Building a Custom Agent Whisper Coaching Interface Using the Genesys Cloud Conversation Control API
You will build a real-time supervisor interface that injects audio or text whispers into active agent conversations using the Genesys Cloud Conversation Control API. The finished system will monitor live conversation states via Event Streams WebSockets, validate supervisor permissions and media channel capabilities, execute whisper commands with precise targeting, and track asynchronous delivery confirmation without disrupting the primary customer media path.
- Licensing Tier: CX 1 or higher. The Conversation Control API is included in standard CX licenses. Audio whisper injection requires active Telephony licensing for the supervisor and agent. Digital whisper (text/chat/email) requires Engagement licensing.
- Granular Permissions:
Conversation:Control:Write,Conversation:Read,Interaction:Read,User:Read,Interaction:Interaction:Read - OAuth Scopes:
conversation:control:write,conversation:read,interaction:read,user:read - External Dependencies: Persistent WebSocket connection to Genesys Cloud Event Streams, OAuth2 client credentials flow implementation, custom frontend framework (React, Vue, or Angular), and a backend service layer for token management and audit logging.
1. Establish Real-Time Conversation State Tracking via Event Streams
Polling the REST API for conversation state changes introduces unacceptable latency for coaching interfaces. A whisper command sent during an agent hold period or while the conversation transitions to transfer state will either fail or inject audio at the wrong moment. You must subscribe to the Genesys Cloud Event Streams WebSocket to receive sub-second state updates.
Initialize a WebSocket connection to /api/v2/events. Pass the active access token as a query parameter or in the Authorization header. Upon connection, you will receive a continuous stream of JSON events. Filter aggressively on the client side to isolate conversation and control event types.
const wsUrl = `wss://${orgName}.mypurecloud.com/api/v2/events?access_token=${accessToken}`;
const eventStream = new WebSocket(wsUrl);
eventStream.onmessage = (event) => {
const data = JSON.parse(event.data);
// Filter for conversation state changes and control events
if (data.type === 'conversation' || data.type === 'control') {
handleConversationEvent(data);
The Trap: Subscribing to the Event Streams endpoint without implementing a server-side or client-side filter for specific conversationId, userId, or type values. The Genesys Cloud event bus broadcasts thousands of events per second for large organizations. An unfiltered WebSocket connection will saturate the browser network thread, exhaust client memory, and trigger connection resets.
Architectural Reasoning: We implement a subscription filter using the filter parameter in the WebSocket handshake payload or maintain a reactive state store that only processes events matching the supervisor’s assigned queue or team. This reduces payload processing overhead by 90 percent and ensures the UI only reacts to conversations the supervisor is authorized to coach. The WebSocket must also implement automatic reconnection with exponential backoff, as Genesys Cloud enforces connection limits and periodically rotates streaming endpoints.
2. Construct and Validate the Whisper Control Payload
Before issuing a whisper command, you must validate the conversation topology. The Conversation Control API rejects payloads that target inactive media channels or conversations lacking whisper routing rules. Query the conversation details first to inspect the mediaChannels array and verify the whisperSupported flag.
GET /api/v2/conversations/{conversationId}
Authorization: Bearer {access_token}
Inspect the response for the active agent participant. Extract the participantId and verify the media channel configuration. Only proceed if the conversation state is ACTIVE and the target channel supports whisper injection.
Construct the control payload using the POST /api/v2/conversations/{conversationId}/control endpoint. The payload must specify the controlType, targetUserId or targetParticipantId, and mediaType. For audio coaching, set mediaType to AUDIO. For digital channels, use TEXT.
"controlType": "WHISPER",
"targetUserId": "agent-uuid-here",
"mediaType": "AUDIO",
"audioMixLevel": 0.8,
"metadata": {
"coachingSessionId": "coach-12345",
"supervisorId": "supervisor-uuid-here"
The Trap: Omitting the audioMixLevel parameter or setting it to 1.0. Genesys Cloud media servers mix the whisper stream with the existing agent audio path. A mix level of 1.0 causes signal clipping when the customer speaks simultaneously, resulting in distorted audio that degrades coaching effectiveness.
Architectural Reasoning: We default audioMixLevel to 0.6 or 0.7 to ensure the whisper audio sits beneath the primary conversation stream. The metadata block is mandatory for audit compliance and cross-referencing with WFM or Speech Analytics systems. Genesys Cloud does not enforce metadata schemas, so we define a strict internal contract here to enable downstream reporting. The API returns a 200 OK with a controlId. This response only confirms the command entered the media queue. It does not confirm delivery.
3. Execute the Whisper Command and Manage Media Stream Lifecycle
Send the control payload via HTTPS POST. Capture the controlId from the response body. You must track this identifier against the WebSocket event stream to determine actual execution status. The Genesys Cloud media server processes whisper commands asynchronously to prevent blocking the primary SIP or WebRTC media path.
async function initiateWhisper(conversationId, payload) {
const response = await fetch(`/api/v2/conversations/${conversationId}/control`, {
method: 'POST',
headers: {
'Authorization': `Bearer ${accessToken}`
body: JSON.stringify(payload)
if (!response.ok) {
throw new Error(`Control API failed: ${response.status} ${response.statusText}`);
const data = await response.json();
return data.id; // Returns controlId
Monitor the WebSocket for control events matching the returned controlId. The event payload will contain a status field indicating QUEUED, EXECUTING, COMPLETED, or FAILED. Update the supervisor UI state accordingly. Implement a timeout watcher of five seconds. If the control event does not arrive within the window, mark the UI as PENDING_DELIVERY rather than SUCCESS.
The Trap: Treating the 200 OK response as final confirmation of whisper delivery. Under high media server load or during carrier network congestion, the whisper command may queue for ten to fifteen seconds. If the UI displays a green checkmark immediately, supervisors assume the agent heard the coaching cue. When the audio finally arrives late, the coaching moment has passed.
Architectural Reasoning: We decouple command submission from delivery confirmation. The frontend maintains a pending control registry. Each registry entry polls the WebSocket event stream and falls back to a REST status check if the WebSocket drops. This dual-channel verification pattern ensures accurate UI state even during network partitions. The timeout mechanism prevents UI freezes and allows supervisors to retry or switch to text whisper if audio delivery stalls.
4. Implement Supervisor UI State Synchronization and Fallback Logic
A coaching interface must handle concurrent whisper requests, agent state transitions, and supervisor handoffs. Multiple supervisors attempting to whisper to the same agent simultaneously causes audio mixing conflicts and cognitive overload for the agent. Implement a soft-lock mechanism that queries active controls before allowing new whisper submissions.
Query existing controls for the conversation:
GET /api/v2/conversations/{conversationId}/controls
Filter the response for controlType: "WHISPER" and status: "EXECUTING". If an active whisper exists, disable the audio whisper button in the UI and surface the currently coaching supervisor identifier. Allow text whisper to remain enabled, as Genesys Cloud routes digital whispers through a separate non-competing channel.
When the agent initiates a transfer, places the call on hold, or ends the conversation, the media channel topology changes. The WebSocket will emit a conversation event with state: "IN_TRANSFER" or state: "HOLD". Intercept this event and immediately cancel pending whispers.
DELETE /api/v2/conversations/{conversationId}/controls/{controlId}
The Trap: Allowing whisper commands to persist across conversation state changes. If an agent transfers a call while a whisper is queued, the media server attempts to inject audio into a dissolving media path. This triggers 409 Conflict responses, floods the API logs with errors, and leaves the supervisor UI in an inconsistent state.
Architectural Reasoning: We bind whisper lifecycle to conversation state machine transitions. The frontend maintains a reactive state store that maps conversationId to allowedActions. When the state shifts to HOLD, IN_TRANSFER, or ENDED, the store automatically revokes WHISPER_AUDIO permissions for that conversation. The UI reflects this change instantly. This pattern prevents wasted API calls, reduces error rates, and aligns the coaching interface with Genesys Cloud media routing behavior.
Edge Case 1: Audio Clipping During Whisper Injection
The failure condition: The agent hears fragmented whisper audio, metallic distortion, or complete silence while the supervisor confirms the command was sent.
The root cause: Sample rate mismatch between the supervisor client audio capture and the Genesys Cloud media server expectations. Genesys Cloud standardizes on 16kHz mono PCM for telephony whisper streams. If the frontend captures audio at 48kHz stereo and sends it without transcoding, the media server drops packets during mixing. Additionally, carrier network jitter can cause RTP packet loss on the whisper path.
The solution: Enforce 16kHz mono audio encoding in the supervisor client before transmission. Use the WebRTC MediaRecorder API with explicit codec constraints. Implement a 200ms pre-roll buffer in your application layer to absorb network jitter. If distortion persists, lower the audioMixLevel to 0.5 and verify that the agent endpoint supports SIP codec negotiation for PCMU or PCMA. Cross-reference with the Speech Analytics audio quality reports to isolate whether the issue originates in the supervisor network or the Genesys media cluster.
Edge Case 2: Whisper Drops on Agent Transfer or Conference
The failure condition: Whisper commands return 409 Conflict or 400 Bad Request immediately after the agent clicks the transfer button or adds a third party to the call.
The root cause: Conversation state transitions to IN_TRANSFER or CONFERENCE. Genesys Cloud suspends direct media control on the primary leg to preserve call integrity. The whisper injection path is severed until the transfer completes or the conference stabilizes.
The solution: Implement state-aware command routing. When the WebSocket emits a state change to IN_TRANSFER, automatically cancel all pending whispers via the DELETE /controls/{controlId} endpoint. Switch the UI to a monitoring-only view that displays real-time transcription or call metrics. Once the state returns to ACTIVE post-transfer, re-enable whisper controls. This approach prevents API error accumulation and aligns supervisor actions with actual media availability. Reference the WFM real-time adherence guide for similar state-handling patterns.
Edge Case 3: OAuth Token Expiry During Long Coaching Sessions
The failure condition: Whisper commands begin returning 401 Unauthorized after thirty to forty minutes of continuous use, despite the supervisor remaining logged into the application.
The root cause: Access tokens issued via the Genesys Cloud OAuth2 service expire after a fixed duration (typically thirty minutes). The frontend holds the initial token in memory without implementing a refresh cycle.
The solution: Implement a silent refresh mechanism using the OAuth2 refresh token grant type. Store the refresh token in a secure, httpOnly cookie or encrypted storage. Trigger a token renewal request sixty seconds before expiry. Replace the expired token in all active API interceptors and WebSocket reconnection handlers. Never expose refresh tokens to client-side JavaScript execution contexts. This pattern ensures uninterrupted coaching sessions and complies with enterprise security standards for token lifecycle management.
