Building a Custom Queue Overflow Handler Using the Genesys Cloud Routing API and AWS Step Functions
This guide details the architecture and implementation of an external, stateful queue overflow handler that monitors Genesys Cloud queue statistics via Webhooks, evaluates complex business rules in AWS Step Functions, and executes remediation actions through the Routing API. The end result is a production-grade automation system that detects congestion, applies overflow policies (such as dynamic member injection or flow diversion), monitors recovery, and reverts changes with guaranteed idempotency and fault tolerance.
  • Licensing Tier: Genesys Cloud CX 2 or CX 3. Webhooks require CX 2 minimum. Advanced routing features may require CX 3.
  • Genesys Permissions:
    • Platform > Webhook > Edit (to create/manage webhooks).
    • Routing > Queue > Edit (to modify queue settings or members via API).
    • Routing > Queue > View (to read statistics).
    • Routing > User > View (if adding users as overflow members).
  • OAuth Scopes:
    • webhooks:read, webhooks:write.
    • routing:queue:edit, routing:queue:view.
    • oauth:client:read (for token management).
  • AWS Dependencies:
    • AWS Step Functions (Standard workflow for durability).
    • AWS Lambda (for API execution).
    • AWS Secrets Manager (for OAuth credentials).
    • IAM roles with least-privilege access to invoke Lambda and access Secrets Manager.
  • External Dependencies:
    • Stable network path from AWS to Genesys Cloud endpoints (VPC Endpoints recommended for enterprise security).
    • Queue configuration in Genesys Cloud must allow API modifications (e.g., not locked by a higher-tier admin policy).
1. Webhook Configuration for Event-Driven Triggers
The overflow handler relies on Genesys Cloud pushing state changes to AWS. We use the routing.queue.statistics event type, which publishes metrics at a configurable interval.
Configuration:
Create a webhook via the API or Admin UI. The configuration must target the AWS Step Functions StartExecution endpoint or an intermediary API Gateway endpoint that triggers the Step Function.
Webhook JSON Payload Example:
  "name": "QueueOverflowMonitor",
  "enabled": true,
  "eventTypes": ["routing.queue.statistics"],
  "requestUri": "https://api.ap-southeast-1.amazonaws.com/v1/executions",
  "method": "POST",
  "authScheme": "oauth_client_credentials",
  "requestHeaders": {
  "requestTemplate": "{\"input\": {\"queueId\": \"{{ $.queueId }}\", \"metrics\": {{ $.metrics }}, \"timestamp\": \"{{ $.timestamp }}\"}}",
  "filter": {
    "condition": "AND",
    "filters": [
        "key": "queueId",
        "operator": "EQ",
        "value": "your-target-queue-id"
The Trap: Webhook Storms and Eventual Consistency
The most common failure mode occurs when administrators deploy this webhook across hundreds of queues without rate limiting or batching. Genesys Cloud fires statistics events for every queue at the configured interval. If you have 500 queues and a 60-second interval, you generate 500 invocations per minute. This spikes AWS costs and can hit Step Function execution limits.
Architectural Mitigation: Implement a filter in the Webhook to target specific queues, or use a batching strategy where the Webhook posts to an SQS queue, and a Lambda batches messages before triggering the Step Function. Additionally, statistics events reflect the state at the time of sampling. By the time the Step Function executes, the queue state may have changed. Never act on the webhook payload alone. The Step Function must always issue a GET /api/v2/routing/queues/{queueId}/statistics call to verify the current state before executing any overflow action. This prevents phantom overflow remediation.
2. Lambda Wrapper for Genesys Cloud API Execution
AWS Step Functions cannot directly call REST APIs. We require a Lambda function that handles OAuth token management, makes the API call, and returns structured results.
Production-Ready Lambda Python Snippet:
This Lambda handles token refresh, retries, and error classification.
import json
import os
import boto3
import requests
from requests.adapters import HTTPAdapter
from urllib3.util.retry import Retry
secrets_client = boto3.client('secretsmanager')
GENESYS_ORG_ID = os.environ['GENESYS_ORG_ID']
BASE_URL = f"https://{GENESYS_ORG_ID}.mypurecloud.com"
def get_oauth_token():
    secret_name = os.environ['OAUTH_SECRET_NAME']
    response = secrets_client.get_secret_value(SecretId=secret_name)
    secret = json.loads(response['SecretString'])
    return secret['access_token'], secret['expires_at']
def call_genesys_api(method, endpoint, payload=None):
    token, _ = get_oauth_token()
    headers = {
    session = requests.Session()
    retry_strategy = Retry(
        total=3,
        backoff_factor=1,
        status_forcelist=[429, 500, 502, 503, 504]
    session.mount('https://', HTTPAdapter(max_retries=retry_strategy))
    url = f"{BASE_URL}{endpoint}"
        if method == "GET":
            response = session.get(url, headers=headers, timeout=10)
        elif method == "POST":
            response = session.post(url, headers=headers, json=payload, timeout=10)
        elif method == "PUT":
            response = session.put(url, headers=headers, json=payload, timeout=10)
        response.raise_for_status()
        return {"success": True, "status_code": response.status_code, "body": response.json()}
            # Token expired, attempt refresh logic here or fail fast for Step Function retry
            return {"success": false, "error": "AUTH_FAILURE", "message": "Token expired, requires refresh"}
        return {"success": false, "error": "API_FAILURE", "message": str(e), "status_code": response.status_code}
        return {"success": false, "error": "NETWORK_FAILURE", "message": str(e)}
def lambda_handler(event, context):
    action = event.get('action') # e.g., "CHECK_STATE", "ADD_MEMBERS", "REVERT"
    queue_id = event.get('queueId')
    if action == "CHECK_STATE":
        return call_genesys_api("GET", f"/api/v2/routing/queues/{queue_id}/statistics")
    elif action == "ADD_MEMBERS":
        members = event.get('members', [])
        return call_genesys_api("POST", f"/api/v2/routing/queues/{queue_id}/members", members)
    # Add other actions as needed
The Trap: Token Expiration and Race Conditions
OAuth tokens expire after a fixed duration. If the Step Function execution spans a long period (e.g., waiting for queue recovery), the token stored in Secrets Manager may expire. The Lambda must detect 401 Unauthorized responses and trigger a token refresh.
Architectural Mitigation: Implement a distributed lock or atomic update mechanism in Secrets Manager when refreshing tokens. If multiple Step Function executions trigger a refresh simultaneously, the last write wins, which is acceptable, but you must avoid concurrent writes corrupting the secret. A more robust pattern uses a dedicated Lambda for token refresh that acquires a DynamoDB lock, updates the secret, and releases the lock. Ensure your Lambda code handles 401 by calling the refresh routine before failing the task.
3. Step Function State Machine Design
The Step Function orchestrates the overflow logic. It must handle the lifecycle: Detect → Verify → Act → Wait → Recover → Revert.
ASL (Amazon States Language) Structure:
  "Comment": "Queue Overflow Handler",
  "StartAt": "VerifyCurrentState",
  "States": {
    "VerifyCurrentState": {
      "Type": "Task",
      "Resource": "arn:aws:lambda:us-east-1:123456789012:function:GenesysApiWrapper",
      "Parameters": {
        "action": "CHECK_STATE",
        "queueId.$": "$.queueId"
      "ResultPath": "$.currentState",
      "Next": "EvaluateOverflowCondition",
      "Retry": [
          "ErrorEquals": ["Lambda.ServiceException", "Lambda.AWSLambdaException"],
          "MaxAttempts": 2,
          "BackoffRate": 2
    "EvaluateOverflowCondition": {
      "Type": "Choice",
      "Choices": [
          "Variable": "$.currentState.body.waitTime",
          "NumericGreaterThan": 120,
          "Next": "ExecuteOverflowAction"
      "Default": "EndNormal"
    "ExecuteOverflowAction": {
      "Type": "Task",
      "Parameters": {
        "action": "ADD_MEMBERS",
        "queueId.$": "$.queueId",
        "members": [
          {"userId": "overflow-agent-1", "skills": [{"name": "General", "level": 5}]},
          {"userId": "overflow-agent-2", "skills": [{"name": "General", "level": 5}]}
      "ResultPath": "$.actionResult",
      "Next": "WaitForRecovery",
      "Catch": [
          "ErrorEquals": ["States.TaskFailed"],
          "Next": "HandleActionFailure"
    "WaitForRecovery": {
      "Type": "Wait",
      "Seconds": 300,
      "Next": "CheckRecovery"
    "CheckRecovery": {
      "Type": "Task",
      "Parameters": {
      "ResultPath": "$.recoveryState",
      "Next": "EvaluateRecovery"
    "EvaluateRecovery": {
      "Type": "Choice",
      "Choices": [
          "Variable": "$.recoveryState.body.waitTime",
          "NumericLessThan": 60,
          "Next": "RevertOverflowAction"
      "Default": "WaitForRecovery"
    "RevertOverflowAction": {
      "Type": "Task",
      "Parameters": {
        "action": "REMOVE_MEMBERS",
        "members": [
          {"userId": "overflow-agent-1"},
          {"userId": "overflow-agent-2"}
      "End": true
    "EndNormal": {
      "Type": "Succeed"
    "HandleActionFailure": {
      "Type": "Fail",
      "Error": "OverflowActionFailed",
      "Cause": "Failed to execute overflow action. Check API logs."
The Trap: Idempotency and Duplicate Executions
Genesys Cloud Webhooks retry on 5xx errors. If the Step Function receives a duplicate execution request, it may start a parallel workflow. This leads to race conditions where overflow members are added multiple times, or revert actions conflict with active actions.
Architectural Mitigation: Enforce idempotency at the Step Function level. Use the ExecutionName parameter in the StartExecution API call to ensure uniqueness based on a key derived from the queue ID and a time window (e.g., queue-123-overflow-1715428800). Alternatively, implement a “mutex” pattern using DynamoDB. Before executing the overflow action, the Lambda checks DynamoDB for an active execution lock. If a lock exists, the Step Function terminates gracefully. When reverting, the Lambda removes the lock. This prevents overlapping executions from corrupting queue state.
4. API Payloads and Action Execution
The overflow handler typically performs one of two actions: adding members to the queue or modifying queue settings. Adding members is the most common and least disruptive approach.
Adding Members via API:
Use POST /api/v2/routing/queues/{queueId}/members.
JSON Payload:
    "userId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
    "skills": [
        "name": "Support",
        "level": 5
    "wrapUpDelay": 0,
    "maxContacts": 0
The Trap: Rate Limits and 429 Responses
Genesys Cloud enforces rate limits on the Routing API. High-volume overflow events across many queues can trigger 429 Too Many Requests. The Step Function must handle retries with exponential backoff.
Architectural Mitigation: Configure the Retry block in the Step Function task states to catch 429 errors. The Lambda wrapper should also inspect the Retry-After header in the response and delay accordingly. If you anticipate burst traffic, stagger the execution start times using a random delay in the webhook trigger or use Step Function’s Rate or Capacity settings to throttle concurrent executions. Never assume the API call succeeds on the first attempt.
Edge Case 1: Webhook Redelivery and Duplicate Executions
  • Failure Condition: The Step Function starts twice for the same queue event. Overflow members are added twice, or the revert action fails because members are not found.
  • Root Cause: Genesys Cloud retries the webhook on network timeouts or 5xx responses. The Step Function does not natively deduplicate invocations.
  • Solution: Implement idempotency keys. When the Webhook triggers the Step Function, include a unique ID in the input. Use a DynamoDB table with a TTL to track active executions keyed by queueId and actionType. The Lambda checks this table before making API calls. If an entry exists, the Lambda returns a success response without acting, allowing the Step Function to complete safely.
Edge Case 2: Queue Configuration Drift
  • Failure Condition: An administrator manually changes queue settings or removes overflow members while the Step Function is in the WaitForRecovery state. The Step Function attempts to revert changes that no longer exist, causing API errors.
  • Root Cause: External changes to the queue state are not communicated to the Step Function.
  • Solution: The RevertOverflowAction step must handle 404 or 400 errors gracefully. If the API returns an error indicating the member is not in the queue, the Lambda should treat this as a success condition (the desired state is already achieved). Update the Lambda to parse error messages and map “member not found” to a successful revert.
Edge Case 3: OAuth Token Race Condition
  • Failure Condition: Multiple Lambda functions attempt to refresh the OAuth token simultaneously. One refresh overwrites the other, causing temporary 401 errors for in-flight requests.
  • Root Cause: Concurrent writes to Secrets Manager without coordination.
  • Solution: Use a distributed locking mechanism. Before updating the secret, the Lambda acquires a lock in DynamoDB. If the lock is held, the Lambda waits or retries. After updating the secret, the lock is released. Ensure the lock has a TTL to prevent deadlocks if the Lambda crashes. Alternatively, use a singleton pattern where only one Lambda instance is responsible for token refresh, and other instances poll for the new token.
