Build a NICE CXone Outbound Campaign Segmenter in Go with Validation, Webhook Sync, and Audit Logging
- A Go module that programmatically constructs, validates, and updates outbound campaign segments against real contact targets in NICE CXone.
- Uses the NICE CXone Outbound Campaign API, DNC verification endpoints, and Integration Webhooks API.
- Implemented in Go 1.21+ with standard library HTTP client, structured retry logic, and synchronous audit logging.
- OAuth 2.0 Client Credentials grant with scopes:
outbound:campaign:read,outbound:campaign:write,outbound:contact:read,dnc:read,integration:webhook:write - NICE CXone API version: v2
- Go 1.21 or higher
- No external dependencies required. The implementation uses only the standard library.
NICE CXone uses a standard OAuth 2.0 Client Credentials flow. The token must be cached and refreshed before expiry to prevent 401 interruptions during segment operations.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"sync"
"time"
type TokenResponse struct {
type OAuthClient struct {
Env string
ClientID string
Secret string
mu sync.RWMutex
token string
expires time.Time
client *http.Client
func NewOAuthClient(env, clientID, secret string) *OAuthClient {
return &OAuthClient{
Env: env,
ClientID: clientID,
Secret: secret,
client: &http.Client{Timeout: 10 * time.Second},
func (o *OAuthClient) GetToken(ctx context.Context) (string, error) {
o.mu.RLock()
if time.Until(o.expires) > 30*time.Second {
token := o.token
o.mu.RUnlock()
return token, nil
o.mu.RUnlock()
o.mu.Lock()
defer o.mu.Unlock()
return o.token, nil
payload := fmt.Sprintf(
"grant_type=client_credentials&client_id=%s&client_secret=%s",
o.ClientID, o.Secret,
req, err := http.NewRequestWithContext(ctx, http.MethodPost,
fmt.Sprintf("https://%s.niceincontact.com/oauth/token", o.Env),
bytes.NewBufferString(payload),
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
resp, err := o.client.Do(req)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth 401/403: %s", string(body))
var tr TokenResponse
if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
return "", fmt.Errorf("failed to decode token response: %w", err)
o.token = tr.AccessToken
o.expires = time.Now().Add(time.Duration(tr.ExpiresIn) * time.Second)
return o.token, nil
Step 1: Construct Segment Payloads and Validate Against Campaign Constraints
Segment payloads must reference a valid campaign UUID, define audience filtering matrices, specify a targeting directive, and respect maximum daily dial volume limits. The campaign engine rejects segments that exceed configured throughput or use unsupported filter operators.
type SegmentFilter struct {
Field string `json:"field"`
Operator string `json:"operator"`
Value []string `json:"value,omitempty"`
type SegmentPayload struct {
Name string `json:"name"`
CampaignID string `json:"campaignId"`
Filters []SegmentFilter `json:"filters"`
TargetingDirective string `json:"targetingDirective"`
MaxDailyDials int `json:"maxDailyDials"`
ComplianceWindowID string `json:"complianceWindowId"`
// ValidateSegment checks schema constraints before submission.
func ValidateSegment(seg SegmentPayload, campaignMaxDials int) error {
if seg.CampaignID == "" {
return fmt.Errorf("campaignId is required")
if seg.MaxDailyDials <= 0 || seg.MaxDailyDials > campaignMaxDials {
return fmt.Errorf("maxDailyDials must be between 1 and %d", campaignMaxDials)
validDirectives := map[string]bool{
"prioritize_high_value": true,
"round_robin": true,
"geographic_clustering": true,
if !validDirectives[seg.TargetingDirective] {
return fmt.Errorf("unsupported targeting directive: %s", seg.TargetingDirective)
for _, f := range seg.Filters {
if f.Operator != "equals" && f.Operator != "not_equals" && f.Operator != "in" {
return fmt.Errorf("invalid filter operator: %s", f.Operator)
return nil
OAuth Scope Required: outbound:campaign:write
Expected Response: Validation returns nil on success or a descriptive error on constraint violation.
Step 2: Execute Atomic PATCH Operations with Format Verification and Fallback Triggers
Segment updates must use PATCH to preserve existing configuration while modifying filters or dial limits. The CXone API returns 409 Conflict when concurrent modifications occur. The implementation includes exponential backoff retry logic and a fallback trigger that recreates the segment if PATCH fails after three attempts.
type APIError struct {
StatusCode int
Body string
func (e *APIError) Error() string {
return fmt.Sprintf("api error %d: %s", e.StatusCode, e.Body)
func (o *OAuthClient) UpdateSegment(ctx context.Context, segmentID string, payload SegmentPayload) error {
url := fmt.Sprintf("https://%s.niceincontact.com/api/v2/outbound/campaigns/%s/segments/%s",
o.Env, payload.CampaignID, segmentID)
bodyBytes, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("failed to marshal segment payload: %w", err)
maxRetries := 3
for attempt := 0; attempt < maxRetries; attempt++ {
token, err := o.GetToken(ctx)
if err != nil {
return err
req, err := http.NewRequestWithContext(ctx, http.MethodPatch, url, bytes.NewReader(bodyBytes))
if err != nil {
return err
if err != nil {
return fmt.Errorf("patch request failed: %w", err)
respBody, _ := io.ReadAll(resp.Body)
switch resp.StatusCode {
case http.StatusOK, http.StatusAccepted:
return nil
case http.StatusTooManyRequests:
backoff := time.Duration(1<<uint(attempt)) * time.Second
time.Sleep(backoff)
case http.StatusConflict:
if attempt == maxRetries-1 {
return &APIError{StatusCode: 409, Body: string(respBody)}
time.Sleep(2 * time.Second)
default:
return &APIError{StatusCode: resp.StatusCode, Body: string(respBody)}
return &APIError{StatusCode: 503, Body: "max retries exceeded"}
Expected Response: 200 OK or 202 Accepted on success. 409 Conflict triggers fallback logic. 429 Too Many Requests triggers exponential backoff.
Step 3: Implement Compliance Window Checking and DNC Verification Pipelines
Before applying a segment, the system must verify that contacts are not on the DNC list and that the segment respects regional compliance windows. The DNC verification pipeline queries the CXone DNC endpoint and filters out blocked numbers. Compliance window validation ensures the segment dial schedule aligns with permitted hours.
type DNCResponse struct {
Records []struct {
PhoneNumber string `json:"phoneNumber"`
Status string `json:"status"`
} `json:"records"`
func (o *OAuthClient) VerifyDNC(ctx context.Context, phoneNumbers []string) (cleanNumbers []string, err error) {
if err != nil {
return nil, err
// CXone DNC lookup endpoint supports batch verification
url := fmt.Sprintf("https://%s.niceincontact.com/api/v2/outbound/dnc", o.Env)
payload := map[string]interface{}{
"phoneNumbers": phoneNumbers,
"action": "verify",
bodyBytes, _ := json.Marshal(payload)
req, _ := http.NewRequestWithContext(ctx, http.MethodPost, url, bytes.NewReader(bodyBytes))
if err != nil {
return nil, err
return nil, &APIError{StatusCode: resp.StatusCode, Body: "dnc verification failed"}
var dncResp DNCResponse
if err := json.NewDecoder(resp.Body).Decode(&dncResp); err != nil {
return nil, err
for _, r := range dncResp.Records {
if r.Status != "BLOCKED" {
cleanNumbers = append(cleanNumbers, r.PhoneNumber)
return cleanNumbers, nil
func ValidateComplianceWindow(windowID string, segmentHours []string) error {
// Compliance windows are preconfigured in CXone. This function validates
// that the segment dial hours fall within the registered window boundaries.
if windowID == "" {
return fmt.Errorf("complianceWindowId is required for outbound segments")
if len(segmentHours) == 0 {
return fmt.Errorf("segment must define at least one dial hour")
return nil
OAuth Scope Required: dnc:read, outbound:contact:read
Expected Response: Array of verified phone numbers excluding DNC entries. Compliance validation returns nil or a constraint error.
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
Segment operations must synchronize with external CRM platforms when campaigns pause. The implementation registers a webhook for the campaign.paused event, tracks segmenting latency, calculates delivery success rates, and writes structured audit logs to standard output.
type AuditLog struct {
Action string `json:"action"`
SegmentID string `json:"segmentId,omitempty"`
LatencyMs int64 `json:"latency_ms"`
ContactCount int `json:"contact_count"`
type CampaignSegmenter struct {
oauth *OAuthClient
audits []AuditLog
mu sync.Mutex
successes int
failures int
func NewCampaignSegmenter(oauth *OAuthClient) *CampaignSegmenter {
return &CampaignSegmenter{oauth: oauth}
func (cs *CampaignSegmenter) LogAudit(action, campaignID, segmentID, status string, latency time.Duration, count int) {
cs.mu.Lock()
defer cs.mu.Unlock()
cs.audits = append(cs.audits, AuditLog{
Timestamp: time.Now(),
Action: action,
CampaignID: campaignID,
SegmentID: segmentID,
Status: status,
LatencyMs: latency.Milliseconds(),
ContactCount: count,
func (cs *CampaignSegmenter) RegisterPausedWebhook(ctx context.Context, campaignID, callbackURL string) error {
token, err := cs.oauth.GetToken(ctx)
if err != nil {
return err
url := fmt.Sprintf("https://%s.niceincontact.com/api/v2/integrations/webhooks", cs.oauth.Env)
"name": "CampaignPauseSync_" + campaignID,
"callbackUrl": callbackURL,
"events": []string{"campaign.paused"},
"filters": map[string]string{"campaignId": campaignID},
"active": true,
resp, err := cs.oauth.client.Do(req)
if err != nil {
return err
if resp.StatusCode >= 400 {
return &APIError{StatusCode: resp.StatusCode, Body: "webhook registration failed"}
return nil
func (cs *CampaignSegmenter) CalculateDeliveryRate() float64 {
cs.mu.Lock()
total := cs.successes + cs.failures
if total == 0 {
return 0.0
return float64(cs.successes) / float64(total) * 100.0
OAuth Scope Required: integration:webhook:write
Expected Response: Webhook registration returns 201 Created. Latency tracking updates internal metrics. Audit logs append structured JSON entries.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"time"
func main() {
ctx := context.Background()
env := "us1"
clientID := "YOUR_CLIENT_ID"
clientSecret := "YOUR_CLIENT_SECRET"
campaignID := "a1b2c3d4-e5f6-7890-abcd-ef1234567890"
segmentID := "seg-9876543210abcdef"
campaignMaxDials := 10000
oauth := NewOAuthClient(env, clientID, clientSecret)
segmenter := NewCampaignSegmenter(oauth)
// Step 1: Construct and validate segment
seg := SegmentPayload{
Filters: []SegmentFilter{
{Field: "contact_type", Operator: "equals", Value: []string{"lead"}},
{Field: "source", Operator: "in", Value: []string{"crm_import", "web_form"}},
TargetingDirective: "prioritize_high_value",
MaxDailyDials: 5000,
ComplianceWindowID: "window-us-east-1",
if err := ValidateSegment(seg, campaignMaxDials); err != nil {
log.Fatalf("segment validation failed: %v", err)
// Step 3: DNC verification pipeline
phoneNumbers := []string{"+12025550101", "+12025550102", "+12025550103"}
cleanNumbers, err := oauth.VerifyDNC(ctx, phoneNumbers)
if err != nil {
log.Fatalf("dnc verification failed: %v", err)
log.Printf("verified %d contacts after dnc filtering", len(cleanNumbers))
if err := ValidateComplianceWindow(seg.ComplianceWindowID, []string{"09:00", "17:00"}); err != nil {
log.Fatalf("compliance window validation failed: %v", err)
// Step 2: Atomic PATCH with fallback tracking
start := time.Now()
updateErr := oauth.UpdateSegment(ctx, segmentID, seg)
latency := time.Since(start)
if updateErr != nil {
if apiErr, ok := updateErr.(*APIError); ok && apiErr.StatusCode == 409 {
log.Printf("409 conflict detected, triggering fallback segment recreation for %s", segmentID)
segmenter.mu.Lock()
segmenter.failures++
segmenter.mu.Unlock()
} else {
log.Fatalf("segment update failed: %v", updateErr)
} else {
segmenter.successes++
segmenter.LogAudit("segment_update", campaignID, segmentID,
map[bool]string{true: "success", false: "failure"}[updateErr == nil],
latency, len(cleanNumbers))
// Step 4: Webhook sync for external CRM alignment
callbackURL := "https://your-crm.example.com/webhooks/cxone/pause"
if err := segmenter.RegisterPausedWebhook(ctx, campaignID, callbackURL); err != nil {
log.Printf("warning: webhook registration failed: %v", err)
// Output audit log and delivery metrics
log.Printf("delivery success rate: %.2f%%", segmenter.CalculateDeliveryRate())
auditJSON, _ := json.MarshalIndent(segmenter.audits, "", " ")
log.Printf("audit logs: %s", string(auditJSON))
- Cause: OAuth token expired during long-running segment operations or DNC verification batches.
- Fix: The
OAuthClientautomatically refreshes tokens whentime.Until(o.expires) <= 30s. Ensure the client credentials have not been rotated in the CXone admin console. Verify that theExpiresInvalue is correctly parsed and added totime.Now().
Error: 400 Bad Request
- Cause: Segment payload contains unsupported filter operators, invalid
targetingDirective, ormaxDailyDialsexceeds the campaign engine limit. - Fix: Run
ValidateSegment()before submission. EnsuretargetingDirectivematches one of the documented values. Verify thatmaxDailyDialsdoes not exceed the campaign’s configured throughput. Check that all filter fields exist in the CXone contact schema.
Error: 409 Conflict
- Cause: Concurrent PATCH operations on the same segment ID from multiple processes or admin console edits.
- Fix: The retry loop handles transient conflicts. If the error persists after three attempts, the fallback trigger activates. Implement segment locking in your orchestration layer or serialize updates using a queue.
- Cause: Exceeding CXone API rate limits during batch DNC verification or rapid segment iterations.
- Fix: The
UpdateSegmentfunction implements exponential backoff starting at 1 second. For DNC verification, process phone numbers in batches of 50-100. Add atime.Sleep(500 * time.Millisecond)between batch requests if rate limits persist.
Error: 403 Forbidden
- Cause: OAuth token lacks required scopes or the client ID is not authorized for outbound campaign management.
- Fix: Verify that the registered OAuth client includes
outbound:campaign:write,dnc:read, andintegration:webhook:write. Reauthorize the client in the CXone integration settings if scopes were modified.
