Someone could give me some reference about this?
“total calls forwarded”
“clear calls”
My client have an Avaya Switch.
Regards
“clear calls”
Regards
Good doco for this would be “Reporting Technical Reference guide” or “Stat Server User’s guide”
Citation:
Forwarded calls: The total number of calls that were distributed from this queue to an agent and then forwarded to another destination by means of redirection or forwarding.
Cleared calls : The total number of voice interactions that were cleared from this virtual queue. The concept of cleared calls applies to routing strategies where an interaction may wait in a virtual queue for one of several targets to become available. When a target does become available, the call is distributed to that target and is “cleared” from other targets.
I need to know the following:
What event of the PBX, does that Genesys generate one call on the statistic, that it´s called "Call_Forwarded ?
In Nortel it was when a set was ringing and no agent answered Nortel “forwarded” the call to another extension like the operator.
