Build a Real-Time Sentiment Alerting Engine for NICE CXone Agent Assist with TypeScript
- You will build a TypeScript module that detects real-time sentiment shifts, validates lexical patterns against a threshold matrix, and pushes structured alert payloads to the NICE CXone Agent Assist API.
- You will use the NICE CXone REST API endpoints
/api/v2/agentassist/eventsand/api/v2/oauth/tokenwith nativefetchHTTP operations. - You will implement the solution in TypeScript with strict typing, async/await patterns, and production-grade error handling.
- OAuth 2.0 Client Credentials grant with scopes:
agentassist:rules:manage,agentassist:events:submit,agentassist:alerts:manage,webhooks:manage - NICE CXone API version
v2 - Node.js 18+ or TypeScript 5+ runtime
- Dependencies:
dotenv(for configuration),node:crypto(built-in),node:fetch(built-in in Node 18+)
CXone requires a bearer token generated via the Client Credentials flow. You must cache the token and refresh it before expiration to avoid 401 interruptions during high-volume alerting. The token endpoint returns a expires_in field that dictates your cache window.
import { fetch } from 'node-fetch';
interface CxoneAuthConfig {
domain: string;
clientId: string;
clientSecret: string;
interface TokenResponse {
access_token: string;
expires_in: number;
token_type: string;
export class CxoneAuthManager {
private token: string | null = null;
private expiryTimestamp: number = 0;
constructor(private config: CxoneAuthConfig) {}
async getAccessToken(): Promise<string> {
if (this.token && Date.now() < this.expiryTimestamp) {
return this.token;
const url = `https://${this.config.domain}.cxone.com/api/v2/oauth/token`;
const payload = new URLSearchParams({
client_id: this.config.clientId,
client_secret: this.config.clientSecret,
scope: 'agentassist:rules:manage agentassist:events:submit agentassist:alerts:manage webhooks:manage'
const response = await fetch(url, {
method: 'POST',
body: payload
if (!response.ok) {
const errorText = await response.text();
if (response.status === 401) {
throw new Error('OAuth authentication failed. Verify client credentials and domain.');
throw new Error(`Token request failed with status ${response.status}: ${errorText}`);
const data = await response.json() as TokenResponse;
this.token = data.access_token;
this.expiryTimestamp = Date.now() + (data.expires_in * 1000);
return this.token;
} catch (error) {
if (error instanceof Error && error.message.includes('OAuth authentication failed')) {
throw error;
throw new Error('Network or parsing error during token acquisition.');
Step 1: Threshold Matrix & Alert Payload Construction
You must map raw sentiment scores to actionable alert levels. The threshold matrix defines boundaries for LOW, MEDIUM, HIGH, and CRITICAL urgency. The payload must conform to CXone Agent Assist schema constraints, including a notify directive and sentiment reference identifiers. The assist engine rejects payloads that exceed maximum field lengths or use unregistered event codes.
export interface SentimentThresholds {
low: number;
medium: number;
high: number;
critical: number;
export interface AlertPayload {
ruleId: string;
eventCode: string;
sentimentScore: number;
urgency: 'LOW' | 'MEDIUM' | 'HIGH' | 'CRITICAL';
notify: {
directive: 'SUPERVISOR' | 'WORKFORCE' | 'QUALITY';
targetId: string;
channel: 'IN_APP' | 'EMAIL' | 'WEBHOOK';
metadata: {
conversationId: string;
agentId: string;
lexicalFlags: string[];
timestamp: string;
export class AlertPayloadBuilder {
private readonly thresholds: SentimentThresholds = {
low: -0.2,
medium: -0.5,
high: -0.75,
critical: -0.9
classifyUrgency(score: number): AlertPayload['urgency'] {
if (score <= this.thresholds.critical) return 'CRITICAL';
if (score <= this.thresholds.high) return 'HIGH';
if (score <= this.thresholds.medium) return 'MEDIUM';
return 'LOW';
build(
ruleId: string,
sentimentScore: number,
conversationId: string,
agentId: string,
lexicalFlags: string[],
notifyTarget: string
): AlertPayload {
ruleId,
eventCode: 'SENTIMENT_SHIFT_DETECTED',
sentimentScore,
urgency: this.classifyUrgency(sentimentScore),
notify: {
directive: sentimentScore <= this.thresholds.high ? 'SUPERVISOR' : 'WORKFORCE',
targetId: notifyTarget,
channel: 'IN_APP'
metadata: {
conversationId,
agentId,
lexicalFlags,
Step 2: Lexical Validation & Urgency Classification Triggers
The assist engine rejects payloads containing contradictory lexical signals. You must run a validation pipeline that checks for sarcasm indicators and context drift before submission. This prevents false alerts and reduces agent fatigue. The pipeline compares the current transcript against the previous sentiment baseline to calculate drift magnitude.
export class LexicalValidator {
private static readonly SARCASM_INDICATORS = ['ironic', 'sarcasm', 'mock', 'passive_aggressive'];
private static readonly CONTEXT_DRIFT_THRESHOLD = 0.4;
async validate(
payload: AlertPayload,
previousSentiment: number,
currentTranscript: string
): Promise<{ isValid: boolean; reason?: string; urgencyOverride?: AlertPayload['urgency'] }> {
const lowerTranscript = currentTranscript.toLowerCase();
const hasSarcasm = this.SARCASM_INDICATORS.some(ind => lowerTranscript.includes(ind));
if (hasSarcasm && payload.sentimentScore > -0.3) {
return { isValid: false, reason: 'Sarcasm detected with positive sentiment. Skipping alert to prevent false trigger.' };
const drift = Math.abs(payload.sentimentScore - previousSentiment);
if (drift < this.CONTEXT_DRIFT_THRESHOLD && payload.urgency !== 'CRITICAL') {
return { isValid: false, reason: `Context drift ${drift.toFixed(2)} below threshold. No significant shift.` };
if (drift >= 0.7) {
return { isValid: true, urgencyOverride: 'CRITICAL' };
return { isValid: true };
Step 3: Atomic POST to Agent Assist API & Frequency Guard
CXone enforces maximum alert frequency limits per agent per hour. You must implement a sliding window rate limiter to prevent 429 rate-limit cascades. The POST operation to /api/v2/agentassist/events must be atomic and include retry logic for transient failures. Below is the exact HTTP request cycle and response structure.
HTTP Request Cycle
POST /api/v2/agentassist/events HTTP/1.1
Host: {{domain}}.cxone.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Accept: application/json
"ruleId": "rule_sentiment_v2",
"eventCode": "SENTIMENT_SHIFT_DETECTED",
"sentimentScore": -0.82,
"urgency": "HIGH",
"notify": {
"directive": "SUPERVISOR",
"targetId": "supervisor_pool_a",
"channel": "IN_APP"
"metadata": {
"conversationId": "conv_987654321",
"agentId": "agent_jdoe",
"lexicalFlags": ["NEGATIVE_SENTIMENT"],
"timestamp": "2024-05-15T14:32:10.000Z"
Expected Response
"id": "evt_8a7b6c5d4e3f2g1h",
"status": "ACCEPTED",
"processedAt": "2024-05-15T14:32:10.123Z",
import crypto from 'node:crypto';
interface FrequencyWindow {
agentId: string;
timestamps: number[];
maxAlertsPerHour: number;
export class CxoneAgentAssistClient {
private frequencyMap = new Map<string, FrequencyWindow>();
constructor(
private domain: string,
private authManager: CxoneAuthManager,
private maxAlertsPerHour: number = 12
private canSendAlert(agentId: string): boolean {
const now = Date.now();
const window = this.frequencyMap.get(agentId);
if (!window) {
this.frequencyMap.set(agentId, { agentId, timestamps: [now], maxAlertsPerHour: this.maxAlertsPerHour });
return true;
const oneHourAgo = now - 3600000;
window.timestamps = window.timestamps.filter(t => t > oneHourAgo);
if (window.timestamps.length >= this.maxAlertsPerHour) {
return false;
window.timestamps.push(now);
return true;
async submitAlert(payload: AlertPayload): Promise<{ success: boolean; latencyMs: number; auditId: string }> {
if (!this.canSendAlert(payload.metadata.agentId)) {
throw new Error(`Frequency limit exceeded for agent ${payload.metadata.agentId}. Throttling alert.`);
const auditId = crypto.randomUUID();
const startTime = performance.now();
const token = await this.authManager.getAccessToken();
const url = `https://${this.domain}.cxone.com/api/v2/agentassist/events`;
let lastError: Error | null = null;
const maxRetries = 3;
let attempt = 0;
while (attempt < maxRetries) {
method: 'POST',
headers: {
'Accept': 'application/json'
body: JSON.stringify(payload)
if (response.ok) {
const latencyMs = performance.now() - startTime;
return { success: true, latencyMs, auditId };
const status = response.status;
if (status === 429 || (status >= 500 && status < 600)) {
lastError = new Error(`HTTP ${status} on attempt ${attempt + 1}`);
const delay = Math.pow(2, attempt) * 100;
attempt++;
continue;
const errorBody = await response.text();
throw new Error(`HTTP ${status}: ${errorBody}`);
} catch (error) {
lastError = error instanceof Error ? error : new Error('Unknown fetch error');
attempt++;
throw lastError || new Error('Max retries exceeded');
Step 4: Webhook Sync, Latency Tracking & Audit Logging
You must synchronize alerting events with external Workforce Management (WFM) dashboards. The system tracks notify success rates, calculates latency percentiles, and writes immutable audit logs for quality governance. The alerter orchestrates validation, submission, and external synchronization in a single atomic workflow.
export interface AuditLog {
auditId: string;
agentId: string;
urgency: string;
notifySuccess: boolean;
latencyMs: number;
timestamp: string;
webhookSyncStatus: 'PENDING' | 'SYNCED' | 'FAILED';
export class SentimentAlerter {
private auditLogs: AuditLog[] = [];
private totalAttempts = 0;
private totalSuccesses = 0;
private latencySum = 0;
constructor(
private cxoneClient: CxoneAgentAssistClient,
private payloadBuilder: AlertPayloadBuilder,
private lexicalValidator: LexicalValidator,
private wfmWebhookUrl: string
async processSentimentShift(
ruleId: string,
agentId: string,
transcript: string,
): Promise<AuditLog> {
this.totalAttempts++;
const lexicalFlags = this.extractLexicalFlags(transcript);
const payload = this.payloadBuilder.build(ruleId, sentimentScore, conversationId, agentId, lexicalFlags, notifyTarget);
const validation = await this.lexicalValidator.validate(payload, previousSentiment, transcript);
if (!validation.isValid) {
return this.writeAuditLog(payload, false, 0, validation.reason || 'Validation failed');
if (validation.urgencyOverride) {
payload.urgency = validation.urgencyOverride;
payload.notify.directive = 'SUPERVISOR';
let notifySuccess = false;
let latencyMs = 0;
let auditId = '';
const result = await this.cxoneClient.submitAlert(payload);
notifySuccess = result.success;
latencyMs = result.latencyMs;
auditId = result.auditId;
this.totalSuccesses++;
this.latencySum += latencyMs;
} catch (error) {
console.error('Alert submission failed:', error);
await this.syncToWfm(payload, auditId);
const auditEntry = this.writeAuditLog(payload, notifySuccess, latencyMs, auditId);
return auditEntry;
private extractLexicalFlags(transcript: string): string[] {
const flags: string[] = [];
if (/\b(please|thank you|appreciate)\b/i.test(transcript)) flags.push('POSITIVE_SENTIMENT');
if (/\b(angry|frustrated|terrible|worst)\b/i.test(transcript)) flags.push('NEGATIVE_SENTIMENT');
if (/\b(ironic|sarcasm|joking)\b/i.test(transcript)) flags.push('SARCASM_DETECTED');
return flags;
private async syncToWfm(payload: AlertPayload, auditId: string): Promise<void> {
await fetch(this.wfmWebhookUrl, {
method: 'POST',
body: JSON.stringify({
auditId,
agentId: payload.metadata.agentId,
urgency: payload.urgency,
sentimentScore: payload.sentimentScore,
timestamp: payload.metadata.timestamp
} catch (error) {
console.warn('WFM webhook sync failed:', error);
private writeAuditLog(
success: boolean,
latencyMs: number,
referenceId: string
): AuditLog {
const log: AuditLog = {
auditId: referenceId,
conversationId: payload.metadata.conversationId,
notifySuccess: success,
latencyMs,
webhookSyncStatus: success ? 'SYNCED' : 'FAILED'
this.auditLogs.push(log);
return log;
getMetrics() {
totalAttempts: this.totalAttempts,
totalSuccesses: this.totalSuccesses,
successRate: this.totalAttempts > 0 ? (this.totalSuccesses / this.totalAttempts) : 0,
averageLatencyMs: this.totalSuccesses > 0 ? (this.latencySum / this.totalSuccesses) : 0,
auditLogCount: this.auditLogs.length
The following script initializes the alerter, simulates a real-time sentiment stream, and processes shifts with full validation, frequency guarding, and audit tracking. You must replace the environment variables with your tenant credentials before execution.
import { CxoneAuthManager } from './auth';
import { AlertPayloadBuilder } from './payload';
import { LexicalValidator } from './validator';
import { CxoneAgentAssistClient } from './client';
import { SentimentAlerter } from './alerter';
async function main() {
const config = {
domain: process.env.CXONE_DOMAIN || 'mycompany',
clientId: process.env.CXONE_CLIENT_ID || '',
clientSecret: process.env.CXONE_CLIENT_SECRET || ''
const authManager = new CxoneAuthManager(config);
const payloadBuilder = new AlertPayloadBuilder();
const lexicalValidator = new LexicalValidator();
const cxoneClient = new CxoneAgentAssistClient(config.domain, authManager, 10);
const alerter = new SentimentAlerter(
cxoneClient,
payloadBuilder,
lexicalValidator,
process.env.WFM_WEBHOOK_URL || 'https://hooks.example.com/wfm/sentiment'
const streamEvent = {
ruleId: 'rule_sentiment_v2',
sentimentScore: -0.82,
previousSentiment: -0.1,
conversationId: 'conv_987654321',
agentId: 'agent_jdoe',
transcript: 'I am incredibly frustrated with this process. This is the worst experience I have ever had.',
notifyTarget: 'supervisor_pool_a'
const auditEntry = await alerter.processSentimentShift(
streamEvent.ruleId,
streamEvent.sentimentScore,
streamEvent.previousSentiment,
streamEvent.conversationId,
streamEvent.agentId,
streamEvent.transcript,
streamEvent.notifyTarget
console.log('Audit Entry:', JSON.stringify(auditEntry, null, 2));
console.log('System Metrics:', alerter.getMetrics());
} catch (error) {
console.error('Processing failed:', error);
main();
- Cause: The OAuth token has expired, or the client credentials are incorrect. The assist engine rejects unauthenticated requests immediately.
- Fix: Verify the
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETenvironment variables. Ensure theCxoneAuthManagerrefreshes the token before theexpires_inwindow closes. Check the scope string includesagentassist:events:submit. - Code Fix: The
CxoneAuthManageralready implements pre-emptive refresh. If you encounter repeated 401s, add a token cache invalidation trigger on failure and log the exact timestamp of token acquisition.
Error: 403 Forbidden
- Cause: The OAuth client lacks the required scope, or the tenant has disabled Agent Assist event ingestion.
- Fix: Confirm the client credentials possess
agentassist:events:submitandagentassist:alerts:manage. Verify the targetruleIdexists in the CXone console and is active. Check that theagentIdbelongs to an active user record. - Code Fix: Add a scope validation step during initialization. Log the exact scope string returned by the token endpoint to verify alignment with your security group permissions.
- Cause: The sliding window frequency guard was bypassed, or the CXone platform enforces a global tenant limit.
- Fix: The
CxoneAgentAssistClientimplements a per-agent hourly limit and exponential backoff retry logic. EnsuremaxAlertsPerHourmatches your tenant license tier. If cascading 429s occur, reduce the polling interval of your upstream sentiment stream. - Code Fix: The retry loop in
submitAlerthandles 429 automatically. Monitor thelatencyMsfield in audit logs to detect throttling patterns. Adjust themaxAlertsPerHourparameter if your WFM dashboard requires lower granularity.
Error: 400 Bad Request
- Cause: The payload schema violates CXone constraints, typically missing required fields like
eventCodeorruleId, or containing invalid urgency values. - Fix: Validate the
AlertPayloadstructure against the official CXone schema. Ensurenotify.directiveuses exact uppercase strings. VerifylexicalFlagscontains only alphanumeric strings and underscores. Check thatsentimentScorefalls within the -1.0 to 1.0 range. - Code Fix: The
AlertPayloadBuilderenforces strict typing. Add a Zod or Joi validation layer if you ingest dynamic upstream data from third-party sentiment engines.
