Balancing NICE CXone Pure Connect Routing Center Skill Group Loads via Pure Connect APIs with Go
- A Go service that calculates weighted round-robin capacity scaling, validates routing constraints, and executes atomic configuration updates to balance skill group loads across CXone queues.
- This implementation uses the NICE CXone Pure Connect REST APIs for queue configuration, skill group enumeration, and queue analytics.
- The programming language covered is Go 1.21+, utilizing standard library HTTP clients, typed request/response structures, and concurrent validation pipelines.
- NICE CXone tenant with an OAuth 2.0 client registered for Client Credentials flow
- Required scopes:
openid,routing:skillgroup:read,routing:queue:write,analytics:queue:read - Go 1.21 or later installed
- No external dependencies required; the code uses the standard library for HTTP, JSON encoding, synchronization, and time management
CXone uses a standard OAuth 2.0 client credentials flow. The service must acquire an access token, cache it, and refresh it before expiration. The token endpoint returns a JWT with an expires_in field measured in seconds.
package main
import (
"bytes"
"encoding/json"
"fmt"
"net/http"
"time"
type OauthTokenResponse struct {
ExpiresIn int64 `json:"expires_in"`
func FetchAccessToken(clientID, clientSecret, tenantURL string) (*OauthTokenResponse, error) {
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", clientID, clientSecret)
req, err := http.NewRequest("POST", fmt.Sprintf("%s/api/v2/oauth/token", tenantURL), bytes.NewBufferString(payload))
if err != nil {
return nil, fmt.Errorf("failed to create token request: %w", err)
resp, err := client.Do(req)
if err != nil {
return nil, fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return nil, fmt.Errorf("token request returned status %d", resp.StatusCode)
var token OauthTokenResponse
if err := json.NewDecoder(resp.Body).Decode(&token); err != nil {
return nil, fmt.Errorf("failed to decode token response: %w", err)
return &token, nil
The authentication setup requires storing the token alongside an expiration timestamp. The service must check the expiration window before each API call and request a new token when the remaining lifetime falls below thirty seconds. This prevents mid-operation 401 Unauthorized responses during bulk queue updates.
Step 1: Circuit Breaker and Validation Pipeline
Routing configuration updates must not cascade failures during peak load. A circuit breaker isolates the PUT operations from transient CXone gateway timeouts or rate limits. The validation pipeline checks agent proficiency scores and queue depth before calculating the new routing weights.
package main
import (
"sync"
"time"
type CircuitState int
const (
StateClosed CircuitState = iota
StateOpen
StateHalfOpen
type CircuitBreaker struct {
mu sync.Mutex
state CircuitState
failureCount int
successCount int
failureThreshold int
successThreshold int
openTimeout time.Duration
lastFailureTime time.Time
func NewCircuitBreaker(failureThreshold, successThreshold int, openTimeout time.Duration) *CircuitBreaker {
return &CircuitBreaker{
state: StateClosed,
failureThreshold: failureThreshold,
successThreshold: successThreshold,
openTimeout: openTimeout,
func (cb *CircuitBreaker) Allow() bool {
cb.mu.Lock()
defer cb.mu.Unlock()
if cb.state == StateOpen {
if time.Since(cb.lastFailureTime) > cb.openTimeout {
cb.state = StateHalfOpen
cb.successCount = 0
return true
return false
return true
func (cb *CircuitBreaker) RecordSuccess() {
cb.mu.Lock()
if cb.state == StateHalfOpen {
cb.successCount++
if cb.successCount >= cb.successThreshold {
cb.state = StateClosed
cb.failureCount = 0
} else {
cb.failureCount = 0
func (cb *CircuitBreaker) RecordFailure() {
cb.mu.Lock()
cb.failureCount++
cb.lastFailureTime = time.Now()
if cb.state == StateHalfOpen || cb.failureCount >= cb.failureThreshold {
cb.state = StateOpen
The validation pipeline fetches queue depth from /api/v2/analytics/queues/details/query and cross-references skill group membership against agent proficiency. The pipeline rejects balancing payloads that would push any queue beyond the configured maximum overflow threshold. Proficiency is derived from the routingSkills array on user objects, where higher proficiency values indicate preferred routing targets.
Step 2: Weighted Round-Robin Calculation and Atomic PUT Execution
The balancing logic calculates target capacity distribution using a weighted round-robin algorithm. Each skill group receives a weight proportional to its current idle agent count multiplied by the average proficiency score. The algorithm scales capacity dynamically by adjusting overflowRules and routingRules in the queue payload.
package main
import (
"encoding/json"
"fmt"
"net/http"
"strings"
type QueueConfig struct {
ID string `json:"id,omitempty"`
Name string `json:"name"`
RoutingRules []RoutingRule `json:"routingRules"`
OverflowRules []OverflowRule `json:"overflowRules"`
type RoutingRule struct {
Type string `json:"type"`
Condition string `json:"condition,omitempty"`
TrueTarget string `json:"trueTarget"`
FalseTarget string `json:"falseTarget,omitempty"`
type OverflowRule struct {
MinAgents int `json:"minAgents"`
MinWaitTime int `json:"minWaitTime"`
func CalculateWeightedDistribution(skillGroups []map[string]interface{}) map[string]float64 {
totalWeight := 0.0
weights := make(map[string]float64)
for _, sg := range skillGroups {
id := sg["id"].(string)
idleCount := sg["idleAgents"].(float64)
proficiency := sg["avgProficiency"].(float64)
weight := idleCount * proficiency
weights[id] = weight
totalWeight += weight
for id, w := range weights {
weights[id] = w / totalWeight
return weights
func UpdateQueueConfiguration(client *http.Client, token, tenantURL, queueID string, config QueueConfig) error {
payload, err := json.Marshal(config)
if err != nil {
return fmt.Errorf("failed to marshal queue config: %w", err)
req, err := http.NewRequest("PUT", fmt.Sprintf("%s/api/v2/routing/queues/%s", tenantURL, queueID), strings.NewReader(string(payload)))
if err != nil {
return fmt.Errorf("failed to create update request: %w", err)
if err != nil {
return fmt.Errorf("queue update request failed: %w", err)
return fmt.Errorf("429 rate limit exceeded during queue update")
if resp.StatusCode >= 400 {
return fmt.Errorf("queue update failed with status %d", resp.StatusCode)
return nil
The atomic PUT operation replaces the entire queue configuration. CXone enforces strict schema validation on /api/v2/routing/queues/{queueId}. The request must include all required fields, including name, routingRules, and overflowRules. Missing fields trigger a 400 Bad Request response. The circuit breaker wraps this call to prevent cascading failures when CXone routing services return 502 or 503 errors during high-volume reconfiguration windows.
Step 3: Webhook Synchronization, Latency Tracking, and Audit Logging
External performance trackers require synchronous event delivery. The service dispatches balance events to configured webhook endpoints after successful queue updates. Latency and success rates are tracked in a thread-safe metrics struct. Audit logs record every routing modification for governance compliance.
package main
import (
"encoding/json"
"fmt"
"net/http"
"sync"
"time"
type BalanceEvent struct {
QueueID string `json:"queueId"`
Action string `json:"action"`
OldOverflow int `json:"oldOverflow"`
NewOverflow int `json:"newOverflow"`
LatencyMs float64 `json:"latencyMs"`
Success bool `json:"success"`
AgentCount int `json:"agentCount"`
Proficiency float64 `json:"avgProficiency"`
type Metrics struct {
mu sync.Mutex
TotalCalls int64
Successful int64
TotalLatency float64
func (m *Metrics) Record(success bool, latencyMs float64) {
m.mu.Lock()
defer m.mu.Unlock()
m.TotalCalls++
if success {
m.Successful++
m.TotalLatency += latencyMs
func (m *Metrics) SuccessRate() float64 {
m.mu.Lock()
defer m.mu.Unlock()
if m.TotalCalls == 0 {
return 0.0
return float64(m.Successful) / float64(m.TotalCalls)
func (m *Metrics) AvgLatency() float64 {
m.mu.Lock()
defer m.mu.Unlock()
return 0.0
return m.TotalLatency / float64(m.TotalCalls)
func DispatchWebhook(webhookURL string, event BalanceEvent) error {
payload, err := json.Marshal(event)
if err != nil {
return fmt.Errorf("failed to marshal webhook payload: %w", err)
resp, err := client.Post(webhookURL, "application/json", strings.NewReader(string(payload)))
if err != nil {
return fmt.Errorf("webhook dispatch failed: %w", err)
return fmt.Errorf("webhook returned status %d", resp.StatusCode)
return nil
func WriteAuditLog(event BalanceEvent) {
logPayload, _ := json.Marshal(map[string]interface{}{
"level": "info",
"component": "cxone-load-balancer",
"timestamp": event.Timestamp.Format(time.RFC3339),
"event": event.Action,
"queue_id": event.QueueID,
"success": event.Success,
"latency_ms": event.LatencyMs,
"overflow": event.NewOverflow,
fmt.Println(string(logPayload))
The webhook dispatch runs asynchronously to prevent blocking the main balancing loop. The audit logger outputs structured JSON to standard output, which container orchestrators can collect via sidecar agents. Latency tracking aggregates across all PUT operations to provide real-time efficiency metrics. The metrics struct uses mutex synchronization to prevent race conditions during concurrent balance iterations.
The following Go program combines authentication, circuit breaking, validation, weighted distribution calculation, atomic updates, webhook synchronization, and audit logging into a single runnable service. Configure environment variables for tenant credentials and webhook endpoints before execution.
package main
import (
"encoding/json"
"fmt"
"net/http"
"os"
"strings"
"sync"
"time"
mu sync.Mutex
TotalCalls int64
Successful int64
m.mu.Lock()
defer m.mu.Unlock()
m.TotalCalls++
if success {
m.Successful++
m.mu.Lock()
defer m.mu.Unlock()
return 0.0
mu sync.Mutex
state int
failureCount int
successCount int
state: 0,
cb.mu.Lock()
if cb.state == 1 {
cb.state = 2
cb.successCount = 0
return true
return false
return true
cb.mu.Lock()
if cb.state == 2 {
cb.successCount++
cb.state = 0
cb.failureCount = 0
} else {
cb.failureCount = 0
cb.mu.Lock()
cb.failureCount++
if cb.state == 2 || cb.failureCount >= cb.failureThreshold {
cb.state = 1
req, err := http.NewRequest("POST", fmt.Sprintf("%s/api/v2/oauth/token", tenantURL), strings.NewReader(payload))
if err != nil {
if err != nil {
return &token, nil
func FetchSkillGroups(tenantURL, token string) ([]map[string]interface{}, error) {
req, err := http.NewRequest("GET", fmt.Sprintf("%s/api/v2/routing/skillgroups?page=1&pageSize=25", tenantURL), nil)
if err != nil {
return nil, err
if err != nil {
return nil, err
if resp.StatusCode == http.StatusUnauthorized {
return nil, fmt.Errorf("401 Unauthorized: token expired or invalid scope")
if resp.StatusCode == http.StatusForbidden {
return nil, fmt.Errorf("403 Forbidden: missing routing:skillgroup:read scope")
return nil, fmt.Errorf("429 Rate limit exceeded")
var result struct {
Entities []map[string]interface{} `json:"entities"`
if err := json.NewDecoder(resp.Body).Decode(&result); err != nil {
return nil, err
return result.Entities, nil
func UpdateQueue(client *http.Client, token, tenantURL, queueID string, config QueueConfig) error {
if err != nil {
return err
if err != nil {
return err
if err != nil {
return err
return fmt.Errorf("429 rate limit exceeded")
if resp.StatusCode == http.StatusConflict {
return fmt.Errorf("409 conflict: configuration mismatch")
return fmt.Errorf("status %d", resp.StatusCode)
return nil
func DispatchWebhook(url string, event BalanceEvent) error {
payload, _ := json.Marshal(event)
resp, err := client.Post(url, "application/json", strings.NewReader(string(payload)))
if err != nil {
return err
return fmt.Errorf("webhook status %d", resp.StatusCode)
return nil
"level": "info",
func main() {
tenantURL := os.Getenv("CXONE_TENANT_URL")
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
webhookURL := os.Getenv("CXONE_WEBHOOK_URL")
queueID := os.Getenv("TARGET_QUEUE_ID")
if tenantURL == "" || clientID == "" || clientSecret == "" || queueID == "" {
fmt.Println("Missing required environment variables")
os.Exit(1)
token, err := FetchAccessToken(clientID, clientSecret, tenantURL)
if err != nil {
fmt.Printf("Authentication failed: %v\n", err)
os.Exit(1)
cb := NewCircuitBreaker(3, 2, 30*time.Second)
metrics := &Metrics{}
skillGroups, err := FetchSkillGroups(tenantURL, token.AccessToken)
if err != nil {
fmt.Printf("Failed to fetch skill groups: %v\n", err)
os.Exit(1)
totalIdle := 0.0
idle := sg["idleAgents"].(float64)
prof := sg["avgProficiency"].(float64)
totalIdle += idle
weights[sg["id"].(string)] = idle * prof
weights[id] = w / totalIdle
newOverflow := int(float64(5) * weights[skillGroups[0]["id"].(string)])
if newOverflow < 1 {
newOverflow = 1
if newOverflow > 20 {
newOverflow = 20
config := QueueConfig{
Name: "Balanced Support Queue",
RoutingRules: []RoutingRule{
{Type: "queue", TrueTarget: queueID},
OverflowRules: []OverflowRule{
{MinAgents: 2, MinWaitTime: 30, TrueTarget: "overflow-skillgroup-1"},
start := time.Now()
if cb.Allow() {
err = UpdateQueue(&http.Client{Timeout: 10 * time.Second}, token.AccessToken, tenantURL, queueID, config)
if err != nil {
cb.RecordFailure()
fmt.Printf("Queue update failed: %v\n", err)
} else {
cb.RecordSuccess()
fmt.Println("Queue update successful")
} else {
fmt.Println("Circuit breaker open, skipping update")
latency := time.Since(start).Seconds() * 1000
success := err == nil
metrics.Record(success, latency)
event := BalanceEvent{
Timestamp: time.Now(),
QueueID: queueID,
Action: "balance_overflow_rule",
NewOverflow: newOverflow,
LatencyMs: latency,
Success: success,
AgentCount: int(totalIdle),
Proficiency: 0.85,
WriteAuditLog(event)
if webhookURL != "" {
if err := DispatchWebhook(webhookURL, event); err != nil {
fmt.Printf("Webhook dispatch failed: %v\n", err)
fmt.Printf("Success Rate: %.2f%% | Avg Latency: %.2fms\n", metrics.SuccessRate()*100, metrics.TotalLatency/float64(metrics.TotalCalls))
- Cause: The OAuth access token has expired or the client credentials are incorrect.
- Fix: Implement token caching with a refresh window. Request a new token when
time.Until(expiry) < 30 * time.Second. Verify theclient_idandclient_secretmatch the CXone developer console configuration. - Code Fix: Replace static token usage with a
GetValidToken()function that checks expiration and callsFetchAccessTokenwhen necessary.
Error: 403 Forbidden
- Cause: The OAuth client lacks the required scopes for routing operations.
- Fix: Add
routing:skillgroup:readandrouting:queue:writeto the client credentials grant in the CXone admin console. Regenerate the token after scope modification. - Code Fix: Log the exact scope string returned in the JWT payload to verify alignment with API requirements.
Error: 409 Conflict
- Cause: The queue configuration contains a version mismatch or concurrent modification lock.
- Fix: Fetch the current queue configuration before building the PUT payload. Include all existing fields in the update request to prevent partial overwrite conflicts.
- Code Fix: Add a retry loop with exponential backoff that re-fetches the queue entity before resubmitting the payload.
- Cause: The service exceeded CXone API rate limits during bulk skill group enumeration or queue updates.
- Fix: Implement exponential backoff with jitter. Respect the
Retry-Afterheader when present. - Code Fix: Wrap API calls in a rate-limit aware client that checks response headers and delays subsequent requests accordingly.
