I am using TServer 7.0.206 for Avaya and I came across the following problem:
attach data is not being delivered along with EventRinging, instead it is delivered right AFTER it with EventUSerDataChanged
Here is the flow:
IVR>twostep ransfer>VDN1(Attach data 1,2,3)>VDN2(attach data 4,5,6)>agent
we are using LDS, but I do not think it matters… (at least not yet)
URS is set to routconsultcall = true
The problem is that when the call arrives at agent’s place, EventRinging contains attach data 4,5,6 no prob, but it only has 1 for attach data from VDN1 and no 2 or 3. The problem disappears if I add 2 second delay before VDN1, thus making sure that IVR completes the transfer before routing the call.
What makes things weirder:
when call arrives at VDN2, EventRouteRequest contains attach data 1,2,3 no problem.
EventRouteUsed from VDN2 to agent contains 4,5,6 and only 1
EventPartyChange for two step happens somewhere during VDN1 or during VDN2, but ALWAYS before URS sends the call to the agent.
Desktop is informed of 2,3 come AFTER EventRinging through EventUSerDataChanged (100 ms after original EventRinging)
What is going on? Has anyone seen this behaviour before?
It seems like TServer has trouble with handling consult call attachdata. I am using “joint” for consultcall attach data, therefore, calls added to consult call should also be reflected in the original call.
Any ideas?
