Building a Daily Analytics Export Pipeline to S3 with Genesys Cloud and Python
You will build a Python script that queries the Genesys Cloud CX Analytics API for interaction details, paginates through the entire dataset, and streams the JSON payload directly to an Amazon S3 bucket.
This tutorial uses the Genesys Cloud analytics/conversations/details/query endpoint and the AWS boto3 SDK.
The implementation covers Python 3.9+ with strict type hinting and robust error handling.
Genesys Cloud Requirements
- OAuth 2.0 Client: You must have a registered OAuth 2.0 application in Genesys Cloud with the
client_credentialsgrant type. - Required Scopes: The client must have the
analytics:conversation:readscope. - API Endpoint:
https://api.us.genesys.cloud(or your specific region).
AWS Requirements
- IAM User/Role: An IAM entity with
s3:PutObjectpermissions for the target bucket. - Credentials:
AWS_ACCESS_KEY_IDandAWS_SECRET_ACCESS_KEYconfigured in your environment or.envfile. - Bucket: An existing S3 bucket with a defined prefix (e.g.,
analytics-exports/).
Python Dependencies
Install the required libraries using pip. We use httpx for async-capable HTTP requests (preferred over requests for better connection pooling and timeout handling in modern Python), boto3 for AWS, and pydantic for data validation.
pip install httpx boto3 pydantic python-dotenv
Genesys Cloud uses OAuth 2.0 Bearer tokens. For server-to-server jobs, the client_credentials flow is standard. You must cache the token and handle expiration (typically 3600 seconds) to avoid unnecessary authentication overhead.
The following class handles token acquisition and caching. It includes a simple in-memory cache. In a production cron job, you might prefer writing the token to a secure file or using a secret manager, but for this script, an in-memory dictionary suffices.
import httpx
from typing import Optional
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, domain: str = "api.us.genesys.cloud"):
self.client_id = client_id
self.token_url = f"https://{domain}/oauth/token"
self._token_expiry: float = 0
def get_token(self) -> str:
Returns a valid OAuth2 bearer token.
Refreshes if the current token is expired or missing.
# Check if we have a valid token (with 30s buffer)
if self._token and time.time() < (self._token_expiry - 30):
return self._token
payload = {
"client_id": self.client_id,
"client_secret": self._secret_secret # Note: In real code, inject secret securely
# Simulating secret injection for the example
# In reality, pass client_secret to __init__
headers = {"Content-Type": "application/json"}
with httpx.Client(timeout=30.0) as client:
response = client.post(
self.token_url,
data=payload,
headers=headers
if response.status_code != 200:
raise Exception(f"Auth failed: {response.status_code} {response.text}")
data = response.json()
self._token = data["access_token"]
self._token_expiry = time.time() + data["expires_in"]
return self._token
# Helper to fix the attribute name for the example
@property
def _secret_secret(self) -> str:
return self.client_secret
Note: In the complete working example below, we will integrate this logic cleanly.
Step 1: Configuring the Analytics Query
The Genesys Cloud Analytics API is resource-intensive. You must define the date_from and date_to explicitly. The API returns a maximum of 1000 items per page. To retrieve all data for a day, you must implement pagination using the next_page token.
The query body requires specific fields. We will request interactions (the core conversation data) and metrics (summary data).
import json
def build_query_body(date: datetime) -> dict:
Constructs the JSON body for the analytics query.
Queries all interactions for the provided date (UTC).
# Genesys API expects ISO 8601 format
date_from = date.strftime("%Y-%m-%dT00:00:00Z")
date_to = (date + timedelta(days=1)).strftime("%Y-%m-%dT00:00:00Z")
query_body = {
"date_from": date_from,
"date_to": date_to,
"size": 1000, # Maximum page size
"filter": {
"type": "AND",
"clauses": [
"type": "EQUALS",
"field": "interaction.type",
"value": "voice" # Example: Filter for Voice only. Remove for all types.
"select": [
"interactions.id",
"interactions.type",
"interactions.initiationDirection",
"interactions.startTime",
"interactions.endTime",
"interactions.totalHandleTime",
"metrics.voice.totalHandleTime",
"metrics.voice.talkTime"
return query_body
Step 2: Executing the Paginated Fetch
We will use httpx to send the POST request to /api/v2/analytics/conversations/details/query. This endpoint accepts a POST body (unlike many GET endpoints) to avoid URL length limits with complex filters.
Critical logic here:
- Check for
429 Too Many Requests. Implement exponential backoff. - Check for
next_pagein the response. If present, update thepage_tokenin the query body and loop. - Yield chunks of data to avoid loading the entire day’s analytics into RAM.
import httpx
from typing import Generator, Dict, Any
def fetch_analytics_chunks(
token: str,
query_body: Dict[str, Any],
) -> Generator[Dict[str, Any], None, None]:
Generator that yields chunks of analytics data.
Handles pagination and rate limiting (429).
url = f"https://{domain}/api/v2/anversations/details/query"
headers = {
"Accept": "application/json"
while True:
# Exponential backoff counter
retry_count = 0
max_retries = 5
while retry_count < max_retries:
with httpx.Client(timeout=60.0) as client:
response = client.post(url, json=query_body, headers=headers)
if response.status_code == 200:
yield data
# Check for pagination
if "next_page" in data:
query_body["page_token"] = data["next_page"]
break # Break retry loop, continue while loop
else:
return # No more pages
elif response.status_code == 429:
# Rate limited
wait_time = 2 ** retry_count
time.sleep(wait_time)
retry_count += 1
else:
raise Exception(f"API Error: {response.status_code} {response.text}")
if retry_count >= max_retries:
raise Exception("Max retries reached due to rate limiting.")
Correction: The endpoint path in the previous snippet had a typo (/api/v2/anversations...). The correct path is /api/v2/analytics/conversations/details/query.
Step 3: Streaming to Amazon S3
Writing to S3 efficiently means avoiding creating multiple small files. Instead, we will stream the JSON chunks into a single S3 object. However, S3 put_object requires the full body or a multipart upload.
For a daily export, the data size is usually manageable (under 5GB). We can accumulate the JSON lines in memory and write them in larger batches, or use boto3’s streaming capabilities. To keep memory usage low, we will write to a temporary file on disk and then upload it, or stream directly if the payload is small.
A more robust approach for large datasets is to write JSON Lines (.jsonl) to S3. This allows downstream analytics tools (like Athena) to process the file efficiently.
We will use boto3 to create a client and upload the data.
import boto3
from botocore.exceptions import ClientError
import io
def upload_to_s3(
s3_client: boto3.client,
bucket: str,
key: str,
json_lines: list
) -> bool:
Uploads a list of JSON objects as a single JSON Lines file to S3.
# Convert list of dicts to JSON Lines string
json_lines_content = "\n".join(json.dumps(line) for line in json_lines)
s3_client.put_object(
Bucket=bucket,
Key=key,
Body=json_lines_content.encode('utf-8'),
ContentType='application/json'
return True
except ClientError as e:
print(f"Error uploading to S3: {e}")
return False
This script combines authentication, pagination, and S3 upload. It is designed to be run as a daily cron job.
#!/usr/bin/env python3
Genesys Cloud Daily Analytics Export to S3
Author: Senior Developer Advocate
import os
import sys
import json
import httpx
import boto3
from datetime import datetime, timedelta, timezone
from typing import Optional, Generator, Dict, Any, List
# --- Configuration ---
GENESYS_CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
GENESYS_CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
GENESYS_DOMAIN = os.getenv("GENESYS_DOMAIN", "api.us.genesys.cloud")
AWS_BUCKET = os.getenv("AWS_BUCKET", "my-analytics-bucket")
AWS_REGION = os.getenv("AWS_REGION", "us-east-1")
# --- Auth Manager ---
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, domain: str):
self.domain = domain
self._expiry: float = 0
if self._token and time.time() < (self._expiry - 60):
return self._token
payload = {
resp = client.post(self.token_url, data=payload)
resp.raise_for_status()
data = resp.json()
self._expiry = time.time() + data["expires_in"]
return self._token
# --- Data Fetcher ---
def fetch_all_interactions(auth: GenesysAuth, query_body: Dict[str, Any]) -> Generator[Dict[str, Any], None, None]:
Paginates through Genesys Analytics API and yields individual interaction records.
token = auth.get_token()
url = f"https://{auth.domain}/api/v2/analytics/conversations/details/query"
headers = {
while True:
retry = 0
while retry < 5:
resp = client.post(url, json=query_body, headers=headers)
if resp.status_code == 200:
data = resp.json()
# Yield individual interactions to keep memory low
for interaction in data.get("interactions", []):
yield interaction
break
else:
return
elif resp.status_code == 429:
wait = 2 ** retry
time.sleep(wait)
retry += 1
else:
raise Exception(f"API Error: {resp.status_code} {resp.text}")
if retry >= 5:
raise Exception("Rate limit exceeded after retries.")
# --- S3 Writer ---
def write_to_s3(interactions: List[Dict], bucket: str, key: str) -> None:
s3 = boto3.client('s3', region_name=AWS_REGION)
# Create JSON Lines content
lines = [json.dumps(i, default=str) for i in interactions]
body = "\n".join(lines)
s3.put_object(
Bucket=bucket,
Key=key,
Body=body.encode('utf-8'),
print(f"Successfully uploaded {len(interactions)} records to s3://{bucket}/{key}")
# --- Main Execution ---
def main():
if not GENESYS_CLIENT_ID or not GENESYS_CLIENT_SECRET:
print("Error: GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET env vars required.")
sys.exit(1)
# Target date: Yesterday (standard for daily batch jobs to ensure data closure)
target_date = datetime.now(timezone.utc) - timedelta(days=1)
print(f"Starting export for {target_date.date()}")
# 1. Setup Auth
auth = GenesysAuth(GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, GENESYS_DOMAIN)
# 2. Build Query
date_from = target_date.strftime("%Y-%m-%dT00:00:00Z")
date_to = (target_date + timedelta(days=1)).strftime("%Y-%m-%dT00:00:00Z")
query_body = {
"date_to": date_to,
"size": 1000,
"select": ["interactions.id", "interactions.type", "interactions.startTime", "interactions.endTime"]
# 3. Fetch Data
interactions = []
for interaction in fetch_all_interactions(auth, query_body):
interactions.append(interaction)
# Optional: Flush to S3 every 10,000 records if memory is a concern
if len(interactions) >= 10000:
write_to_s3(interactions, AWS_BUCKET, f"analytics/{target_date.date()}/part-{len(interactions)}.jsonl")
interactions = [] # Clear buffer
print(f"Error fetching data: {e}")
sys.exit(1)
# 4. Final Upload
if interactions:
write_to_s3(interactions, AWS_BUCKET, f"analytics/{target_date.date()}/final.jsonl")
print("Export complete.")
main()
Cause: The OAuth token is expired or invalid.
Fix: Ensure your GenesysAuth class correctly handles token refresh. Check that the client_id and client_secret match an active OAuth 2.0 client in Genesys Cloud. Verify the client has the analytics:conversation:read scope.
Cause: You are hitting the Genesys Cloud API rate limits. The Analytics API has strict limits (often 10 requests per second per tenant).
Fix: The provided code includes exponential backoff (time.sleep(2 ** retry)). If you still hit this limit, increase the sleep duration or reduce the frequency of polls. For daily jobs, this is rarely an issue unless you are querying high-volume accounts.
Error: 403 Forbidden
Cause: The OAuth client lacks the required scope.
Fix: Go to Genesys Cloud Admin > Security > OAuth 2.0 Clients. Select your client and ensure analytics:conversation:read is checked.
Error: ClientError: An error occurred (AccessDenied) when calling the PutObject operation
Cause: The AWS IAM user does not have write permissions to the S3 bucket.
Fix: Verify the IAM policy attached to the credentials used by boto3. It must include:
"Effect": "Allow",
"Action": "s3:PutObject",
"Resource": "arn:aws:s3:::YOUR_BUCKET_NAME/*"
