Building a Dead Letter Queue for Genesys Cloud Webhook Failures
  • A Python-based service that intercepts failed Genesys Cloud webhooks, stores the payload in Amazon SQS for asynchronous retry, and re-delivers them using exponential backoff.
  • This solution uses the AWS SDK for Python (Boto3) and the FastAPI framework to handle incoming HTTP POST requests and manage queue lifecycle.
  • The implementation covers Python 3.9+ with dependencies managed via pip.
  • AWS Account: An active AWS account with permissions to create SQS queues and Lambda functions (optional, if running on AWS) or EC2/ECS.
  • Genesys Cloud Account: A tenant with webhook configuration privileges.
  • Python Environment: Python 3.9 or higher installed locally or in your deployment environment.
  • Dependencies: pip install fastapi uvicorn boto3 pydantic httpx
  • IAM Policy: An IAM role or user with SQS:SendMessage, SQS:ReceiveMessage, SQS:DeleteMessage, and SQS:GetQueueAttributes.
This solution operates as a receiver of webhooks from Genesys Cloud. Therefore, it does not authenticate to Genesys Cloud for the incoming requests. However, the retry mechanism must authenticate to Genesys Cloud to re-post the data if you are using a custom endpoint that requires authentication, or more commonly, you simply forward the original payload to a secondary processing system.
For this tutorial, we assume the “Dead Letter Queue” pattern is used to store failed payloads so a background worker can re-process them against your internal APIs or re-trigger a Genesys Cloud event via the API if necessary.
If you need to re-post to Genesys Cloud (e.g., to update a conversation state that failed to update), you need an OAuth token. Below is the setup for obtaining a token using the Client Credentials Grant, which is standard for server-to-server background jobs.
import httpx
import os
from typing import Optional
GENESYS_CLOUD_ENV = os.getenv("GENESYS_CLOUD_ENV", "mypurecloud.com")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
def get_genesys_oauth_token() -> str:
    Retrieves an OAuth token from Genesys Cloud using Client Credentials.
    Scope: analytics:conversation:view
    url = f"https://api.{GENESYS_CLOUD_ENV}/oauth/token"
    data = {
        "client_id": CLIENT_ID,
        "client_secret": CLIENT_SECRET,
        "scope": "analytics:conversation:view"
    with httpx.Client() as client:
            response = client.post(url, headers=headers, data=data)
            response.raise_for_status()
            token_data = response.json()
            return token_data.get("access_token")
            print(f"Failed to obtain OAuth token: {e.response.status_code} - {e.response.text}")
            raise
            print(f"Unexpected error during OAuth: {e}")
            raise
Step 1: Configure the Dead Letter Queue (SQS)
We use Amazon SQS as the durable store for failed webhooks. SQS provides automatic visibility timeouts and message retention, which are critical for retry logic.
First, create the queue if it does not exist. In a production environment, this should be done via Infrastructure as Code (Terraform/CloudFormation), but for this tutorial, we will use Boto3 to ensure the queue exists at startup.
import boto3
import logging
import json
sqs = boto3.client('sqs')
QUEUE_URL = os.getenv("DLQ_SQS_QUEUE_URL")
QUEUE_NAME = "GenesysWebhookDLQ"
def ensure_queue_exists():
    Ensures the SQS queue exists. If not, creates it with high visibility timeout for retries.
        response = sqs.get_queue_attributes(
            QueueUrl=QUEUE_URL,
            AttributeNames=['QueueArn']
        logger.info(f"Queue {QUEUE_NAME} already exists.")
    except sqs.exceptions.NoSuchQueue:
        logger.info(f"Creating queue {QUEUE_NAME}...")
        response = sqs.create_queue(
            QueueName=QUEUE_NAME,
            Attributes={
                'VisibilityTimeout': '300',  # 5 minutes visibility timeout
                'MessageRetentionPeriod': '1209600',  # 14 days
                'ReceiveMessageWaitTimeSeconds': '20',  # Long polling
                'DelaySeconds': '0'
        global QUEUE_URL
        QUEUE_URL = response['QueueUrl']
        logger.info(f"Queue created: {QUEUE_URL}")
        logger.error(f"Error managing SQS queue: {e}")
        raise
Step 2: Implement the Webhook Receiver with Failure Detection
Genesys Cloud sends webhooks as HTTP POST requests. The receiver must respond with a 200 OK immediately to acknowledge receipt. If the receiver crashes or takes too long, Genesys Cloud will retry automatically. However, if the processing logic fails after the 200 response, we have lost the data unless we queue it.
The pattern here is:
  1. Receive webhook.
  2. Respond 200 OK to Genesys Cloud immediately.
  3. Process the payload asynchronously.
  4. If processing fails, send the original payload to the Dead Letter Queue (DLQ).
from fastapi import FastAPI, Request, BackgroundTasks
from fastapi.responses import JSONResponse
import uuid
app = FastAPI(title="Genesys Webhook DLQ Handler")
@app.post("/webhook/receive")
async def receive_webhook(request: Request, background_tasks: BackgroundTasks):
    Endpoint exposed to Genesys Cloud.
    Returns 200 immediately to prevent Genesys from retrying the send.
    Offloads processing to background task.
        body = await request.json()
    except json.JSONDecodeError:
        # Genesys might send malformed JSON in rare edge cases
        return JSONResponse(status_code=400, content={"error": "Invalid JSON"})
    # Generate a unique ID for this event for tracing
    event_id = str(uuid.uuid4())
    webhook_data = {
        "event_id": event_id,
        "original_payload": body,
        "received_at": datetime.utcnow().isoformat(),
        "retry_count": 0
    # Offload processing. If this fails, the background task will handle DLQ logic.
    background_tasks.add_task(process_webhook_async, webhook_data)
    # Immediate 200 response to Genesys Cloud
    return JSONResponse(status_code=200, content={"status": "accepted"})
from datetime import datetime
def process_webhook_async(data: dict):
    Simulates business logic processing.
    If it fails, pushes to SQS DLQ.
        # --- YOUR BUSINESS LOGIC HERE ---
        # Example: Update a local database, send an email, etc.
        simulate_processing_error = False
        if simulate_processing_error:
            raise Exception("Simulated database connection failure")
        # Success path
        logger.info(f"Event {data['event_id']} processed successfully.")
        logger.error(f"Processing failed for event {data['event_id']}: {str(e)}")
        send_to_dlq(data)
Step 3: Implement the DLQ Sender and Retry Worker
The send_to_dlq function serializes the failed payload and sends it to SQS. The retry worker polls SQS, attempts re-processing, and implements exponential backoff by adjusting the message visibility timeout or delaying re-sends.
def send_to_dlq(data: dict):
    Sends the failed webhook payload to the SQS Dead Letter Queue.
        message_body = json.dumps(data)
        response = sqs.send_message(
            QueueUrl=QUEUE_URL,
            MessageBody=message_body,
            MessageGroupId='default'  # If using FIFO queue
        logger.info(f"Message sent to DLQ. ID: {response.get('MessageId')}")
        logger.critical(f"Failed to send to DLQ: {e}")
        # In production, alert here (PagerDuty, Slack, etc.)
def retry_worker():
    Polls the DLQ, processes messages, and implements exponential backoff.
    This should run as a separate process or cron job.
    logger.info("Starting DLQ Retry Worker...")
    while True:
            # Long polling for messages
            messages = sqs.receive_message(
                QueueUrl=QUEUE_URL,
                MaxNumberOfMessages=10,
                WaitTimeSeconds=20,
                AttributeNames=['All']
            if 'Messages' not in messages:
                time.sleep(1)
            for msg in messages['Messages']:
                body = json.loads(msg['Body'])
                receipt_handle = msg['ReceiptHandle']
                event_id = body.get('event_id')
                retry_count = body.get('retry_count', 0)
                logger.info(f"Retrying event {event_id} (Attempt: {retry_count + 1})")
                    # Re-attempt the business logic
                    # Note: We pass the original_payload here
                    original_payload = body['original_payload']
                    if retry_count < 3 and simulate_processing_error:
                        raise Exception("Simulated transient error")
                    # If successful, delete from queue
                    sqs.delete_message(
                        QueueUrl=QUEUE_URL,
                        ReceiptHandle=receipt_handle
                    logger.info(f"Event {event_id} processed successfully after retry.")
                    logger.error(f"Retry failed for {event_id}: {e}")
                    # Exponential Backoff Logic
                    retry_count += 1
                    body['retry_count'] = retry_count
                    if retry_count >= 5:
                        # Max retries reached. Move to a permanent archive or alert.
                        logger.critical(f"Max retries exceeded for {event_id}. Sending to permanent archive.")
                        # Optionally send to a different 'archive' queue or database
                        sqs.delete_message(
                            QueueUrl=QUEUE_URL,
                    # Calculate backoff delay: 2^retry_count seconds (e.g., 2, 4, 8, 16, 32)
                    delay = min(2 ** retry_count, 60)
                    # Re-send to DLQ with updated retry count
                    # Note: In SQS, you can't easily update a message in-place.
                    # We delete and re-send with a delay or just let it re-appear after visibility timeout.
                    # For simple exponential backoff with SQS, we can change the VisibilityTimeout of the message
                    # so it becomes visible again later.
                    new_visibility = min(2 ** retry_count * 10, 300) # Scale visibility timeout
                    sqs.change_message_visibility(
                        QueueUrl=QUEUE_URL,
                        ReceiptHandle=receipt_handle,
                        VisibilityTimeout=new_visibility
                    logger.info(f"Message {event_id} visibility extended to {new_visibility}s for backoff.")
            logger.error(f"Worker loop error: {e}")
            time.sleep(5)
Below is the complete, runnable Python application using FastAPI. This script combines the receiver and the background worker logic for demonstration purposes. In production, separate the worker into a distinct process.
File: main.py
import os
import json
import uuid
import logging
import boto3
import httpx
# --- Configuration ---
# AWS SQS Configuration
AWS_REGION = os.getenv("AWS_REGION", "us-east-1")
sqs = boto3.client('sqs', region_name=AWS_REGION)
QUEUE_URL = None
# Genesys Cloud Configuration (for potential re-posting)
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID", "")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET", "")
# --- SQS Setup ---
def init_sqs():
    global QUEUE_URL
            QueueUrl=f"https://sqs.{AWS_REGION}.amazonaws.com/{os.getenv('AWS_ACCOUNT_ID', '000000000000')}/{QUEUE_NAME}",
        logger.info(f"SQS Queue found: {QUEUE_URL}")
        logger.info(f"Creating SQS Queue: {QUEUE_NAME}")
            Attributes={
        logger.info(f"SQS Queue created: {QUEUE_URL}")
        logger.error(f"Failed to initialize SQS: {e}")
        raise
# --- OAuth Helper ---
def get_genesys_token() -> Optional[str]:
    if not CLIENT_ID or not CLIENT_SECRET:
        logger.warning("Genesys Credentials missing. OAuth disabled.")
        return None
    data = {
        with httpx.Client(timeout=10.0) as client:
            resp = client.post(url, data=data)
            resp.raise_for_status()
            return resp.json().get("access_token")
        logger.error(f"OAuth Error: {e}")
        return None
# --- Business Logic Simulation ---
def process_business_logic(payload: dict) -> bool:
    Replace this with your actual integration logic.
    Returns True on success, raises Exception on failure.
    # Simulate a random failure to demonstrate DLQ
    import random
    if random.random() < 0.3: # 30% chance of failure
        raise Exception("Simulated Database Timeout")
    logger.info(f"Successfully processed payload with ID: {payload.get('event_id')}")
    return True
# --- DLQ Operations ---
    if not QUEUE_URL:
        logger.critical("SQS Queue URL not initialized.")
        return
        sqs.send_message(
            QueueUrl=QUEUE_URL,
        logger.info(f"Sent to DLQ: {data.get('event_id')}")
def retry_worker_loop():
    if not QUEUE_URL:
        logger.error("SQS Queue URL not initialized. Exiting worker.")
        return
    while True:
                QueueUrl=QUEUE_URL,
                WaitTimeSeconds=20
                time.sleep(1)
                logger.info(f"Processing retry for {event_id} (Count: {retry_count})")
                    # Attempt to process again
                    process_business_logic(body['original_payload'])
                    # Success: Delete from queue
                    sqs.delete_message(
                        QueueUrl=QUEUE_URL,
                    logger.info(f"Retry successful for {event_id}.")
                    retry_count += 1
                        logger.critical(f"Max retries exceeded for {event_id}. Dropping.")
                        sqs.delete_message(
                            QueueUrl=QUEUE_URL,
                    else:
                        # Exponential backoff via Visibility Timeout
                        # 2^retry * 10 seconds, max 300s
                        backoff_time = min(2 ** retry_count * 10, 300)
                            QueueUrl=QUEUE_URL,
                            VisibilityTimeout=backoff_time
                        logger.info(f"Backoff set to {backoff_time}s for {event_id}")
            time.sleep(5)
# --- FastAPI App ---
@app.on_event("startup")
async def startup_event():
    init_sqs()
    # Start worker in a background thread for demo purposes
    import threading
    worker_thread = threading.Thread(target=retry_worker_loop, daemon=True)
    worker_thread.start()
    webhook_data = {
        "retry_count": 0
    # Immediate 200 to Genesys
    # Note: In FastAPI, returning before adding background tasks does not run them.
    # We must add the task BEFORE returning or use a different architecture.
    # Corrected flow below is handled by the return statement being at the end logically,
    # but FastAPI allows returning while background tasks are scheduled.
    # To ensure the background task is scheduled, we add it here.
    # However, the return above ends the response.
    # FastAPI executes background tasks after the response is sent.
    # CORRECTION: The return statement must be the last line of the function
    # if we want to ensure the task is added.
    # Actually, FastAPI adds the task to a queue. The response is sent,
    # then the task runs. This is safe.
    # Re-writing the function structure for clarity in the final output:
    # The code above is logically flawed because it returns before adding the task.
    # Let's fix the handler.
@app.post("/webhook/receive-fixed")
async def receive_webhook_fixed(request: Request, background_tasks: BackgroundTasks):
    webhook_data = {
        "retry_count": 0
    # Schedule background processing
    background_tasks.add_task(process_and_queue_on_fail, webhook_data)
    # Return 200 immediately
def process_and_queue_on_fail(data: dict):
        process_business_logic(data['original_payload'])
        logger.error(f"Initial processing failed for {data['event_id']}: {e}")
        send_to_dlq(data)
    import uvicorn
    uvicorn.run(app, host="0.0.0.0", port=8000)
Error: 403 Forbidden on SQS send_message
  • Cause: The IAM role executing the Python script lacks SQS:SendMessage permissions.
  • Fix: Update the IAM policy attached to the EC2 instance, Lambda, or ECS task role:
    "Version": "2012-10-17",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "sqs:SendMessage",
                "sqs:ReceiveMessage",
                "sqs:DeleteMessage",
                "sqs:GetQueueAttributes",
                "sqs:ChangeMessageVisibility"
            "Resource": "arn:aws:sqs:<region>:<account-id>:GenesysWebhookDLQ"
Error: 401 Unauthorized on Genesys Cloud OAuth
  • Cause: Invalid client_id, client_secret, or incorrect scope.
  • Fix: Verify the credentials in the Genesys Cloud Admin Console under Admin > Security > OAuth Clients. Ensure the client type is “Confidential” and the scope matches your requirements (e.g., analytics:conversation:view).
Error: Webhook Payload Too Large
  • Cause: SQS has a 256 KB message size limit. Genesys Cloud webhooks can exceed this if they contain large conversation transcripts or custom data.
  • Fix: Implement a preprocessing step that stores the large payload in Amazon S3 and sends only the S3 key and metadata to SQS.
def send_large_payload_to_dlq(data: dict, s3_client, bucket_name):
    event_id = data['event_id']
    # Upload payload to S3
    s3_client.put_object(
        Bucket=bucket_name,
        Key=f"webhooks/{event_id}.json",
        Body=json.dumps(data['original_payload'])
    # Send reference to SQS
    sqs.send_message(
        QueueUrl=QUEUE_URL,
        MessageBody=json.dumps({
            "s3_key": f"webhooks/{event_id}.json",
            "retry_count": 0
Error: 504 Gateway Timeout from Genesys Cloud
  • Cause: The endpoint took longer than 30 seconds to respond.
  • Fix: Ensure the /webhook/receive endpoint returns 200 OK immediately. Do not perform database writes or external API calls in the synchronous request handler. Use background_tasks or a message broker to offload work.
