Balancing Genesys Cloud Multi-Skill Queue Assignments with Python and Linear Programming
A Python worker that queries real-time agent states, solves a linear programming problem to calculate optimal queue capacities, and applies those capacities via the Routing API to minimize estimated average wait times. This tutorial uses the Genesys Cloud Routing API and scipy.optimize.linprog. The code is written in Python 3.9+.
- OAuth 2.0 Client Credentials flow with scopes:
routing:agent:view,routing:queue:view,routing:queue:write - Genesys Cloud Python SDK v2.0.0+ (referenced for architecture context)
- Python 3.9+,
requests,scipy,numpy - Environment variables for
GENESYS_REGION,GENESYS_CLIENT_ID,GENESYS_CLIENT_SECRET - Target queue configuration mapping queue IDs to skill IDs
Genesys Cloud uses OAuth 2.0 client credentials flow for machine-to-machine authentication. The SDK class PureCloudPlatformClientV2 handles token lifecycle internally, but implementing the flow directly with requests provides full visibility into expiration windows and refresh boundaries. The following class caches tokens and refreshes them before expiration.
import os
import requests
from typing import Optional, Dict, Any
class GenesysAuth:
def __init__(self, region: str, client_id: str, client_secret: str):
self.region = region
self.client_id = client_id
self.expires_at: float = 0.0
self.base_url = f"https://{region}.mygenesys.com"
def get_token(self) -> str:
if self.token and time.time() < self.expires_at:
return self.token
url = f"{self.base_url}/oauth/token"
payload = {
"client_id": self.client_id,
response = requests.post(url, headers=headers, data=payload)
response.raise_for_status()
data: Dict[str, Any] = response.json()
self.token = data["access_token"]
self.expires_at = time.time() + data["expires_in"] - 300
return self.token
def make_request(self, method: str, path: str, **kwargs) -> requests.Response:
kwargs.setdefault("headers", {})
kwargs["headers"]["Authorization"] = f"Bearer {self.get_token()}"
kwargs["headers"]["Content-Type"] = "application/json"
url = f"{self.base_url}{path}"
return requests.request(method, url, **kwargs)
Step 1: Fetch Real-Time Agent Availability and Skill Mappings
The Routing API exposes user definitions and real-time states on separate endpoints. You must paginate through /api/v2/routing/users to retrieve skill assignments, then fetch bulk states from /api/v2/routing/users/state. The code below implements continuation token pagination and exponential backoff for 429 rate limits.
import json
def fetch_with_retry(auth: GenesysAuth, method: str, path: str, params: Dict = None) -> requests.Response:
max_retries = 3
response = auth.make_request(method, path, params=params)
retry_after = float(response.headers.get("Retry-After", 2 ** attempt))
print(f"Rate limited. Retrying in {retry_after} seconds.")
time.sleep(retry_after)
return response
raise RuntimeError("Max retries exceeded for 429 response")
def get_all_users(auth: GenesysAuth) -> List[Dict[str, Any]]:
users: List[Dict[str, Any]] = []
continuation_token: Optional[str] = None
while True:
params = {"page_size": 250}
if continuation_token:
params["continuation_token"] = continuation_token
resp = fetch_with_retry(auth, "GET", "/api/v2/routing/users", params=params)
data = resp.json()
users.extend(data.get("entities", []))
continuation_token = data.get("continuation_token")
if not continuation_token:
break
return users
def get_available_agents_per_skill(auth: GenesysAuth, users: List[Dict[str, Any]], skill_ids: set) -> Dict[str, int]:
resp = fetch_with_retry(auth, "GET", "/api/v2/routing/users/state")
states = resp.json().get("entities", [])
user_map = {u["id"]: u for u in users}
skill_availability: Dict[str, int] = {sid: 0 for sid in skill_ids}
for state in states:
if state.get("stateCode") != "Available":
user_id = state.get("userId")
user = user_map.get(user_id)
if not user:
for skill in user.get("skills", []):
skill_id = skill.get("id")
if skill_id in skill_availability:
skill_availability[skill_id] += 1
return skill_availability
Step 2: Calculate Optimal Capacities with Linear Programming
Queue capacity directly influences Erlang-C wait time estimates. Linear programming requires a linear objective function and linear constraints. You approximate wait time minimization by weighting capacity variables inversely to available agents. The solver minimizes total weighted capacity while enforcing coverage ratio bounds.
import numpy as np
from scipy.optimize import linprog
from typing import List, Tuple, Dict
def calculate_optimal_capacities(
queue_config: List[Dict[str, Any]],
skill_availability: Dict[str, int],
min_coverage_ratio: float = 0.85
# Extract ordered queue IDs and skill mappings
queue_ids = [q["queue_id"] for q in queue_config]
skill_ids = [q["skill_id"] for q in queue_config]
n = len(queue_ids)
# Objective: minimize sum(weight_i * capacity_i)
# weight_i inversely proportional to availability (proxy for wait time)
c = np.array([1.0 / max(skill_availability.get(sid, 0), 1) for sid in skill_ids])
# Bounds: [min_capacity, max_capacity] per queue
bounds = [(q.get("min_capacity", 1), q.get("max_capacity", 200)) for q in queue_config]
# Constraints: capacity_i <= available_i / min_coverage_ratio
# Rewritten as: capacity_i <= limit_i
# linprog expects A_ub @ x <= b_ub
A_ub = np.eye(n)
b_ub = np.array([
max(skill_availability.get(sid, 0), 1) / min_coverage_ratio
result = linprog(c, A_ub=A_ub, b_ub=b_ub, bounds=bounds, method='highs')
if not result.success:
raise RuntimeError(f"LP solver failed: {result.message}")
optimal_capacities = {}
for i, qid in enumerate(queue_ids):
optimal_capacities[qid] = max(1, round(result.x[i]))
return optimal_capacities
Step 3: Rebalance Queue Capacities via PUT
The Routing API accepts capacity updates via PUT /api/v2/routing/queues/{queueId}. You must send only the fields you intend to modify. The request body below updates inbound_capacity while preserving existing queue configuration. Error handling covers 400 (invalid capacity range), 403 (scope mismatch), and 409 (concurrent modification).
def update_queue_capacity(auth: GenesysAuth, queue_id: str, capacity: int) -> Dict[str, Any]:
path = f"/api/v2/routing/queues/{queue_id}"
payload = {"inbound_capacity": capacity}
resp = fetch_with_retry(auth, "PUT", path, json=payload)
if resp.status_code == 409:
print(f"Conflict updating queue {queue_id}. Resource modified concurrently.")
# In production, implement optimistic locking with version headers
return {"status": "conflict", "queue_id": queue_id}
return resp.json()
The following script integrates authentication, data fetching, linear programming, and capacity updates. Replace the placeholder configuration with your environment values.
import os
import sys
import requests
import numpy as np
from typing import List, Dict, Any, Optional
class GenesysAuth:
return self.token
data = {
response = requests.post(url, headers=headers, data=data)
payload = response.json()
self.token = payload["access_token"]
self.expires_at = time.time() + payload["expires_in"] - 300
return self.token
max_retries = 3
print(f"Rate limited on {path}. Retrying in {retry_after}s.")
return response
raise RuntimeError(f"Max retries exceeded for {path}")
while True:
data = resp.json()
break
return users
if not user:
n = len(queue_ids)
A_ub = np.eye(n)
b_ub = np.array([
return {qid: max(1, round(result.x[i])) for i, qid in enumerate(queue_ids)}
print(f"Conflict updating queue {queue_id}.")
return resp.json()
def main():
region = os.environ.get("GENESYS_REGION", "mypurecloud.ie")
client_id = os.environ.get("GENESYS_CLIENT_ID")
client_secret = os.environ.get("GENESYS_CLIENT_SECRET")
if not all([region, client_id, client_secret]):
print("Missing environment variables: GENESYS_REGION, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET")
sys.exit(1)
auth = GenesysAuth(region, client_id, client_secret)
# Configuration: map queues to skills and define capacity bounds
queue_config = [
{"queue_id": "a1b2c3d4-1111-2222-3333-444444444444", "skill_id": "s1-skill-id", "min_capacity": 1, "max_capacity": 50},
{"queue_id": "e5f6g7h8-5555-6666-7777-888888888888", "skill_id": "s2-skill-id", "min_capacity": 1, "max_capacity": 50}
target_skills = {q["skill_id"] for q in queue_config}
print("Fetching users and skill mappings...")
users = get_all_users(auth)
print("Fetching real-time agent states...")
availability = get_available_agents_per_skill(auth, users, target_skills)
print(f"Available agents per skill: {availability}")
print("Solving linear programming model...")
optimal = calculate_optimal_capacities(queue_config, availability, min_coverage_ratio=0.80)
print(f"Optimal capacities: {optimal}")
print("Applying capacity updates...")
for qid, cap in optimal.items():
result = update_queue_capacity(auth, qid, cap)
print(f"Queue {qid} updated to capacity {cap}")
print(f"Failed to update queue {qid}: {e}")
print("Rebalancing complete.")
main()
- Cause: Expired or invalid OAuth token, incorrect client credentials, or missing
Authorizationheader. - Fix: Verify
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETmatch the OAuth client registered in the Admin Console. Ensure themake_requestmethod attaches the Bearer token before every call. The providedGenesysAuthclass automatically refreshes tokens 300 seconds before expiration.
Error: 403 Forbidden
- Cause: OAuth client lacks required scopes.
- Fix: Navigate to Admin > Security > OAuth Clients. Edit your client and ensure
routing:agent:view,routing:queue:view, androuting:queue:writeare checked. Save and regenerate the client secret if scopes were added retroactively.
- Cause: Exceeding Genesys Cloud rate limits (typically 100 requests per second per client for REST APIs).
- Fix: The
fetch_with_retryfunction implements exponential backoff. For high-frequency workers, add a fixed delay between iterations or implement a token bucket rate limiter. Respect theRetry-Afterheader when present.
Error: 400 Bad Request
- Cause: Invalid capacity values, malformed JSON, or updating read-only fields.
- Fix: Validate that
inbound_capacityfalls between 1 and the queue maximum. Ensure the request body contains onlyinbound_capacity(oroutbound_capacityif applicable). Do not send the full queue object unless performing a complete replacement.
Error: LP Infeasibility or Unbounded
- Cause: Constraints conflict with bounds, or
min_coverage_ratioexceeds available agent capacity. - Fix: Lower
min_coverage_ratioor increasemax_capacityinqueue_config. Verify thatskill_availabilitycontains accurate counts. The solver usesscipy.optimize.linprogwith the HiGHS method, which returns explicit failure messages when constraints cannot be satisfied.
