Building a Custom Data Action for Genesys Cloud Architect using Python
- You will build a Python FastAPI microservice that acts as a Data Action endpoint for Genesys Cloud Architect.
- You will implement logic to accept a JSON payload from Architect, call an external REST API, and transform the response.
- You will configure the Genesys Cloud platform to invoke this service and map the returned data to conversation variables.
- Genesys Cloud Account: You need a developer or admin account with permissions to create Data Actions (
dataaction:custom:write). - Python Environment: Python 3.9+ installed with
pip. - Dependencies:
fastapi,uvicorn,httpx,pydantic. - External API: For this tutorial, we will use the JSONPlaceholder API as a mock external service. It requires no authentication and returns predictable JSON.
- Hosting: A way to host your Python service publicly (e.g., AWS EC2, Heroku, Render, or a local tunnel like ngrok for testing).
Genesys Cloud Data Actions use a specific authentication model. Unlike standard API calls where your application holds a bearer token, the Architect flow sends a request to your endpoint with a specific header containing the user’s context.
Your Data Action endpoint does not need to authenticate with Genesys Cloud to receive the call. However, if your Python service needs to call back into Genesys Cloud APIs (e.g., to update a contact record), you must implement OAuth 2.0 Client Credentials flow.
For this tutorial, we focus on the inbound call from Architect. Architect sends a X-Genesys-Auth-Token header. You must validate this token to ensure the request is legitimate.
Validating the Genesys Cloud Token
You can validate the token by sending it to the Genesys Cloud introspection endpoint.
import httpx
import os
GENESYS_ORG_ID = os.getenv("GENESYS_ORG_ID")
GENESYS_REGION = os.getenv("GENESYS_REGION", "us-east-1") # Default to us-east-1
def get_genesis_base_url(region: str) -> str:
if region == "us-east-1":
return "https://api.mypurecloud.com"
elif region == "us-east-2":
return "https://api.mypurecloud.com" # Alias
elif region == "eu-west-1":
return "https://api.eu.purecloud.com"
# Add other regions as needed
async def validate_genesys_token(token: str) -> bool:
Validates the X-Genesys-Auth-Token received from Architect.
Returns True if valid, False otherwise.
base_url = get_genesis_base_url(GENESYS_REGION)
introspect_url = f"{base_url}/api/v2/oauth2/introspect"
headers = {
"Authorization": f"Bearer {token}"
payload = {
"token": token
async with httpx.AsyncClient() as client:
response = await client.post(
introspect_url,
headers=headers,
json=payload,
timeout=10.0
# A 200 OK with active=true means the token is valid
if response.status_code == 200:
data = response.json()
return data.get("active", False)
return False
print(f"Token validation error: {e}")
return False
Note: In production, you should cache the validation result for the duration of the token’s expiration (usually 1 hour) to avoid hitting the Genesys API on every single Architect call.
Step 1: Define the FastAPI Application and Schema
We will use FastAPI because it automatically generates OpenAPI documentation and handles JSON parsing efficiently. We need to define the schema for the input coming from Architect and the output going back.
Architect sends a JSON body with a data object containing the inputs you defined in the Data Action configuration.
from fastapi import FastAPI, Request, HTTPException
from typing import Optional
import httpx
import os
import logging
# Configure logging
app = FastAPI(title="Genesys Cloud Data Action Example")
# Define the input schema based on what Architect will send
class ArchitectInput(BaseModel):
# This matches the 'name' field you will define in Genesys Cloud Admin
customer_id: int = Field(..., description="The ID of the customer to look up")
# Define the output schema that Architect will map to variables
class ArchitectOutput(BaseModel):
# These keys will be available in Architect as variables
full_name: str
email: str
phone: str
is_premium_member: bool
Step 2: Implement the Core Logic (External API Call)
This is the core of the Data Action. It receives the customer_id, calls jsonplaceholder.typicode.com, and transforms the response.
EXTERNAL_API_BASE = "https://jsonplaceholder.typicode.com"
async def fetch_external_data(customer_id: int) -> dict:
Calls the external REST API and returns the raw JSON.
Handles timeouts and HTTP errors.
url = f"{EXTERNAL_API_BASE}/users/{customer_id}"
response = await client.get(url)
# Raise an exception for 4xx/5xx status codes
response.raise_for_status()
return response.json()
logger.error(f"HTTP Error calling external API: {e.response.status_code}")
raise HTTPException(
status_code=e.response.status_code,
detail=f"External API failed: {e.response.status_code}"
except httpx.TimeoutException:
logger.error("Timeout calling external API")
status_code=504,
detail="External API timed out"
logger.error(f"Network error calling external API: {e}")
status_code=502,
detail="Could not connect to external API"
def transform_external_data(raw_data: dict) -> ArchitectOutput:
Maps the external API response to the Genesys Cloud variable schema.
# Map fields from JSONPlaceholder to our desired output structure
# Note: JSONPlaceholder users don't have a 'premium' field, so we mock it
return ArchitectOutput(
full_name=raw_data.get("name", "Unknown User"),
email=raw_data.get("email", "unknown@example.com"),
phone=raw_data.get("phone", "000-000-0000"),
is_premium_member=False # Mock logic: in real life, check a DB
Step 3: Create the Data Action Endpoint
This endpoint handles the request from Genesys Cloud. It validates the token, parses the input, calls the external service, and returns the result in the exact format Genesys expects.
Genesys Cloud expects the response body to contain a data object with the output variables.
@app.post("/data-action/customer-lookup")
async def customer_lookup(request: Request):
Endpoint invoked by Genesys Cloud Architect Data Action.
# 1. Validate the Genesys Cloud Authentication Token
auth_token = request.headers.get("X-Genesys-Auth-Token")
if not auth_token:
raise HTTPException(status_code=401, detail="Missing X-Genesys-Auth-Token header")
is_valid = await validate_genesys_token(auth_token)
if not is_valid:
raise HTTPException(status_code=403, detail="Invalid Genesys Cloud Auth Token")
# 2. Parse the Incoming JSON Payload
body = await request.json()
# Architect sends inputs inside the 'data' key
input_data = body.get("data")
if not input_data:
raise HTTPException(status_code=400, detail="Missing 'data' in request body")
# Parse using Pydantic for validation
architect_input = ArchitectInput(**input_data)
raise HTTPException(status_code=400, detail=f"Invalid input format: {str(e)}")
# 3. Execute the Business Logic
raw_data = await fetch_external_data(architect_input.customer_id)
output_data = transform_external_data(raw_data)
except HTTPException:
raise
logger.error(f"Unexpected error in data action: {e}")
raise HTTPException(status_code=500, detail="Internal server error")
# 4. Return the Result in Genesys Cloud Format
# The response MUST have a 'data' key containing the variables
"data": {
"full_name": output_data.full_name,
"email": output_data.email,
"phone": output_data.phone,
"is_premium_member": output_data.is_premium_member
Step 4: Configure Genesys Cloud Admin
Now that the code is ready, you must configure the Data Action in Genesys Cloud.
Host the Service: Run your FastAPI app. For local testing, use
ngrok.uvicorn main:app --host 0.0.0.0 --port 8000 ngrok http 8000Copy the HTTPS URL (e.g.,
https://abc123.ngrok.io). -
Create the Data Action:
- Log in to Genesys Cloud Admin.
- Navigate to Admin > Developers > Data actions.
- Click Create data action.
- Name:
Customer Lookup - Description:
Fetches customer details from external API - Endpoint URL: Paste your ngrok URL +
/data-action/customer-lookup(e.g.,https://abc123.ngrok.io/data-action/customer-lookup) - Request Method:
POST
Define Input Variables:
- Click Add input variable.
- Name:
customer_id - Type:
Integer - Description:
The external customer ID
Define Output Variables:
- Click Add output variable.
- Name:
full_name - Type:
String - Name:
email - Type:
String - Name:
phone - Type:
String - Name:
is_premium_member - Type:
Boolean
Save the Data Action.
Step 5: Use in Architect
- Open Architect.
- Drag the Data Action node onto your flow.
- Select Customer Lookup from the dropdown.
- Configure Inputs:
- Set
customer_idto a dynamic variable (e.g.,customer.idor a prompt result).
- Set
- Configure Outputs:
- Architect automatically creates variables for the outputs you defined.
- You can now use
dataAction.customer_lookup.full_namein subsequent nodes (e.g., a Prompt or Set Variables node).
Below is the complete main.py file. Save this as main.py.
import os
import logging
import httpx
# --- Configuration ---
GENESYS_ORG_ID = os.getenv("GENESYS_ORG_ID", "your-org-id")
# --- Logging ---
# --- Pydantic Models ---
full_name: str
email: str
phone: str
# --- FastAPI App ---
"""Returns the Genesys Cloud API base URL for the given region."""
regions = {
"us-east-1": "https://api.mypurecloud.com",
"us-east-2": "https://api.mypurecloud.com",
"eu-west-1": "https://api.eu.purecloud.com",
"ap-southeast-2": "https://api.au.purecloud.com"
return regions.get(region, "https://api.mypurecloud.com")
headers = {
payload = {"token": token}
introspect_url,
headers=headers,
json=payload,
timeout=10.0
return False
logger.error(f"Token validation error: {e}")
return False
status_code=504,
status_code=502,
# 1. Validate Token
if not auth_token:
if not is_valid:
# 2. Parse Input
if not input_data:
# 3. Execute Logic
raise
# 4. Return Result
"data": {
- Cause: The
X-Genesys-Auth-Tokenheader is missing, expired, or invalid. - Fix: Ensure your Data Action configuration in Genesys Cloud has the correct URL. Check your Python logs to see if the token validation step is failing. If you are testing locally with ngrok, ensure the ngrok tunnel is active and the URL is correct.
Error: 400 Bad Request - “Missing ‘data’ in request body”
- Cause: The request body sent by Architect does not match the expected structure.
- Fix: Verify that you defined the input variables in the Genesys Cloud Admin console correctly. Architect always wraps inputs in a
dataobject. Ensure your Python code accessesbody.get("data").
Error: 504 Gateway Timeout
- Cause: The external API call took too long. Genesys Cloud has a timeout for Data Actions (typically 30 seconds).
- Fix: Increase the timeout in your
httpx.AsyncClientif appropriate, or optimize the external API call. Add retry logic for transient failures.
Error: Variable Mapping Fails in Architect
- Cause: The JSON keys returned by your Python service do not exactly match the output variable names defined in Genesys Cloud Admin.
- Fix: Check the
ArchitectOutputmodel and the return statement in your FastAPI endpoint. Ensure the keys (full_name,email, etc.) match the names you entered in the Admin console.
