry-After").orElse("1"));
Thread.sleep(retryAfter * 1000);
attempt++;
continue;
throw new RuntimeException("SMS send failed with status " + status + ": " + response.body());
throw lastException;
Why this matters: The CXone SMS gateway processes segments sequentially per concatenationId. If you send part 3 before part 1, the gateway queues them but may delay reassembly. Atomic POST with retry logic ensures every segment reaches the queue without dropping during transient network congestion or rate limiting.
Step 4: Webhook Reassembly Tracking and Latency Metrics
CXone pushes delivery status to the webhookUrl you provided. The payload contains status, errorMessage, and deliveredDate. You must track latency between segment dispatch and final delivery, calculate assembly success rates, and generate audit logs for governance.
import java.time.Instant;
import java.time.temporal.ChronoUnit;
import java.util.Map;
public class SmsWebhookHandler {
private static final Map<String, Instant> segmentDispatchTimes = new ConcurrentHashMap<>();
private static final Map<String, Integer> concatenationCounts = new ConcurrentHashMap<>();
private static final Map<String, Integer> successfulAssemblies = new ConcurrentHashMap<>();
public static void registerDispatch(String concatenationId, int totalParts) {
Instant now = Instant.now();
segmentDispatchTimes.put(concatenationId, now);
concatenationCounts.put(concatenationId, totalParts);
public static void handleWebhook(String body) throws Exception {
JsonNode json = mapper.readTree(body);
String concatenationId = json.get("concatenationId").asText();
String status = json.get("status").asText();
String messageId = json.get("id").asText();
System.out.println("Webhook received for message: " + messageId + " | Status: " + status);
if ("delivered".equals(status)) {
successfulAssemblies.merge(concatenationId, 1, Integer::sum);
Integer expected = concatenationCounts.get(concatenationId);
Integer received = successfulAssemblies.getOrDefault(concatenationId, 0);
if (expected != null && received >= expected) {
Instant dispatchTime = segmentDispatchTimes.get(concatenationId);
long latencySeconds = ChronoUnit.SECONDS.between(dispatchTime, Instant.now());
System.out.println("CONCATENATION COMPLETE: " + concatenationId +
" | Latency: " + latencySeconds + "s | Parts: " + received + "/" + expected);
// Audit log generation
logAudit(concatenationId, received, latencySeconds);
} else if ("undeliverable".equals(status) || "rejected".equals(status)) {
System.err.println("CONCATENATION FAILED: " + concatenationId + " | Reason: " + json.get("errorMessage"));
private static void logAudit(String concatenationId, int parts, long latencySeconds) {
// In production, write to structured logging or SIEM
System.out.printf("AUDIT_LOG | concatenationId=%s | parts=%d | latency=%ds | outcome=SUCCESS%n",
concatenationId, parts, latencySeconds);
Why this matters: Carriers often reorder segments during transit. The webhook handler counts successful deliveries per concatenationId. When the count matches totalParts, the assembly is complete. Tracking latency and success rates provides visibility into carrier routing delays and prevents silent truncation during high-volume scaling.
The following Java class integrates authentication, segmentation, payload construction, atomic sending, and webhook handling into a single executable module. Replace the placeholder credentials before execution.
public class CxoneSmsConcatenator {
private static final String ORG_ID = "YOUR_ORG_ID";
private static final String CLIENT_ID = "YOUR_CLIENT_ID";
private static final String CLIENT_SECRET = "YOUR_CLIENT_SECRET";
private static final String WEBHOOK_URL = "https://your-server.com/cxone/sms/webhook";
String token = CxoneAuth.fetchAccessToken(ORG_ID, CLIENT_ID, CLIENT_SECRET);
String longMessage = "This is a long form message designed to test the NICE CXone SMS concatenation engine. " +
"It exceeds standard GSM-7 limits and requires explicit segmentation matrix validation. " +
"The system will split this text, inject UDH headers, and track reassembly via webhooks. " +
"Proper encoding verification prevents truncation during carrier scaling. " +
"Audit logging ensures governance compliance for all transmitted segments.";
String toNumber = "+14155552671";
String fromNumber = "+14155559876";
SmsSegmenter.SegmentResult segments = SmsSegmenter.calculateSegments(longMessage);
String concatenationId = java.util.UUID.randomUUID().toString();
SmsWebhookHandler.registerDispatch(concatenationId, segments.totalParts());
System.out.println("Starting concatenation: " + concatenationId + " | Parts: " + segments.totalParts());
for (int i = 0; i < segments.totalParts(); i++) {
String payload = SmsPayloadBuilder.buildConcatenationPayload(
toNumber, fromNumber, segments.parts().get(i),
concatenationId, segments.totalParts(), i,
segments.encoding(), WEBHOOK_URL
String response = SmsSender.sendSegment(token, ORG_ID, payload);
System.out.println("Segment " + (i + 1) + " queued: " + mapper.readTree(response).get("id").asText());
System.out.println("All segments dispatched. Awaiting webhook reassembly events.");
} catch (Exception e) {
e.printStackTrace();
Error: 400 Bad Request - Invalid Concatenation Schema
- What causes it: The
partIndexexceedstotalParts, ortotalPartsexceeds 10. The CXone gateway validates the segmentation matrix before queuing. - How to fix it: Verify your segmentation calculation respects the 10-segment maximum. Ensure
partIndexis 1-based and matches the array position. - Code showing the fix: The
SmsSegmenter.calculateSegmentsmethod throws an explicit exception whentotalParts > 10. Adjust your message length or switch to MMS endpoints for longer content.
- What causes it: You exceeded the CXone SMS rate limit for your organization tier. The gateway throttles outbound POST operations.
- How to fix it: Implement exponential backoff. The
SmsSender.sendSegmentmethod reads theRetry-Afterheader and sleeps accordingly. - Code showing the fix: The retry loop in
SmsSenderincrementsattemptand sleeps for the duration specified by the gateway. Do not bypass this logic.
Error: 413 Payload Too Large
- What causes it: The JSON payload exceeds the CXone request size limit, or the webhook URL is malformed.
- How to fix it: Trim unnecessary fields from the payload. Ensure
webhookUrlis a valid HTTPS endpoint. CXone rejects HTTP webhooks for SMS status callbacks. - Code showing the fix: Validate the webhook URL format before constructing the payload. Use
java.net.URI.create(webhookUrl)to verify syntax.
