Build a Client-Side Throttling Layer for Genesys Cloud Agent Assist Knowledge Queries in Node.js
  • A Node.js module that intercepts, deduplicates, and rate-limits Agent Assist knowledge queries before they reach the Genesys Cloud API.
  • Uses the genesys-cloud-purecloud-platform-client-v2 SDK for authentication and request execution against /api/v2/agentassist/knowledge/query.
  • Written in modern JavaScript with async/await, in-memory cache matrices, cap validation pipelines, webhook synchronization, and audit logging.
  • Genesys Cloud OAuth 2.0 Client Credentials or JWT client registered in your organization
  • Required OAuth scope: agentassist:knowledge:query
  • Node.js 18 or higher
  • genesys-cloud-purecloud-platform-client-v2 version 8.0 or higher
  • axios for external webhook delivery and audit log shipping
  • os module (built-in) for CPU constraint validation
The Genesys Cloud Node.js SDK manages token lifecycle automatically, but you must initialize the platform client with explicit environment and scope configuration. The code below demonstrates a production-ready authentication block with token caching enabled and explicit error handling for credential failures.
const { PlatformClient } = require('genesys-cloud-purecloud-platform-client-v2');
const authenticateGenesys = async (clientId, clientSecret, environmentUrl) => {
  const platformClient = PlatformClient.create({
    basePath: environmentUrl,
    enableTokenCaching: true,
    tokenCachePath: './.genesys-token-cache.json'
    await platformClient.auth.loginClientCredentials(
      clientId,
      clientSecret,
      ['agentassist:knowledge:query']
    console.log('OAuth2 token acquired. Scope: agentassist:knowledge:query');
    return platformClient;
  } catch (err) {
    if (err.status === 401) {
      throw new Error('Authentication failed: Invalid client credentials or environment URL.');
    if (err.status === 403) {
      throw new Error('Forbidden: Client lacks agentassist:knowledge:query scope.');
    throw new Error(`Authentication error: ${err.message}`);
The SDK stores the access token and refresh token in the specified cache path. Subsequent requests automatically attach the bearer token. If the token expires, the SDK triggers a silent refresh before executing the API call.
Step 1: Initialize Throttle Configuration and Cap Validation Pipeline
The throttling engine requires strict boundaries to prevent backend overload during scaling events. You must define CPU load thresholds, maximum concurrent request limits, and token expiry checks before allowing any query to proceed.
const os = require('os');
class AgentAssistThrottler {
  constructor(config) {
    this.platformClient = config.platformClient;
    this.maxConcurrent = config.maxConcurrent || 10;
    this.cpuThreshold = config.cpuThreshold || 0.8;
    this.capWindowMs = config.capWindowMs || 60000;
    this.cacheTtlMs = config.cacheTtlMs || 300000;
    this.webhookUrl = config.webhookUrl;
    this.cacheMatrix = new Map();
    this.activeRequests = new Set();
    this.capTimestamps = [];
    this.auditLogs = [];
    this.metrics = {
      totalQueries: 0,
      cacheHits: 0,
      capBlocks: 0,
      apiCalls: 0,
      latencies: []
  async validateCapAndConstraints() {
    const cpuLoad = os.loadavg()[0] / os.cpus().length;
    if (cpuLoad > this.cpuThreshold) {
      throw new Error(`CPU constraint exceeded: Current load ${cpuLoad.toFixed(2)} exceeds threshold ${this.cpuThreshold}`);
    const now = Date.now();
    this.capTimestamps = this.capTimestamps.filter(ts => now - ts < this.capWindowMs);
    if (this.capTimestamps.length >= this.maxConcurrent) {
      this.metrics.capBlocks++;
      await this.syncWebhook('CAP_REACHED', { blocked: true, active: this.capTimestamps.length });
      throw new Error('Maximum concurrent request cap reached. Throttling enforced.');
    const tokenInfo = this.platformClient.auth.getAccessToken();
    if (!tokenInfo || tokenInfo.expiresAt < now + 300000) {
      await this.platformClient.auth.refreshToken();
    return true;
The validateCapAndConstraints method checks system CPU usage against a defined threshold, enforces a sliding window cap on concurrent requests, and verifies token freshness. If the cap is reached, the method throws an error and triggers a webhook synchronization event.
Step 2: Construct Throttling Payloads and Cache Matrix Logic
The cache matrix uses a query-ref hash to deduplicate identical knowledge queries. You must implement stale entry evaluation, automatic purge triggers, and hit ratio calculation to maintain memory efficiency.
const crypto = require('crypto');
  generateQueryRef(payload) {
    const normalized = JSON.stringify({
      text: payload.text,
      language: payload.language,
      maxResults: payload.maxResults
    return crypto.createHash('sha256').update(normalized).digest('hex').substring(0, 16);
  async evaluateCache(queryRef) {
    const cached = this.cacheMatrix.get(queryRef);
    if (cached) {
      const age = Date.now() - cached.timestamp;
      if (age > this.cacheTtlMs) {
        this.cacheMatrix.delete(queryRef);
        return null;
      this.metrics.cacheHits++;
      return cached.response;
    return null;
  async purgeStaleEntries() {
    for (const [key, value] of this.cacheMatrix) {
      if (now - value.timestamp > this.cacheTtlMs) {
        this.cacheMatrix.delete(key);
    this.recordAudit('CACHE_PURGE', { remaining: this.cacheMatrix.size });
  calculateHitRatio() {
    const total = this.metrics.totalQueries || 1;
    return (this.metrics.cacheHits / total).toFixed(3);
  recordAudit(event, details) {
    this.auditLogs.push({
      event,
      details
The generateQueryRef method creates a deterministic reference for each query payload. The evaluateCache method performs atomic Map lookups, evaluates TTL expiration, and returns cached responses when valid. The purgeStaleEntries method runs asynchronously to prevent cache bloat, while calculateHitRatio provides real-time efficiency metrics.
Step 3: Execute Agent Assist Query with Retry and 429 Handling
The core query method combines cap validation, cache evaluation, SDK execution, and exponential backoff for rate-limit responses. The Genesys Cloud Agent Assist endpoint expects a specific JSON structure and returns a flat array of knowledge suggestions.
  async queryKnowledge(payload) {
    const queryRef = this.generateQueryRef(payload);
    this.metrics.totalQueries++;
    const cached = await this.evaluateCache(queryRef);
    if (cached) {
      return { source: 'cache', ref: queryRef, data: cached };
    await this.validateCapAndConstraints();
    this.capTimestamps.push(Date.now());
    this.activeRequests.add(queryRef);
    const startTime = Date.now();
      const response = await this.platformClient.Agentassist.queryKnowledge({
        body: {
          text: payload.text,
          language: payload.language || 'en-US',
          maxResults: payload.maxResults || 5
      const latency = Date.now() - startTime;
      this.metrics.latencies.push(latency);
      this.metrics.apiCalls++;
      this.cacheMatrix.set(queryRef, {
        response: response.body,
        timestamp: Date.now()
      this.recordAudit('QUERY_SUCCESS', { ref: queryRef, latency, results: response.body?.length });
      return { source: 'api', ref: queryRef, data: response.body, latency };
    } catch (err) {
      this.activeRequests.delete(queryRef);
      if (err.status === 429) {
        const retryAfter = parseInt(err.headers?.['retry-after'] || '2', 10);
        await new Promise(res => setTimeout(res, retryAfter * 1000));
        return this.queryKnowledge(payload);
      if (err.status === 401 || err.status === 403) {
      this.recordAudit('QUERY_FAILURE', { ref: queryRef, status: err.status, error: err.message });
      throw err;
    } finally {
      if (this.metrics.totalQueries % 50 === 0) {
        await this.purgeStaleEntries();
The queryKnowledge method checks the cache first, validates system constraints, executes the SDK call, and handles 429 responses with exponential backoff using the Retry-After header. The SDK method Agentassist.queryKnowledge maps directly to POST /api/v2/agentassist/knowledge/query. Cache entries are stored with timestamps, and automatic purging triggers every 50 queries to prevent memory bloat.
Step 4: Synchronize Events and Expose Throttler Management
External monitoring requires webhook synchronization on cap events and audit log exposure for governance. The final step implements webhook delivery and exposes a management interface for automated systems.
  async syncWebhook(eventType, payload) {
    if (!this.webhookUrl) return;
      await axios.post(this.webhookUrl, {
        event: eventType,
        payload,
        metrics: {
          hitRatio: this.calculateHitRatio(),
          activeRequests: this.activeRequests.size,
          capUtilization: this.capTimestamps.length / this.maxConcurrent
    } catch (err) {
      console.error('Webhook delivery failed:', err.message);
  getThrottleStatus() {
      cacheSize: this.cacheMatrix.size,
      capUtilization: this.capTimestamps.length / this.maxConcurrent,
      avgLatency: this.metrics.latencies.length
        ? (this.metrics.latencies.reduce((a, b) => a + b, 0) / this.metrics.latencies.length).toFixed(2)
        : 0,
      auditLogCount: this.auditLogs.length
The syncWebhook method posts cap events and performance metrics to an external monitoring endpoint. The getThrottleStatus method exposes real-time throttler state for automated management systems. Both methods run asynchronously to prevent blocking the main query pipeline.
The following script combines all components into a single runnable module. Replace the placeholder credentials and webhook URL with your environment values.
    this.metrics = {
      totalQueries: 0,
      cacheHits: 0,
      capBlocks: 0,
      apiCalls: 0,
      latencies: []
    return true;
      text: payload.text,
    if (cached) {
        return null;
    return null;
      event,
      details
    if (cached) {
        body: {
          text: payload.text,
    } catch (err) {
      throw err;
    } finally {
        event: eventType,
        payload,
        metrics: {
    } catch (err) {
        : 0,
const run = async () => {
    basePath: 'https://api.mypurecloud.com',
      'YOUR_CLIENT_ID',
      'YOUR_CLIENT_SECRET',
    const throttler = new AgentAssistThrottler({
      platformClient,
      maxConcurrent: 8,
      cpuThreshold: 0.75,
      capWindowMs: 60000,
      cacheTtlMs: 300000,
      webhookUrl: 'https://your-monitoring-endpoint.com/hooks/genesys-cap'
    const result1 = await throttler.queryKnowledge({ text: 'How do I reset my password?', language: 'en-US', maxResults: 3 });
    console.log('Query 1:', result1);
    const result2 = await throttler.queryKnowledge({ text: 'How do I reset my password?', language: 'en-US', maxResults: 3 });
    console.log('Query 2 (Cache Hit):', result2);
    console.log('Throttle Status:', throttler.getThrottleStatus());
  } catch (err) {
    console.error('Execution failed:', err.message);
run();
Common Errors and Debugging
  • Cause: The OAuth client lacks the agentassist:knowledge:query scope, or the token cache contains an expired credential.
  • Fix: Verify the client credentials in the Genesys Cloud admin console. Ensure the scope array matches exactly. The SDK refresh logic handles expiration, but manual intervention is required if the client secret rotates.
  • Code Fix: The validateCapAndConstraints method checks token expiry and triggers refreshToken(). If authentication fails repeatedly, regenerate the client secret and update the environment variables.
  • Cause: Genesys Cloud enforces platform-level rate limits, or the custom cap pipeline blocks the request.
  • Fix: The queryKnowledge method parses the Retry-After header and implements exponential backoff. Platform limits cannot be bypassed. Adjust maxConcurrent and capWindowMs to align with your organization quota.
  • Code Fix: The retry logic uses setTimeout with the server-provided delay. Add jitter in production environments to prevent thundering herd scenarios.
Error: Cache Bloat or Memory Pressure
  • Cause: High query volume with low duplication causes the cacheMatrix to exceed available heap space.
  • Fix: The purgeStaleEntries method runs every 50 queries. Reduce cacheTtlMs if memory consumption grows. Monitor getThrottleStatus().cacheSize during load testing.
  • Code Fix: Implement LRU eviction by tracking access order in the Map, or switch to a dedicated in-memory store like Redis for distributed deployments.
Error: Webhook Delivery Failures
  • Cause: The external monitoring endpoint returns 5xx errors, or network timeouts occur during cap synchronization.
  • Fix: The syncWebhook method catches delivery failures and logs them without blocking the main pipeline. Verify endpoint availability and add retry logic if governance requires guaranteed delivery.
  • Code Fix: Wrap the axios call in a retry decorator or queue failed events for offline replay.
