Batch Updating Cognigy.AI Knowledge Base Articles via Python SDK
A Python module that batches knowledge base article updates using atomic HTTP PATCH operations, validates payloads against consistency constraints and maximum batch size limits, triggers index recalculation, verifies format drift and broken links, synchronizes with external CMS via webhooks, tracks latency and success rates, and generates governance audit logs. This implementation uses the Cognigy.AI REST API surface with httpx as the transport layer, wrapped in a type-safe client structure equivalent to the official Python SDK. The code covers Python 3.10+.
  • OAuth2 Client Credentials grant configured in Cognigy.AI tenant
  • Required scopes: knowledge:articles:write, knowledge:index:manage, webhook:trigger
  • Python runtime: 3.10 or newer
  • External dependencies: httpx>=0.25.0, pydantic>=2.5.0, rich>=13.0.0
  • Base API URL format: https://{tenant}.cognigy.ai/api/v1
Cognigy.AI uses standard OAuth2 Client Credentials flow for server-to-server access. The client must cache the access token and refresh it before expiration to prevent 401 interruptions during batch operations.
import httpx
import logging
from typing import Optional
logger = logging.getLogger("cognigy_kb_updater")
class TokenResponse(BaseModel):
    access_token: str
    token_type: str = Field(default="Bearer")
    expires_in: int
class CognigyAuthClient:
    def __init__(self, tenant: str, client_id: str, client_secret: str):
        self.base_url = f"https://{tenant}.cognigy.ai/api/v1"
        self.client_id = client_id
        self.token: Optional[TokenResponse] = None
    async def get_access_token(self) -> str:
        if self.token and time.time() < self.token_expiry:
            return self.token.access_token
            response = await client.post(
                f"{self.base_url}/oauth/token",
                data={
                    "client_id": self.client_id,
                    "scope": "knowledge:articles:write knowledge:index:manage webhook:trigger"
            response.raise_for_status()
            token_data = TokenResponse(**response.json())
            self.token = token_data
            self.token_expiry = time.time() + token_data.expires_in - 30
The batch update payload requires three core structures: article-ref for unique identification, content-matrix for structured knowledge content, and patch directive to specify atomic modifications. Pydantic enforces consistency constraints and prevents malformed submissions.
from pydantic import BaseModel, Field, field_validator, model_validator
from typing import List, Dict, Any, Optional
import uuid
from datetime import datetime
class ArticleRef(BaseModel):
    version: int
    tenant_id: str
class ContentMatrix(BaseModel):
    title: str
    body: str
    metadata: Dict[str, Any] = Field(default_factory=dict)
    internal_links: List[str] = Field(default_factory=list)
    @field_validator("body")
    @classmethod
    def validate_body_format(cls, v: str) -> str:
        if len(v) < 10:
            raise ValueError("Knowledge article body must contain at least 10 characters")
        return v
class PatchDirective(BaseModel):
    operation: str = Field(pattern="^(replace|add|remove)$")
    path: str
    value: Optional[Any] = None
class BatchArticleUpdate(BaseModel):
    article_ref: ArticleRef
    content_matrix: ContentMatrix
    patch_directives: List[PatchDirective]
    @model_validator(mode="after")
    def validate_directive_paths(self) -> "BatchArticleUpdate":
        valid_paths = ["/content_matrix.title", "/content_matrix.body", "/content_matrix.metadata", "/content_matrix.internal_links"]
        for directive in self.patch_directives:
            if directive.path not in valid_paths:
                raise ValueError(f"Invalid patch path: {directive.path}. Allowed: {valid_paths}")
        return self
Step 2: Batch Processing and Size Limit Enforcement
Cognigy.AI enforces a maximum batch size of 50 articles per request. The processor splits incoming data into compliant chunks and validates each chunk before transmission.
class BatchProcessor:
    MAX_BATCH_SIZE = 50
    @staticmethod
    def chunk_articles(articles: List[Dict[str, Any]], chunk_size: int = MAX_BATCH_SIZE) -> List[List[BatchArticleUpdate]]:
        validated_chunks = []
        for i in range(0, len(articles), chunk_size):
            chunk = articles[i:i + chunk_size]
            validated_chunk = [BatchArticleUpdate(**item) for item in chunk]
            validated_chunks.append(validated_chunk)
        return validated_chunks
    @staticmethod
    def format_batch_payload(chunk: List[BatchArticleUpdate]) -> Dict[str, Any]:
            "batchId": str(uuid.uuid4()),
            "timestamp": datetime.utcnow().isoformat(),
            "articles": [
                    "articleRef": a.article_ref.model_dump(),
                    "contentMatrix": a.content_matrix.model_dump(),
                    "patchDirectives": [d.model_dump() for d in a.patch_directives]
                for a in chunk
Step 3: Atomic HTTP PATCH Execution with Retry Logic
The API accepts batch updates via PATCH /api/v1/knowledge/articles/batch. The client implements exponential backoff for 429 rate limit responses and tracks per-article latency. Scopes required: knowledge:articles:write.
import asyncio
class CognigyArticleUpdater:
    def __init__(self, auth_client: CognigyAuthClient):
        self.auth_client = auth_client
        self.base_url = auth_client.base_url
        self.latency_log: List[Dict[str, Any]] = []
        self.audit_log: List[Dict[str, Any]] = []
    async def execute_batch_patch(self, payload: Dict[str, Any]) -> Dict[str, Any]:
        token = await self.auth_client.get_access_token()
        headers = {
            "X-Cognigy-Batch-Operation": "atomic_update"
        async with httpx.AsyncClient(timeout=30.0) as client:
            for attempt in range(5):
                start_time = time.time()
                    response = await client.patch(
                        f"{self.base_url}/knowledge/articles/batch",
                        headers=headers,
                        json=payload
                    self.latency_log.append({"batchId": payload["batchId"], "latency_ms": latency_ms, "status": response.status_code})
                        retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
                        logger.warning("Rate limited. Retrying in %s seconds", retry_after)
                    return response.json()
                    if e.response.status_code in (401, 403):
                        logger.error("Authentication or authorization failed: %s", e.response.text)
                        raise
                    if e.response.status_code == 400:
                        logger.error("Payload validation failed: %s", e.response.text)
                        raise
                    if attempt == 4:
                        raise
                    await asyncio.sleep(2 ** attempt)
Step 4: Index Recalculation and Search Relevance Triggers
After successful patch operations, the knowledge index must recalculate to maintain search relevance. The API provides POST /api/v1/knowledge/index/rebuild which triggers an asynchronous index optimization job. Scopes required: knowledge:index:manage.
    async def trigger_index_rebuild(self, batch_id: str) -> Dict[str, Any]:
        headers = {
        async with httpx.AsyncClient(timeout=15.0) as client:
                f"{self.base_url}/knowledge/index/rebuild",
                headers=headers,
                json={"trigger_source": "batch_update", "correlation_id": batch_id}
    async def poll_index_status(self, job_id: str) -> bool:
            for _ in range(30):
                response = await client.get(
                    f"{self.base_url}/knowledge/index/jobs/{job_id}",
                    headers=headers
                if response.status_code == 200:
                    status = response.json().get("status")
                    if status == "completed":
                        return True
                    if status == "failed":
                        raise RuntimeError("Index rebuild failed")
                await asyncio.sleep(2)
        return False
Step 5: Broken Link and Format Drift Verification Pipeline
Before and after patching, the pipeline verifies internal link integrity and checks for format drift that could break search parsing. This validation runs against the Cognigy.AI content schema.
    async def verify_article_integrity(self, articles: List[BatchArticleUpdate]) -> List[Dict[str, Any]]:
        validation_results = []
        for article in articles:
            issues = []
            for link in article.content_matrix.internal_links:
                if not link.startswith("/api/v1/knowledge/articles/") and not link.startswith("http"):
                    issues.append({"type": "broken_link", "value": link})
            if len(article.content_matrix.body) > 50000:
                issues.append({"type": "format_drift", "reason": "body_exceeds_max_characters"})
            validation_results.append({
                "article_id": article.article_ref.id,
                "valid": len(issues) == 0,
                "issues": issues
        return validation_results
Step 6: Webhook Synchronization, Latency Tracking, and Audit Logging
Successful updates emit webhook payloads to external CMS endpoints, record latency metrics, and append structured audit entries for governance compliance. Scopes required: webhook:trigger.
    async def sync_external_cms(self, batch_id: str, results: Dict[str, Any]) -> None:
        webhook_url = "https://external-cms.example.com/api/v1/cognigy/sync"
        payload = {
            "event": "article_batch_patched",
            "batch_id": batch_id,
            "updated_count": len(results.get("updated", [])),
            "failed_count": len(results.get("failed", [])),
            "latency_ms": self.latency_log[-1]["latency_ms"] if self.latency_log else 0
            response = await client.post(webhook_url, json=payload)
            if response.status_code not in (200, 202):
                logger.warning("CMS webhook sync failed: %s", response.status_code)
    def generate_audit_entry(self, batch_id: str, success_rate: float, latency_avg: float) -> Dict[str, Any]:
        entry = {
            "audit_id": str(uuid.uuid4()),
            "operation": "batch_patch_update",
            "success_rate": success_rate,
            "avg_latency_ms": latency_avg,
            "governance_compliant": success_rate >= 0.95
        self.audit_log.append(entry)
        return entry
The following script combines all components into a single executable module. Replace the placeholder credentials and article data before execution.
import asyncio
import logging
import sys
async def run_kb_batch_update():
    tenant = "your-tenant"
    client_id = "your-client-id"
    client_secret = "your-client-secret"
    auth = CognigyAuthClient(tenant, client_id, client_secret)
    updater = CognigyArticleUpdater(auth)
    processor = BatchProcessor()
    sample_articles = [
            "article_ref": {"id": "kb-001", "version": 3, "tenant_id": "tenant-1"},
            "content_matrix": {"title": "Updated Policy A", "body": "Revised compliance guidelines for enterprise scaling.", "metadata": {"category": "compliance"}, "internal_links": ["/api/v1/knowledge/articles/kb-002"]},
            "patch_directives": [{"operation": "replace", "path": "/content_matrix.title", "value": "Updated Policy A"}]
            "article_ref": {"id": "kb-002", "version": 1, "tenant_id": "tenant-1"},
            "content_matrix": {"title": "Search Optimization Guide", "body": "Index recalculation improves retrieval accuracy during high volume updates.", "metadata": {"category": "technical"}, "internal_links": []},
            "patch_directives": [{"operation": "add", "path": "/content_matrix.metadata", "value": {"priority": "high"}}]
        validation = await updater.verify_article_integrity([BatchArticleUpdate(**a) for a in sample_articles])
        if not all(v["valid"] for v in validation):
            logger.error("Validation failed: %s", validation)
            sys.exit(1)
        chunks = processor.chunk_articles(sample_articles)
        all_results = []
        total_success = 0
        total_failed = 0
        for chunk in chunks:
            payload = processor.format_batch_payload(chunk)
            result = await updater.execute_batch_patch(payload)
            all_results.append(result)
            total_success += len(result.get("updated", []))
            total_failed += len(result.get("failed", []))
            index_job = await updater.trigger_index_rebuild(payload["batchId"])
            await updater.poll_index_status(index_job["jobId"])
            await updater.sync_external_cms(payload["batchId"], result)
        success_rate = total_success / (total_success + total_failed) if (total_success + total_failed) > 0 else 0
        avg_latency = sum(l["latency_ms"] for l in updater.latency_log) / len(updater.latency_log) if updater.latency_log else 0
        audit = updater.generate_audit_entry("final-batch", success_rate, avg_latency)
        logger.info("Audit entry generated: %s", audit)
        logger.info("Batch complete. Success rate: %.2f%%", success_rate * 100)
        logger.error("Batch update failed: %s", str(e))
        sys.exit(1)
    asyncio.run(run_kb_batch_update())
Common Errors and Debugging
Error: 400 Bad Request - Payload Validation Failed
  • What causes it: Missing required fields in article-ref, invalid patch directive paths, or content-matrix body exceeding character limits.
  • How to fix it: Verify Pydantic validation rules match the Cognigy.AI schema. Ensure all patch paths reference valid JSON pointer locations.
  • Code showing the fix:
# Validate paths before construction
valid_paths = ["/content_matrix.title", "/content_matrix.body", "/content_matrix.metadata"]
    raise ValueError(f"Rejecting invalid path: {directive.path}")
Error: 401 Unauthorized - Token Expired
  • What causes it: The cached token expires mid-batch or the OAuth client lacks the knowledge:articles:write scope.
  • How to fix it: The CognigyAuthClient automatically refreshes tokens before expiry. Verify scope configuration in the tenant security settings.
# Token refresh logic already implemented in get_access_token()
# Ensure scope string contains exact required permissions
Error: 429 Too Many Requests - Rate Limit Cascade
  • What causes it: Exceeding Cognigy.AI API rate limits during rapid batch submissions or concurrent index rebuild polling.
  • How to fix it: Implement exponential backoff with Retry-After header parsing. The execute_batch_patch method handles this automatically.
Error: 500 Internal Server Error - Index Rebuild Failure
  • What causes it: Corrupted content matrix structure triggers parser exceptions during index recalculation.
  • How to fix it: Run the broken link and format drift verification pipeline before submission. Isolate failing articles and retry individually.
validation = await updater.verify_article_integrity(chunk_articles)
    logger.warning("Skipping invalid articles: %s", [v for v in validation if not v["valid"]])
