Branch NICE CXone Flow Dialog Versions via Java Flow API
- This tutorial constructs a production-grade Java service that forks NICE CXone Flow dialog versions by generating branching payloads with
version-ref,node-matrix, andforkdirectives. - The implementation uses the NICE CXone Flow API (
/api/v2/flows/{flowId}/versions/{versionId}) with explicit HTTP control for atomic updates, diff calculation, and schema validation. - The code is written in Java 17 using OkHttp for network operations and Jackson for JSON processing.
- OAuth Client Credentials grant with scopes:
view:flow,edit:flow - CXone Flow API v2 (JSON-based flow definition schema)
- Java 17 or later with Maven or Gradle
- External dependencies:
com.squareup.okhttp3:okhttp:4.12.0,com.fasterxml.jackson.core:jackson-databind:2.16.1,com.fasterxml.jackson.core:jackson-annotations:2.16.1
CXone uses OAuth 2.0 Client Credentials flow. Production integrations must cache tokens and handle expiration. The following class manages token acquisition, caching, and automatic refresh.
import okhttp3.*;
import java.io.IOException;
import java.time.Instant;
public class CxoneAuthManager {
private final OkHttpClient httpClient;
private final String clientId;
private final String clientSecret;
private final String authUrl;
private String accessToken;
private Instant tokenExpiry;
private final ObjectMapper mapper = new ObjectMapper();
public CxoneAuthManager(String region, String clientId, String clientSecret) {
this.clientId = clientId;
this.authUrl = String.format("https://api.%s.niceincontact.com/oauth/token", region);
this.httpClient = new OkHttpClient.Builder()
.connectTimeout(10, TimeUnit.SECONDS)
.readTimeout(10, TimeUnit.SECONDS)
.build();
public synchronized String getAccessToken() throws IOException {
if (accessToken != null && Instant.now().isBefore(tokenExpiry)) {
return accessToken;
RequestBody form = new FormBody.Builder()
.add("grant_type", "client_credentials")
.add("client_id", clientId)
.add("client_secret", clientSecret)
.build();
Request request = new Request.Builder()
.url(authUrl)
.post(form)
.build();
try (Response response = httpClient.newCall(request).execute()) {
if (!response.isSuccessful()) {
throw new IOException("OAuth token request failed: " + response.code());
JsonNode json = mapper.readTree(response.body().string());
this.accessToken = json.get("access_token").asText();
this.tokenExpiry = Instant.now().plus(json.get("expires_in").asLong(), TimeUnit.SECONDS.toChronoUnit());
return accessToken;
Step 1: Fetch Base Flow Version and Prepare HTTP Client
Retrieve the target flow version to establish a baseline for diff calculation and branching. The request requires the view:flow scope.
import okhttp3.*;
public class FlowVersionFetcher {
private final CxoneAuthManager authManager;
private final String baseUrl;
public FlowVersionFetcher(CxoneAuthManager authManager, String region) {
this.authManager = authManager;
this.baseUrl = String.format("https://api.%s.niceincontact.com/api/v2", region);
.connectTimeout(15, TimeUnit.SECONDS)
.readTimeout(30, TimeUnit.SECONDS)
.addInterceptor(chain -> {
String token = authManager.getAccessToken();
return chain.proceed(chain.request().newBuilder()
.build());
.build();
public String fetchVersion(String flowId, String versionId) throws IOException {
.url(String.format("%s/flows/%s/versions/%s", baseUrl, flowId, versionId))
.get()
.build();
if (response.code() == 401) throw new IOException("Unauthorized: Invalid or expired token");
if (response.code() == 403) throw new IOException("Forbidden: Missing view:flow scope");
if (response.code() == 429) throw new IOException("Rate limited: 429 Too Many Requests");
if (!response.isSuccessful()) throw new IOException("Unexpected error: " + response.code());
return response.body().string();
Step 2: Construct Branching Payload with versionRef, nodeMatrix, and fork Directive
CXone flow definitions are JSON documents. Branching requires appending version lineage and structural routing matrices. The payload below constructs the required directives.
import com.fasterxml.jackson.databind.node.ObjectNode;
import java.util.Map;
public class BranchPayloadBuilder {
public String buildBranchPayload(String baseVersionJson, String sourceVersionId, String branchName, Map<String, String> nodeMatrix) throws Exception {
ObjectNode base = (ObjectNode) mapper.readTree(baseVersionJson);
ObjectNode metadata = mapper.createObjectNode();
metadata.put("versionRef", sourceVersionId);
metadata.put("fork", "true");
metadata.put("branchName", branchName);
metadata.put("forkedAt", System.currentTimeMillis());
ObjectNode matrixNode = mapper.createObjectNode();
nodeMatrix.forEach(matrixNode::put);
metadata.set("nodeMatrix", matrixNode);
base.set("branchingMetadata", metadata);
return mapper.writeValueAsString(base);
Step 3: Validate Schema Constraints, Depth Limits, and Node Connectivity
CXone enforces storage limits and maximum branch depth. The validation pipeline checks disconnected nodes and type mismatches before submission.
import java.util.*;
public class BranchValidator {
private static final int MAX_DEPTH = 12;
private static final long MAX_PAYLOAD_BYTES = 2 * 1024 * 1024; // 2MB limit
public void validate(String payloadJson, String flowId) throws Exception {
if (payloadJson.getBytes().length > MAX_PAYLOAD_BYTES) {
throw new IllegalArgumentException("Payload exceeds storage constraint of 2MB");
JsonNode root = mapper.readTree(payloadJson);
JsonNode nodes = root.get("nodes");
JsonNode edges = root.get("edges");
if (nodes == null || edges == null) {
throw new IllegalArgumentException("Invalid flow schema: missing nodes or edges array");
// Disconnected node checking via BFS
Set<String> visited = new HashSet<>();
Set<String> allNodeIds = new HashSet<>();
Map<String, List<String>> adjacency = new HashMap<>();
for (JsonNode n : nodes) {
allNodeIds.add(n.get("id").asText());
adjacency.put(n.get("id").asText(), new ArrayList<>());
for (JsonNode e : edges) {
String from = e.get("from").asText();
String to = e.get("to").asText();
adjacency.get(from).add(to);
if (!allNodeIds.isEmpty()) {
String startNode = allNodeIds.iterator().next();
Queue<String> queue = new LinkedList<>(Collections.singletonList(startNode));
while (!queue.isEmpty()) {
String current = queue.poll();
if (visited.add(current)) {
queue.addAll(adjacency.getOrDefault(current, Collections.emptyList()));
if (visited.size() < allNodeIds.size()) {
throw new IllegalArgumentException("Fork validation failed: disconnected nodes detected");
// Type mismatch verification
String type = n.get("type").asText();
if (!type.matches("^(dialog|condition|action|endpoint|queue|transfer)$")) {
throw new IllegalArgumentException("Type mismatch verification failed: invalid node type '" + type + "'");
// Branch depth limit check (simulated via edge path length)
int maxDepth = calculateMaxDepth(adjacency);
if (maxDepth > MAX_DEPTH) {
throw new IllegalArgumentException("Maximum branch depth limit exceeded: " + maxDepth + " > " + MAX_DEPTH);
private int calculateMaxDepth(Map<String, List<String>> graph) {
int max = 0;
for (String start : graph.keySet()) {
max = Math.max(max, dfsDepth(start, graph, new HashSet<>()));
return max;
private int dfsDepth(String node, Map<String, List<String>> graph, Set<String> visited) {
if (visited.contains(node) || !graph.containsKey(node)) return 0;
visited.add(node);
int currentDepth = 0;
for (String child : graph.get(node)) {
currentDepth = Math.max(currentDepth, dfsDepth(child, graph, visited));
return currentDepth + 1;
Step 4: Execute Atomic PUT with Diff Calculation and Snapshot Trigger
Atomic updates require conditional headers and explicit diff logging. This step calculates structural differences, triggers a snapshot via custom headers, and handles 429 retries.
import okhttp3.*;
public class AtomicFlowUpdater {
private final int retryAttempts = 3;
public AtomicFlowUpdater(CxoneAuthManager authManager, String region) {
.header("X-NICE-Snapshot", "trigger-fork-snapshot")
.build());
.build();
public String executeAtomicPut(String flowId, String versionId, String payloadJson, String etag) throws IOException {
RequestBody body = RequestBody.create(payloadJson, MediaType.parse("application/json"));
.put(body)
.header("If-Match", etag)
.build();
int attempt = 0;
while (attempt < retryAttempts) {
if (response.code() == 409) {
return handleMergeConflict(payloadJson, response.body().string());
if (response.code() == 429) {
attempt++;
long delay = (long) Math.pow(2, attempt) * 1000;
Thread.sleep(delay);
continue;
throw new IOException("Atomic PUT failed: " + response.code() + " " + response.message());
return calculateDiff(payloadJson, response.body().string());
} catch (InterruptedException e) {
Thread.currentThread().interrupt();
throw new IOException("Retry interrupted", e);
throw new IOException("Exceeded retry limit for 429 responses");
private String handleMergeConflict(String clientPayload, String serverPayload) throws Exception {
JsonNode client = mapper.readTree(clientPayload);
JsonNode server = mapper.readTree(serverPayload);
if (!client.get("nodes").equals(server.get("nodes"))) {
throw new IOException("Merge conflict: node structure diverged during fork iteration");
return "Resolved: metadata aligned, proceeding with snapshot";
private String calculateDiff(String original, String updated) throws Exception {
JsonNode orig = mapper.readTree(original);
JsonNode upd = mapper.readTree(updated);
int nodeDiff = Math.abs(orig.get("nodes").size() - upd.get("nodes").size());
return String.format("Diff calculation complete: %d node changes detected", nodeDiff);
Step 5: Sync Webhooks, Track Metrics, and Generate Audit Logs
Production branching requires external synchronization, latency tracking, and governance logging. The following utility handles webhook dispatch, metric aggregation, and audit trail generation.
import okhttp3.*;
import java.util.concurrent.atomic.AtomicInteger;
public class BranchGovernanceManager {
private final OkHttpClient webhookClient = new OkHttpClient();
private final AtomicInteger successCount = new AtomicInteger(0);
private final AtomicInteger failureCount = new AtomicInteger(0);
private final StringBuilder auditLog = new StringBuilder();
public void recordBranchEvent(String flowId, String versionId, String branchName, long latencyMs, boolean success, String diffResult) {
successCount.incrementAndGet();
String logEntry = String.format("[%s] Flow: %s | Version: %s | Branch: %s | Latency: %dms | Success: %b | Diff: %s%n",
Instant.now().toString(), flowId, versionId, branchName, latencyMs, success, diffResult);
auditLog.append(logEntry);
if (success) {
dispatchGitWebhook(flowId, versionId, branchName);
private void dispatchGitWebhook(String flowId, String versionId, String branchName) {
String payload = mapper.writeValueAsString(Map.of(
"event", "flow.version.forked",
"flowId", flowId,
"versionId", versionId,
"branchName", branchName,
"timestamp", Instant.now().toString()
RequestBody body = RequestBody.create(payload, MediaType.parse("application/json"));
.url("https://your-git-server.com/webhooks/cxone-branch-sync")
.post(body)
.build();
webhookClient.newCall(request).enqueue(new Callback() {
@Override public void onFailure(Call call, IOException e) {
System.err.println("Webhook sync failed: " + e.getMessage());
@Override public void onResponse(Call call, Response response) throws IOException {
response.close();
} catch (Exception e) {
System.err.println("Webhook payload serialization failed: " + e.getMessage());
public String getAuditLog() {
return auditLog.toString();
public double getForkSuccessRate() {
int total = successCount.get() + failureCount.get();
return total == 0 ? 0.0 : (double) successCount.get() / total;
The following class integrates all components into a single executable brancher service. Replace placeholder credentials and identifiers before execution.
public class CxoneFlowBrancher {
// 1. Initialize Authentication
CxoneAuthManager auth = new CxoneAuthManager("us", "YOUR_CLIENT_ID", "YOUR_CLIENT_SECRET");
// 2. Fetch Base Version
FlowVersionFetcher fetcher = new FlowVersionFetcher(auth, "us");
String flowId = "YOUR_FLOW_ID";
String versionId = "YOUR_BASE_VERSION_ID";
String baseJson = fetcher.fetchVersion(flowId, versionId);
// 3. Construct Branching Payload
BranchPayloadBuilder builder = new BranchPayloadBuilder();
Map<String, String> nodeMatrix = Map.of("node_1", "route_A", "node_2", "route_B");
String branchPayload = builder.buildBranchPayload(baseJson, versionId, "prod-branch-v2", nodeMatrix);
// 4. Validate Schema and Constraints
BranchValidator validator = new BranchValidator();
validator.validate(branchPayload, flowId);
// 5. Execute Atomic PUT with Metrics Tracking
AtomicFlowUpdater updater = new AtomicFlowUpdater(auth, "us");
BranchGovernanceManager governance = new BranchGovernanceManager();
long start = System.nanoTime();
String etag = "W/\"your-base-version-etag\""; // Retrieve from GET response headers
String diffResult = updater.executeAtomicPut(flowId, versionId, branchPayload, etag);
long latencyMs = (System.nanoTime() - start) / 1_000_000;
governance.recordBranchEvent(flowId, versionId, "prod-branch-v2", latencyMs, true, diffResult);
System.out.println("Branching complete. Success rate: " + governance.getForkSuccessRate());
System.out.println("Audit Log:");
System.out.println(governance.getAuditLog());
System.err.println("Branching pipeline failed: " + e.getMessage());
e.printStackTrace();
- What causes it: The OAuth token expired or the client credentials are invalid.
- How to fix it: Verify
client_idandclient_secret. Ensure theCxoneAuthManagercache is not holding an expired token. Restart the token fetch cycle. - Code showing the fix: The
getAccessToken()method automatically refreshes whenInstant.now().isBefore(tokenExpiry)evaluates to false.
Error: 403 Forbidden
- What causes it: The OAuth token lacks
view:floworedit:flowscopes. - How to fix it: Regenerate the OAuth token with the required scopes. Verify the CXone user role assigned to the OAuth client has Flow Administrator permissions.
- What causes it: CXone rate limits are exceeded during rapid fork iterations or batch versioning.
- How to fix it: Implement exponential backoff. The
AtomicFlowUpdaterretries up to three times withMath.pow(2, attempt) * 1000millisecond delays. Increase theretryAttemptsthreshold for high-volume pipelines.
Error: 400 Bad Request (Schema/Depth Validation)
- What causes it: The payload exceeds 2MB, contains disconnected nodes, or exceeds the 12-level branch depth limit.
- How to fix it: Review the
BranchValidatoroutput. Remove orphaned nodes from thenodesarray. Flatten deeply nested condition trees. VerifynodeMatrixreferences match existing node IDs.
Error: 409 Conflict (Merge Conflict)
- What causes it: Another process modified the flow version between the GET fetch and the PUT submission.
- How to fix it: Re-fetch the version, recalculate the diff, and merge changes before resubmitting. The
handleMergeConflictmethod throws a descriptive exception when node structures diverge.
