Batch Process Cognigy.AI Utterance Exports with a Go Worker Pool and NER Extraction
  • A Go application that triggers a Cognigy.AI utterance export, polls for completion, downloads the CSV payload, and processes it through a concurrent worker pool.
  • Each worker applies regex-based Named Entity Recognition (NER) to extract structured data from raw utterances, appends the results to the dataset, and uploads the enriched CSV back to the training API with version control tags.
  • The implementation uses the NICE CXone Bot API, standard library net/http, encoding/csv, regexp, and golang.org/x/sync/errgroup for production-grade concurrency.
  • OAuth 2.0 Client Credentials grant configured in CXone with scopes: bot:export:read, bot:import:write
  • CXone API base URL (e.g., https://{region}.nicecxone.com) and a valid Bot ID
  • Go 1.21 or later
  • External dependency: golang.org/x/sync/errgroup
  • Standard library packages: context, crypto/rand, encoding/csv, encoding/json, fmt, io, mime/multipart, net/http, os, regexp, strings, sync, time
CXone uses standard OAuth 2.0 Client Credentials flow. Tokens expire after one hour. You must cache the token and refresh it before expiration to avoid 401 interruptions during batch processing.
package main
import (
	"context"
	"encoding/json"
	"fmt"
	"net/http"
	"sync"
	"time"
type OAuthConfig struct {
	BaseURL      string
	ClientID     string
	ClientSecret string
type OAuthToken struct {
	AccessToken string    `json:"access_token"`
	ExpiresIn   int       `json:"expires_in"`
	ExpiresAt   time.Time
type TokenCache struct {
	mu   sync.RWMutex
	token *OAuthToken
func (c *TokenCache) Get(ctx context.Context, cfg OAuthConfig) (string, error) {
	c.mu.RLock()
	if c.token != nil && time.Now().Before(c.token.ExpiresAt) {
		accessToken := c.token.AccessToken
		c.mu.RUnlock()
		return accessToken, nil
	c.mu.RUnlock()
	c.mu.Lock()
	defer c.mu.Unlock()
		return c.token.AccessToken, nil
	token, err := fetchToken(ctx, cfg)
	if err != nil {
		return "", fmt.Errorf("oauth token fetch failed: %w", err)
	c.token = token
	return token.AccessToken, nil
func fetchToken(ctx context.Context, cfg OAuthConfig) (*OAuthToken, error) {
	payload := map[string]string{
		"client_id":     cfg.ClientID,
		"client_secret": cfg.ClientSecret,
		"grant_type":    "client_credentials",
		"scope":         "bot:export:read bot:import:write",
	body := &strings.Builder{}
	for k, v := range payload {
		if body.Len() > 0 {
			body.WriteString("&")
		body.WriteString(fmt.Sprintf("%s=%s", k, v))
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, cfg.BaseURL+"/oauth/token", strings.NewReader(body.String()))
	if err != nil {
		return nil, err
	resp, err := client.Do(req)
	if err != nil {
		return nil, err
	defer resp.Body.Close()
		return nil, fmt.Errorf("oauth failed with status %d", resp.StatusCode)
	var token OAuthToken
	if err := json.NewDecoder(resp.Body).Decode(&token); err != nil {
		return nil, err
	token.ExpiresAt = time.Now().Add(time.Duration(token.ExpiresIn) * time.Second)
	return &token, nil
The cache uses a double-checked locking pattern to prevent redundant token requests under concurrent load. The expiration buffer is implicit in the time.Now().Before(c.token.ExpiresAt) check. You should always request tokens before they expire rather than after.
Step 1: Trigger Export and Poll for Completion
The CXone export endpoint is asynchronous. You submit a request, receive a job ID, and poll until the status changes to completed. The response includes a signed downloadUrl for the CSV payload.
type ExportJob struct {
	ID          string `json:"id"`
	Status      string `json:"status"`
	DownloadURL string `json:"downloadUrl"`
func triggerExport(ctx context.Context, baseURL, botID, token string) (string, error) {
	payload := map[string]string{"name": "batch_ner_export", "format": "csv"}
	body, err := json.Marshal(payload)
	if err != nil {
		return "", err
	url := fmt.Sprintf("%s/api/v2/bots/%s/exports", baseURL, botID)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, bytes.NewReader(body))
	if err != nil {
		return "", err
	resp, err := http.DefaultClient.Do(req)
	if err != nil {
		return "", err
	if resp.StatusCode != http.StatusCreated {
		return "", fmt.Errorf("export trigger failed: %d", resp.StatusCode)
	var job ExportJob
	if err := json.NewDecoder(resp.Body).Decode(&job); err != nil {
		return "", err
	// Poll until completed
	ticker := time.NewTicker(5 * time.Second)
	defer ticker.Stop()
	for {
		select {
		case <-ctx.Done():
			return "", ctx.Err()
		case <-ticker.C:
			pollReq, _ := http.NewRequestWithContext(ctx, http.MethodGet, fmt.Sprintf("%s/api/v2/bots/%s/exports/%s", baseURL, botID, job.ID), nil)
			pollReq.Header.Set("Authorization", "Bearer "+token)
			pollResp, err := http.DefaultClient.Do(pollReq)
			if err != nil {
			defer pollResp.Body.Close()
			var updated ExportJob
			json.NewDecoder(pollResp.Body).Decode(&updated)
			if updated.Status == "completed" {
				return updated.DownloadURL, nil
			if updated.Status == "failed" {
				return "", fmt.Errorf("export job failed")
The polling loop respects context cancellation. CXone export jobs can take several minutes depending on dataset size. The 5-second interval balances API load with responsiveness. You must handle downloadUrl expiration; signed URLs typically remain valid for 15 minutes.
Step 2: Download Segments and Initialize Worker Pool
Large utterance exports exceed single-request memory limits. You download the CSV, parse headers, and split rows into fixed-size chunks. The worker pool consumes these chunks concurrently.
type UtteranceRow struct {
	Headers []string
	Values  []string
func downloadAndChunkCSV(ctx context.Context, downloadURL string, chunkSize int) (chan []UtteranceRow, error) {
	req, err := http.NewRequestWithContext(ctx, http.MethodGet, downloadURL, nil)
	if err != nil {
		return nil, err
	if err != nil {
		return nil, err
		return nil, fmt.Errorf("csv download failed: %d", resp.StatusCode)
	reader := csv.NewReader(resp.Body)
	headers, err := reader.Read()
	if err != nil {
		return nil, err
	output := make(chan []UtteranceRow, 10)
	go func() {
		defer close(output)
		var chunk []UtteranceRow
		for {
			select {
			case <-ctx.Done():
				return
			default:
				record, err := reader.Read()
				if err == io.EOF {
					if len(chunk) > 0 {
						output <- chunk
					return
				if err != nil {
					return
				row := UtteranceRow{Headers: headers, Values: record}
				chunk = append(chunk, row)
				if len(chunk) >= chunkSize {
					output <- chunk
					chunk = nil
	return output, nil
The channel-based design decouples download I/O from CPU-bound regex processing. The chunkSize parameter controls memory pressure. Values between 500 and 2000 rows per chunk yield optimal throughput for standard CXone export sizes.
Step 3: Execute NER Regex Extraction Concurrently
NER extraction in this context means identifying structured data patterns (dates, phone numbers, emails, ticket IDs) and appending them as new columns. You compile regex patterns once and reuse them across workers to avoid recompilation overhead.
var (
	dateRegex   = regexp.MustCompile(`\b\d{1,2}[\/\-]\d{1,2}[\/\-]\d{2,4}\b`)
	phoneRegex  = regexp.MustCompile(`\b\d{3}[-.\s]?\d{3}[-.\s]?\d{4}\b`)
	emailRegex  = regexp.MustCompile(`[a-zA-Z0-9._%+-]+@[a-zA-Z0-9.-]+\.[a-zA-Z]{2,}`)
	ticketRegex = regexp.MustCompile(`\b[TICKET-]\d{4,}\b`)
func processChunk(ctx context.Context, chunk []UtteranceRow) ([]UtteranceRow, error) {
	var errGroup errgroup.Group
	results := make([][]UtteranceRow, len(chunk))
	for i, row := range chunk {
		i := i
		row := row
		errGroup.Go(func() error {
			// Locate utterance column index (case-insensitive)
			utteranceIdx := -1
			for idx, h := range row.Headers {
				if strings.EqualFold(h, "utterance") || strings.EqualFold(h, "text") {
					utteranceIdx = idx
					break
			if utteranceIdx == -1 || utteranceIdx >= len(row.Values) {
				return fmt.Errorf("missing utterance column in row %d", i)
			text := row.Values[utteranceIdx]
			dates := dateRegex.FindAllString(text, -1)
			phones := phoneRegex.FindAllString(text, -1)
			emails := emailRegex.FindAllString(text, -1)
			tickets := ticketRegex.FindAllString(text, -1)
			// Append new entity columns
			row.Headers = append(row.Headers, "ner_dates", "ner_phones", "ner_emails", "ner_tickets")
			row.Values = append(row.Values,
				strings.Join(dates, ";"),
				strings.Join(phones, ";"),
				strings.Join(emails, ";"),
				strings.Join(tickets, ";"),
			results[i] = []UtteranceRow{row}
			return nil
	if err := errGroup.Wait(); err != nil {
		return nil, err
	// Flatten results
	var flattened []UtteranceRow
	for _, r := range results {
		flattened = append(flattened, r...)
	return flattened, nil
The errgroup ensures that if any worker fails, the entire batch operation aborts cleanly. You must locate the utterance column dynamically because CXone export formats may vary slightly across bot versions. The regex patterns are compiled at package initialization to eliminate per-call overhead.
Step 4: Upload Enriched Dataset with Version Tags
CXone accepts enriched training data via multipart form upload. The import creates a new training version. You embed version control tags directly in the name field and attach metadata for traceability.
func uploadEnrichedData(ctx context.Context, baseURL, botID, token, versionTag string, rows []UtteranceRow) error {
	var buf bytes.Buffer
	writer := multipart.NewWriter(&buf)
	// Write metadata
	if err := writer.WriteField("name", fmt.Sprintf("enriched_ner_%s_%s", versionTag, time.Now().Format("20060102_150405"))); err != nil {
		return err
	if err := writer.WriteField("description", fmt.Sprintf("Automated NER enrichment batch %s", versionTag)); err != nil {
		return err
	// Write CSV file
	part, err := writer.CreateFormFile("file", "enriched_utterances.csv")
	if err != nil {
		return err
	w := csv.NewWriter(part)
	if len(rows) == 0 {
		return fmt.Errorf("no rows to upload")
	if err := w.Write(rows[0].Headers); err != nil {
		return err
	for _, r := range rows {
		if err := w.Write(r.Values); err != nil {
			return err
	w.Flush()
	writer.Close()
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v2/bots/%s/imports", baseURL, botID), &buf)
	if err != nil {
		return err
	req.Header.Set("Content-Type", writer.FormDataContentType())
	if err != nil {
		return err
	if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
		return fmt.Errorf("import failed: %d %s", resp.StatusCode, string(body))
	return nil
The multipart writer buffers the entire enriched dataset in memory before transmission. For datasets exceeding 50 MB, you should stream directly to the request body using io.Pipe. The version tag follows ISO 8601 formatting to ensure chronological sorting in the CXone admin console.
package main
import (
	"bytes"
	"context"
	"encoding/csv"
	"encoding/json"
	"fmt"
	"io"
	"mime/multipart"
	"net/http"
	"os"
	"regexp"
	"strings"
	"sync"
	"time"
	"golang.org/x/sync/errgroup"
	BaseURL      string
	ClientID     string
	ClientSecret string
	ExpiresAt   time.Time
	mu   sync.RWMutex
	token *OAuthToken
	c.mu.RLock()
		c.mu.RUnlock()
	c.mu.RUnlock()
	c.mu.Lock()
	defer c.mu.Unlock()
	if err != nil {
	c.token = token
		if body.Len() > 0 {
	if err != nil {
		return nil, err
	if err != nil {
		return nil, err
		return nil, err
	return &token, nil
	Headers []string
	Values  []string
var (
	if err != nil {
		return "", err
	if err != nil {
		return "", err
	if err != nil {
		return "", err
	var job ExportJob
		return "", err
	defer ticker.Stop()
	for {
		select {
		case <-ctx.Done():
		case <-ticker.C:
			if err != nil {
	if err != nil {
		return nil, err
	if err != nil {
		return nil, err
	if err != nil {
		return nil, err
	go func() {
		defer close(output)
		for {
			select {
			case <-ctx.Done():
				return
			default:
				if err == io.EOF {
					if len(chunk) > 0 {
						output <- chunk
					return
				if err != nil {
					return
					output <- chunk
					chunk = nil
	return output, nil
		i := i
		row := row
			utteranceIdx := -1
					utteranceIdx = idx
					break
			return nil
		return nil, err
		return err
		return err
	if err != nil {
		return err
	if len(rows) == 0 {
		return err
			return err
	w.Flush()
	writer.Close()
	if err != nil {
		return err
	if err != nil {
		return err
	return nil
func main() {
	ctx := context.Background()
	cfg := OAuthConfig{
		BaseURL:      os.Getenv("CXONE_BASE_URL"),
		ClientID:     os.Getenv("CXONE_CLIENT_ID"),
		ClientSecret: os.Getenv("CXONE_CLIENT_SECRET"),
	botID := os.Getenv("CXONE_BOT_ID")
	versionTag := os.Getenv("VERSION_TAG")
	if cfg.BaseURL == "" || cfg.ClientID == "" || cfg.ClientSecret == "" || botID == "" {
		fmt.Println("Missing required environment variables")
		os.Exit(1)
	cache := &TokenCache{}
	token, err := cache.Get(ctx, cfg)
	if err != nil {
		fmt.Printf("Authentication failed: %v\n", err)
		os.Exit(1)
	downloadURL, err := triggerExport(ctx, cfg.BaseURL, botID, token)
	if err != nil {
		fmt.Printf("Export failed: %v\n", err)
		os.Exit(1)
	chunks, err := downloadAndChunkCSV(ctx, downloadURL, 1000)
	if err != nil {
		fmt.Printf("Download failed: %v\n", err)
		os.Exit(1)
	var allRows []UtteranceRow
	for chunk := range chunks {
		processed, err := processChunk(ctx, chunk)
		if err != nil {
			fmt.Printf("Processing failed: %v\n", err)
			os.Exit(1)
		allRows = append(allRows, processed...)
	if err := uploadEnrichedData(ctx, cfg.BaseURL, botID, token, versionTag, allRows); err != nil {
		fmt.Printf("Upload failed: %v\n", err)
		os.Exit(1)
	fmt.Println("Batch NER enrichment completed successfully")
  • Cause: The OAuth token expired during the export polling phase or CSV download.
  • Fix: Implement token refresh before each API call. The TokenCache.Get method checks expiration and fetches a new token automatically. Ensure your client credentials have not been rotated in CXone.
  • Code Fix: Replace static token usage with token, err := cache.Get(ctx, cfg) before every HTTP request.
  • Cause: CXone enforces strict rate limits on export polling and import endpoints. Concurrent requests from multiple workers or rapid polling trigger throttling.
  • Fix: Add exponential backoff with jitter to retry logic. The polling loop uses a fixed 5-second interval, which is safe. For upload retries, wrap the HTTP call in a retry function.
  • Code Fix:
func retryOnRateLimit(ctx context.Context, fn func() error) error {
	retries := 3
	for i := 0; i < retries; i++ {
		err := fn()
		if err == nil {
			return nil
		if strings.Contains(err.Error(), "429") || strings.Contains(err.Error(), "429") {
			backoff := time.Duration(1<<uint(i)) * time.Second * time.Duration(1+rand.Float64())
			time.Sleep(backoff)
		return err
	return fmt.Errorf("max retries exceeded")
Error: 400 Bad Request (Import Validation)
  • Cause: The enriched CSV contains mismatched column counts, missing required fields (intent, utterance), or unsupported characters in entity columns.
  • Fix: Validate row length consistency before upload. CXone requires the original columns to remain intact. The regex extraction appends columns, which is safe. Ensure semicolon separators in extracted arrays do not conflict with CSV delimiters by wrapping values in quotes.
  • Code Fix: The csv.Writer automatically handles quoting. Verify that row.Values length matches row.Headers length in every processed row.
Error: Context Deadline Exceeded
  • Cause: Large exports exceed the default HTTP client timeout or the polling loop runs indefinitely.
  • Fix: Attach a context with a reasonable timeout (e.g., 10 minutes for export, 5 minutes for download) and propagate it through all goroutines. The errgroup respects context cancellation and aborts workers cleanly.
