Batch NICE Cognigy.AI Model Training Datasets with Python
This script constructs, validates, and uploads batched training datasets to the Cognigy.AI platform using atomic HTTP POST operations with automatic upload triggers. It uses the Cognigy.AI REST API v2 with httpx and pydantic for schema enforcement and telemetry tracking. The implementation is written in Python 3.9+ and handles JSONL formatting, checksum verification, class imbalance detection, and webhook synchronization for external ML pipeline alignment.
  • OAuth Client: Confidential client registered in Cognigy.AI with ai:datasets:write, ai:packages:upload, ai:training:execute, and ai:webhooks:manage scopes
  • API Version: Cognigy.AI API v2
  • Runtime: Python 3.9+
  • External Dependencies: httpx>=0.24.0, pydantic>=2.0.0, tenacity>=8.2.0, structlog>=23.1.0
Cognigy.AI uses standard OAuth 2.0 client credentials flow. The following implementation caches tokens and refreshes automatically when expiration approaches. Token caching reduces authentication latency and prevents unnecessary credential exchanges during batch iteration.
import httpx
from dataclasses import dataclass
from typing import Optional
@dataclass
class OAuthToken:
    access_token: str
    token_type: str
    expires_in: int
    created_at: float
class CognigyAuthManager:
    def __init__(self, client_id: str, client_secret: str, base_url: str):
        self.client_id = client_id
        self.token_endpoint = f"{base_url}/oauth/token"
        self._token: Optional[OAuthToken] = None
        self._client = httpx.Client(timeout=15.0)
        if self._token and not self._is_expired():
            return self._token.access_token
        payload = {
            "client_id": self.client_id,
        response = self._client.post(self.token_endpoint, data=payload)
        response.raise_for_status()
        data = response.json()
        self._token = OAuthToken(
            access_token=data["access_token"],
            token_type=data["token_type"],
            expires_in=data["expires_in"],
            created_at=time.time()
    def _is_expired(self) -> bool:
        if not self._token:
            return True
        return time.time() >= (self._token.created_at + self._token.expires_in - 30)
Step 1: Construct Batching Payloads and Validate Schemas
Cognigy.AI requires training payloads to conform to strict structural rules. The batching payload must contain a dataset-ref identifier, a sample-matrix defining intent distribution, and a package directive controlling upload behavior. Schema validation prevents ingestion failures before network transmission.
import json
from pydantic import BaseModel, Field, field_validator
from typing import Dict, List
class SampleMatrix(BaseModel):
    intents: Dict[str, int] = Field(..., description="Intent to sample count mapping")
    max_samples_per_intent: int = Field(default=5000, le=10000)
    min_samples_per_intent: int = Field(default=50, ge=10)
    @field_validator("intents")
    def validate_class_distribution(cls, v: Dict[str, int]) -> Dict[str, int]:
        if not v:
            raise ValueError("Sample matrix must contain at least one intent")
        total = sum(v.values())
        if total == 0:
            raise ValueError("Sample matrix cannot contain zero total samples")
        return v
class PackageDirective(BaseModel):
    auto_trigger_training: bool = Field(default=True)
    overwrite_existing: bool = Field(default=False)
    compression: str = Field(default="gzip", pattern="^(gzip|none)$")
class BatchingPayload(BaseModel):
    dataset_ref: str = Field(..., pattern="^[a-zA-Z0-9_-]+$")
    sample_matrix: SampleMatrix
    package_directive: PackageDirective
    metadata: Dict[str, str] = Field(default_factory=dict)
    def serialize(self) -> str:
        return json.dumps(self.model_dump(), indent=2)
The dataset-ref must match an existing dataset identifier in your Cognigy.AI tenant. The sample-matrix enforces intent distribution boundaries. The package directive controls whether the platform automatically initiates model retraining after ingestion. This structure aligns with Cognigy.AI’s ingestion pipeline expectations and prevents partial uploads.
Step 2: JSONL Formatting, Checksum Generation, and Validation Logic
Training data must be delivered in JSONL format with a verifiable checksum. The platform validates checksum integrity before unpacking. This step also implements class imbalance verification and size constraint enforcement to prevent ingestion errors during CXone scaling.
import hashlib
import gzip
import io
from typing import Generator, Tuple
class DatasetBatcher:
    MAX_PAYLOAD_SIZE_BYTES = 50 * 1024 * 1024  # 50 MB
    MAX_SAMPLES_PER_BATCH = 10000
    MIN_CLASS_RATIO = 0.05  # 5% minimum per intent
    def __init__(self, payload: BatchingPayload):
        self.payload = payload
        self._jsonl_buffer: List[str] = []
        self._checksum: str = ""
    def add_samples(self, samples: List[Dict[str, any]]) -> None:
        current_count = sum(self.payload.sample_matrix.intents.values())
        if current_count + len(samples) > self.MAX_SAMPLES_PER_BATCH:
            raise ValueError(
                f"Batch exceeds maximum sample limit of {self.MAX_SAMPLES_PER_BATCH}"
        for sample in samples:
            if "intent" not in sample or "utterance" not in sample:
                raise ValueError("Malformed entry: missing intent or utterance field")
            intent = sample["intent"]
            if intent not in self.payload.sample_matrix.intents:
                raise ValueError(f"Intent {intent} not declared in sample matrix")
            self._jsonl_buffer.append(json.dumps(sample, ensure_ascii=False))
    def verify_class_balance(self) -> None:
        intent_counts: Dict[str, int] = {}
        for line in self._jsonl_buffer:
            entry = json.loads(line)
            intent_counts[entry["intent"]] = intent_counts.get(entry["intent"], 0) + 1
        total = sum(intent_counts.values())
        for intent, count in intent_counts.items():
            ratio = count / total if total > 0 else 0
            if ratio < self.MIN_CLASS_RATIO:
                raise ValueError(
                    f"Class imbalance detected: intent {intent} has {ratio:.2%} "
                    f"of total samples. Minimum threshold is {self.MIN_CLASS_RATIO:.2%}"
    def generate_package(self) -> Tuple[bytes, str]:
        if not self._jsonl_buffer:
            raise ValueError("Cannot generate empty package")
        self.verify_class_balance()
        jsonl_content = "\n".join(self._jsonl_buffer) + "\n"
        jsonl_bytes = jsonl_content.encode("utf-8")
        if self.payload.package_directive.compression == "gzip":
            buffer = io.BytesIO()
            with gzip.GzipFile(fileobj=buffer, mode="wb") as gz:
                gz.write(jsonl_bytes)
            package_bytes = buffer.getvalue()
        else:
            package_bytes = jsonl_bytes
        if len(package_bytes) > self.MAX_PAYLOAD_SIZE_BYTES:
            raise ValueError(
                f"Package exceeds size limit of {self.MAX_PAYLOAD_SIZE_BYTES} bytes"
        self._checksum = hashlib.sha256(package_bytes).hexdigest()
        return package_bytes, self._checksum
The verify_class_balance method prevents skewed training distributions that degrade NLU accuracy. The checksum calculation uses SHA-256 over the final compressed or uncompressed payload. Cognigy.AI compares this checksum against the x-cognigy-checksum header during ingestion.
Step 3: Atomic HTTP POST with Format Verification and Upload Triggers
Atomic uploads require strict header formatting and synchronous verification. The following implementation sends the payload with format verification headers and handles platform responses deterministically.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import httpx
import structlog
class CognigyBatchUploader:
    def __init__(self, auth: CognigyAuthManager, base_url: str):
        self.auth = auth
        self.base_url = base_url
        self.client = httpx.Client(timeout=httpx.Timeout(30.0, connect=10.0))
    @retry(
        stop=stop_after_attempt(3),
        wait=wait_exponential(multiplier=1, min=2, max=10),
        retry=retry_if_exception_type(httpx.HTTPStatusError)
    def upload_package(
        self,
        batcher: DatasetBatcher,
        package_bytes: bytes,
        checksum: str
    ) -> dict:
        token = self.auth.get_access_token()
        payload_json = batcher.payload.serialize()
        headers = {
            "X-Cognigy-Checksum": checksum,
            "X-Cognigy-Format": "jsonl",
            "X-Cognigy-Package-Type": "training-dataset"
        url = f"{self.base_url}/api/v2/ai/packages/upload"
        files = {
            "metadata": (None, payload_json, "application/json"),
            "package": ("training_batch.jsonl.gz", package_bytes,
                       "application/gzip" if batcher.payload.package_directive.compression == "gzip"
                       else "application/x-ndjson")
        response = self.client.post(url, headers=headers, files=files)
        result = response.json()
        logger.info(
            "package_uploaded",
            dataset_ref=batcher.payload.dataset_ref,
            package_id=result.get("packageId"),
            sample_count=sum(batcher.payload.sample_matrix.intents.values()),
            checksum=checksum
        return result
The multipart form data structure separates metadata from the binary package. Cognigy.AI parses the metadata field first to validate the dataset-ref and sample-matrix before streaming the binary payload. The X-Cognigy-Checksum header enables early rejection of corrupted transfers.
Step 4: Webhook Synchronization, Latency Tracking, and Audit Logging
External ML pipelines require deterministic event synchronization. The following implementation registers dataset packaged webhooks, tracks batching latency, and generates governance-compliant audit logs.
from typing import List
class BatchTelemetryManager:
        self.auth = auth
        self.client = httpx.Client(timeout=15.0)
        self._latency_log: List[float] = []
        self._success_count: int = 0
        self._failure_count: int = 0
    def register_webhook(self, dataset_ref: str, webhook_url: str) -> dict:
        payload = {
            "datasetRef": dataset_ref,
            "events": ["DATASET_PACKAGED", "TRAINING_STARTED", "TRAINING_COMPLETED"],
            "endpoint": webhook_url,
            "secret": "cognigy_audit_webhook_secret",
            "active": True
        url = f"{self.base_url}/api/v2/ai/webhooks"
        headers = {
        response = self.client.post(url, headers=headers, json=payload)
        return response.json()
    def record_success(self, latency_seconds: float) -> None:
        self._latency_log.append(latency_seconds)
        self._success_count += 1
    def record_failure(self) -> None:
        self._failure_count += 1
    def get_metrics(self) -> dict:
        total = self._success_count + self._failure_count
        avg_latency = sum(self._latency_log) / len(self._latency_log) if self._latency_log else 0.0
        success_rate = self._success_count / total if total > 0 else 0.0
            "total_batches": total,
            "success_count": self._success_count,
            "failure_count": self._failure_count,
            "success_rate": success_rate,
            "average_latency_seconds": avg_latency,
            "timestamp": datetime.now(timezone.utc).isoformat()
    def generate_audit_log(self, dataset_ref: str, checksum: str, status: str) -> dict:
            "event_type": "BATCH_UPLOAD",
            "dataset_ref": dataset_ref,
            "checksum": checksum,
            "status": status,
            "governance_tag": "nlu_training_audit",
            "pipeline_sync": True
The telemetry manager tracks latency across batch iterations and calculates success rates for capacity planning. The audit log structure satisfies NLU governance requirements by recording checksums, timestamps, and pipeline synchronization flags. Webhook registration ensures external ML systems receive deterministic event notifications.
import httpx
def run_batch_pipeline(
    client_id: str,
    client_secret: str,
    base_url: str,
    dataset_ref: str,
    webhook_url: str,
    training_samples: List[Dict[str, any]]
) -> dict:
    auth = CognigyAuthManager(client_id, client_secret, base_url)
    telemetry = BatchTelemetryManager(auth, base_url)
    uploader = CognigyBatchUploader(auth, base_url)
    payload = BatchingPayload(
        dataset_ref=dataset_ref,
        sample_matrix=SampleMatrix(
            intents={"book_flight": 1000, "cancel_reservation": 800, "change_date": 700},
            max_samples_per_intent=5000,
            min_samples_per_intent=50
        package_directive=PackageDirective(
            auto_trigger_training=True,
            overwrite_existing=False,
            compression="gzip"
        metadata={"source": "automated_pipeline", "version": "1.2.0"}
    batcher = DatasetBatcher(payload)
        batcher.add_samples(training_samples)
        package_bytes, checksum = batcher.generate_package()
        telemetry.register_webhook(dataset_ref, webhook_url)
        start_time = time.time()
        result = uploader.upload_package(batcher, package_bytes, checksum)
        latency = time.time() - start_time
        telemetry.record_success(latency)
        audit_entry = telemetry.generate_audit_log(dataset_ref, checksum, "SUCCESS")
            "upload_result": result,
            "telemetry": telemetry.get_metrics(),
            "audit_log": audit_entry,
        telemetry.record_failure()
        audit_entry = telemetry.generate_audit_log(dataset_ref, "", f"FAILURE:{str(e)}")
            "error": str(e),
    SAMPLES = [
        {"intent": "book_flight", "utterance": "I need a ticket to London", "entities": [{"type": "city", "value": "London"}]},
        {"intent": "cancel_reservation", "utterance": "Please cancel my booking for tomorrow", "entities": []},
        {"intent": "change_date", "utterance": "Move my flight to next Friday", "entities": [{"type": "date", "value": "2024-01-15"}]}
    result = run_batch_pipeline(
        client_id="YOUR_CLIENT_ID",
        client_secret="YOUR_CLIENT_SECRET",
        base_url="https://your-tenant.cognigy.ai",
        dataset_ref="nlu_production_v2",
        webhook_url="https://your-ml-pipeline.example.com/webhooks/cognigy",
        training_samples=SAMPLES * 100
    print(result)
Error: 400 Bad Request (Schema Validation Failure)
This occurs when the dataset-ref does not exist in the tenant, the sample-matrix contains undeclared intents, or the multipart metadata structure is malformed. Verify that the dataset identifier matches an active dataset in Cognigy.AI. Ensure the sample-matrix.intents dictionary exactly matches the intent keys present in the JSONL payload.
# Fix: Validate dataset existence before batching
def verify_dataset_exists(auth: CognigyAuthManager, base_url: str, dataset_ref: str) -> bool:
    token = auth.get_access_token()
    url = f"{base_url}/api/v2/ai/datasets/{dataset_ref}"
    response = httpx.get(url, headers={"Authorization": f"Bearer {token}"})
    return response.status_code == 200
Error: 413 Payload Too Large
Cognigy.AI enforces a 50 MB limit per package upload. This triggers when JSONL content exceeds compression thresholds or when batch iteration accumulates too many samples. Reduce the sample count per batch or switch to uncompressed JSONL if compression overhead increases payload size.
Rate limiting activates when concurrent batch uploads exceed tenant quotas. The tenacity retry decorator implements exponential backoff. If failures persist, implement batch queuing with a maximum concurrency of three parallel uploads.
Error: Checksum Mismatch Rejection
The platform rejects packages when the X-Cognigy-Checksum header does not match the computed SHA-256 of the transmitted bytes. This typically occurs when the compression stream is not fully flushed before checksum calculation. Ensure GzipFile context managers close properly before hashing.
