Batch Export NICE CXone Web Messaging History Using Java SDK
  • A Java utility that exports historical Web Messaging conversations in validated batches using cursor-based pagination.
  • Uses the NICE CXone Java SDK (nice-cxp-sdk-java) and the /api/v2/messages/queries/details endpoint.
  • Covers Java 17+ with production-grade error handling, compliance webhook synchronization, and structured audit logging.
  • OAuth 2.0 Client Credentials grant with scopes: messages:read, conversations:read, webhooks:write
  • CXone Java SDK v2.20.0+ (com.nice.cxp:cxone-api-client)
  • Java 17+ runtime
  • External dependencies: com.fasterxml.jackson.core:jackson-databind, org.slf4j:slf4j-api, com.google.guava:guava
NICE CXone uses OAuth 2.0 Client Credentials flow. The Java SDK handles token acquisition and automatic refresh when you initialize the ApiClient with your organization ID, client ID, and client secret. You must configure the base URL to match your CXone environment region.
import com.nice.cxp.client.ApiClient;
import com.nice.cxp.client.Configuration;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class CxoneAuthSetup {
    private static final Logger log = LoggerFactory.getLogger(CxoneAuthSetup.class);
    public static ApiClient initializeApiClient(String orgId, String clientId, String clientSecret, String basePath) {
        ApiClient client = new ApiClient();
        client.setBasePath(basePath);
        client.setAccessToken(orgId, clientId, clientSecret);
        // Configure automatic token refresh and timeout thresholds
        client.setConnectTimeout(10000);
        client.setReadTimeout(30000);
        log.info("CXone ApiClient initialized for org: {}", orgId);
        return client;
The SDK caches the bearer token in memory and automatically requests a new token before expiration. If you require explicit token caching across JVM restarts, implement a custom TokenStore and pass it to the ApiClient constructor.
Step 1: Batch Payload Construction and Schema Validation
CXone enforces strict constraints on historical message exports. The messaging engine limits query windows to 30 days and caps page sizes at 1000 records. You must validate your batch configuration before issuing HTTP requests to prevent 400 Bad Request responses from the platform.
The following record structures the batch payload, and the validation method enforces CXone engine constraints.
import java.time.Instant;
import java.util.List;
import java.util.UUID;
public record BatchExportConfig(
    List<UUID> conversationIds,
    Instant fromTimestamp,
    Instant toTimestamp,
    int pageSize,
    String cursor
public class BatchValidator {
    private static final int MAX_PAGE_SIZE = 1000;
    private static final int MAX_WINDOW_DAYS = 30;
    public static void validate(BatchExportConfig config) {
        if (config.conversationIds == null || config.conversationIds.isEmpty()) {
            throw new IllegalArgumentException("Conversation ID list cannot be null or empty");
        if (config.pageSize < 1 || config.pageSize > MAX_PAGE_SIZE) {
            throw new IllegalArgumentException("Page size must be between 1 and " + MAX_PAGE_SIZE);
        long windowSeconds = config.toTimestamp.getEpochSecond() - config.fromTimestamp.getEpochSecond();
        if (windowSeconds < 0 || windowSeconds > MAX_WINDOW_DAYS * 86400L) {
            throw new IllegalArgumentException("Export window exceeds maximum " + MAX_WINDOW_DAYS + " day limit");
        if (config.cursor != null && !config.cursor.matches("^[A-Za-z0-9+/=]+$")) {
            throw new IllegalArgumentException("Invalid pagination cursor format");
This validation prevents batching failures caused by oversized windows or malformed pagination tokens. CXone rejects queries that span beyond the retention policy or exceed the engine’s memory allocation for a single request.
Step 2: Atomic GET Operations and Cursor Pagination
Historical retrieval requires atomic GET operations against /api/v2/messages/queries/details. The endpoint returns a cursor field when additional pages exist. You must trigger automatic pagination by passing the returned cursor back into the next request until it resolves to null.
Below is the complete HTTP request and response cycle for a single page, followed by the SDK implementation that handles pagination loops.
HTTP Request
GET /api/v2/messages/queries/details?conversationId=123e4567-e89b-12d3-a456-426614174000&from=2024-01-01T00:00:00Z&to=2024-01-31T23:59:59Z&pageSize=500&sort=timestamp:asc HTTP/1.1
Host: api-us-01.nicecxone.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Accept: application/json
HTTP Response
HTTP/1.1 200 OK
  "items": [
      "id": "msg-9a8b7c6d-5e4f-3210-abcd-ef1234567890",
      "conversationId": "123e4567-e89b-12d3-a456-426614174000",
      "timestamp": "2024-01-15T14:22:01Z",
      "author": { "id": "agent-001", "type": "agent" },
      "text": "Please verify your account details.",
      "readStatus": "read",
      "attachments": [],
      "messageType": "text"
  "pageSize": 500,
  "total": 1240,
  "cursor": "eyJwYWdlIjoxLCJzb3J0IjoidGltZXN0YW1wOmFzYyJ9",
  "hasMore": true
The SDK implementation below wraps this cycle with retry logic for 429 responses and automatic cursor advancement.
import com.nice.cxp.api.messages.MessagesApi;
import com.nice.cxp.client.ApiException;
import java.util.ArrayList;
public class MessagePaginationHandler {
    private static final Logger log = LoggerFactory.getLogger(MessagePaginationHandler.class);
    private final MessagesApi messagesApi;
    public MessagePaginationHandler(MessagesApi messagesApi) {
        this.messagesApi = messagesApi;
    public List<com.nice.cxp.model.MessageDetails> fetchAllMessages(
            UUID conversationId, Instant from, Instant to, int pageSize) throws ApiException {
        List<com.nice.cxp.model.MessageDetails> allMessages = new ArrayList<>();
        String cursor = null;
        int retryCount = 0;
        final int MAX_RETRIES = 3;
        do {
                var response = messagesApi.queryMessagesDetails(
                    conversationId.toString(),
                    from.toString(),
                    to.toString(),
                    "timestamp:asc",
                    pageSize,
                    cursor,
                    null, null, null, null, null, null, null, null, null
                List<com.nice.cxp.model.MessageDetails> items = response.getItems();
                if (items != null) {
                    allMessages.addAll(items);
                cursor = response.getCursor();
                retryCount = 0; // Reset retry counter on success
            } catch (ApiException e) {
                if (e.getCode() == 429 && retryCount < MAX_RETRIES) {
                    long retryAfter = e.getRetryAfter() != null ? e.getRetryAfter() : (long) Math.pow(2, retryCount);
                    log.warn("Rate limited on conversation {}. Retrying after {} seconds", conversationId, retryAfter);
                        TimeUnit.SECONDS.sleep(retryAfter);
                    } catch (InterruptedException ie) {
                        Thread.currentThread().interrupt();
                        throw new RuntimeException("Pagination interrupted", ie);
                    retryCount++;
                } else {
                    throw e;
        } while (cursor != null);
        return allMessages;
This loop guarantees complete retrieval without manual page tracking. The exponential backoff prevents cascading rate limits when processing large conversation batches.
Step 3: Read Receipt Checking and Media Attachment Verification
Compliance archives require complete audit trails. You must verify that each retrieved message contains a valid readStatus and that media attachments are fully resolved before committing the batch to storage. The following pipeline filters incomplete records and logs truncation warnings.
import com.nice.cxp.model.MessageDetails;
import java.util.stream.Collectors;
public record VerificationResult(
    List<MessageDetails> validMessages,
    List<String> warnings,
    int totalProcessed
public class MessageVerificationPipeline {
    private static final Logger log = LoggerFactory.getLogger(MessageVerificationPipeline.class);
    public static VerificationResult validateAuditTrail(List<MessageDetails> messages) {
        List<MessageDetails> valid = new java.util.ArrayList<>();
        List<String> warnings = new java.util.ArrayList<>();
        for (MessageDetails msg : messages) {
            boolean hasReadReceipt = msg.getReadStatus() != null && !msg.getReadStatus().isEmpty();
            boolean hasAttachments = msg.getAttachments() != null && !msg.getAttachments().isEmpty();
            boolean attachmentsResolved = true;
            if (hasAttachments) {
                for (var att : msg.getAttachments()) {
                    if (att.getDownloadUrl() == null || att.getContentType() == null) {
                        attachmentsResolved = false;
                        break;
            if (!hasReadReceipt) {
                warnings.add("Missing read receipt for message: " + msg.getId());
            if (hasAttachments && !attachmentsResolved) {
                warnings.add("Incomplete media attachment metadata for message: " + msg.getId());
            if (hasReadReceipt && attachmentsResolved) {
                valid.add(msg);
        log.info("Verification complete. Valid: {}, Warnings: {}", valid.size(), warnings.size());
        return new VerificationResult(valid, warnings, messages.size());
This pipeline ensures that downstream compliance systems receive only fully resolved messages. Messages missing read receipts or attachment metadata are excluded from the valid batch and flagged for manual review.
The following class integrates authentication, batch validation, pagination, verification, webhook synchronization, metrics tracking, and audit logging into a single executable module. Replace the placeholder credentials before execution.
import com.nice.cxp.api.webhooks.WebhooksApi;
import java.io.FileWriter;
import java.io.IOException;
import java.util.*;
public class WebMessageHistoryBatcher {
    private static final Logger log = LoggerFactory.getLogger(WebMessageHistoryBatcher.class);
    private final ApiClient apiClient;
    private final WebhooksApi webhooksApi;
    private final Map<String, Long> metrics = new HashMap<>();
    private final List<String> auditLog = new ArrayList<>();
    public WebMessageHistoryBatcher(String orgId, String clientId, String clientSecret, String basePath) {
        this.apiClient = new ApiClient();
        this.apiClient.setBasePath(basePath);
        this.apiClient.setAccessToken(orgId, clientId, clientSecret);
        this.apiClient.setConnectTimeout(10000);
        this.apiClient.setReadTimeout(30000);
        this.messagesApi = new MessagesApi(this.apiClient);
        this.webhooksApi = new WebhooksApi(this.apiClient);
    public void executeBatchExport(List<UUID> conversationIds, Instant from, Instant to) {
        long batchStart = System.currentTimeMillis();
        log.info("Starting batch export for {} conversations", conversationIds.size());
        BatchExportConfig config = new BatchExportConfig(conversationIds, from, to, 500, null);
        BatchValidator.validate(config);
        List<String> webhookTargets = registerComplianceWebhook();
        int totalValid = 0;
        int totalWarnings = 0;
        for (UUID convId : conversationIds) {
            long convStart = System.currentTimeMillis();
                List<MessageDetails> rawMessages = paginateAndFetch(convId, from, to);
                var verification = MessageVerificationPipeline.validateAuditTrail(rawMessages);
                totalValid += verification.validMessages.size();
                totalWarnings += verification.warnings.size();
                if (!verification.warnings.isEmpty()) {
                    auditLog.add(String.format("CONVERSATION:%s|WARNINGS:%d|TIMESTAMP:%s",
                        convId, verification.warnings.size(), Instant.now().toString()));
                log.error("Failed to export conversation {}. Status: {}", convId, e.getCode());
                auditLog.add(String.format("CONVERSATION:%s|ERROR:%d|TIMESTAMP:%s",
                    convId, e.getCode(), Instant.now().toString()));
            } finally {
                metrics.put("conversation_" + convId, System.currentTimeMillis() - convStart);
        long batchDuration = System.currentTimeMillis() - batchStart;
        metrics.put("batch_duration_ms", batchDuration);
        metrics.put("total_valid_messages", (long) totalValid);
        metrics.put("total_warnings", (long) totalWarnings);
        triggerWebhookSync(webhookTargets, totalValid);
        writeAuditLog();
        log.info("Batch export completed in {} ms", batchDuration);
    private List<MessageDetails> paginateAndFetch(UUID conversationId, Instant from, Instant to) throws ApiException {
        List<MessageDetails> allMessages = new ArrayList<>();
        int retryCount = 0;
        do {
                    conversationId.toString(), from.toString(), to.toString(),
                    "timestamp:asc", 500, cursor, null, null, null, null, null, null, null, null, null
                List<MessageDetails> items = response.getItems();
                if (items != null) allMessages.addAll(items);
                retryCount = 0;
                if (e.getCode() == 429 && retryCount < 3) {
                    try { TimeUnit.SECONDS.sleep(retryAfter); }
                    catch (InterruptedException ie) { Thread.currentThread().interrupt(); throw new RuntimeException(ie); }
                    retryCount++;
                } else {
                    throw e;
        return allMessages;
    private List<String> registerComplianceWebhook() {
            var webhook = new com.nice.cxp.model.Webhook();
            webhook.setUrl("https://compliance-archive.internal/api/v1/cxone/batch-complete");
            webhook.setMethod("POST");
            webhook.setEvents(List.of("messages.batch.completed"));
            webhook.setActive(true);
            var created = webhooksApi.postWebhooks(webhook);
            log.info("Registered compliance webhook: {}", created.getId());
            return List.of(created.getId());
            log.warn("Webhook registration failed: {}", e.getMessage());
            return List.of();
    private void triggerWebhookSync(List<String> webhookIds, int messageCount) {
        // CXone automatically fires registered webhooks on batch completion events.
        // This method logs the synchronization trigger for external tracking.
        log.info("Triggering compliance archive sync for {} messages via webhooks: {}", messageCount, webhookIds);
    private void writeAuditLog() {
        try (FileWriter writer = new FileWriter("batch_audit_" + Instant.now().toEpochMilli() + ".log")) {
            for (String entry : auditLog) {
                writer.write(entry + System.lineSeparator());
        } catch (IOException e) {
            log.error("Failed to write audit log", e);
        String orgId = "your-org-id";
        String clientId = "your-client-id";
        String clientSecret = "your-client-secret";
        String basePath = "https://api-us-01.nicecxone.com";
        List<UUID> targetConversations = List.of(
            UUID.fromString("123e4567-e89b-12d3-a456-426614174000"),
            UUID.fromString("987fcdeb-51a2-43b6-c9d8-1029384756ab")
        Instant from = Instant.parse("2024-01-01T00:00:00Z");
        Instant to = Instant.parse("2024-01-31T23:59:59Z");
        var batcher = new WebMessageHistoryBatcher(orgId, clientId, clientSecret, basePath);
        batcher.executeBatchExport(targetConversations, from, to);
  • Cause: Invalid client credentials, expired OAuth token, or missing messages:read scope on the registered client.
  • Fix: Verify the client ID and secret match the CXone Admin Console. Ensure the OAuth client has messages:read and conversations:read scopes assigned. Restart the JVM to clear stale token caches.
  • Cause: The messaging query endpoint enforces rate limits per organization. Rapid pagination or parallel conversation processing triggers throttling.
  • Fix: Implement exponential backoff with Retry-After header parsing. The provided paginateAndFetch method already includes this logic. Reduce pageSize to 250 if processing high-volume queues.
Error: 400 Bad Request
  • Cause: Export window exceeds 30 days, invalid cursor format, or malformed ISO 8601 timestamps.
  • Fix: Run BatchValidator.validate() before execution. Ensure from and to timestamps use Z suffix for UTC. Reset cursor to null when starting a new batch.
  • Cause: Temporary CXone platform degradation or corrupted conversation metadata.
  • Fix: Implement circuit-breaker logic. Skip the failing conversation ID, log it to the audit file, and continue processing remaining IDs. Retry the failed ID after 60 seconds.
