Bot Flow 400 Error: NLU Intent Mapping Fails After Zendesk Import
Stuck on mapping our old Zendesk chatbot intents to Genesys Cloud CX AI. In Zendesk, we just matched keywords to ticket tags, but here the Architect flow seems much stricter. When I try to save a new AI Bot flow with imported intents, I get a 400 Bad Request error. The payload says intent_name is missing, even though I clearly defined it in the JSON import. I am using the default bot template from the migration guide. This feels totally different from the simple tag-based logic we used before. Is there a specific syntax for the intent_id that I am missing?
The error logs show validation_failed: intent_mapping at the NLU_Process node. I have checked the timezone settings (Paris) and ensured all entities are linked, but the flow refuses to deploy. In Zendesk, if a keyword matched, it just created a ticket. Here, if the NLU confidence is low, it drops the interaction. How do I force the bot to accept these mapped intents without throwing a validation error? Any tips on debugging the intent structure in the Architect UI would be huge.
The 400 error typically stems from a mismatch between the legacy Zendesk intent structure and the strict schema requirements of Genesys Cloud CX AI. The import process often strips or renames the intent_name field if it does not conform to the expected casing or if the surrounding metadata is incomplete. Here is the corrected JSON payload structure that aligns with the current Genesys API expectations for intent mapping.
 "name": "Order_Status_Check",
 "description": "Handles user queries regarding order tracking",
 "intent_name": "order_status",
 "training_phrases": [
 "where is my package",
 "track my order",
 "status of shipment"
 "language_code": "en-US"
The critical element here is the explicit intent_name field. In many Zendesk exports, this might be buried under a tag or label attribute. The Genesys parser expects intent_name to be a top-level key with a lowercase, underscore-separated string. If your import script is generating camelCase or spaces, the validation fails immediately.
Additionally, check your training_phrases array. Empty arrays or null values here can sometimes trigger a cascade failure that reports as a missing intent_name due to how the backend validates the entire intent object. Ensure each phrase is a non-empty string.
From an analytics perspective, we’ve seen similar issues when migrating data across regions with different latency profiles. The validation engine might time out or drop fields if the payload exceeds certain size thresholds. Keep your initial import batches small. If the error persists, try isolating a single intent with minimal training phrases to rule out data corruption in the larger JSON file. This approach mirrors how we debug SIP registration failures on BYOC trunks-isolate the variable, validate the config, then scale up.
This is actually a known issue… The Zendesk import pipeline often drops the intent_name field if the source JSON lacks explicit schema validation. The Genesys Cloud Terraform provider expects a strict intent_name key at the root level of the intent object. Without it, the API returns a 400 Bad Request.
Check your HCL configuration. You likely need to add a json block with explicit intent mapping before applying.
resource "genesyscloud_flow" "bot_flow" {
 name = "Zendesk Migration"
 intent {
 name = "order_status"
 # Ensure intent_name is explicitly set
 intent_name = "order_status"
If you are using the CLI for bulk imports, run genesys cloud:ai:bot:list to verify the schema structure before pushing. The default template in the migration guide is outdated for Q3 2024 releases. Always validate the payload against the latest OpenAPI spec.
Warning: Do not force-apply Terraform changes on live bot flows. It will overwrite existing NLU models and cause immediate routing failures. Test in a sandbox org first.
