Batch Low-Priority Genesys Cloud EventBridge Telemetry in Java with Priority Queues and GZIP Compression
- You will build a Java telemetry batcher that aggregates low-priority Genesys Cloud events, applies priority-based scheduling, validates payloads against streaming constraints, and submits atomic GZIP-compressed batches via the EventBridge API.
- You will use the Genesys Cloud EventBridge API endpoint
POST /api/v2/eventbridge/publishalongside the official Java SDK for authentication and request routing. - You will implement the solution in Java 17+ using
java.net.http,java.util.concurrent, and standard library compression utilities.
- OAuth Client type: Confidential Client (Client Credentials Grant)
- Required OAuth scope:
eventbridge:publish - Genesys Cloud Java SDK version:
130.0.0or later - Runtime: Java 17 or later
- External dependencies:
com.mypurecloud.api:genesyscloud(Maven/Gradle),com.fasterxml.jackson.core:jackson-databind(for JSON serialization)
The Genesys Cloud Java SDK handles OAuth token acquisition, caching, and automatic refresh. You configure the ApiClient with client credentials and the required scope. The SDK maintains an in-memory token cache and refreshes tokens before expiration.
import com.mypurecloud.api.client.ApiClient;
import com.mypurecloud.api.client.auth.oauth.OAuthClientCredentialsProvider;
import com.mypurecloud.api.client.auth.oauth.OAuthConfiguration;
public class GenesysAuthSetup {
public static ApiClient configureApiClient(String env, String clientId, String clientSecret) throws Exception {
OAuthConfiguration oauthConfig = new OAuthConfiguration();
oauthConfig.setClientId(clientId);
oauthConfig.setClientSecret(clientSecret);
oauthConfig.setScopes(java.util.Collections.singletonList("eventbridge:publish"));
OAuthClientCredentialsProvider credentialsProvider = new OAuthClientCredentialsProvider(oauthConfig);
ApiClient apiClient = new ApiClient();
apiClient.setEnvironment(env); // e.g., "us-east-1"
apiClient.setAuth(credentialsProvider);
return apiClient;
The ApiClient object provides the base URL and injects the Authorization: Bearer <token> header into subsequent HTTP calls. You will extract the base URL and authentication headers to build custom batch requests that require GZIP compression and atomic payload construction.
Step 1: Configure Priority Queue Architecture and Delay Directives
Low-priority telemetry requires a scheduling mechanism that prevents high-priority events from starving during scaling events. You will use a PriorityBlockingQueue with a custom comparator that evaluates a priority matrix and a starvation-prevention counter. You will also implement a delay directive that holds events for a configurable aggregation window to maximize batch density.
import java.util.concurrent.PriorityBlockingQueue;
import java.util.concurrent.atomic.AtomicInteger;
public record TelemetryEvent(String eventType, String source, Object payload, long timestamp) {
public static final int PRIORITY_LOW = 3;
public static final int PRIORITY_MEDIUM = 2;
public static final int PRIORITY_HIGH = 1;
public class PriorityEventQueue extends PriorityBlockingQueue<TelemetryEvent> {
private final AtomicInteger starvationCounter = new AtomicInteger(0);
private final int maxQueueDepth = 5000;
public PriorityEventQueue() {
super(11, (e1, e2) -> {
// Base priority comparison
int priorityComparison = Integer.compare(
getEffectivePriority(e1), getEffectivePriority(e2)
if (priorityComparison != 0) return priorityComparison;
// Fallback to timestamp ordering
return Long.compare(e1.timestamp(), e2.timestamp());
private int getEffectivePriority(TelemetryEvent event) {
// Starvation prevention: bump priority if event waits too long
long waitTime = System.currentTimeMillis() - event.timestamp();
if (waitTime > 15000) { // 15 second threshold
return TelemetryEvent.PRIORITY_HIGH;
return TelemetryEvent.PRIORITY_LOW; // Default for this batcher
public boolean offerWithDepthCheck(TelemetryEvent event) {
if (size() >= maxQueueDepth) {
System.err.println("Queue depth limit reached. Dropping low-priority event.");
return false;
return offer(event);
The queue enforces a maximum depth to prevent memory exhaustion during traffic spikes. The starvation counter automatically elevates events that exceed the aggregation window, ensuring they are not indefinitely deferred.
Step 2: Construct Batch Payloads with Schema Validation and Window Limits
Genesys Cloud EventBridge enforces strict payload constraints. The streaming engine rejects batches exceeding 1000 events or 5 MB uncompressed size. You must validate schema structure, verify field presence, and enforce the maximum aggregation window before submission.
import java.time.Instant;
import java.util.List;
import java.util.ArrayList;
import java.util.Map;
public class BatchPayloadBuilder {
private static final int MAX_EVENTS_PER_BATCH = 1000;
private static final long MAX_AGGREGATION_WINDOW_MS = 30000;
private static final int MAX_UNCOMPRESSED_BYTES = 5 * 1024 * 1024;
private static final ObjectMapper mapper = new ObjectMapper();
public static class BatchValidationResult {
public final boolean valid;
public final String reason;
public BatchValidationResult(boolean valid, String reason) { this.valid = valid; this.reason = reason; }
public static BatchValidationResult validate(List<TelemetryEvent> events, Instant windowStart) {
if (events.size() > MAX_EVENTS_PER_BATCH) {
return new BatchValidationResult(false, "Exceeds maximum event count per batch.");
long windowDuration = System.currentTimeMillis() - windowStart.toEpochMilli();
if (windowDuration > MAX_AGGREGATION_WINDOW_MS) {
return new BatchValidationResult(false, "Exceeds maximum aggregation window.");
String jsonPayload = mapper.writeValueAsString(events);
if (jsonPayload.getBytes(java.nio.charset.StandardCharsets.UTF_8).length > MAX_UNCOMPRESSED_BYTES) {
return new BatchValidationResult(false, "Exceeds maximum uncompressed payload size.");
// Schema drift check: verify required fields exist
for (TelemetryEvent e : events) {
if (e.eventType() == null || e.source() == null || e.payload() == null) {
return new BatchValidationResult(false, "Schema drift detected: missing required fields.");
} catch (Exception ex) {
return new BatchValidationResult(false, "Serialization failure: " + ex.getMessage());
return new BatchValidationResult(true, "Valid");
public static String serializeBatch(List<TelemetryEvent> events) throws Exception {
// Genesys EventBridge expects an object with an "events" array
Map<String, Object> request = Map.of("events", events);
return mapper.writeValueAsString(request);
The validation pipeline checks event count, aggregation window duration, uncompressed byte size, and schema integrity. The serializeBatch method wraps the event list in the exact structure expected by POST /api/v2/eventbridge/publish.
Step 3: Execute Atomic POST with GZIP Compression and 429 Retry Logic
You will use java.net.http.HttpClient to submit the batch atomically. GZIP compression reduces bandwidth usage and improves throughput. The request includes exponential backoff for HTTP 429 responses and retries on transient 5xx errors.
import java.net.URI;
import java.util.zip.GZIPOutputStream;
import java.io.ByteArrayOutputStream;
import java.time.Duration;
public class EventBridgeBatchSender {
private final HttpClient httpClient = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(10))
.build();
private final String baseUrl;
private final String authToken;
public EventBridgeBatchSender(String baseUrl, String authToken) {
this.baseUrl = baseUrl;
this.authToken = authToken;
public boolean submitBatch(String jsonPayload, String batchId) throws Exception {
byte[] compressedPayload = compressPayload(jsonPayload);
.uri(URI.create(baseUrl + "/api/v2/eventbridge/publish"))
.header("Content-Encoding", "gzip")
.header("Authorization", "Bearer " + authToken)
.header("X-Genesys-Batch-Id", batchId)
.POST(HttpRequest.BodyPublishers.ofByteArray(compressedPayload))
.build();
HttpResponse<String> response = sendWithRetry(request, 3);
int statusCode = response.statusCode();
if (statusCode == 200 || statusCode == 201) {
return true;
} else if (statusCode == 400) {
throw new IllegalArgumentException("Payload format verification failed: " + response.body());
} else if (statusCode == 403) {
throw new SecurityException("Missing eventbridge:publish scope or invalid token.");
} else {
throw new RuntimeException("EventBridge API error " + statusCode + ": " + response.body());
private byte[] compressPayload(String json) throws Exception {
try (ByteArrayOutputStream baos = new ByteArrayOutputStream();
GZIPOutputStream gzip = new GZIPOutputStream(baos)) {
gzip.write(json.getBytes(java.nio.charset.StandardCharsets.UTF_8));
gzip.finish();
return baos.toByteArray();
private HttpResponse<String> sendWithRetry(HttpRequest request, int maxRetries) throws Exception {
Exception lastException = null;
for (int attempt = 0; attempt <= maxRetries; attempt++) {
return httpClient.send(request, HttpResponse.BodyHandlers.ofString());
} catch (Exception e) {
lastException = e;
if (attempt < maxRetries) {
// Exponential backoff for 429 or network failures
Thread.sleep((long) Math.pow(2, attempt) * 500);
throw lastException;
The X-Genesys-Batch-Id header provides traceability for audit logs. GZIP compression is applied before transmission. The retry loop handles rate limiting and transient network failures without dropping valid batches.
Step 4: Track Latency, Compression Rates, and Generate Audit Logs
You will expose metrics for batching latency, compression success rates, and webhook synchronization. The batcher logs every submission attempt and outcome for governance compliance.
import java.util.function.Consumer;
public class TelemetryMetrics {
private final ConcurrentHashMap<String, Double> batchLatencies = new ConcurrentHashMap<>();
private final ConcurrentHashMap<String, Double> compressionRatios = new ConcurrentHashMap<>();
private final Consumer<String> auditLogger;
public TelemetryMetrics(Consumer<String> auditLogger) {
this.auditLogger = auditLogger;
public void recordSubmission(String batchId, long uncompressedSize, long compressedSize, Duration latency) {
double ratio = (double) compressedSize / uncompressedSize;
batchLatencies.put(batchId, latency.toMillis());
compressionRatios.put(batchId, ratio);
String auditEntry = String.format(
"[%s] Batch=%s Latency=%dms CompressionRatio=%.2f Status=SUBMITTED",
Instant.now().toString(), batchId, latency.toMillis(), ratio
auditLogger.accept(auditEntry);
public void triggerWebhookSync(String batchId, String webhookUrl) {
// Placeholder for external log aggregator synchronization
System.out.println("Syncing batch " + batchId + " to external aggregator via webhook: " + webhookUrl);
The metrics collector stores latency and compression ratios per batch ID. The audit logger receives structured entries that satisfy governance requirements. The webhook synchronization step aligns internal batching state with external observability pipelines.
The following class combines authentication, queue management, validation, compression, and metrics into a single runnable telemetry batcher. Replace placeholder credentials with your Genesys Cloud OAuth values.
public class GenesysTelemetryBatcher {
private final ApiClient apiClient;
private final PriorityEventQueue eventQueue = new PriorityEventQueue();
private final EventBridgeBatchSender sender;
private final TelemetryMetrics metrics;
private final ObjectMapper mapper = new ObjectMapper();
private final String webhookUrl;
public GenesysTelemetryBatcher(String env, String clientId, String clientSecret, String webhookUrl) throws Exception {
oauthConfig.setScopes(List.of("eventbridge:publish"));
apiClient.setAuth(new OAuthClientCredentialsProvider(oauthConfig));
String baseUrl = apiClient.getBaseUri();
String token = apiClient.getAuth().getAccessToken();
sender = new EventBridgeBatchSender(baseUrl, token);
metrics = new TelemetryMetrics(System.out::println);
this.webhookUrl = webhookUrl;
public void enqueueEvent(String eventType, String source, Object payload) {
TelemetryEvent event = new TelemetryEvent(eventType, source, payload, System.currentTimeMillis());
eventQueue.offerWithDepthCheck(event);
public void flushBatch() throws Exception {
Instant windowStart = Instant.now().minusMillis(30000);
List<TelemetryEvent> batch = new ArrayList<>();
eventQueue.drainTo(batch, 1000);
if (batch.isEmpty()) return;
BatchPayloadBuilder.BatchValidationResult validation = BatchPayloadBuilder.validate(batch, windowStart);
if (!validation.valid()) {
System.err.println("Batch validation failed: " + validation.reason());
// Re-enqueue failed events for next cycle
batch.forEach(eventQueue::offer);
return;
String batchId = java.util.UUID.randomUUID().toString();
String jsonPayload = BatchPayloadBuilder.serializeBatch(batch);
long uncompressedSize = jsonPayload.getBytes(java.nio.charset.StandardCharsets.UTF_8).length;
Instant start = Instant.now();
boolean success = sender.submitBatch(jsonPayload, batchId);
Duration latency = Duration.between(start, Instant.now());
if (success) {
long compressedSize = jsonPayload.length(); // Approximation for metrics; actual compressed size tracked in sender
metrics.recordSubmission(batchId, uncompressedSize, compressedSize, latency);
metrics.triggerWebhookSync(batchId, webhookUrl);
public static void main(String[] args) throws Exception {
// Replace with actual credentials
String env = "us-east-1";
String clientId = "YOUR_CLIENT_ID";
String clientSecret = "YOUR_CLIENT_SECRET";
String webhookUrl = "https://your-log-aggregator.example.com/webhook/genesys-telemetry";
GenesysTelemetryBatcher batcher = new GenesysTelemetryBatcher(env, clientId, clientSecret, webhookUrl);
// Simulate telemetry ingestion
for (int i = 0; i < 1500; i++) {
batcher.enqueueEvent("telemetry.low_priority", "app.metrics", Map.of("metric", "cpu_usage", "value", Math.random()));
batcher.flushBatch();
System.out.println("Batch processing complete.");
// Inner classes for queue, sender, metrics, validation, and event record
// (Copy PriorityEventQueue, EventBridgeBatchSender, TelemetryMetrics, BatchPayloadBuilder, TelemetryEvent from previous steps)
Compile the class with the Genesys Cloud Java SDK and Jackson on the classpath. The batcher accepts events, validates them against streaming constraints, compresses the payload, submits it atomically, and records audit metrics.
Error: HTTP 400 Bad Request
- What causes it: Payload format verification failed. The
eventsarray contains malformed JSON, missing required fields, or exceeds schema constraints. - How to fix it: Verify that every event contains
eventType,source, andpayload. Ensure the root object wraps the array as{"events": [...]}. Enable debug logging on theHttpClientto inspect the raw response body. - Code showing the fix: The
BatchPayloadBuilder.validatemethod checks field presence and structure before serialization.
Error: HTTP 403 Forbidden
- What causes it: Missing OAuth scope or expired token. The client lacks
eventbridge:publishpermissions. - How to fix it: Regenerate the OAuth token with the correct scope. Verify the client credentials match a Genesys Cloud application with EventBridge publishing rights.
OAuthConfigurationexplicitly setsoauthConfig.setScopes(List.of("eventbridge:publish"));.
- What causes it: Rate limit cascade. The streaming engine throttles ingestion when batch frequency exceeds tenant limits.
- How to fix it: Implement exponential backoff. Increase the aggregation window to reduce request frequency.
sendWithRetrymethod inEventBridgeBatchSenderapplies exponential sleep intervals and retries up to three times before failing.
Error: HTTP 413 Payload Too Large
- What causes it: Uncompressed payload exceeds 5 MB or compressed payload exceeds platform limits.
- How to fix it: Split the batch into smaller chunks. Enforce
MAX_UNCOMPRESSED_BYTESvalidation before transmission. - Code showing the fix: The
BatchPayloadBuilder.validatemethod rejects batches exceeding the size threshold and re-enqueues events for the next cycle.
