Balancing NICE CXone Routing Queues with Node.js Using Least-Connections and BullMQ
  • A Node.js service that polls CXone routing queue metrics, calculates optimal split percentages using a least-connections algorithm, and applies configuration updates with ETag conflict resolution.
  • Uses the CXone Routing API (/api/v2/routing/queues/{queueId} and /api/v2/routing/queues/{queueId}/metrics) with OAuth 2.0 client credentials.
  • Implements Node.js with axios, bullmq, and standard library modules.
  • CXone OAuth Client ID and Secret with scopes: routing:queue:read, routing:queue:write
  • CXone API base URL (typically https://api.cxone.com or environment-specific)
  • Node.js 18+
  • Redis instance running on localhost:6379 (required for BullMQ)
  • Dependencies: npm install axios bullmq dotenv uuid
  • Environment variables in .env:
    • CXONE_BASE_URL
    • CXONE_CLIENT_ID
    • CXONE_CLIENT_SECRET
    • QUEUE_IDS (comma-separated list of CXone queue IDs to balance)
    • DASHBOARD_WEBHOOK_URL (optional, for exporting decisions)
CXone uses OAuth 2.0 client credentials flow. The service must cache the access token and refresh it before expiration. The token response includes an expires_in field measured in seconds. The code below implements a TTL cache with a sixty-second safety buffer to prevent edge-case expiration during active polling.
require('dotenv').config();
const CXONE_BASE = process.env.CXONE_BASE_URL || 'https://api.cxone.com';
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
let accessToken = null;
let tokenExpiry = 0;
async function getOAuthToken() {
  if (accessToken && Date.now() < tokenExpiry) {
    return accessToken;
  const payload = new URLSearchParams();
  payload.append('grant_type', 'client_credentials');
  payload.append('client_id', CLIENT_ID);
  payload.append('client_secret', CLIENT_SECRET);
  const response = await axios.post(`${CXONE_BASE}/oauth/token`, payload, {
  accessToken = response.data.access_token;
  tokenExpiry = Date.now() + (response.data.expires_in * 1000) - 60000;
  return accessToken;
async function cxoneRequest(method, path, body = null) {
  const token = await getOAuthToken();
  const config = {
    headers: {
      'Accept': 'application/json'
  if (body) config.data = body;
  const url = `${CXONE_BASE}${path}`;
  return axios[method](url, body, config);
Step 1: Poll Queue Metrics for Real-Time Load
The CXone Routing API exposes current queue statistics at /api/v2/routing/queues/{queueId}/metrics. This endpoint returns waiting, in-progress, and abandoned counts. The least-connections algorithm requires the total active connections (in_progress + waiting) per queue. The code fetches metrics concurrently for all target queues and normalizes the response.
async function fetchQueueMetrics(queueIds) {
  const metricsRequests = queueIds.map(id =>
    cxoneRequest('get', `/api/v2/routing/queues/${id}/metrics`)
      .then(res => ({ id, metrics: res.data }))
      .catch(err => {
        console.error(`Failed to fetch metrics for ${id}: ${err.message}`);
        return { id, metrics: null, error: err.message };
  const results = await Promise.all(metricsRequests);
  return results.filter(r => r.metrics !== null);
Required OAuth scope: routing:queue:read
Expected response body:
  "waiting": 8,
  "in_progress": 24,
  "abandoned": 2,
  "total": 34
Step 2: Calculate Load Distribution Using Least-Connections
The least-connections algorithm assigns higher routing percentages to queues with fewer active sessions. The calculation uses inverse load weighting. A minimum floor prevents starving underutilized queues. The algorithm normalizes weights into percentages that sum to one hundred.
function calculateSplitPercentages(queueMetrics, minPercentage = 10) {
  // Calculate inverse load weight for each queue
  const weights = queueMetrics.map(q => {
    const activeConnections = (q.metrics.in_progress || 0) + (q.metrics.waiting || 0);
      weight: 1 / (activeConnections + 1),
      activeConnections
  const totalWeight = weights.reduce((sum, w) => sum + w.weight, 0);
  // Normalize to percentages
  let percentages = weights.map(w => ({
    percentage: Math.round((w.weight / totalWeight) * 100)
  // Apply minimum floor and redistribute remainder
  const belowFloor = percentages.filter(p => p.percentage < minPercentage);
  const aboveFloor = percentages.filter(p => p.percentage >= minPercentage);
  belowFloor.forEach(p => p.percentage = minPercentage);
  const currentSum = percentages.reduce((sum, p) => sum + p.percentage, 0);
  const remainder = 100 - currentSum;
  if (remainder > 0 && aboveFloor.length > 0) {
    const addPerQueue = Math.floor(remainder / aboveFloor.length);
    const extra = remainder % aboveFloor.length;
    aboveFloor.forEach((p, idx) => {
      p.percentage += addPerQueue + (idx < extra ? 1 : 0);
  return percentages;
Step 3: Apply Updates with ETag Conflict Resolution
CXone queue configuration lives at /api/v2/routing/queues/{queueId}. The API supports optimistic concurrency control via ETag headers. The service must fetch the current queue configuration, extract the ETag, modify the routing.split array, and send the update with If-Match: <etag>. If another process modified the queue between fetch and update, the API returns 412 Precondition Failed.
async function updateQueueSplit(queueId, newPercentage, currentEtag) {
  // Fetch current queue configuration to preserve existing structure
  const queueResponse = await cxoneRequest('get', `/api/v2/routing/queues/${queueId}`);
  const queueConfig = queueResponse.data;
  const serverEtag = queueResponse.headers['etag'];
  // Conflict resolution: abort if ETag changed since last read
  if (currentEtag && serverEtag !== currentEtag) {
    throw new Error(`ETag mismatch for queue ${queueId}. Expected ${currentEtag}, got ${serverEtag}`);
  // Ensure routing.split exists
  if (!queueConfig.routing) queueConfig.routing = {};
  if (!Array.isArray(queueConfig.routing.split)) queueConfig.routing.split = [];
  // Update or create the split entry for this queue
  const splitIndex = queueConfig.routing.split.findIndex(s => s.destination?.id === queueId);
  if (splitIndex >= 0) {
    queueConfig.routing.split[splitIndex].percentage = newPercentage;
  } else {
    queueConfig.routing.split.push({
      destination: { id: queueId, type: 'queue' },
      percentage: newPercentage
  // Apply PUT with If-Match header
  const updateResponse = await cxoneRequest('put', `/api/v2/routing/queues/${queueId}`, queueConfig, {
    headers: { 'If-Match': serverEtag }
    queueId,
    newPercentage,
    updatedEtag: updateResponse.headers['etag'],
    success: true
Required OAuth scope: routing:queue:write
Step 4: Handle API Quota Exhaustion with BullMQ and Export Decisions
CXone enforces API quotas per tenant. When the service hits a 429 Too Many Requests response, it must defer the update rather than fail immediately. BullMQ provides a reliable job queue with built-in retry mechanisms. The worker processes update jobs, catches 429 responses, and retries with exponential backoff. Completed decisions export to a JSON log and optionally POST to a dashboard webhook.
const { Queue, Worker } = require('bullmq');
const fs = require('fs');
const path = require('path');
const updateQueue = new Queue('cxone_queue_updates', { connection: { host: 'localhost', port: 6379 } });
async function processQueueUpdate(job) {
  const { queueId, newPercentage, currentEtag } = job.data;
  let attempts = 0;
  const maxAttempts = 5;
  while (attempts < maxAttempts) {
      const result = await updateQueueSplit(queueId, newPercentage, currentEtag);
      // Export decision to monitoring dashboard
      const decisionLog = {
        queueId,
        newPercentage,
        previousEtag: currentEtag,
        updatedEtag: result.updatedEtag,
        status: 'SUCCESS'
      appendDecisionLog(decisionLog);
      await postToDashboard(decisionLog);
      return result;
    } catch (error) {
      const axiosError = error.response ? error.response : null;
      if (axiosError && axiosError.status === 429) {
        attempts++;
        const delay = Math.pow(2, attempts) * 1000;
        console.warn(`429 Quota exceeded for ${queueId}. Retrying in ${delay}ms (attempt ${attempts}/${maxAttempts})`);
        continue;
      if (axiosError && axiosError.status === 412) {
        console.error(`412 Conflict for ${queueId}. Another process modified the queue.`);
        return { queueId, status: 'CONFLICT', error: error.message };
      throw error;
  throw new Error(`Max retry attempts reached for queue ${queueId}`);
async function appendDecisionLog(decision) {
  const logPath = path.join(__dirname, 'load_balancing_decisions.json');
  const exists = fs.existsSync(logPath);
  const content = exists ? JSON.parse(fs.readFileSync(logPath, 'utf8')) : [];
  content.push(decision);
  fs.writeFileSync(logPath, JSON.stringify(content, null, 2));
async function postToDashboard(decision) {
  const webhookUrl = process.env.DASHBOARD_WEBHOOK_URL;
  if (!webhookUrl) return;
    await axios.post(webhookUrl, decision, { timeout: 5000 });
  } catch (err) {
    console.warn(`Dashboard export failed: ${err.message}`);
The following script combines authentication, metric polling, algorithm calculation, BullMQ job enqueueing, and worker processing. Replace the environment variables in the .env file before execution.
const QUEUE_IDS = (process.env.QUEUE_IDS || '').split(',').filter(Boolean);
  if (accessToken && Date.now() < tokenExpiry) return accessToken;
  return accessToken;
async function cxoneRequest(method, path, body = null, extraHeaders = {}) {
  const config = {
    headers: {
      'Accept': 'application/json',
      ...extraHeaders
  return axios[method](`${CXONE_BASE}${path}`, body, config);
  const results = await Promise.all(queueIds.map(async (id) => {
      const res = await cxoneRequest('get', `/api/v2/routing/queues/${id}/metrics`);
      return { id, metrics: res.data };
    } catch (err) {
      console.error(`Metrics fetch failed for ${id}: ${err.message}`);
      return null;
  return results.filter(Boolean);
    const active = (q.metrics.in_progress || 0) + (q.metrics.waiting || 0);
    return { id: q.id, weight: 1 / (active + 1) };
    aboveFloor.forEach((p, idx) => { p.percentage += addPerQueue + (idx < extra ? 1 : 0); });
  return percentages;
    throw new Error(`ETag mismatch for ${queueId}`);
  const idx = queueConfig.routing.split.findIndex(s => s.destination?.id === queueId);
  if (idx >= 0) {
    queueConfig.routing.split[idx].percentage = newPercentage;
  } else {
    queueConfig.routing.split.push({ destination: { id: queueId, type: 'queue' }, percentage: newPercentage });
  return { queueId, newPercentage, updatedEtag: updateResponse.headers['etag'] };
const updateJobQueue = new Queue('cxone_queue_updates', { connection: { host: 'localhost', port: 6379 } });
  let attempts = 0;
  while (attempts < 5) {
      const decision = { timestamp: new Date().toISOString(), queueId, newPercentage, status: 'SUCCESS' };
      fs.appendFileSync('decisions.log', JSON.stringify(decision) + '\n');
      return result;
    } catch (error) {
      const status = error.response?.status;
      if (status === 429) {
        attempts++;
        await new Promise(r => setTimeout(r, Math.pow(2, attempts) * 1000));
        continue;
      if (status === 412) throw new Error('Concurrency conflict detected');
      throw error;
  throw new Error('Max retries exceeded');
const worker = new Worker('cxone_queue_updates', processQueueUpdate, { connection: { host: 'localhost', port: 6379 } });
async function runBalancer() {
  console.log('Starting CXone Queue Balancer...');
  setInterval(async () => {
    if (QUEUE_IDS.length === 0) return;
    const metrics = await fetchQueueMetrics(QUEUE_IDS);
    if (metrics.length === 0) return;
    const splits = calculateSplitPercentages(metrics);
    for (const split of splits) {
      await updateJobQueue.add('update_split', {
        queueId: split.id,
        newPercentage: split.percentage,
        currentEtag: null
      }, { removeOnComplete: true, attempts: 5, backoff: { type: 'exponential', delay: 1000 } });
    console.log(`Evaluated splits at ${new Date().toISOString()}`);
  }, 15000);
runBalancer().catch(console.error);
  • What causes it: The OAuth token has expired, the client credentials are incorrect, or the token endpoint returned an invalid payload.
  • How to fix it: Verify CXONE_CLIENT_ID and CXONE_CLIENT_SECRET in the environment. Ensure the token cache refreshes before expires_in elapses. The provided code subtracts sixty seconds from the expiry timestamp to prevent mid-request expiration.
  • Code showing the fix: The getOAuthToken function checks Date.now() < tokenExpiry and forces a fresh POST to /oauth/token when the threshold is crossed.
Error: 403 Forbidden
  • What causes it: The OAuth client lacks the required scopes. Queue metrics require routing:queue:read. Queue configuration updates require routing:queue:write.
  • How to fix it: Navigate to the CXone Admin Console, locate the OAuth client, and append both scopes to the client configuration. Restart the Node.js service to trigger a new token request.
  • Code showing the fix: No code change is required. The scopes are granted at the CXone tenant level. The service will automatically use the new scopes on the next token refresh cycle.
Error: 412 Precondition Failed
  • What causes it: The ETag header sent in If-Match does not match the current server version. Another admin or automation modified the queue between the GET and PUT requests.
  • How to fix it: Implement a retry loop that fetches the latest configuration, recalculates the split, and attempts the PUT again. The BullMQ worker should treat 412 as a terminal failure for that job instance and log the conflict.
  • Code showing the fix: The updateQueueSplit function throws immediately on 412. The worker catches this, marks the job as failed, and allows the next polling cycle to fetch fresh state.
  • What causes it: The tenant API quota has been exhausted. CXone enforces rate limits per client and per tenant. Burst polling across multiple queues triggers this limit.
  • How to fix it: Defer updates using BullMQ with exponential backoff. The worker sleeps for 2^n seconds between retries. Reduce polling frequency if quota exhaustion persists.
  • Code showing the fix: The processQueueUpdate worker contains a while (attempts < 5) loop that catches status === 429, increments the attempt counter, and delays execution before retrying.
