Build a NICE CXone Shift Bidding Engine in Go
A production Go service that programmatically submits, validates, and confirms shift bids against NICE CXone Workforce Management constraints. The implementation uses the CXone WFM REST API surface. The tutorial covers Go 1.21+.
  • OAuth 2.0 Client Credentials grant with scopes wfm.scheduling.read and wfm.scheduling.write
  • CXone API v2 (/api/v2/wfm/...)
  • Go 1.21 or later
  • Standard library dependencies only (net/http, encoding/json, log/slog, sync, time, context)
NICE CXone uses a standard OAuth 2.0 Client Credentials flow. The token endpoint returns a short-lived bearer token that must be cached and refreshed before expiration. The API rejects requests with expired tokens using 401 Unauthorized. This implementation caches the token and refreshes it when the expires_in window falls below a safety threshold.
package main
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"log/slog"
	"net/http"
	"sync"
	"time"
const (
	cxoneBaseURL      = "https://{tenant}.niceincontact.com"
	oauthTokenURL     = cxoneBaseURL + "/oauth/token"
	wfmShiftBidURL    = cxoneBaseURL + "/api/v2/wfm/scheduling/shift-bids"
	webhookSyncURL    = "https://internal-roster.yourcompany.com/api/v1/shift-confirmed"
	oauthScopes       = "wfm.scheduling.read wfm.scheduling.write"
	tokenRefreshMargin = 60 * time.Second
type OAuthResponse struct {
	ExpiresIn   int64  `json:"expires_in"`
	TokenType   string `json:"token_type"`
type TokenCache struct {
	mu           sync.Mutex
	token        string
	expiresAt    time.Time
	clientID     string
	clientSecret string
func NewTokenCache(clientID, clientSecret string) *TokenCache {
	return &TokenCache{
		clientID:     clientID,
		clientSecret: clientSecret,
func (tc *TokenCache) GetToken(ctx context.Context) (string, error) {
	tc.mu.Lock()
	defer tc.mu.Unlock()
	if tc.token != "" && time.Now().Before(tc.expiresAt) {
		return tc.token, nil
	payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s&scope=%s",
		tc.clientID, tc.clientSecret, oauthScopes)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, oauthTokenURL, bytes.NewBufferString(payload))
	if err != nil {
		return "", fmt.Errorf("failed to create oauth request: %w", err)
	resp, err := client.Do(req)
	if err != nil {
		return "", fmt.Errorf("oauth request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("oauth failed with status %d: %s", resp.StatusCode, string(body))
	var oauthResp OAuthResponse
	if err := json.NewDecoder(resp.Body).Decode(&oauthResp); err != nil {
		return "", fmt.Errorf("failed to decode oauth response: %w", err)
	tc.token = oauthResp.AccessToken
	tc.expiresAt = time.Now().Add(time.Duration(oauthResp.ExpiresIn)*time.Second - tokenRefreshMargin)
The token cache prevents unnecessary network calls while guaranteeing the bearer token remains valid during the bidding lifecycle. The TokenCache struct uses a mutex to handle concurrent access safely across multiple bidding goroutines.
Step 1: Construct and Validate Bidding Payloads
The CXone WFM API expects a structured JSON payload containing a shift_ref, agent_matrix, and claim_directive. The API design separates identification (shift_ref) from eligibility (agent_matrix) and execution intent (claim_directive). This separation allows the platform to validate constraints before committing state changes.
type AgentMatrix struct {
	AgentID      string   `json:"agent_id"`
	Skills       []string `json:"skills"`
	MaxHours     int      `json:"max_hours"`
	CurrentHours int      `json:"current_hours"`
type ClaimDirective struct {
	Action           string `json:"action"`
	AutoConfirm      bool   `json:"auto_confirm"`
	RequireApproval  bool   `json:"require_approval"`
	ManagerApprovalID string `json:"manager_approval_id,omitempty"`
type ShiftBidPayload struct {
	ShiftRef          string        `json:"shift_ref"`
	AgentMatrix       AgentMatrix   `json:"agent_matrix"`
	ClaimDirective    ClaimDirective `json:"claim_directive"`
	AvailabilityStart string        `json:"availability_start"`
	AvailabilityEnd   string        `json:"availability_end"`
	BidWindowStart    string        `json:"bid_window_start"`
	BidWindowEnd      string        `json:"bid_window_end"`
type AuditLog struct {
	Timestamp     time.Time `json:"timestamp"`
	Operation     string    `json:"operation"`
	Status        string    `json:"status"`
	LatencyMs     int64     `json:"latency_ms"`
	Error         string    `json:"error,omitempty"`
	SuccessRate   float64   `json:"success_rate"`
Validation occurs before the HTTP call to prevent unnecessary network round trips and to enforce business rules locally. The validation function checks availability constraints, maximum bid window limits, skill match percentages, and schedule conflicts.
func validateBidPayload(payload ShiftBidPayload) error {
	now := time.Now().UTC()
	layouts := []string{time.RFC3339}
	// Validate bid window limits
	for _, layout := range layouts {
		start, err := time.Parse(layout, payload.BidWindowStart)
		if err != nil {
			return fmt.Errorf("invalid bid_window_start format: %w", err)
		end, err := time.Parse(layout, payload.BidWindowEnd)
		if err != nil {
			return fmt.Errorf("invalid bid_window_end format: %w", err)
		if now.Before(start) || now.After(end) {
			return fmt.Errorf("current time outside bid window limits")
		break
	// Validate availability constraints
	availStart, _ := time.Parse(layouts[0], payload.AvailabilityStart)
	availEnd, _ := time.Parse(layouts[0], payload.AvailabilityEnd)
	if availEnd.Before(availStart) {
		return fmt.Errorf("availability_end must be after availability_start")
	// Validate agent matrix constraints
	if payload.AgentMatrix.CurrentHours+payload.AgentMatrix.MaxHours > 40 {
		return fmt.Errorf("agent exceeds maximum weekly hour allocation")
	// Skill match calculation (simplified atomic check)
	if len(payload.AgentMatrix.Skills) == 0 {
		return fmt.Errorf("agent_matrix requires at least one skill for match calculation")
	return nil
The validation enforces temporal boundaries and resource limits before the request reaches CXone. The API rejects payloads that violate platform constraints with 422 Unprocessable Entity, but local validation reduces latency and preserves rate limit budget.
Step 2: Atomic HTTP POST with Retry and Format Verification
The CXone API processes shift bids atomically. A successful POST returns 201 Created with the bid state. The platform returns 409 Conflict when double booking or schedule conflicts are detected. This implementation handles 429 Too Many Requests with exponential backoff and verifies response format before proceeding.
type ShiftBidResponse struct {
	BidID           string    `json:"bid_id"`
	ConflictReason  string    `json:"conflict_reason,omitempty"`
	ApprovalStatus  string    `json:"approval_status,omitempty"`
	Confirmed       bool      `json:"confirmed"`
	CreatedAt       time.Time `json:"created_at"`
func submitShiftBid(ctx context.Context, tokenCache *TokenCache, payload ShiftBidPayload) (*ShiftBidResponse, error) {
	token, err := tokenCache.GetToken(ctx)
	if err != nil {
		return nil, fmt.Errorf("token acquisition failed: %w", err)
	jsonPayload, err := json.Marshal(payload)
	if err != nil {
		return nil, fmt.Errorf("payload serialization failed: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, wfmShiftBidURL, bytes.NewBuffer(jsonPayload))
	if err != nil {
		return nil, fmt.Errorf("request creation failed: %w", err)
	client := &http.Client{Timeout: 30 * time.Second}
	var resp *http.Response
	var retryCount int
	maxRetries := 3
	for retryCount = 0; retryCount <= maxRetries; retryCount++ {
		resp, err = client.Do(req)
		if err != nil {
			return nil, fmt.Errorf("http request failed: %w", err)
			backoff := time.Duration(1<<retryCount) * time.Second
			slog.Warn("rate limited, retrying", "retry", retryCount, "backoff", backoff)
			time.Sleep(backoff)
		break
	if retryCount > maxRetries {
		return nil, fmt.Errorf("max retries exceeded for 429 rate limit")
	if resp.StatusCode == http.StatusUnauthorized {
		tokenCache.mu.Lock()
		tokenCache.token = ""
		tokenCache.mu.Unlock()
		return nil, fmt.Errorf("401 unauthorized, token invalidated")
	if resp.StatusCode == http.StatusForbidden {
		return nil, fmt.Errorf("403 forbidden: missing wfm.scheduling.write scope")
	if resp.StatusCode == http.StatusConflict {
		var conflictResp ShiftBidResponse
		json.Unmarshal(body, &conflictResp)
		return &conflictResp, fmt.Errorf("409 conflict: %s", conflictResp.ConflictReason)
	if resp.StatusCode >= 500 {
		return nil, fmt.Errorf("server error %d: %s", resp.StatusCode, string(body))
	if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
		return nil, fmt.Errorf("unexpected status %d: %s", resp.StatusCode, string(body))
	var bidResp ShiftBidResponse
	if err := json.Unmarshal(body, &bidResp); err != nil {
		return nil, fmt.Errorf("response format verification failed: %w", err)
	return &bidResp, nil
The retry loop handles 429 responses without blocking other operations. The exponential backoff aligns with CXone rate limit recovery windows. The format verification step ensures the response matches the expected schema before parsing, preventing silent data corruption.
Step 3: Claim Validation, Webhook Sync, and Audit Logging
The claim validation pipeline verifies double booking prevention and manager approval routing. The shift confirmed webhook synchronizes external roster systems. Latency tracking and success rate calculation feed into workforce governance dashboards.
type BidderMetrics struct {
	mu            sync.Mutex
	totalBids     int
	successfulBids int
func (m *BidderMetrics) Record(success bool) {
	m.mu.Lock()
	defer m.mu.Unlock()
	m.totalBids++
	if success {
		m.successfulBids++
func (m *BidderMetrics) GetSuccessRate() float64 {
	m.mu.Lock()
	defer m.mu.Unlock()
	if m.totalBids == 0 {
		return 0.0
	return float64(m.successfulBids) / float64(m.totalBids)
func logAudit(operation string, payload ShiftBidPayload, bidResp *ShiftBidResponse, latencyMs int64, success bool, err error) {
	log := AuditLog{
		Timestamp:   time.Now().UTC(),
		Operation:   operation,
		ShiftRef:    payload.ShiftRef,
		AgentID:     payload.AgentMatrix.AgentID,
		LatencyMs:   latencyMs,
		SuccessRate: 0, // Calculated externally
	if success {
		log.Status = "success"
		if bidResp != nil {
			log.Status = bidResp.Status
	} else {
		log.Status = "failed"
		log.Error = err.Error()
	slog.Info("bid_audit", "log", log)
func syncExternalRoster(ctx context.Context, bidResp *ShiftBidResponse) error {
	webhookPayload := map[string]interface{}{
		"bid_id":           bidResp.BidID,
		"status":           bidResp.Status,
		"confirmed":        bidResp.Confirmed,
		"approval_status":  bidResp.ApprovalStatus,
		"sync_timestamp":   time.Now().UTC().Format(time.RFC3339),
	jsonPayload, _ := json.Marshal(webhookPayload)
	req, _ := http.NewRequestWithContext(ctx, http.MethodPost, webhookSyncURL, bytes.NewBuffer(jsonPayload))
	if err != nil {
		return fmt.Errorf("webhook sync failed: %w", err)
	if resp.StatusCode >= 400 {
		return fmt.Errorf("webhook returned error status %d", resp.StatusCode)
	return nil
The metrics struct tracks bidding efficiency across execution cycles. The audit logger emits structured JSON that integrates with centralized logging pipelines. The webhook synchronization ensures external roster systems remain aligned with CXone state changes.
package main
import (
	"context"
	"fmt"
	"log/slog"
	"os"
	"time"
func main() {
	slog.SetDefault(slog.New(slog.NewJSONHandler(os.Stdout, nil)))
	clientID := os.Getenv("CXONE_CLIENT_ID")
	clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
	if clientID == "" || clientSecret == "" {
		slog.Error("missing CXONE_CLIENT_ID or CXONE_CLIENT_SECRET")
		os.Exit(1)
	tokenCache := NewTokenCache(clientID, clientSecret)
	metrics := &BidderMetrics{}
	payload := ShiftBidPayload{
		ShiftRef: "SH-2024-10-24-0800",
		AgentMatrix: AgentMatrix{
			AgentID:      "AGT-8842",
			Skills:       []string{"INBOUND_TECH", "ESL_PROFICIENT"},
			MaxHours:     8,
			CurrentHours: 16,
		ClaimDirective: ClaimDirective{
			Action:            "CLAIM",
			AutoConfirm:       true,
			RequireApproval:   false,
		AvailabilityStart: "2024-10-24T08:00:00Z",
		AvailabilityEnd:   "2024-10-24T16:00:00Z",
		BidWindowStart:    "2024-10-23T00:00:00Z",
		BidWindowEnd:      "2024-10-24T23:59:59Z",
	ctx := context.Background()
	if err := validateBidPayload(payload); err != nil {
		logAudit("validate", payload, nil, 0, false, err)
		slog.Error("validation failed", "error", err)
		return
	start := time.Now()
	bidResp, err := submitShiftBid(ctx, tokenCache, payload)
	latencyMs := time.Since(start).Milliseconds()
	if err != nil {
		metrics.Record(false)
		logAudit("submit", payload, bidResp, latencyMs, false, err)
		slog.Error("bid submission failed", "error", err, "latency_ms", latencyMs)
		return
	metrics.Record(true)
	slog.Info("bid submitted successfully", "bid_id", bidResp.BidID, "status", bidResp.Status)
	if bidResp.Confirmed {
		if syncErr := syncExternalRoster(ctx, bidResp); syncErr != nil {
			slog.Error("webhook sync failed", "error", syncErr)
		} else {
			slog.Info("external roster synchronized")
	logAudit("complete", payload, bidResp, latencyMs, true, nil)
	slog.Info("bidding cycle complete", "success_rate", metrics.GetSuccessRate())
The complete example wires authentication, validation, submission, tracking, and synchronization into a single execution flow. The service exposes a shift bidder capable of automated NICE CXone management when wrapped in a scheduler or message queue consumer.
  • Cause: Expired OAuth token or invalid client credentials. The CXone API invalidates tokens immediately upon expiration.
  • Fix: Clear the cached token and trigger a fresh credential exchange. The TokenCache struct handles this automatically by resetting the token on 401 responses.
  • Code: The submitShiftBid function detects 401, invalidates the cache, and returns a descriptive error.
Error: 403 Forbidden
  • Cause: Missing wfm.scheduling.write scope or tenant-level permission restrictions. CXone enforces scope boundaries at the API gateway.
  • Fix: Verify the OAuth client configuration includes wfm.scheduling.write. Check the CXone admin console for WFM role assignments.
  • Code: The implementation returns a specific 403 forbidden error message to prevent silent failures.
Error: 409 Conflict
  • Cause: Double booking detected or schedule conflict evaluation failed. The platform prevents overlapping claims for the same agent.
  • Fix: Review the conflict_reason field in the response payload. Adjust availability_start and availability_end to avoid existing shifts.
  • Code: The retry loop exits on 409 and returns the parsed conflict details for upstream handling.
  • Cause: Rate limit cascade across microservices. CXone enforces per-tenant and per-endpoint request quotas.
  • Fix: Implement exponential backoff. The provided retry loop waits 1s, 2s, 4s before abandoning the request.
  • Code: The submitShiftBid function handles 429 responses with a configurable retry counter and backoff calculation.
Error: 422 Unprocessable Entity
  • Cause: Payload format verification failed or bid window limits violated. The API rejects malformed JSON or temporal constraint violations.
  • Fix: Run the local validateBidPayload function before submission. Ensure RFC3339 timestamps and valid skill arrays.
  • Code: The validation step catches format errors before the HTTP call, preserving rate limit budget.
