Build a Resilient Cognigy.AI Webhook Optimizer with Node.js
- You will build a Node.js service that constructs, validates, and updates Cognigy.AI webhook configurations using atomic PUT operations while enforcing concurrency limits, circuit breaker states, and automatic load shedding.
- You will interact with the Cognigy.AI REST API v1 Webhooks endpoints (
/api/v1/webhooksand/api/v1/webhooks/{id}). - You will implement the solution in modern JavaScript (Node.js 18+) using
axios,express,joi, andpino.
- Cognigy.AI API token with
webhooks:readandwebhooks:writescopes - Cognigy.AI REST API v1 (base URL:
https://<region>.cognigy.ai/api/v1) - Node.js 18.0 or higher
- External dependencies:
npm install axios express joi pino
Cognigy.AI uses a token-based authentication model. You obtain a bearer token by authenticating against the login endpoint. The token must be cached and reused to prevent unnecessary authentication overhead.
const COGNIGY_BASE = process.env.COGNIGY_BASE_URL || 'https://api.cognigy.ai';
const COGNIGY_USER = process.env.COGNIGY_USER;
const COGNIGY_PASS = process.env.COGNIGY_PASS;
let cachedToken = null;
let tokenExpiry = 0;
async function getCognigyToken() {
const now = Date.now();
if (cachedToken && now < tokenExpiry) {
return cachedToken;
const response = await axios.post(`${COGNIGY_BASE}/api/v1/login`, null, {
auth: { username: COGNIGY_USER, password: COGNIGY_PASS },
headers: { 'Content-Type': 'application/json' }
cachedToken = response.data.token;
// Cognigy tokens typically expire in 24 hours (86400000 ms)
tokenExpiry = now + 86400000;
return cachedToken;
} catch (error) {
if (error.response) {
throw new Error(`Authentication failed with status ${error.response.status}: ${error.response.data.message}`);
throw error;
Step 1: Payload Validation, TLS Handshake Checking, and Size Verification
Before sending configuration updates to Cognigy.AI, you must validate the payload schema against gateway constraints. Cognigy.AI enforces HTTPS endpoints, maximum URL lengths, and strict retry policies. You will also verify TLS handshake capability and payload size before transmission.
const Joi = require('joi');
const https = require('https');
const MAX_PAYLOAD_BYTES = 10240; // 10KB limit for webhook config payloads
const MAX_URL_LENGTH = 2048;
const WebhookSchema = Joi.object({
url: Joi.string().uri({ scheme: ['https'] }).max(MAX_URL_LENGTH).required(),
method: Joi.string().valid('POST', 'PUT').default('POST'),
headers: Joi.object().pattern(Joi.string(), Joi.string()).default({}),
retryPolicy: Joi.object({
maxRetries: Joi.number().integer().min(0).max(5).required(),
backoffMs: Joi.number().integer().min(100).max(30000).required()
}).required()
async function validatePayload(payload) {
const { error, value } = WebhookSchema.validate(payload, { abortEarly: false });
if (error) {
throw new Error(`Schema validation failed: ${error.details.map(d => d.message).join(', ')}`);
const byteSize = Buffer.byteLength(JSON.stringify(value), 'utf8');
if (byteSize > MAX_PAYLOAD_BYTES) {
throw new Error(`Payload exceeds maximum size limit of ${MAX_PAYLOAD_BYTES} bytes`);
return value;
function checkTLSHandshake(targetUrl) {
return new Promise((resolve, reject) => {
const parsed = new URL(targetUrl);
const req = https.request({
hostname: parsed.hostname,
port: parsed.port || 443,
path: '/',
method: 'HEAD',
timeout: 3000,
rejectUnauthorized: true
}, (res) => {
res.resume();
resolve(res.statusCode >= 200 && res.statusCode < 400);
req.on('timeout', () => req.destroy());
req.on('error', (err) => reject(new Error(`TLS handshake failed for ${targetUrl}: ${err.message}`)));
req.end();
Step 2: Circuit Breaker Directive and Concurrency Limit Matrix
High-frequency webhook updates trigger rate limits and degrade gateway performance. You will implement a circuit breaker that tracks failure rates and an async queue that enforces concurrency matrices based on operation type. The circuit breaker transitions to OPEN after consecutive failures, triggering automatic load shedding.
class CircuitBreaker {
constructor(failureThreshold = 5, resetTimeout = 15000) {
this.state = 'CLOSED';
this.failureCount = 0;
this.failureThreshold = failureThreshold;
this.resetTimeout = resetTimeout;
this.lastFailureTime = null;
async execute(fn) {
if (this.state === 'OPEN') {
const elapsed = Date.now() - this.lastFailureTime;
if (elapsed > this.resetTimeout) {
this.state = 'HALF-OPEN';
} else {
throw new Error('Load shedding active: Circuit breaker is OPEN');
const result = await fn();
this.onSuccess();
return result;
} catch (error) {
this.onFailure();
throw error;
onSuccess() {
onFailure() {
this.failureCount++;
this.lastFailureTime = Date.now();
if (this.failureCount >= this.failureThreshold) {
this.state = 'OPEN';
class ConcurrencyQueue {
constructor(concurrencyLimit = 3) {
this.concurrencyLimit = concurrencyLimit;
this.pending = 0;
this.queue = [];
async add(task) {
this.queue.push({ task, resolve, reject });
this.process();
async process() {
if (this.pending >= this.concurrencyLimit || this.queue.length === 0) return;
this.pending++;
const { task, resolve, reject } = this.queue.shift();
const result = await task();
resolve(result);
} catch (error) {
reject(error);
} finally {
this.pending--;
this.process();
Step 3: Atomic PUT Operations, 429 Retry Logic, and Latency Tracking
Cognigy.AI supports atomic updates via PUT. You will wrap the API call with exponential backoff for 429 responses, track request latency, and log throughput metrics. The client will automatically retry transient rate limits before failing.
const pino = require('pino');
const logger = pino({ level: 'info', transport: { target: 'pino-pretty' } });
const webhookBreaker = new CircuitBreaker(4, 20000);
const webhookQueue = new ConcurrencyQueue(5);
async function updateWebhookAtomic(webhookId, optimizedPayload) {
const startTime = Date.now();
const token = await getCognigyToken();
const updateWithRetry = async (attempt = 1) => {
const response = await axios.put(
`${COGNIGY_BASE}/api/v1/webhooks/${webhookId}`,
optimizedPayload,
headers: {
'Accept': 'application/json'
timeout: 10000
const latency = Date.now() - startTime;
logger.info({
webhookId,
latency,
status: response.status,
attempt,
throughput: `processed in ${latency}ms`
}, 'Webhook update successful');
return response.data;
} catch (error) {
if (error.response && error.response.status === 429 && attempt < 3) {
const backoff = Math.pow(2, attempt) * 1000;
logger.warn({ attempt, backoff }, `Rate limited (429). Retrying in ${backoff}ms`);
await new Promise(r => setTimeout(r, backoff));
return updateWithRetry(attempt + 1);
if (error.response && error.response.status === 429) {
logger.error({ attempt }, 'Maximum retry attempts exceeded for 429');
throw new Error('Endpoint exhausted: Maximum retry limit reached');
throw error;
return webhookBreaker.execute(() => updateWithRetry());
Step 4: Synchronization Webhooks, Audit Logging, and Optimizer Endpoint
You will expose an Express endpoint that accepts optimization directives, runs the validation pipeline, applies atomic updates, and triggers completion webhooks to external gateways. All actions generate structured audit logs for governance.
const express = require('express');
const app = express();
app.use(express.json());
const EXTERNAL_GATEWAY_URL = process.env.EXTERNAL_GATEWAY_URL || 'https://gateway.example.com/webhook-sync';
async function triggerCompletionWebhook(webhookId, success, latency) {
await axios.post(EXTERNAL_GATEWAY_URL, {
event: 'webhook_optimization_complete',
webhookId,
success,
latency,
}, { timeout: 5000 });
} catch (err) {
logger.warn({ error: err.message }, 'Failed to sync optimization event to external gateway');
app.post('/api/optimizer/webhooks', async (req, res) => {
const { webhookId, payload } = req.body;
if (!webhookId || !payload) {
return res.status(400).json({ error: 'webhookId and payload are required' });
const auditLog = {
action: 'webhook_optimization',
webhookId,
initiator: req.ip,
payloadSize: Buffer.byteLength(JSON.stringify(payload))
// Step 1: Validate schema and size
const validatedPayload = await validatePayload(payload);
// Step 2: Verify TLS handshake capability
const tlsValid = await checkTLSHandshake(validatedPayload.url);
if (!tlsValid) {
auditLog.status = 'failed_tls_check';
logger.warn(auditLog, 'TLS handshake verification failed');
return res.status(400).json({ error: 'Target endpoint failed TLS handshake verification' });
// Step 3: Queue and execute atomic update with circuit breaker
const result = await webhookQueue.add(() => updateWebhookAtomic(webhookId, validatedPayload));
const latency = result._latency || 0;
auditLog.status = 'success';
auditLog.latency = latency;
logger.info(auditLog, 'Webhook optimization audit');
// Step 4: Sync completion webhook
await triggerCompletionWebhook(webhookId, true, latency);
return res.json({ success: true, data: result, auditLog });
} catch (error) {
auditLog.status = 'failed';
auditLog.error = error.message;
logger.error(auditLog, 'Webhook optimization failed');
await triggerCompletionWebhook(webhookId, false, 0);
if (error.message.includes('Load shedding')) {
return res.status(503).json({ error: 'Load shedding active. Circuit breaker is open.' });
return res.status(500).json({ error: error.message });
app.listen(3000, () => {
logger.info('Cognigy.AI Webhook Optimizer listening on port 3000');
The following script combines all components into a single runnable module. Save it as webhook-optimizer.js and execute with node webhook-optimizer.js. Ensure environment variables are set.
// Configuration
const logger = pino({ level: 'info' });
// Authentication
if (cachedToken && now < tokenExpiry) return cachedToken;
return cachedToken;
// Validation & TLS Check
}).required()
if (error) throw new Error(`Schema validation failed: ${error.details.map(d => d.message).join(', ')}`);
if (byteSize > MAX_PAYLOAD_BYTES) throw new Error(`Payload exceeds ${MAX_PAYLOAD_BYTES} bytes`);
return value;
path: '/',
method: 'HEAD',
timeout: 3000,
}, (res) => {
res.resume();
req.on('error', (err) => reject(new Error(`TLS handshake failed: ${err.message}`)));
req.end();
// Circuit Breaker & Queue
constructor(failureThreshold = 4, resetTimeout = 20000) {
async execute(fn) {
if (Date.now() - this.lastFailureTime > this.resetTimeout) {
} else {
this.onSuccess();
return result;
} catch (error) {
this.onFailure();
throw error;
onSuccess() { this.failureCount = 0; this.state = 'CLOSED'; }
onFailure() {
if (this.failureCount >= this.failureThreshold) this.state = 'OPEN';
constructor(concurrencyLimit = 5) {
this.pending = 0;
this.queue = [];
async add(task) {
this.process();
async process() {
this.pending++;
resolve(await task());
} catch (error) {
reject(error);
} finally {
this.pending--;
this.process();
const webhookBreaker = new CircuitBreaker();
const webhookQueue = new ConcurrencyQueue();
// Core API Logic
optimizedPayload,
headers: {
timeout: 10000
logger.info({ webhookId, latency, status: response.status, attempt }, 'Webhook update successful');
} catch (error) {
throw error;
webhookId, success, latency, timestamp: new Date().toISOString()
} catch (err) {
logger.warn({ error: err.message }, 'Failed to sync optimization event');
// Express Server
if (!webhookId || !payload) return res.status(400).json({ error: 'webhookId and payload are required' });
const auditLog = { action: 'webhook_optimization', webhookId, initiator: req.ip, timestamp: new Date().toISOString() };
if (!tlsValid) {
} catch (error) {
- What causes it: The bearer token is expired, missing, or the API credentials lack the
webhooks:writescope. - How to fix it: Verify
COGNIGY_USERandCOGNIGY_PASSenvironment variables. Ensure the API token has webhook management permissions. The authentication function automatically refreshes tokens before expiry. - Code showing the fix: The
getCognigyTokenfunction caches the token and throws a descriptive error if the/api/v1/loginendpoint returns a non-200 status.
- What causes it: Cognigy.AI enforces rate limits per tenant. High concurrency or rapid retry loops trigger throttling.
- How to fix it: The
updateWithRetryfunction implements exponential backoff (1s, 2s, 4s) for 429 responses. TheConcurrencyQueuelimits simultaneous requests to 5. If retries exceed 3 attempts, the circuit breaker transitions toOPEN, triggering load shedding. - Code showing the fix: The retry logic in
updateWebhookAtomiccheckserror.response.status === 429and delays execution before the next attempt.
Error: 400 Bad Request (Schema Validation Failed)
- What causes it: The payload violates Cognigy.AI constraints, such as missing
retryPolicy, using HTTP instead of HTTPS, or exceeding byte limits. - How to fix it: Run the payload through
validatePayloadbefore transmission. Ensureurluses thehttpsscheme andretryPolicy.maxRetriesdoes not exceed 5. - Code showing the fix: The
WebhookSchemadefinition enforces strict types and ranges. ThevalidatePayloadfunction throws a aggregated error message if validation fails.
Error: TLS Handshake Failed
- What causes it: The target webhook endpoint rejects connections, uses self-signed certificates, or has a misconfigured SNI record.
checkTLSHandshakefunction performs a pre-flightHEADrequest withrejectUnauthorized: true. Verify that the target server presents a valid certificate chain and responds within 3 seconds. - Code showing the fix: The
checkTLSHandshakefunction returnsfalseif the status code falls outside 200-399 or if the TCP/TLS connection times out.
