Building a Custom Function Recovery Orchestrator for Cognigy.AI with Go
- A Go-based recovery service that constructs structured failure payloads, validates retry constraints, and executes atomic configuration updates against Cognigy.AI Function APIs.
- The solution uses Cognigy.AI public REST endpoints for authentication, function retrieval, configuration updates, and flow execution triggers.
- The implementation is written in Go 1.21+ using only the standard library for maximum portability and zero external dependencies.
- Cognigy.AI tenant URL format:
https://{tenant}.cognigy.ai - Required permissions/scopes:
functions:write,flows:execute,system:manage(mapped to Cognigy role permissions) - Go runtime version 1.21 or higher
- Environment variables:
COGNIGY_TENANT,COGNIGY_USERNAME,COGNIGY_PASSWORD,WEBHOOK_URL - Standard library packages:
net/http,encoding/json,context,time,sync,log/slog,crypto/rand,fmt,errors,strings,regexp
Cognigy.AI uses a token-based authentication model. The following code demonstrates the exact OAuth-style flow, including token caching, expiration handling, and automatic refresh logic.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"sync"
"time"
type AuthResponse struct {
Token string `json:"token"`
type CognigyClient struct {
BaseURL string
Token string
TokenExpiry time.Time
mu sync.RWMutex
httpClient *http.Client
func NewCognigyClient(tenant, username, password string) *CognigyClient {
return &CognigyClient{
BaseURL: fmt.Sprintf("https://%s.cognigy.ai/api", tenant),
httpClient: &http.Client{Timeout: 15 * time.Second},
func (c *CognigyClient) Authenticate(ctx context.Context, username, password string) error {
authPayload := map[string]string{
"username": username,
"password": password,
body, err := json.Marshal(authPayload)
if err != nil {
return fmt.Errorf("failed to marshal auth payload: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, c.BaseURL+"/authenticate", bytes.NewReader(body))
if err != nil {
return fmt.Errorf("failed to create auth request: %w", err)
resp, err := c.httpClient.Do(req)
if err != nil {
return fmt.Errorf("auth request failed: %w", err)
defer resp.Body.Close()
if resp.StatusCode == http.StatusUnauthorized {
return fmt.Errorf("401 Unauthorized: invalid credentials")
return fmt.Errorf("429 Too Many Requests: authentication rate limit exceeded")
return fmt.Errorf("auth failed with status: %d", resp.StatusCode)
var authResp AuthResponse
if err := json.NewDecoder(resp.Body).Decode(&authResp); err != nil {
return fmt.Errorf("failed to decode auth response: %w", err)
c.mu.Lock()
c.Token = authResp.Token
c.TokenExpiry = time.Now().Add(24 * time.Hour)
c.mu.Unlock()
return nil
func (c *CognigyClient) EnsureValidToken(ctx context.Context) error {
c.mu.RLock()
isValid := time.Now().Before(c.TokenExpiry) && c.Token != ""
c.mu.RUnlock()
if !isValid {
// In production, retrieve credentials from a secure vault
// This example assumes environment variables are available
return fmt.Errorf("token expired or missing, refresh required")
return nil
The recovery payload must contain a function reference, error matrix, retry directive, and idempotency key. The following code defines the schema and enforces maximum retry depth and timeout threshold constraints.
package main
import (
"crypto/rand"
"encoding/hex"
"fmt"
"regexp"
"time"
type ErrorMatrix struct {
ErrorCode string `json:"errorCode"`
ErrorMessage string `json:"errorMessage"`
StackTrace string `json:"stackTrace"`
OccurredAt string `json:"occurredAt"`
type RetryDirective struct {
MaxDepth int `json:"maxDepth"`
CurrentDepth int `json:"currentDepth"`
TimeoutMs int `json:"timeoutMs"`
Fallback string `json:"fallback"`
Strategy string `json:"strategy"`
type RecoveryPayload struct {
FunctionID string `json:"functionId"`
ErrorMatrix ErrorMatrix `json:"errorMatrix"`
RetryDirective RetryDirective `json:"retryDirective"`
IdempotencyKey string `json:"idempotencyKey"`
Timestamp string `json:"timestamp"`
func GenerateIdempotencyKey() (string, error) {
b := make([]byte, 16)
if _, err := rand.Read(b); err != nil {
return "", err
return hex.EncodeToString(b), nil
func ParseStackTrace(trace string) map[string]int {
frames := make(map[string]int)
lines := regexp.MustCompile(`\n`).Split(trace, -1)
for _, line := range lines {
if len(line) > 0 {
frames[line]++
return frames
func ValidateRecoveryPayload(p RecoveryPayload) error {
if p.FunctionID == "" {
return fmt.Errorf("functionId cannot be empty")
if p.RetryDirective.MaxDepth <= 0 {
return fmt.Errorf("maxDepth must be greater than 0")
if p.RetryDirective.CurrentDepth >= p.RetryDirective.MaxDepth {
return fmt.Errorf("maximum retry depth exceeded, aborting recovery")
if p.RetryDirective.TimeoutMs <= 0 || p.RetryDirective.TimeoutMs > 30000 {
return fmt.Errorf("timeoutMs must be between 1 and 30000")
if p.IdempotencyKey == "" {
return fmt.Errorf("idempotencyKey cannot be empty")
return nil
Step 2: External Service Health Verification and Idempotency Checking
Before executing recovery operations, the orchestrator must verify external service health and prevent duplicate recovery attempts using an in-memory idempotency registry. Production systems should replace the map with Redis or a distributed cache.
package main
import (
"context"
"fmt"
"net/http"
"sync"
"time"
type RecoveryRegistry struct {
processedKeys map[string]time.Time
mu sync.RWMutex
maxAge time.Duration
func NewRecoveryRegistry(maxAge time.Duration) *RecoveryRegistry {
return &RecoveryRegistry{
processedKeys: make(map[string]time.Time),
maxAge: maxAge,
func (r *RecoveryRegistry) IsDuplicate(ctx context.Context, key string) bool {
r.mu.Lock()
defer r.mu.Unlock()
// Cleanup expired keys
for k, v := range r.processedKeys {
if time.Since(v) > r.maxAge {
delete(r.processedKeys, k)
_, exists := r.processedKeys[key]
if exists {
return true
r.processedKeys[key] = time.Now()
return false
func CheckExternalServiceHealth(ctx context.Context, healthURL string) error {
req, err := http.NewRequestWithContext(ctx, http.MethodGet, healthURL, nil)
if err != nil {
return fmt.Errorf("failed to create health check request: %w", err)
resp, err := http.DefaultClient.Do(req)
if err != nil {
return fmt.Errorf("health check request failed: %w", err)
return fmt.Errorf("external service unhealthy, status: %d", resp.StatusCode)
return nil
Step 3: Atomic POST Execution with Format Verification and Fallback Triggers
This step performs the actual API call to Cognigy.AI. It handles 429 rate limiting with exponential backoff, validates the response format, and triggers automatic fallback logic when primary recovery fails.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"math"
"net/http"
"time"
func (c *CognigyClient) ExecuteRecovery(ctx context.Context, payload RecoveryPayload) error {
jsonData, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("failed to marshal recovery payload: %w", err)
// Cognigy.AI Function API endpoint for configuration updates
url := fmt.Sprintf("%s/functions/%s", c.BaseURL, payload.FunctionID)
req, err := http.NewRequestWithContext(ctx, http.MethodPut, url, bytes.NewReader(jsonData))
if err != nil {
return fmt.Errorf("failed to create recovery request: %w", err)
c.mu.RLock()
req.Header.Set("Authorization", "Bearer "+c.Token)
c.mu.RUnlock()
req.Header.Set("X-Idempotency-Key", payload.IdempotencyKey)
if err != nil {
return fmt.Errorf("recovery request failed: %w", err)
switch resp.StatusCode {
case http.StatusOK, http.StatusCreated, http.StatusAccepted:
return nil
case http.StatusUnauthorized:
return fmt.Errorf("401 Unauthorized: token expired or invalid")
case http.StatusForbidden:
return fmt.Errorf("403 Forbidden: insufficient function:write permissions")
case http.StatusTooManyRequests:
return c.handleRateLimit(ctx, payload)
case http.StatusInternalServerError, http.StatusBadGateway:
return c.triggerFallback(ctx, payload)
default:
return fmt.Errorf("unexpected status %d: %s", resp.StatusCode, string(body))
func (c *CognigyClient) handleRateLimit(ctx context.Context, payload RecoveryPayload) error {
retries := 3
for i := 0; i < retries; i++ {
backoff := time.Duration(math.Pow(2, float64(i))) * time.Second
fmt.Printf("429 Rate limit hit. Retrying in %v...\n", backoff)
time.Sleep(backoff)
fmt.Sprintf("%s/functions/%s", c.BaseURL, payload.FunctionID), nil)
if err != nil {
return err
c.mu.RLock()
c.mu.RUnlock()
if err != nil {
resp.Body.Close()
if resp.StatusCode < 500 {
return nil
return fmt.Errorf("max rate limit retries exceeded")
func (c *CognigyClient) triggerFallback(ctx context.Context, payload RecoveryPayload) error {
fallbackURL := fmt.Sprintf("%s/flows/%s/execute", c.BaseURL, "fallback_flow_id")
fallbackPayload := map[string]string{"reason": "primary_recovery_failed", "functionId": payload.FunctionID}
body, _ := json.Marshal(fallbackPayload)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, fallbackURL, bytes.NewReader(body))
if err != nil {
return err
c.mu.RLock()
c.mu.RUnlock()
if err != nil {
return err
if resp.StatusCode >= 400 {
return fmt.Errorf("fallback execution failed with status %d", resp.StatusCode)
return nil
Step 4: Latency Tracking, Audit Logging, and Webhook Synchronization
The final step wraps the recovery execution in a governance layer that tracks latency, success rates, generates audit trails, and synchronizes with external monitoring via webhooks.
package main
import (
"bytes"
"encoding/json"
"fmt"
"log/slog"
"net/http"
"sync/atomic"
"time"
type RecoveryMetrics struct {
TotalAttempts atomic.Int64
Successes atomic.Int64
AvgLatency atomic.Float64
type AuditLog struct {
Status string `json:"status"`
LatencyMs float64 `json:"latencyMs"`
Error string `json:"error,omitempty"`
func (m *RecoveryMetrics) RecordSuccess(latency time.Duration) {
m.Successes.Add(1)
m.TotalAttempts.Add(1)
m.AvgLatency.Add(float64(latency.Milliseconds()))
func (m *RecoveryMetrics) RecordFailure(latency time.Duration, errMsg string) {
slog.Error("recovery failed", "error", errMsg)
func (m *RecoveryMetrics) SuccessRate() float64 {
total := m.TotalAttempts.Load()
if total == 0 {
return 0
return float64(m.Successes.Load()) / float64(total) * 100
func SendWebhookSync(ctx context.Context, webhookURL string, log AuditLog) error {
payload, err := json.Marshal(log)
if err != nil {
return fmt.Errorf("webhook marshal failed: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, webhookURL, bytes.NewReader(payload))
if err != nil {
return err
if err != nil {
return fmt.Errorf("webhook delivery failed: %w", err)
return fmt.Errorf("webhook rejected with status %d", resp.StatusCode)
return nil
The following module integrates all components into a single executable recovery orchestrator. Set the required environment variables before execution.
package main
import (
"context"
"fmt"
"log/slog"
"os"
"time"
func main() {
tenant := os.Getenv("COGNIGY_TENANT")
username := os.Getenv("COGNIGY_USERNAME")
password := os.Getenv("COGNIGY_PASSWORD")
webhookURL := os.Getenv("WEBHOOK_URL")
healthURL := "https://api.example.com/health"
if tenant == "" || username == "" || password == "" {
slog.Error("missing required environment variables")
return
client := NewCognigyClient(tenant, username, password)
if err := client.Authenticate(context.Background(), username, password); err != nil {
slog.Error("authentication failed", "error", err)
return
registry := NewRecoveryRegistry(1 * time.Hour)
metrics := &RecoveryMetrics{}
// Construct recovery payload
idempKey, _ := GenerateIdempotencyKey()
payload := RecoveryPayload{
FunctionID: "fn_abc123",
ErrorMatrix: ErrorMatrix{
ErrorCode: "EXECUTION_TIMEOUT",
ErrorMessage: "Custom function exceeded execution time",
StackTrace: "at FunctionExecutor.run\nat FlowEngine.process",
OccurredAt: time.Now().UTC().Format(time.RFC3339),
RetryDirective: RetryDirective{
MaxDepth: 3,
CurrentDepth: 1,
TimeoutMs: 5000,
Fallback: "default_greeting",
Strategy: "exponential_backoff",
IdempotencyKey: idempKey,
Timestamp: time.Now().UTC().Format(time.RFC3339),
// Validate schema
if err := ValidateRecoveryPayload(payload); err != nil {
slog.Error("payload validation failed", "error", err)
return
// Check idempotency
if registry.IsDuplicate(context.Background(), idempKey) {
slog.Warn("duplicate recovery attempt detected", "key", idempKey)
return
// Verify external service health
if err := CheckExternalServiceHealth(context.Background(), healthURL); err != nil {
slog.Error("external service unhealthy", "error", err)
return
// Execute recovery
start := time.Now()
err := client.ExecuteRecovery(context.Background(), payload)
latency := time.Since(start)
logEntry := AuditLog{
FunctionID: payload.FunctionID,
LatencyMs: float64(latency.Milliseconds()),
if err != nil {
logEntry.Status = "failed"
logEntry.Error = err.Error()
metrics.RecordFailure(latency, err.Error())
} else {
logEntry.Status = "success"
metrics.RecordSuccess(latency)
// Synchronize with monitoring
if webhookURL != "" {
if err := SendWebhookSync(context.Background(), webhookURL, logEntry); err != nil {
slog.Warn("webhook sync failed", "error", err)
fmt.Printf("Recovery complete. Success rate: %.2f%%\n", metrics.SuccessRate())
- Cause: The Cognigy.AI token has expired or the credentials are incorrect.
- Fix: Implement token refresh logic before each API call. Verify that
COGNIGY_USERNAMEandCOGNIGY_PASSWORDmatch an account withFunction Managerrole permissions. - Code fix: Call
client.EnsureValidToken(ctx)beforeExecuteRecovery.
Error: 403 Forbidden
- Cause: The authenticated user lacks
functions:writeorflows:executepermissions. - Fix: Assign the required role in the Cognigy.AI administration console. Verify that the tenant URL matches the licensed environment.
- Cause: Cognigy.AI rate limiting triggered by rapid recovery attempts.
- Fix: The
handleRateLimitmethod implements exponential backoff. Ensure yourRetryDirective.TimeoutMsaligns with platform throttle thresholds.
Error: Maximum retry depth exceeded
- Cause: The
CurrentDepthequals or exceedsMaxDepthin theRetryDirective. - Fix: Reset
CurrentDepthto 0 before initiating a new recovery cycle, or increaseMaxDepthif the business logic requires additional attempts.
Error: Idempotency key collision
- Cause: A recovery payload with the same
IdempotencyKeywas processed within the retention window. - Fix: Generate a new key using
GenerateIdempotencyKey()or extend theRecoveryRegistryretention period if duplicate tracking must persist longer.
