Build a Resilient Genesys Cloud EventBridge Queue Poller in Java with Circuit Breaking and Audit Tracking
- A Java service that polls Genesys Cloud EventBridge outbound notification queues using structured fetch directives containing queue reference, interval matrix, and fetch parameters.
- The implementation uses the official Genesys Cloud Java SDK for OAuth management and
java.net.http.HttpClientfor atomic HTTP GET operations. - The code covers payload construction, rate limit validation, exponential backoff, circuit breaker logic, external broker synchronization, latency tracking, and audit logging.
- OAuth Client Credentials flow with
eventbridge:readandeventbridge:writescopes - Genesys Cloud Java SDK v15.0.0 or newer
- Java 17 or newer runtime environment
- External dependencies:
com.fasterxml.jackson.core:jackson-databind:2.15.2,org.slf4j:slf4j-api:2.0.9,ch.qos.logback:logback-classic:1.4.11
Genesys Cloud requires OAuth 2.0 Client Credentials for server-to-server integrations. The official Java SDK handles token caching and automatic refresh when configured correctly. You must initialize the ApiClient with your environment URL, client ID, and client secret.
import com.mypurecloud.api.client.ApiClient;
import com.mypurecloud.api.client.auth.oauth.ClientCredentialsProvider;
import com.mypurecloud.api.client.auth.oauth.OAuth;
public class GenesysAuthConfig {
private static final String ENVIRONMENT_URL = "https://api.mypurecloud.com";
private static final String CLIENT_ID = System.getenv("GENESYS_CLIENT_ID");
private static final String CLIENT_SECRET = System.getenv("GENESYS_CLIENT_SECRET");
private static final List<String> SCOPES = List.of("eventbridge:read", "eventbridge:write");
public static ApiClient buildAuthenticatedClient() throws Exception {
OAuth oAuth = new OAuth(ENVIRONMENT_URL, CLIENT_ID, CLIENT_SECRET);
oAuth.setScopes(SCOPES);
ApiClient apiClient = new ApiClient();
apiClient.setOAuth(oAuth);
apiClient.setBasePath(ENVIRONMENT_URL);
// Force initial token fetch and validation
oAuth.getAccessToken();
return apiClient;
The SDK caches the access token in memory and automatically requests a new token before expiration. You will inject this ApiClient into your poller to extract valid bearer tokens for downstream HTTP operations.
Step 1: Construct Polling Payloads with Queue Reference, Interval Matrix, and Fetch Directive
Genesys Cloud EventBridge outbound notifications expose queue states through REST endpoints. You must construct a polling payload that specifies the target queue, the polling interval matrix, and the fetch directive. The payload must conform to the expected JSON schema to avoid 400 Bad Request responses.
import java.util.Map;
import java.util.List;
public record PollingPayload(
String queueRef,
Map<String, Integer> intervalMatrix,
FetchDirective fetchDirective
public record FetchDirective(
int maxItems,
String consistencyLevel,
boolean includeMetadata
public class PayloadBuilder {
private static final ObjectMapper mapper = new ObjectMapper();
public static String buildFetchPayload(String queueId, int intervalSeconds, int batchSize) {
Map<String, Integer> intervalMatrix = Map.of(
"initial", intervalSeconds,
"sustained", intervalSeconds * 2,
"backoff", intervalSeconds * 4
FetchDirective directive = new FetchDirective(
batchSize,
"eventual",
true
PollingPayload payload = new PollingPayload(
String.format("eventbridge:outbound:%s", queueId),
intervalMatrix,
directive
return mapper.writeValueAsString(payload);
} catch (Exception e) {
throw new RuntimeException("Failed to serialize polling payload", e);
The queueRef follows the eventbridge:outbound:{id} format. The intervalMatrix defines timing parameters for initial fetch, sustained polling, and backoff states. The fetchDirective controls batch size and consistency guarantees.
Step 2: Validate Against Rate Constraints and Maximum Concurrent Poll Limits
Genesys Cloud enforces strict rate limits on EventBridge endpoints. You must validate the polling schema against maximum concurrent poll limits before initiating requests. The validation pipeline checks the interval matrix against platform constraints and rejects configurations that would trigger 429 Too Many Requests responses.
public class RateLimitValidator {
private static final int MAX_CONCURRENT_POLLS = 10;
private static final int MIN_INTERVAL_SECONDS = 5;
private static final int MAX_BATCH_SIZE = 100;
public static void validatePayload(String payloadJson) throws IllegalArgumentException {
var node = mapper.readTree(payloadJson);
int sustainedInterval = node.get("intervalMatrix").get("sustained").asInt();
int batchSize = node.get("fetchDirective").get("maxItems").asInt();
if (sustainedInterval < MIN_INTERVAL_SECONDS) {
throw new IllegalArgumentException(
String.format("Interval matrix sustained value %d violates minimum constraint of %d seconds",
sustainedInterval, MIN_INTERVAL_SECONDS)
if (batchSize > MAX_BATCH_SIZE) {
String.format("Fetch directive maxItems %d exceeds platform limit of %d",
batchSize, MAX_BATCH_SIZE)
// Concurrent poll limit is enforced at the executor level
throw new IllegalArgumentException("Invalid polling payload schema: " + e.getMessage(), e);
This validator prevents malformed configurations from reaching the API. It checks the sustained interval against the minimum threshold and validates batch size against the platform maximum. You must call this validator before every polling cycle initialization.
Step 3: Atomic HTTP GET Operations with Circuit Breaker and Exponential Backoff
You will use java.net.http.HttpClient to perform atomic GET operations against the EventBridge queue endpoint. The circuit breaker monitors failure rates and automatically opens when thresholds are exceeded. Exponential backoff with jitter prevents thundering herd scenarios during scaling events.
import java.net.URI;
import java.time.Duration;
import java.util.concurrent.ThreadLocalRandom;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class QueuePollExecutor {
private static final Logger logger = LoggerFactory.getLogger(QueuePollExecutor.class);
private static final HttpClient httpClient = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(10))
.version(HttpClient.Version.HTTP_2)
.build();
private enum CircuitState { CLOSED, OPEN, HALF_OPEN }
private CircuitState circuitState = CircuitState.CLOSED;
private long lastFailureTime = 0;
private int consecutiveFailures = 0;
private static final int FAILURE_THRESHOLD = 5;
private static final long CIRCUIT_OPEN_DURATION_MS = 30_000;
public HttpResponse<String> executeAtomicGet(String baseUrl, String queueRef, String accessToken) throws Exception {
if (isCircuitOpen()) {
if (System.currentTimeMillis() - lastFailureTime > CIRCUIT_OPEN_DURATION_MS) {
circuitState = CircuitState.HALF_OPEN;
logger.info("Circuit breaker transitioning to HALF_OPEN state");
} else {
throw new RuntimeException("Circuit breaker is OPEN. Request rejected.");
String endpoint = String.format("%s/api/v2/eventbridge/outboundnotifications/%s/fetch", baseUrl, queueRef);
.uri(URI.create(endpoint))
.header("Authorization", "Bearer " + accessToken)
.header("Accept", "application/json")
.GET()
.build();
if (response.statusCode() >= 200 && response.statusCode() < 300) {
onSucess();
} else {
onFailure(response.statusCode());
return response;
private void onSucess() {
private void onFailure(int statusCode) {
consecutiveFailures++;
lastFailureTime = System.currentTimeMillis();
if (consecutiveFailures >= FAILURE_THRESHOLD) {
circuitState = CircuitState.OPEN;
logger.warn("Circuit breaker OPENED after {} consecutive failures", consecutiveFailures);
if (statusCode == 429) {
long backoffMs = calculateExponentialBackoff(consecutiveFailures);
logger.info("Rate limit detected. Applying exponential backoff: {}ms", backoffMs);
Thread.sleep(backoffMs);
} else if (statusCode == 401 || statusCode == 403) {
throw new RuntimeException("Authentication failure: HTTP " + statusCode);
} else if (statusCode >= 500) {
logger.error("Server error encountered: HTTP {}", statusCode);
private long calculateExponentialBackoff(int attempt) {
long baseDelay = 1000L;
long maxDelay = 30000L;
long jitter = ThreadLocalRandom.current().nextLong(0, 1000);
return Math.min(baseDelay * (1L << (attempt - 1)) + jitter, maxDelay);
private boolean isCircuitOpen() {
return circuitState == CircuitState.OPEN;
The executor performs atomic GET requests against /api/v2/eventbridge/outboundnotifications/{queueRef}/fetch. It tracks consecutive failures and opens the circuit when the threshold is reached. The exponential backoff calculation uses base-2 progression with random jitter to distribute retry load.
Step 4: Empty Queue Checking and Stale Token Verification Pipelines
You must verify queue depth and token validity before processing responses. Empty queues should trigger immediate sleep cycles to prevent API exhaustion. Stale tokens require explicit refresh cycles before retrying.
public class FetchValidationPipeline {
private static final Logger logger = LoggerFactory.getLogger(FetchValidationPipeline.class);
public static boolean validateFetchResponse(HttpResponse<String> response, ApiClient apiClient) throws Exception {
int statusCode = response.statusCode();
// Stale token verification
if (statusCode == 401) {
logger.warn("Stale token detected. Refreshing OAuth credentials...");
apiClient.getOAuth().refreshAccessToken();
return false; // Caller must retry with new token
String body = response.body();
if (body == null || body.isBlank()) {
logger.warn("Empty response body received from queue endpoint");
return false;
JsonNode rootNode = mapper.readTree(body);
// Empty queue checking
if (rootNode.has("items") && rootNode.get("items").isArray() && rootNode.get("items").size() == 0) {
logger.info("Queue depth evaluation: empty queue detected. Entering sleep cycle.");
return false;
// Format verification
if (!rootNode.has("queueDepth") || !rootNode.has("nextFetchToken")) {
throw new IllegalArgumentException("Response schema validation failed: missing required fields");
return true;
This pipeline checks for 401 status codes and triggers an explicit token refresh via the SDK. It parses the JSON response to verify queue depth and validates the schema structure. Empty queues return false to signal the poller to skip processing and sleep.
Step 5: External Broker Synchronization, Latency Tracking, and Audit Logging
You will synchronize fetched events to an external message broker via webhooks, track polling latency and success rates, and generate audit logs for event governance.
import java.time.Instant;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
public class PollingMetricsAndSync {
private final AtomicLong totalLatencyMs = new AtomicLong(0);
private final AtomicInteger successCount = new AtomicInteger(0);
private final AtomicInteger failureCount = new AtomicInteger(0);
private static final Logger logger = LoggerFactory.getLogger(PollingMetricsAndSync.class);
public void recordLatencyAndSuccess(long latencyMs, boolean success) {
totalLatencyMs.addAndGet(latencyMs);
if (success) {
successCount.incrementAndGet();
} else {
failureCount.incrementAndGet();
public double getAverageLatencyMs() {
int total = successCount.get() + failureCount.get();
return total == 0 ? 0.0 : (double) totalLatencyMs.get() / total;
public double getSuccessRate() {
return total == 0 ? 0.0 : (double) successCount.get() / total;
public void syncToExternalBroker(String webhookUrl, String eventPayload) throws Exception {
.uri(URI.create(webhookUrl))
.POST(HttpRequest.BodyPublishers.ofString(eventPayload))
.build();
HttpResponse<String> response = QueuePollExecutor.httpClient.send(request, HttpResponse.BodyHandlers.ofString());
logger.info("Successfully synchronized queue events to external broker");
} else {
logger.error("Broker synchronization failed with HTTP {}", response.statusCode());
public void generateAuditLog(String queueRef, boolean success, long latencyMs, String token) {
String auditEntry = String.format(
"[AUDIT] Timestamp=%s | QueueRef=%s | Status=%s | Latency=%dms | TokenHash=%s",
Instant.now().toString(),
queueRef,
success ? "SUCCESS" : "FAILURE",
latencyMs,
token.substring(Math.max(0, token.length() - 6))
logger.info(auditEntry);
The metrics component tracks latency and success rates using thread-safe atomic counters. The broker synchronization method posts fetched events to an external webhook endpoint. The audit log generator records governance data with timestamp, queue reference, status, latency, and masked token hash.
import java.util.concurrent.Executors;
import java.util.concurrent.ScheduledExecutorService;
public class EventBridgeQueuePoller {
private static final Logger logger = LoggerFactory.getLogger(EventBridgeQueuePoller.class);
private static final String QUEUE_ID = System.getenv("EVENTBRIDGE_QUEUE_ID");
private static final String BROKER_WEBHOOK = System.getenv("EXTERNAL_BROKER_WEBHOOK");
private final ApiClient apiClient;
private final QueuePollExecutor pollExecutor;
private final PollingMetricsAndSync metrics;
private final ScheduledExecutorService scheduler;
public EventBridgeQueuePoller(ApiClient apiClient) {
this.apiClient = apiClient;
this.pollExecutor = new QueuePollExecutor();
this.metrics = new PollingMetricsAndSync();
this.scheduler = Executors.newSingleThreadScheduledExecutor();
public void startPolling(int intervalSeconds, int batchSize) throws Exception {
String payloadJson = PayloadBuilder.buildFetchPayload(QUEUE_ID, intervalSeconds, batchSize);
RateLimitValidator.validatePayload(payloadJson);
logger.info("Initializing EventBridge queue poller with interval={}s, batchSize={}", intervalSeconds, batchSize);
scheduler.scheduleAtFixedRate(() -> {
executePollCycle(payloadJson, intervalSeconds);
logger.error("Poll cycle failed: {}", e.getMessage(), e);
metrics.recordLatencyAndSuccess(0, false);
}, 0, intervalSeconds, TimeUnit.SECONDS);
private void executePollCycle(String payloadJson, int intervalSeconds) throws Exception {
String accessToken = apiClient.getOAuth().getAccessToken();
long startTime = System.currentTimeMillis();
HttpResponse<String> response = pollExecutor.executeAtomicGet(
ENVIRONMENT_URL,
QUEUE_ID,
accessToken
boolean valid = FetchValidationPipeline.validateFetchResponse(response, apiClient);
long latencyMs = System.currentTimeMillis() - startTime;
if (valid) {
metrics.recordLatencyAndSuccess(latencyMs, true);
metrics.syncToExternalBroker(BROKER_WEBHOOK, response.body());
metrics.generateAuditLog(QUEUE_ID, true, latencyMs, accessToken);
logger.info("Poll cycle completed successfully. Latency: {}ms", latencyMs);
} else {
metrics.recordLatencyAndSuccess(latencyMs, false);
metrics.generateAuditLog(QUEUE_ID, false, latencyMs, accessToken);
Thread.sleep(intervalSeconds * 1000L);
public void shutdown() {
scheduler.shutdown();
if (!scheduler.awaitTermination(5, TimeUnit.SECONDS)) {
scheduler.shutdownNow();
} catch (InterruptedException e) {
Thread.currentThread().interrupt();
public static void main(String[] args) throws Exception {
ApiClient client = GenesysAuthConfig.buildAuthenticatedClient();
EventBridgeQueuePoller poller = new EventBridgeQueuePoller(client);
poller.startPolling(10, 50);
Runtime.getRuntime().addShutdownHook(new Thread(poller::shutdown));
This complete example initializes the authenticated API client, constructs the polling payload, validates rate constraints, and starts a scheduled polling cycle. The poller executes atomic GET requests, validates responses, synchronizes events to an external broker, tracks metrics, and generates audit logs. The shutdown hook ensures graceful termination.
- What causes it: The polling interval falls below the platform minimum threshold or concurrent poll limits are exceeded during scaling events.
- How to fix it: Increase the sustained interval in the
intervalMatrixand verify thatmaxItemsdoes not exceed 100. The exponential backoff logic automatically applies jitter-based delays. - Code showing the fix: The
QueuePollExecutor.onFailuremethod detects 429 status codes and invokescalculateExponentialBackoffwith jitter to distribute retry load.
Error: HTTP 401 Unauthorized
- What causes it: The OAuth access token has expired or the client credentials lack
eventbridge:readscope. - How to fix it: Ensure the
ClientCredentialsProviderincludes botheventbridge:readandeventbridge:writescopes. TheFetchValidationPipelineautomatically triggersapiClient.getOAuth().refreshAccessToken()when 401 is detected. - Code showing the fix: The validation pipeline checks
statusCode == 401and calls the SDK refresh method before returning false to trigger a retry cycle.
Error: Circuit Breaker Open
- What causes it: Five consecutive failures occur within the polling window, triggering automatic circuit isolation.
- How to fix it: Wait for the 30-second open duration to expire. The circuit transitions to HALF_OPEN state, allowing a single probe request. If the probe succeeds, the circuit closes. If it fails, the circuit reopens.
QueuePollExecutortracksconsecutiveFailuresandlastFailureTime. TheisCircuitOpencheck prevents requests during the open window and transitions to HALF_OPEN after the duration expires.
