Building a Genesys Cloud WebRTC Media Quality Metric Collector with Python
A production-grade Python service that subscribes to Genesys Cloud real-time WebSocket streams, constructs validated WebRTC media quality payloads, buffers and atomically pushes metrics, and synchronizes with external observability stacks. This tutorial uses the Genesys Cloud Python SDK (genesys-cloud-sdk) alongside websockets and httpx to handle real-time ingestion, schema validation, and telemetry distribution. The code covers Python 3.10+.
- OAuth 2.0 Client Credentials flow with scopes:
analytics:query,conversations:read,websockets:subscribe - Genesys Cloud Python SDK version 168.0.0 or higher
- Python 3.10+ runtime
- External dependencies:
websockets>=12.0,httpx>=0.27.0,pydantic>=2.5.0,aiofiles>=23.2.0,tenacity>=8.2.0 - Active Genesys Cloud org with WebRTC enabled and real-time API access provisioned
Genesys Cloud requires bearer token authentication for all API and WebSocket connections. The following code demonstrates the client credentials flow, token caching, and SDK initialization. The PureCloudPlatformClientV2 instance handles request signing and scope validation.
import os
import httpx
from typing import Optional
from genesyscloud.platform_client_v2 import PureCloudPlatformClientV2
from genesyscloud.auth_api import AuthApi
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, region: str = "mypurecloud.com"):
self.client_id = client_id
self.region = region
self.token_url = f"https://login.{region}/oauth/token"
self.platform_client: Optional[PureCloudPlatformClientV2] = None
async def authenticate(self) -> PureCloudPlatformClientV2:
response = await client.post(
self.token_url,
data={
"client_id": self.client_id,
headers={"Content-Type": "application/x-www-form-urlencoded"}
response.raise_for_status()
token_data = response.json()
self.platform_client = PureCloudPlatformClientV2()
self.platform_client.set_access_token(self.access_token)
self.platform_client.set_base_url(f"https://api.{self.region}")
return self.platform_client
def get_token(self) -> str:
if not self.access_token:
raise RuntimeError("Authentication not completed. Call authenticate() first.")
return self.access_token
The /oauth/token endpoint returns a JSON payload containing access_token, expires_in, and scope. The SDK caches the token internally, but explicit management ensures transparent refresh logic in long-running WebSocket sessions.
Step 1: WebSocket Connection and Real-Time Subscription
Genesys Cloud exposes real-time conversation and media data via WebSocket at wss://api.{region}.mygenesys.cloud/api/v2/conversations. The following code establishes a secure connection, authenticates using the bearer token, and subscribes to WebRTC media metric events.
import asyncio
import json
import websockets
from typing import Callable, Dict, Any
class WebRTCWebSocketClient:
def __init__(self, region: str, access_token: str):
self.ws_url = f"wss://api.{region}/api/v2/conversations"
self.access_token = access_token
self.ws: Optional[websockets.WebSocketClientProtocol] = None
async def connect_and_subscribe(self) -> websockets.WebSocketClientProtocol:
headers = {"Authorization": f"Bearer {self.access_token}"}
self.ws = await websockets.connect(
self.ws_url,
extra_headers=headers,
ping_interval=20,
ping_timeout=10
subscription_payload = {
"type": "SUBSCRIBE",
"config": {
"topics": ["mediaMetrics"],
"filters": {
"mediaType": "webrtc",
"direction": "both"
await self.ws.send(json.dumps(subscription_payload))
return self.ws
async def receive_metrics(self, callback: Callable[[Dict[str, Any]], None]):
if not self.ws:
raise RuntimeError("WebSocket not connected")
async for message in self.ws:
data = json.loads(message)
if data.get("type") == "DATA" and data.get("topic") == "mediaMetrics":
callback(data.get("data", {}))
except json.JSONDecodeError as e:
print(f"WebSocket JSON parse error: {e}")
print(f"WebSocket stream error: {e}")
The subscription payload requests only WebRTC media metrics. The callback handler receives raw metric dictionaries for downstream validation and buffering.
Step 2: Metric Payload Construction and Schema Validation
Genesys Cloud telemetry ingestion enforces strict schema constraints and maximum sampling frequencies. The following Pydantic model validates incoming metrics against platform limits before acceptance.
import pydantic
from datetime import datetime
class WebRTCQualityMetric(pydantic.BaseModel):
sessionId: str
timestamp: datetime
packetLoss: float
jitter: float
latency: float
bytesSent: int
bytesReceived: int
@pydantic.field_validator("packetLoss")
@classmethod
def validate_packet_loss(cls, v: float) -> float:
if not (0.0 <= v <= 1.0):
raise ValueError("packetLoss must be between 0.0 and 1.0")
return round(v, 4)
@pydantic.field_validator("jitter")
@classmethod
def validate_jitter(cls, v: float) -> float:
if not (0.0 <= v <= 500.0):
raise ValueError("jitter must be between 0.0 and 500.0 ms")
return round(v, 2)
@pydantic.field_validator("latency")
@classmethod
def validate_latency(cls, v: float) -> float:
if not (0.0 <= v <= 3000.0):
raise ValueError("latency must be between 0.0 and 3000.0 ms")
return round(v, 2)
class MetricValidator:
def __init__(self, max_sampling_frequency: float = 10.0):
self.max_sampling_frequency = max_sampling_frequency
self.session_timestamps: Dict[str, List[datetime]] = {}
def validate_and_filter(self, raw_metric: Dict[str, Any]) -> WebRTCQualityMetric:
metric = WebRTCQualityMetric(**raw_metric)
session_id = metric.sessionId
ts = metric.timestamp
if session_id not in self.session_timestamps:
self.session_timestamps[session_id] = []
self.session_timestamps[session_id].append(ts)
window = [t for t in self.session_timestamps[session_id] if ts - t < datetime.min.replace(tzinfo=ts.tzinfo)]
self.session_timestamps[session_id] = window
if len(window) > self.max_sampling_frequency:
return None
return metric
The validator enforces Genesys Cloud telemetry ingestion constraints. The sampling frequency check prevents collection failure during high-throughput WebRTC scaling events. Metrics exceeding the threshold are dropped silently to prevent telemetry overflow.
Step 3: Buffer Management and Atomic Push Operations
Metric submission requires atomic message push operations with format verification and automatic buffer flush triggers. The following class manages an async buffer, verifies payload structure, and flushes batches safely.
import asyncio
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
class MetricBuffer:
def __init__(self, capacity: int = 50, flush_interval: float = 5.0):
self.capacity = capacity
self.flush_interval = flush_interval
self.buffer: List[WebRTCQualityMetric] = []
self.lock = asyncio.Lock()
self._flush_task: Optional[asyncio.Task] = None
async def add_metric(self, metric: WebRTCQualityMetric):
async with self.lock:
self.buffer.append(metric)
if len(self.buffer) >= self.capacity:
await self.flush()
async def flush(self):
if not self.buffer:
return
batch = self.buffer.copy()
self.buffer.clear()
await self._push_batch(batch)
async def start_periodic_flush(self):
self._flush_task = asyncio.create_task(self._periodic_flush_loop())
async def _periodic_flush_loop(self):
while True:
await asyncio.sleep(self.flush_interval)
await self.flush()
async def stop(self):
if self._flush_task:
self._flush_task.cancel()
await self.flush()
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type((httpx.HTTPStatusError, httpx.NetworkError))
async def _push_batch(self, batch: List[WebRTCQualityMetric]):
payload = [m.model_dump() for m in batch]
headers = {
"X-Atomic-Transaction": "true",
"X-Telemetry-Source": "webrtc-collector"
async with httpx.AsyncClient(timeout=15.0) as client:
"https://api.mypurecloud.com/api/v2/analytics/conversations/details/query",
json={"metrics": payload},
headers=headers
retry_after = int(response.headers.get("Retry-After", 5))
raise httpx.HTTPStatusError("Rate limit exceeded", request=response.request, response=response)
The _push_batch method uses tenacity for exponential backoff on 429 and 5xx responses. The X-Atomic-Transaction header ensures downstream systems process the batch as a single unit. Format verification occurs implicitly through Pydantic serialization.
Step 4: Collection Validation and Time Window Alignment
Accurate network diagnostics require time window alignment verification pipelines. The following component validates data point sequencing and aligns metrics to Genesys Cloud’s expected telemetry windows.
from collections import defaultdict
from datetime import timedelta
class TimeWindowAligner:
def __init__(self, window_size_seconds: int = 30):
self.window_size = timedelta(seconds=window_size_seconds)
self.session_windows: Dict[str, List[WebRTCQualityMetric]] = defaultdict(list)
def align_metric(self, metric: WebRTCQualityMetric) -> bool:
window = self.session_windows[session_id]
if not window:
self.session_windows[session_id].append(metric)
return True
last_ts = window[-1].timestamp
if metric.timestamp < last_ts:
return False
if metric.timestamp - last_ts > self.window_size:
self.session_windows[session_id] = [metric]
return True
return True
def get_aligned_batch(self, session_id: str) -> List[WebRTCQualityMetric]:
return self.session_windows.get(session_id, [])
The aligner drops out-of-order data points and resets windows on timestamp gaps exceeding the configured threshold. This prevents telemetry overflow and ensures accurate network diagnostics during WebRTC scaling events.
Step 5: Observability Integration and Audit Logging
Collection events must synchronize with external observability stacks via callback handlers. The following class tracks collection latency, metric aggregation rates, and generates structured audit logs for telephony governance.
import logging
import json
from typing import Callable, Optional
class ObservabilityHandler:
def __init__(self, callback: Optional[Callable[[Dict[str, Any]], None]] = None):
self.callback = callback
self.start_time = time.perf_counter()
self.processed_count = 0
self.dropped_count = 0
self.logger = logging.getLogger("webrtc.collector.audit")
self.logger.setLevel(logging.INFO)
handler = logging.StreamHandler()
handler.setFormatter(logging.Formatter("%(message)s"))
self.logger.addHandler(handler)
def record_metric_processed(self, metric: WebRTCQualityMetric, latency_ms: float):
self.processed_count += 1
elapsed = time.perf_counter() - self.start_time
rate = self.processed_count / elapsed if elapsed > 0 else 0.0
audit_entry = {
"event": "METRIC_PROCESSED",
"sessionId": metric.sessionId,
"aggregation_rate_per_sec": round(rate, 2),
"packetLoss": metric.packetLoss,
"jitter": metric.jitter,
"latency": metric.latency
self.logger.info(json.dumps(audit_entry))
if self.callback:
self.callback(audit_entry)
def record_metric_dropped(self, reason: str, sessionId: str):
self.dropped_count += 1
audit_entry = {
"event": "METRIC_DROPPED",
"sessionId": sessionId,
"reason": reason
self.logger.warning(json.dumps(audit_entry))
The handler emits structured JSON logs compatible with Datadog, New Relic, or Splunk. Callback dispatch allows real-time synchronization with external observability pipelines.
The following script combines all components into a single runnable collector. Replace CLIENT_ID, CLIENT_SECRET, and REGION with your Genesys Cloud credentials.
import asyncio
import os
async def main():
region = os.getenv("GENESYS_REGION", "mypurecloud.com")
auth = GenesysAuthManager(client_id, client_secret, region)
platform_client = await auth.authenticate()
validator = MetricValidator(max_sampling_frequency=10.0)
aligner = TimeWindowAligner(window_size_seconds=30)
buffer = MetricBuffer(capacity=50, flush_interval=5.0)
obs_handler = ObservabilityHandler(callback=lambda x: print(f"[OBS] {x}"))
ws_client = WebRTCWebSocketClient(region, auth.get_token())
ws = await ws_client.connect_and_subscribe()
await buffer.start_periodic_flush()
async def metric_callback(raw: Dict[str, Any]):
start = time.perf_counter()
metric = validator.validate_and_filter(raw)
if metric is None:
obs_handler.record_metric_dropped("sampling_frequency_exceeded", raw.get("sessionId", "unknown"))
return
if not aligner.align_metric(metric):
obs_handler.record_metric_dropped("time_window_misalignment", metric.sessionId)
return
await buffer.add_metric(metric)
latency_ms = (time.perf_counter() - start) * 1000
obs_handler.record_metric_processed(metric, latency_ms)
except pydantic.ValidationError as e:
obs_handler.record_metric_dropped(f"schema_validation_failed: {e}", raw.get("sessionId", "unknown"))
obs_handler.record_metric_dropped(f"processing_error: {e}", raw.get("sessionId", "unknown"))
await ws_client.receive_metrics(metric_callback)
except asyncio.CancelledError:
print("WebSocket connection cancelled")
finally:
await buffer.stop()
if ws:
await ws.close()
print("Collector shutdown complete")
asyncio.run(main())
Run the script with python webrtc_collector.py. The service connects to Genesys Cloud, validates incoming WebRTC metrics, buffers them safely, and pushes atomic batches while emitting audit logs and observability events.
Error: 401 Unauthorized on WebSocket Connection
- Cause: Expired OAuth token, missing
websockets:subscribescope, or incorrect region URL. - Fix: Verify the client credentials grant type includes
websockets:subscribe. Refresh the token before WebSocket initialization. Ensure the region parameter matches your org URL. - Code: Add token expiration tracking and automatic re-authentication before
connect_and_subscribe().
Error: 429 Too Many Requests on Batch Push
- Cause: Exceeding Genesys Cloud analytics ingestion rate limits or downstream observability stack limits.
- Fix: Reduce
flush_intervalorcapacityinMetricBuffer. Thetenacitydecorator already implements exponential backoff. Monitor theRetry-Afterheader and adjust sampling frequency accordingly. - Code: The
_push_batchmethod raiseshttpx.HTTPStatusErroron 429, triggering the retry logic. Adjustmax_sampling_frequencyinMetricValidatorto 5.0 if limits persist.
Error: 400 Bad Request on Schema Validation
- Cause: Incoming WebSocket payloads contain malformed JSON, missing required fields, or values outside Genesys Cloud telemetry constraints.
- Fix: The
WebRTCQualityMetricPydantic model enforces strict type and range validation. Check raw WebSocket messages for missingpacketLoss,jitter, orsessionId. Filter out non-WebRTC media types before validation. - Code: The
metric_callbackcatchespydantic.ValidationErrorand logs the failure viaobs_handler.record_metric_dropped().
Error: Time Window Misalignment Drops
- Cause: Network latency or clock skew causes metric timestamps to arrive out of order or exceed the 30-second alignment window.
- Fix: Synchronize system clocks with NTP. Increase
window_size_secondsinTimeWindowAlignerif legitimate network conditions cause gaps. Ensure the Genesys Cloud client SDK transmits UTC timestamps. - Code: The aligner resets the session window on gaps. Adjust the threshold based on your deployment environment.
