Building a Genesys Cloud Event Dropper and Filter Pipeline in Java
This tutorial builds a Java service that subscribes to Genesys Cloud events, filters out low-value events using a configurable matrix, validates discard actions against retention constraints and maximum drop rate limits, applies priority calculation and sampling evaluation logic, synchronizes discard actions with external monitors via webhooks, tracks latency and success rates, and generates audit logs for governance. The solution uses the official Genesys Cloud Java SDK and REST APIs. The implementation covers Java 17 and later.
- OAuth client type: Confidential Client (Client Credentials Grant)
- Required scopes:
event:read,event:subscribe,analytics:events:read - SDK version:
platform-client-javav140.0.0 or later - Runtime: Java 17+ with Maven or Gradle
- External dependencies:
com.mypurecloud.sdk:platform-client-java,org.slf4j:slf4j-api,com.fasterxml.jackson.core:jackson-databind - Environment variables:
GENESYS_REGION,GENESYS_CLIENT_ID,GENESYS_CLIENT_SECRET
The Genesys Cloud Java SDK handles token caching and automatic refresh when configured correctly. You must initialize the ApiClient with your organization region and attach an OAuthApi instance that performs the client credentials grant.
import com.mypurecloud.sdk.v2.ApiClient;
import com.mypurecloud.sdk.v2.ApiException;
import com.mypurecloud.sdk.v2.auth.OAuth;
import com.mypurecloud.sdk.v2.auth.OAuthApi;
import com.mypurecloud.sdk.v2.model.OAuthClientCredentialsTokenRequest;
import java.util.HashMap;
import java.util.Map;
public class GenesysAuth {
private static final String REGION = System.getenv("GENESYS_REGION");
private static final String CLIENT_ID = System.getenv("GENESYS_CLIENT_ID");
private static final String CLIENT_SECRET = System.getenv("GENESYS_CLIENT_SECRET");
public static ApiClient initializeClient() throws ApiException {
ApiClient client = ApiClient.createDefaultApiClient();
client.setBasePath("https://" + REGION + ".mypurecloud.com");
client.setDebugging(false);
OAuthApi oAuthApi = new OAuthApi(client);
OAuthClientCredentialsTokenRequest tokenRequest = new OAuthClientCredentialsTokenRequest();
tokenRequest.setGrantType("client_credentials");
tokenRequest.setClientId(CLIENT_ID);
tokenRequest.setClientSecret(CLIENT_SECRET);
// Required scopes for event subscription and analytics query
tokenRequest.setScope("event:read event:subscribe analytics:events:read");
client.setOAuth(oAuthApi.requestOAuthClientCredentialsToken(tokenRequest));
return client;
The SDK caches the access token and automatically requests a new token when the current one expires. You do not need to implement manual refresh logic unless you are building a custom token store.
Step 1: Configure Event Subscription with Filter Matrix
Genesys Cloud events are immutable audit records. The platform does not expose an HTTP DELETE endpoint for event deletion. The dropper pipeline operates at ingestion time by creating an event subscription with a filter matrix that restricts which events are delivered to your service. Low-value events are discarded before they enter downstream storage.
import com.mypurecloud.sdk.v2.api.EventsApi;
import com.mypurecloud.sdk.v2.model.EventSubscriptionRequest;
import com.mypurecloud.sdk.v2.model.EventSubscription;
public class EventSubscriptionManager {
private final EventsApi eventsApi;
public EventSubscriptionManager(ApiClient client) {
this.eventsApi = new EventsApi(client);
public EventSubscription createFilteredSubscription(String name, String webhookUrl, Map<String, String> filterMatrix) throws ApiException {
EventSubscriptionRequest request = new EventSubscriptionRequest();
request.setName(name);
request.setWebhookUrl(webhookUrl);
request.setEventTypeFilter("all");
// Apply filter matrix to restrict delivery
// Example: {"routing.queue.name": "LOW_PRIORITY_*", "event.type": "routing.queue.member"}
if (filterMatrix != null) {
request.setFilter(filterMatrix);
request.setRetryPolicy(EventSubscriptionRequest.RetryPolicyEnum.FOURXX);
request.setHeaders(new HashMap<>());
return eventsApi.postEventSubscription(request);
HTTP Request/Response Cycle for Subscription Creation
POST /api/v2/events/subscriptions HTTP/1.1
Host: myorg.mypurecloud.com
"name": "Low-Value Event Dropper",
"webhookUrl": "https://my-monitor.example.com/discard-sync",
"eventTypeFilter": "all",
"filter": {
"retryPolicy": "4xx",
"headers": {}
HTTP/1.1 201 Created
"filter": {
"active": true,
"selfUri": "/api/v2/events/subscriptions/a1b2c3d4-e5f6-7890-abcd-ef1234567890"
Step 2: Query Events with Pagination and Rate Limit Handling
The Analytics Events API provides historical and real-time event data. You must implement pagination and exponential backoff for 429 responses. The SDK throws ApiException with status code 429 when rate limits are exceeded.
import com.mypurecloud.sdk.v2.api.AnalyticsApi;
import com.mypurecloud.sdk.v2.model.EventQueryRequest;
import com.mypurecloud.sdk.v2.model.EventQueryResponse;
import java.time.Instant;
import java.util.ArrayList;
import java.util.List;
public class EventQueryEngine {
private final AnalyticsApi analyticsApi;
private static final int MAX_RETRIES = 3;
private static final long BASE_DELAY_MS = 1000;
public EventQueryEngine(ApiClient client) {
this.analyticsApi = new AnalyticsApi(client);
public List<EventQueryResponse> queryEventsWithPagination(String eventType, Instant startTime, Instant endTime) throws ApiException {
List<EventQueryResponse> allResults = new ArrayList<>();
String cursor = null;
int pageCount = 0;
while (pageCount < 10) { // Safety cap for tutorial
EventQueryRequest request = new EventQueryRequest();
request.setEventType(eventType);
request.setStartTime(startTime.toString());
request.setEndTime(endTime.toString());
request.setPageSize(100);
if (cursor != null) {
request.setNextPageCursor(cursor);
EventQueryResponse response = executeWithRetry(() -> analyticsApi.postAnalyticsEventsQuery(request));
allResults.add(response);
if (response.getNextPageCursor() == null || response.getEvents().isEmpty()) {
break;
cursor = response.getNextPageCursor();
pageCount++;
return allResults;
private <T> T executeWithRetry(ApiCall<T> call) throws ApiException {
int attempts = 0;
while (true) {
return call.invoke();
} catch (ApiException e) {
if (e.getCode() == 429 && attempts < MAX_RETRIES) {
long delay = BASE_DELAY_MS * (1L << attempts);
Thread.sleep(delay);
} catch (InterruptedException ie) {
Thread.currentThread().interrupt();
throw new RuntimeException("Retry interrupted", ie);
attempts++;
} else {
throw e;
@FunctionalInterface
public interface ApiCall<T> {
T invoke() throws ApiException;
Step 3: Apply Priority Calculation, Sampling, and Discard Validation
The dropper pipeline evaluates each event against a priority score, sampling ratio, retention constraints, and maximum drop rate limits. Critical events bypass the discard directive. The validation pipeline generates audit logs and triggers automatic skips when constraints are violated.
import com.mypurecloud.sdk.v2.model.Event;
import java.util.*;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
public class EventDiscardValidator {
private final int maxDropRatePerMinute;
private final int retentionDaysConstraint;
private final double samplingRate;
private final Map<String, String> criticalEventPatterns;
private final AtomicInteger droppedCount = new AtomicInteger(0);
private final AtomicLong windowStart = new AtomicLong(System.currentTimeMillis());
private final List<Map<String, Object>> auditLogs = Collections.synchronizedList(new ArrayList<>());
public EventDiscardValidator(int maxDropRatePerMinute, int retentionDaysConstraint, double samplingRate, List<String> criticalPatterns) {
this.maxDropRatePerMinute = maxDropRatePerMinute;
this.retentionDaysConstraint = retentionDaysConstraint;
this.samplingRate = samplingRate;
this.criticalEventPatterns = new HashMap<>();
for (String p : criticalPatterns) {
criticalEventPatterns.put(p, p);
public void validateAndProcessBatches(List<EventQueryResponse> batches) {
for (EventQueryResponse batch : batches) {
List<Event> events = batch.getEvents();
if (events == null) continue;
for (Event event : events) {
if (shouldSkipCriticalEvent(event)) {
continue;
if (violatesRetentionConstraint(event)) {
continue;
if (exceedsMaxDropRate()) {
logAudit("RATE_LIMIT_EXCEEDED", event, "Dropping paused due to max drop rate");
continue;
if (applySamplingAndPriority(event)) {
droppedCount.incrementAndGet();
logAudit("EVENT_DROPPED", event, "Low-value event filtered by priority/sampling");
private boolean shouldSkipCriticalEvent(Event event) {
if (event == null || event.getEventType() == null) return false;
for (String pattern : criticalEventPatterns.keySet()) {
if (event.getEventType().contains(pattern)) {
return true;
return false;
private boolean violatesRetentionConstraint(Event event) {
if (event.getTimestamp() == null) return false;
Instant eventTime = Instant.parse(event.getTimestamp());
Instant cutoff = Instant.now().minusSeconds(retentionDaysConstraint * 24L * 3600L);
return eventTime.isBefore(cutoff);
private boolean exceedsMaxDropRate() {
long now = System.currentTimeMillis();
long windowMs = 60_000L;
if (now - windowStart.get() > windowMs) {
windowStart.set(now);
droppedCount.set(0);
return droppedCount.get() >= maxDropRatePerMinute;
private boolean applySamplingAndPriority(Event event) {
// Deterministic sampling based on event ID hash
String eventId = event.getId() != null ? event.getId() : "unknown";
int hash = Math.abs(eventId.hashCode());
double threshold = samplingRate * 100;
// Priority calculation: lower score = higher priority = less likely to drop
int priorityScore = calculatePriorityScore(event);
// Drop if random threshold met AND priority is low
return (hash % 100 < threshold) && priorityScore < 5;
private int calculatePriorityScore(Event event) {
int score = 5;
if (event.getEventType() != null) {
if (event.getEventType().contains("routing.conversation")) score += 3;
if (event.getEventType().contains("routing.queue")) score += 2;
return score;
private void logAudit(String action, Event event, String reason) {
Map<String, Object> log = new HashMap<>();
log.put("timestamp", Instant.now().toString());
log.put("action", action);
log.put("eventId", event.getId());
log.put("eventType", event.getEventType());
log.put("reason", reason);
auditLogs.add(log);
public List<Map<String, Object>> getAuditLogs() {
return Collections.unmodifiableList(auditLogs);
Step 4: Sync Discards via Webhooks and Track Metrics
The pipeline exposes a webhook sender that notifies external monitors when events are discarded. It also tracks latency and success rates for governance reporting.
import java.net.URI;
import java.time.Duration;
import java.util.concurrent.CompletableFuture;
public class DiscardSyncService {
private final HttpClient httpClient;
private final String webhookUrl;
private final Map<String, Integer> metrics = new ConcurrentHashMap<>();
private final AtomicLong totalLatencyNs = new AtomicLong(0);
private final AtomicInteger totalRequests = new AtomicInteger(0);
public DiscardSyncService(String webhookUrl) {
this.webhookUrl = webhookUrl;
this.httpClient = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(5))
.build();
public CompletableFuture<Void> notifyDiscard(Map<String, Object> auditLog) {
long startNs = System.nanoTime();
totalRequests.incrementAndGet();
String jsonPayload = toJson(auditLog);
.uri(URI.create(webhookUrl))
.header("X-Event-Source", "genesys-dropper")
.POST(HttpRequest.BodyPublishers.ofString(jsonPayload))
.build();
return httpClient.sendAsync(request, HttpResponse.BodyHandlers.ofString())
.thenAccept(response -> {
long durationNs = System.nanoTime() - startNs;
totalLatencyNs.addAndGet(durationNs);
metrics.merge("sync_" + response.statusCode(), 1, Integer::sum);
.exceptionally(ex -> {
metrics.merge("sync_error", 1, Integer::sum);
return null;
public Map<String, Object> getMetrics() {
int total = totalRequests.get();
long avgLatency = total > 0 ? totalLatencyNs.get() / total : 0;
return Map.of(
"totalRequests", total,
"averageLatencyNanoseconds", avgLatency,
"statusCodeDistribution", metrics,
"successRate", total > 0 ? (double) metrics.getOrDefault("sync_200", 0) / total : 0.0
private String toJson(Object obj) {
return com.fasterxml.jackson.databind.ObjectMapper.getDefault().writeValueAsString(obj);
} catch (Exception e) {
throw new RuntimeException("JSON serialization failed", e);
The following class integrates authentication, subscription management, event querying, discard validation, and webhook synchronization into a single executable pipeline.
import java.time.temporal.ChronoUnit;
import java.util.*;
public class GenesysEventDropperPipeline {
private final ApiClient apiClient;
private final EventQueryEngine queryEngine;
private final EventDiscardValidator validator;
private final DiscardSyncService syncService;
public GenesysEventDropperPipeline(ApiClient apiClient, String webhookUrl) throws ApiException {
this.apiClient = apiClient;
this.eventsApi = new EventsApi(apiClient);
this.queryEngine = new EventQueryEngine(apiClient);
this.validator = new EventDiscardValidator(100, 30, 0.7, Arrays.asList("routing.conversation", "outbound.call"));
this.syncService = new DiscardSyncService(webhookUrl);
public void run() throws ApiException, InterruptedException {
System.out.println("Initializing Genesys Cloud Event Dropper Pipeline...");
// Step 1: Create subscription with filter matrix
Map<String, String> filterMatrix = Map.of(
"routing.queue.name", "LOW_PRIORITY_*",
"event.type", "routing.queue.member"
EventSubscriptionRequest subRequest = new EventSubscriptionRequest();
subRequest.setName("Dropper-Subscription");
subRequest.setWebhookUrl("https://placeholder.example.com/webhook");
subRequest.setEventTypeFilter("all");
subRequest.setFilter(filterMatrix);
subRequest.setRetryPolicy(EventSubscriptionRequest.RetryPolicyEnum.FOURXX);
EventSubscription subscription = eventsApi.postEventSubscription(subRequest);
System.out.println("Subscription created: " + subscription.getId());
// Step 2: Query events for the last hour
Instant endTime = Instant.now();
Instant startTime = endTime.minus(1, ChronoUnit.HOURS);
List<EventQueryResponse> batches = queryEngine.queryEventsWithPagination("all", startTime, endTime);
System.out.println("Retrieved " + batches.size() + " event batches");
// Step 3: Validate and drop low-value events
validator.validateAndProcessBatches(batches);
List<Map<String, Object>> auditLogs = validator.getAuditLogs();
System.out.println("Processed " + auditLogs.size() + " events through discard pipeline");
// Step 4: Sync discards to external monitor
List<CompletableFuture<Void>> syncFutures = new ArrayList<>();
for (Map<String, Object> log : auditLogs) {
syncFutures.add(syncService.notifyDiscard(log));
CompletableFuture.allOf(syncFutures.toArray(new CompletableFuture[0])).join();
// Step 5: Report metrics
Map<String, Object> metrics = syncService.getMetrics();
System.out.println("Pipeline Metrics: " + metrics);
System.out.println("Audit Logs: " + auditLogs);
ApiClient client = GenesysAuth.initializeClient();
String webhookUrl = System.getenv("DISCARD_WEBHOOK_URL");
if (webhookUrl == null) {
webhookUrl = "https://monitor.example.com/discard-sync";
GenesysEventDropperPipeline pipeline = new GenesysEventDropperPipeline(client, webhookUrl);
pipeline.run();
System.err.println("API Error: " + e.getCode() + " - " + e.getMessage());
System.err.println("Response Body: " + e.getResponseBody());
System.err.println("Pipeline Error: " + e.getMessage());
e.printStackTrace();
- Cause: The OAuth token is expired, invalid, or missing required scopes.
- Fix: Verify
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETare correct. Ensure the token request includesevent:read,event:subscribe, andanalytics:events:read. The SDK automatically refreshes tokens, but initial token generation must succeed before API calls. - Code: Check
OAuthApi.requestOAuthClientCredentialsToken()response. If it throwsApiExceptionwith code 401, credentials are misconfigured.
Error: 403 Forbidden
- Cause: The OAuth application lacks the required scopes, or the user role does not have permission to create event subscriptions or query analytics events.
- Fix: Navigate to the Genesys Cloud Admin Console, open Applications, select your OAuth app, and add the missing scopes. Assign the
Event AdminorAnalytics Adminrole to the service account. - Code: The SDK throws
ApiExceptionwith status 403. Loge.getMessage()to identify the exact permission failure.
- Cause: The pipeline exceeded the Genesys Cloud API rate limit for event queries or subscription operations.
- Fix: The
EventQueryEngine.executeWithRetry()method implements exponential backoff. If failures persist, reducepageSize, increase query intervals, or implement a request queue. - Code: Monitor the
Retry-Afterheader in the response body. The retry logic automatically sleeps forBASE_DELAY_MS * (1 << attempts).
Error: 400 Bad Request (Filter Matrix Invalid)
- Cause: The filter matrix contains unsupported operators or malformed field names. Genesys Cloud event filters support exact match, wildcard, and prefix/suffix operators.
- Fix: Validate filter keys against the official event schema documentation. Use
routing.queue.nameinstead of custom internal identifiers. - Code: The
EventsApi.postEventSubscription()call returns a 400 with a detailed validation error in the response body. Parsee.getResponseBody()for field-level errors.
Error: Event Immutability Constraint
- Cause: Attempting to delete events via HTTP DELETE.
- Fix: Genesys Cloud events are immutable. The dropper pipeline must operate at ingestion or query time. Use the filter matrix on subscriptions to prevent low-value events from reaching your system. Use the discard validation logic to skip processing and logging for filtered events.
- Code: The provided implementation uses logical discards via
EventDiscardValidatorand subscription filters. Do not attempteventsApi.deleteEvent(...).
