Broadcasting Genesys Cloud Workforce Management Alerts via WebSocket with Python SDK
- A Python module that creates workforce management alerts, constructs validated WebSocket broadcast payloads, pushes them to subscribed clients, tracks acknowledgments and latency, suppresses duplicates, and generates audit logs.
- This implementation uses the Genesys Cloud Python SDK for REST operations and the
websocketslibrary for real-time frame transmission. - The programming language covered is Python 3.9+.
- OAuth client credentials with scopes:
wfm:scheduling:write,wfm:scheduling:read - Genesys Cloud Python SDK version 2.18.0 or higher
- Python 3.9 runtime or higher
- External dependencies:
genesyscloud>=2.18.0,websockets>=12.0,httpx>=0.25.0,pydantic>=2.0,aiofiles>=23.0
The Genesys Cloud Python SDK handles OAuth 2.0 client credentials flow automatically. You must configure the platform client with your organization domain, client ID, and client secret. Token caching and automatic refresh are built into the SDK.
import os
from genesyscloud.platformclient.v2 import PureCloudPlatformClientV2, Configuration
from genesyscloud.platformclient.v2.rest import ApiException
def initialize_platform_client() -> PureCloudPlatformClientV2:
"""Configures and returns an authenticated Genesys Cloud platform client."""
config = Configuration(
host=os.getenv("GENESYS_DOMAIN", "w1.genesyscloud.com"),
client_id=os.getenv("GENESYS_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLIENT_SECRET")
platform_client = PureCloudPlatformClientV2(config)
platform_client.login()
except ApiException as e:
if e.status == 401:
raise RuntimeError("Authentication failed. Verify client credentials and OAuth scopes.")
elif e.status == 429:
raise RuntimeError("Rate limit exceeded. Implement exponential backoff before retrying.")
raise e
return platform_client
Step 1: Create WFM Alert and Extract Reference ID
You must create the alert via REST before broadcasting it over WebSocket. The response contains the authoritative alert ID that your broadcast payload must reference. This call requires the wfm:scheduling:write scope.
from genesyscloud.platformclient.v2 import WfmApi
import httpx
async def create_wfm_alert(platform_client: PureCloudPlatformClientV2, title: str, description: str, severity: str) -> str:
"""Creates a WFM alert and returns its ID. Falls back to httpx if SDK fails for debugging."""
wfm_api = WfmApi(platform_client)
# Construct realistic request body
alert_body = {
"title": title,
"description": description,
"severity": severity,
"alertType": "manual",
"isActive": True,
"recipients": {
"groups": ["wfm:manager:all"],
"users": []
response = wfm_api.post_wfm_scheduling_alerts(body=alert_body)
return response.id
# Fallback to raw httpx for transparent debugging
async with httpx.AsyncClient() as client:
token = platform_client._config.get_access_token()
resp = await client.post(
f"https://{platform_client._config.host}/api/v2/wfm/scheduling/alerts",
json=alert_body,
headers={"Authorization": f"Bearer {token}", "Content-Type": "application/json"}
if resp.status_code == 403:
raise PermissionError("Missing wfm:scheduling:write scope.")
resp.raise_for_status()
return resp.json()["id"]
Step 2: Construct and Validate Broadcast Payloads
Genesys Cloud real-time engine constraints enforce a 64KB maximum message size and require specific schema fields for subscription scope matching. You must validate the payload before transmission to prevent broadcasting failure.
import json
import hashlib
from pydantic import BaseModel, Field, validator
from typing import List, Dict
MAX_WS_FRAME_SIZE = 65536 # 64KB limit enforced by Genesys real-time engine
class BroadcastPayload(BaseModel):
alert_id: str
recipient_groups: List[str] = Field(default_factory=list)
priority: str = Field(default="normal", pattern="^(critical|high|normal|low)$")
message: str
timestamp: float
client_id: str
@validator("message")
def verify_message_format(cls, v: str) -> str:
if not v.strip():
raise ValueError("Message cannot be empty or whitespace only.")
return v
def build_broadcast_payload(alert_id: str, groups: List[str], priority: str, message: str, timestamp: float, client_id: str) -> str:
"""Constructs and validates a WebSocket broadcast payload."""
payload = BroadcastPayload(
alert_id=alert_id,
recipient_groups=groups,
priority=priority,
message=message,
timestamp=timestamp,
client_id=client_id
payload_json = payload.json()
if len(payload_json.encode("utf-8")) > MAX_WS_FRAME_SIZE:
raise ValueError(f"Payload exceeds {MAX_WS_FRAME_SIZE} byte limit. Truncate message or reduce group matrix.")
return payload_json
def generate_message_hash(payload_json: str) -> str:
"""Generates a deterministic hash for duplicate suppression."""
return hashlib.sha256(payload_json.encode("utf-8")).hexdigest()
Step 3: Establish WebSocket Connection and Send Atomic Frames
Genesys Cloud WebSockets use the wss://{domain}/ws/v2 endpoint. You must subscribe to the appropriate stream path before sending control or broadcast frames. Atomic text frame operations ensure the real-time engine processes the entire payload as a single unit.
import asyncio
import websockets
async def broadcast_via_websocket(domain: str, access_token: str, payload_json: str, stream_path: str = "wfm/scheduling/alerts") -> dict:
"""Connects to Genesys WebSocket, subscribes, sends atomic frame, and returns transmission metadata."""
ws_url = f"wss://{domain}/ws/v2"
headers = {
"Authorization": f"Bearer {access_token}",
"Accept": "application/json"
metadata = {
"sent_at": time.time(),
"status": "pending",
"ack_received": False,
"frame_size_bytes": len(payload_json.encode("utf-8"))
async with websockets.connect(ws_url, extra_headers=headers) as ws:
# Subscribe to the WFM alert stream
subscription_msg = json.dumps({
"action": "subscribe",
"path": stream_path,
"clientId": "python-wfm-broadcaster-v1"
await ws.send(subscription_msg)
# Wait for subscription confirmation
confirm = await ws.recv()
confirm_data = json.loads(confirm)
if confirm_data.get("type") != "subscriptionConfirmation":
raise RuntimeError(f"Subscription failed: {confirm_data}")
# Atomic text frame transmission
await ws.send(payload_json)
metadata["status"] = "sent"
metadata["sent_at"] = time.time()
# Listen for acknowledgment or engine response
response = await asyncio.wait_for(ws.recv(), timeout=5.0)
response_data = json.loads(response)
metadata["ack_received"] = True
metadata["ack_timestamp"] = time.time()
metadata["engine_response"] = response_data
except asyncio.TimeoutError:
metadata["status"] = "timeout"
metadata["error"] = "No acknowledgment received within 5 seconds"
return metadata
Step 4: Implement Acknowledgment Tracking and Duplicate Suppression
You must track broadcast latency, verify read receipts, and prevent alert fatigue by suppressing duplicate transmissions. The following pipeline maintains a sliding window of processed message hashes and calculates round-trip latency.
from collections import deque
from typing import Optional
class BroadcastTracker:
def __init__(self, window_size: int = 100):
self.sent_hashes = deque(maxlen=window_size)
self.ack_log: Dict[str, dict] = {}
def is_duplicate(self, message_hash: str) -> bool:
return message_hash in self.sent_hashes
def record_broadcast(self, message_id: str, metadata: dict) -> float:
"""Records broadcast event and calculates latency if acknowledged."""
latency_ms = 0.0
if metadata.get("ack_received") and metadata.get("ack_timestamp"):
latency_ms = (metadata["ack_timestamp"] - metadata["sent_at"]) * 1000
metadata["latency_ms"] = latency_ms
self.ack_log[message_id] = metadata
return latency_ms
def get_read_receipt_rate(self) -> float:
"""Calculates percentage of broadcasts that received acknowledgments."""
if not self.ack_log:
return 0.0
ack_count = sum(1 for m in self.ack_log.values() if m.get("ack_received"))
return (ack_count / len(self.ack_log)) * 100.0
Step 5: External Synchronization and Audit Logging
You must expose callback handlers for alignment with external communication platforms and generate audit logs for notification governance. The following implementation uses httpx for external sync and aiofiles for asynchronous audit logging.
import aiofiles
import httpx
from typing import Callable, Awaitable
BroadcastCallback = Callable[[str, float, dict], Awaitable[None]]
async def execute_external_sync(message_id: str, latency_ms: float, payload: dict, callback_url: str) -> bool:
"""Synchronizes broadcast events with external communication platforms."""
sync_payload = {
"event": "wfm_alert_broadcast",
"message_id": message_id,
"latency_ms": latency_ms,
"payload": payload,
"timestamp": time.time()
resp = await client.post(callback_url, json=sync_payload)
return resp.status_code in (200, 201, 202)
print(f"External sync failed for {message_id}: {e}")
return False
async def write_audit_log(message_id: str, metadata: dict, payload_hash: str, audit_path: str = "broadcast_audit.log") -> None:
"""Generates append-only audit logs for notification governance."""
audit_entry = {
"payload_hash": payload_hash,
"status": metadata.get("status"),
"ack_received": metadata.get("ack_received"),
"latency_ms": metadata.get("latency_ms"),
"frame_size_bytes": metadata.get("frame_size_bytes"),
"logged_at": time.time()
async with aiofiles.open(audit_path, mode="a", encoding="utf-8") as f:
await f.write(json.dumps(audit_entry) + "\n")
The following script combines all components into a production-ready alert broadcaster. Replace the environment variables with your credentials before execution.
import os
import asyncio
import uuid
# Import functions from previous sections (assume same file or module)
# from .auth import initialize_platform_client
# from .rest import create_wfm_alert
# from .payload import build_broadcast_payload, generate_message_hash
# from .websocket import broadcast_via_websocket
# from .tracker import BroadcastTracker
# from .sync import execute_external_sync, write_audit_log
async def main():
# 1. Authenticate
tracker = BroadcastTracker(window_size=150)
# 2. Create alert via REST
alert_id = await create_wfm_alert(
platform_client,
title="Shift Coverage Gap Detected",
description="Insufficient staffing for Zone A during peak hours.",
severity="high"
# 3. Construct broadcast payload
client_id = str(uuid.uuid4())
timestamp = time.time()
payload_json = build_broadcast_payload(
alert_id=alert_id,
groups=["wfm:manager:zone_a", "wfm:supervisor:all"],
priority="high",
message="Immediate coverage adjustment required. Review shift swap requests.",
client_id=client_id
except ValueError as e:
print(f"Payload validation failed: {e}")
return
message_hash = generate_message_hash(payload_json)
# 4. Duplicate suppression check
if tracker.is_duplicate(message_hash):
print("Duplicate broadcast suppressed to prevent alert fatigue.")
return
# 5. Transmit via WebSocket
metadata = await broadcast_via_websocket(
domain=config.host,
access_token=token,
payload_json=payload_json
# 6. Track and calculate latency
message_id = f"bcast-{uuid.uuid4().hex[:8]}"
latency_ms = tracker.record_broadcast(message_id, metadata)
tracker.sent_hashes.append(message_hash)
# 7. External synchronization
callback_url = os.getenv("EXTERNAL_SYNC_URL", "https://hooks.internal-platform.com/wfm-alerts")
await execute_external_sync(message_id, latency_ms, json.loads(payload_json), callback_url)
# 8. Audit logging
await write_audit_log(message_id, metadata, message_hash)
print(f"Broadcast complete. ID: {message_id}, Latency: {latency_ms:.2f}ms, Ack: {metadata.get('ack_received')}")
print(f"System read receipt rate: {tracker.get_read_receipt_rate():.1f}%")
asyncio.run(main())
- What causes it: Expired OAuth token, invalid client credentials, or missing
wfm:scheduling:writescope. - How to fix it: Verify environment variables. The SDK automatically refreshes tokens, but initial authentication must succeed. Check the console output for token expiration timestamps.
- Code showing the fix:
if e.status == 401:
print("Refreshing token cache...")
platform_client._config.clear_tokens()
Error: 403 Forbidden
- What causes it: The OAuth client lacks the required scope for the WFM alerts endpoint or WebSocket subscription path.
- How to fix it: Add
wfm:scheduling:readandwfm:scheduling:writeto your OAuth client configuration in the Genesys Cloud admin console. - Code showing the fix: Scope validation is handled during the REST call. The fallback
httpxrequest explicitly checks for 403 and raises a descriptive exception.
- What causes it: Exceeding Genesys Cloud rate limits on REST calls or WebSocket frame transmission frequency.
- How to fix it: Implement exponential backoff with jitter. Genesys Cloud returns
Retry-Afterheaders on rate-limited responses. - Code showing the fix:
import random
async def retry_with_backoff(func, *args, max_retries=3, **kwargs):
return await func(*args, **kwargs)
if e.status == 429:
retry_after = int(e.headers.get("Retry-After", 2 ** attempt))
jitter = random.uniform(0, 0.5)
wait_time = retry_after + jitter
print(f"Rate limited. Retrying in {wait_time:.2f}s...")
else:
raise e
raise RuntimeError("Max retries exceeded for rate-limited operation.")
Error: WebSocket Frame Size Exceeded
- What causes it: Payload exceeds the 64KB real-time engine constraint.
- How to fix it: The
build_broadcast_payloadfunction enforcesMAX_WS_FRAME_SIZE. Reduce the recipient group matrix length or truncate the message field before transmission. - Code showing the fix: The Pydantic validator and explicit byte check in
build_broadcast_payloadprevent oversized frames from reaching the WebSocket layer.
Error: Subscription Scope Mismatch
- What causes it: Attempting to broadcast to a path the authenticated user lacks read access to.
- How to fix it: Verify the user or service account has WFM scheduling permissions. The subscription confirmation response will indicate
type: "subscriptionError"if scopes are insufficient. - Code showing the fix: The
broadcast_via_websocketfunction checksconfirm_data.get("type")and raises a descriptive error on mismatch.
