Building a Genesys Cloud Web SDK Notification Orchestrator in Go
- You will build a Go service that constructs, validates, and dispatches notification payloads to Genesys Cloud Web SDK clients.
- You will use the Genesys Cloud REST API for user preference validation and audit logging, combined with a structured payload contract for browser-side
postMessageconsumption. - You will implement this in Go 1.21+ with production-ready error handling, frequency throttling, metric tracking, and webhook synchronization.
- OAuth client credentials (Confidential Client) with scopes:
admin:notification:read,user:preference:read,user:notification:read,analytics:events:read - Genesys Cloud API v2
- Go 1.21+
- Standard library only (
net/http,context,encoding/json,log/slog,sync,time,errors,fmt,strings)
Genesys Cloud uses OAuth 2.0 Client Credentials flow for server-to-server communication. You must cache the access token and handle expiry before making API calls. The following code demonstrates token acquisition, caching, and automatic refresh logic.
package main
import (
"context"
"encoding/json"
"fmt"
"net/http"
"time"
const (
genesysBaseURL = "https://api.mypurecloud.com"
oauthEndpoint = "/api/v2/oauth/token"
type OAuthClient struct {
ClientID string
ClientSecret string
Token string
ExpiresAt time.Time
mu sync.Mutex
httpClient *http.Client
type OAuthResponse struct {
Scope string `json:"scope"`
func NewOAuthClient(clientID, clientSecret string) *OAuthClient {
return &OAuthClient{
ClientID: clientID,
ClientSecret: clientSecret,
httpClient: &http.Client{Timeout: 10 * time.Second},
func (o *OAuthClient) GetToken(ctx context.Context) (string, error) {
o.mu.Lock()
defer o.mu.Unlock()
if o.Token != "" && time.Now().Before(o.ExpiresAt.Add(-30*time.Second)) {
return o.Token, nil
payload := fmt.Sprintf("client_id=%s&client_secret=%s&grant_type=client_credentials",
url.QueryEscape(o.ClientID), url.QueryEscape(o.ClientSecret))
req, err := http.NewRequestWithContext(ctx, http.MethodPost, genesysBaseURL+oauthEndpoint, strings.NewReader(payload))
if err != nil {
return "", fmt.Errorf("failed to create oauth request: %w", err)
resp, err := o.httpClient.Do(req)
if err != nil {
return "", fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth authentication failed with status %d", resp.StatusCode)
var oauthResp OAuthResponse
if err := json.NewDecoder(resp.Body).Decode(&oauthResp); err != nil {
return "", fmt.Errorf("failed to decode oauth response: %w", err)
o.Token = oauthResp.AccessToken
o.ExpiresAt = time.Now().Add(time.Duration(oauthResp.ExpiresIn) * time.Second)
return o.Token, nil
The Genesys Cloud Web SDK expects notifications to follow a strict contract. You must construct payloads containing notification references, a template matrix for UI rendering, and an alert directive. The following validator checks schema compliance before dispatch.
type NotificationPayload struct {
ID string `json:"id"`
Reference string `json:"reference"`
Template map[string]interface{} `json:"template_matrix"`
Alert AlertDirective `json:"alert_directive"`
BadgeCount int `json:"badge_count"`
AutoDismiss bool `json:"auto_dismiss"`
Locale string `json:"locale"`
type AlertDirective struct {
Priority string `json:"priority"`
Action string `json:"action"`
Timeout int `json:"timeout_ms"`
func ValidatePayload(p NotificationPayload) error {
if p.ID == "" || p.Reference == "" {
return errors.New("notification id and reference are required")
if len(p.Template) == 0 {
return errors.New("template matrix cannot be empty")
if p.Alert.Priority == "" || p.Alert.Action == "" {
return errors.New("alert directive requires priority and action fields")
if p.Alert.Timeout < 0 || p.Alert.Timeout > 60000 {
return errors.New("alert timeout must be between 0 and 60000 milliseconds")
if p.BadgeCount < 0 {
return errors.New("badge count cannot be negative")
return nil
Step 2: Frequency Limits and User Preference Checking
Prevent notification spam by enforcing maximum frequency limits and verifying user preferences via the Genesys Cloud API. You must query /api/v2/users/{userId}/preferences to confirm the user accepts notifications in the requested locale.
type UserPreferences struct {
NotificationsEnabled bool `json:"notifications_enabled"`
PreferredLocale string `json:"preferred_locale"`
type FrequencyTracker struct {
mu sync.Mutex
records map[string][]time.Time
limit int
window time.Duration
func NewFrequencyTracker(limit int, window time.Duration) *FrequencyTracker {
return &FrequencyTracker{
records: make(map[string][]time.Time),
limit: limit,
window: window,
func (f *FrequencyTracker) CheckAndRecord(userID string) error {
f.mu.Lock()
defer f.mu.Unlock()
now := time.Now()
cutoff := now.Add(-f.window)
var valid []time.Time
for _, t := range f.records[userID] {
if t.After(cutoff) {
valid = append(valid, t)
if len(valid) >= f.limit {
return fmt.Errorf("maximum notification frequency limit (%d/%v) exceeded for user %s", f.limit, f.window, userID)
f.records[userID] = append(valid, now)
return nil
func (o *OAuthClient) ValidateUserPreferences(ctx context.Context, userID, requestedLocale string) (*UserPreferences, error) {
token, err := o.GetToken(ctx)
if err != nil {
return nil, err
req, err := http.NewRequestWithContext(ctx, http.MethodGet, fmt.Sprintf("%s/api/v2/users/%s/preferences", genesysBaseURL, userID), nil)
if err != nil {
return nil, err
if err != nil {
return nil, err
return nil, errors.New("api rate limit exceeded: 429")
return nil, fmt.Errorf("preference check failed with status %d", resp.StatusCode)
var prefs UserPreferences
if err := json.NewDecoder(resp.Body).Decode(&prefs); err != nil {
return nil, err
if !prefs.NotificationsEnabled {
return nil, errors.New("user has disabled notifications")
if requestedLocale != prefs.PreferredLocale && requestedLocale != "en-US" {
return nil, fmt.Errorf("locale mismatch: requested %s, user prefers %s", requestedLocale, prefs.PreferredLocale)
return &prefs, nil
Step 3: Browser postMessage Contract and Badge Logic
The Web SDK consumes notifications via window.postMessage. You must format the payload as an atomic JSON structure that includes permission checks, badge updates, and auto-dismiss triggers. The following builder prepares the exact contract the frontend expects.
type PostMessageContract struct {
Type string `json:"type"`
Payload NotificationPayload `json:"payload"`
Permissions BrowserPermissions `json:"permissions"`
Metadata Metadata `json:"metadata"`
type BrowserPermissions struct {
Notification bool `json:"notification"`
Badge bool `json:"badge"`
type Metadata struct {
GeneratedAt string `json:"generated_at"`
Source string `json:"source"`
func BuildPostMessageContract(payload NotificationPayload, perms BrowserPermissions) PostMessageContract {
return PostMessageContract{
Type: "GENESYS_NOTIFICATION",
Payload: payload,
Permissions: perms,
Metadata: Metadata{
GeneratedAt: time.Now().UTC().Format(time.RFC3339),
Source: "genesys-cloud-go-notifier",
Step 4: Webhook Sync, Latency Tracking, and Audit Logging
Synchronize notification events with external messaging services via outbound webhooks. Track latency and success rates using structured counters. Generate audit logs for client governance using log/slog.
type NotifierMetrics struct {
mu sync.Mutex
TotalSent int
TotalFailed int
TotalLatency time.Duration
func (m *NotifierMetrics) RecordSuccess(latency time.Duration) {
m.mu.Lock()
defer m.mu.Unlock()
m.TotalSent++
m.TotalLatency += latency
func (m *NotifierMetrics) RecordFailure() {
m.mu.Lock()
defer m.mu.Unlock()
m.TotalFailed++
func (m *NotifierMetrics) GetSuccessRate() float64 {
m.mu.Lock()
defer m.mu.Unlock()
total := m.TotalSent + m.TotalFailed
if total == 0 {
return 0.0
return float64(m.TotalSent) / float64(total)
func (m *NotifierMetrics) GetAvgLatency() time.Duration {
m.mu.Lock()
defer m.mu.Unlock()
if m.TotalSent == 0 {
return 0
return m.TotalLatency / time.Duration(m.TotalSent)
func SyncWebhook(ctx context.Context, targetURL string, contract PostMessageContract) error {
jsonData, err := json.Marshal(contract)
if err != nil {
return fmt.Errorf("failed to marshal webhook payload: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, targetURL, bytes.NewReader(jsonData))
if err != nil {
return err
req.Header.Set("X-Notification-Source", "genesys-cloud-orchestrator")
resp, err := client.Do(req)
if err != nil {
return fmt.Errorf("webhook sync failed: %w", err)
if resp.StatusCode >= 400 {
return fmt.Errorf("webhook returned error status %d", resp.StatusCode)
return nil
The following module integrates authentication, validation, frequency tracking, payload construction, webhook synchronization, metric tracking, and audit logging into a single UserNotifier interface. Run this with go run main.go after setting environment variables.
package main
import (
"bytes"
"context"
"encoding/json"
"errors"
"fmt"
"log/slog"
"net/http"
"os"
"strings"
"sync"
"time"
// OAuthClient, NotificationPayload, AlertDirective, UserPreferences, FrequencyTracker,
// PostMessageContract, BrowserPermissions, Metadata, NotifierMetrics definitions from above steps go here.
// (Include all types and functions from Steps 1-4 in this file for a runnable example)
type UserNotifier struct {
oauth *OAuthClient
tracker *FrequencyTracker
metrics *NotifierMetrics
webhook string
logger *slog.Logger
func NewUserNotifier(clientID, clientSecret, webhookURL string) *UserNotifier {
return &UserNotifier{
oauth: NewOAuthClient(clientID, clientSecret),
tracker: NewFrequencyTracker(5, 10*time.Minute),
metrics: &NotifierMetrics{},
webhook: webhookURL,
logger: slog.Default(),
func (n *UserNotifier) SendNotification(ctx context.Context, userID string, payload NotificationPayload) (PostMessageContract, error) {
start := time.Now()
// 1. Schema validation
if err := ValidatePayload(payload); err != nil {
n.metrics.RecordFailure()
n.logger.Error("validation failed", "user_id", userID, "error", err)
return PostMessageContract{}, fmt.Errorf("payload validation failed: %w", err)
// 2. Frequency limit check
if err := n.tracker.CheckAndRecord(userID); err != nil {
n.logger.Warn("frequency limit exceeded", "user_id", userID, "error", err)
return PostMessageContract{}, err
// 3. User preference and localization verification
prefs, err := n.oauth.ValidateUserPreferences(ctx, userID, payload.Locale)
if err != nil {
n.logger.Error("preference check failed", "user_id", userID, "error", err)
payload.Locale = prefs.PreferredLocale
// 4. Construct postMessage contract
perms := BrowserPermissions{Notification: true, Badge: true}
contract := BuildPostMessageContract(payload, perms)
// 5. Webhook synchronization
if n.webhook != "" {
if err := SyncWebhook(ctx, n.webhook, contract); err != nil {
n.logger.Warn("webhook sync failed, continuing", "error", err)
// 6. Record metrics and audit log
latency := time.Since(start)
n.metrics.RecordSuccess(latency)
n.logger.Info("notification dispatched",
"user_id", userID,
"notification_id", payload.ID,
"locale", payload.Locale,
"latency_ms", latency.Milliseconds(),
"success_rate", fmt.Sprintf("%.2f", n.metrics.GetSuccessRate()),
"avg_latency_ms", n.metrics.GetAvgLatency().Milliseconds())
return contract, nil
func main() {
ctx := context.Background()
clientID := os.Getenv("GENESYS_CLIENT_ID")
clientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
webhookURL := os.Getenv("WEBHOOK_URL")
if clientID == "" || clientSecret == "" {
fmt.Println("Missing environment variables: GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET")
os.Exit(1)
notifier := NewUserNotifier(clientID, clientSecret, webhookURL)
payload := NotificationPayload{
Reference: "order_update_294",
Template: map[string]interface{}{"title": "Order Shipped", "body": "Your package is on the way."},
Alert: AlertDirective{Priority: "high", Action: "view_details", Timeout: 15000},
BadgeCount: 3,
AutoDismiss: true,
Locale: "en-US",
Timestamp: time.Now(),
contract, err := notifier.SendNotification(ctx, "user_12345", payload)
if err != nil {
slog.Error("failed to send notification", "error", err)
os.Exit(1)
fmt.Println("Notification contract generated successfully:")
enc := json.NewEncoder(os.Stdout)
enc.SetIndent("", " ")
enc.Encode(contract)
- Cause: The OAuth token has expired or the client credentials are invalid.
- Fix: Ensure the
GetTokenmethod is called before every API request. The implementation above caches tokens and refreshes them 30 seconds before expiry. Verify that your OAuth client is configured as a Confidential Client in the Genesys Cloud admin console.
Error: 403 Forbidden
- Cause: The OAuth token lacks the required scopes, or the user ID does not belong to the authenticated tenant.
- Fix: Request the exact scopes:
admin:notification:read,user:preference:read,user:notification:read. Verify that theuserIdparameter matches a user within your Genesys Cloud organization.
- Cause: Genesys Cloud API rate limits have been exceeded.
- Fix: Implement exponential backoff with jitter. The webhook synchronization and preference validation calls should wrap the HTTP client in a retry loop. The following snippet demonstrates a production-ready retry mechanism:
func retryWithBackoff(ctx context.Context, fn func() error, maxRetries int) error {
var lastErr error
for i := 0; i < maxRetries; i++ {
lastErr = fn()
if lastErr == nil {
return nil
if !strings.Contains(lastErr.Error(), "429") {
return lastErr
jitter := time.Duration(rand.Intn(1000)) * time.Millisecond
delay := time.Duration(1<<uint(i)) * time.Second + jitter
select {
case <-ctx.Done():
return ctx.Err()
case <-time.After(delay):
return lastErr
Error: Payload Schema Validation Failure
- Cause: Missing required fields in
NotificationPayloador invalidAlertDirectivevalues. - Fix: Ensure
ID,Reference,Template, andAlertfields are populated. TheTimeoutfield must not exceed 60000 milliseconds. TheValidatePayloadfunction enforces these constraints before any network call occurs.
Error: Locale Mismatch
- Cause: The requested notification locale does not match the user’s Genesys Cloud preference.
- Fix: The orchestrator automatically overrides the requested locale with
prefs.PreferredLocaleafter fetching user preferences. This prevents rendering failures in the Web SDK.
