Balance Genesys Cloud Routing Load Across Sites Using Python and the Routing API
- A Python orchestration service that constructs, validates, and pushes site routing configurations to Genesys Cloud, calculates latency and bandwidth metrics, verifies DNS and site health, triggers automatic reroutes, syncs via webhooks, logs audits, and exposes a programmatic load balancer interface.
- This implementation uses the Genesys Cloud Routing API endpoints
/api/v2/routing/sitesand/api/v2/routing/locationsalongside thegenesyscloud_python_sdk. - The tutorial covers Python 3.9+ using
httpx,pydantic, and async orchestration patterns.
- OAuth Client Credentials flow configured in Genesys Cloud Admin Console
- Required scopes:
routing:site:admin,routing:location:admin,routing:location:read - SDK version:
genesyscloud_python_sdkv2.4.0+ - Runtime: Python 3.9 or higher
- External dependencies:
httpx>=0.25.0,pydantic>=2.5.0,aiofiles>=23.2.1
The Genesys Cloud OAuth 2.0 client credentials flow requires a POST to /oauth/token. You must cache the access token and implement refresh logic before expiration. The following code demonstrates token acquisition, caching, and SDK initialization.
import httpx
import logging
from typing import Optional
from genesyscloud_python_sdk import PureCloudPlatformClientV2, RoutingApi
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, env_base_url: str = "https://api.mypurecloud.com"):
self.client_id = client_id
self.base_url = env_base_url.rstrip("/")
self.http = httpx.Client(timeout=10.0)
if self.access_token and time.time() < self.token_expiry - 60:
return self.access_token
logger.info("Acquiring OAuth access token")
url = f"{self.base_url}/oauth/token"
data = {
"client_id": self.client_id,
"scope": "routing:site:admin routing:location:admin routing:location:read"
response = self.http.post(url, headers=headers, data=data)
response.raise_for_status()
token_data = response.json()
self.token_expiry = time.time() + token_data["expires_in"]
logger.info("Token acquired successfully")
logger.error(f"OAuth token request failed: {e.response.status_code} - {e.response.text}")
raise
logger.error(f"Unexpected error during token acquisition: {e}")
raise
def initialize_sdk(self) -> RoutingApi:
token = self.get_access_token()
platform_client = PureCloudPlatformClientV2()
platform_client.set_access_token(token)
platform_client.set_base_url(self.base_url)
return RoutingApi(platform_client)
OAuth Scope Requirement: routing:site:admin routing:location:admin routing:location:read
HTTP Cycle Example:
- Method:
POST - Path:
/oauth/token - Headers:
Content-Type: application/x-www-form-urlencoded - Body:
grant_type=client_credentials&client_id=YOUR_CLIENT_ID&client_secret=YOUR_CLIENT_SECRET&scope=routing:site:admin - Response:
{"access_token": "eyJhbGci...", "expires_in": 3600, "scope": "routing:site:admin ..."}
Step 1: Construct and Validate Balancing Payloads
You must construct routing payloads that reference sites, define traffic distribution matrices, and enforce distribution directives. The following Pydantic schema validates geographic constraints and maximum failover depth before transformation into Genesys Cloud format.
from pydantic import BaseModel, field_validator, ValidationError
from typing import List, Dict
import ipaddress
class SiteReference(BaseModel):
region: str
capacity: int
class DistributeDirective(BaseModel):
strategy: str # "weighted", "round_robin", "latency_based"
weights: Dict[str, float]
max_failover_depth: int = 3
@field_validator("max_failover_depth")
@classmethod
def validate_failover_depth(cls, v: int) -> int:
if v < 1 or v > 5:
raise ValueError("Max failover depth must be between 1 and 5 to prevent routing loops")
return v
class TrafficMatrix(BaseModel):
source_region: str
target_sites: List[SiteReference]
distribute: DistributeDirective
geographic_constraint: bool = True
@field_validator("target_sites")
@classmethod
def validate_geographic_constraints(cls, v: List[SiteReference], info) -> List[SiteReference]:
if not v:
raise ValueError("Traffic matrix requires at least one target site")
return v
def construct_balancing_payload(matrix: TrafficMatrix) -> dict:
"""Transforms orchestration schema into Genesys Cloud /api/v2/routing/sites format"""
site_configs = []
for idx, site in enumerate(matrix.target_sites):
weight = matrix.distribute.weights.get(site.id, 0.0)
site_configs.append({
"siteId": site.id,
"name": site.name,
"capacity": site.capacity,
"priority": idx + 1,
"weight": weight,
"region": site.region,
"enabled": True
"name": f"TrafficMatrix_{matrix.source_region}",
"description": f"Auto-balanced routing for {matrix.source_region}",
"sites": site_configs,
"distributionStrategy": matrix.distribute.strategy,
"maxFailoverDepth": matrix.distribute.max_failover_depth,
"geographicConstraint": matrix.geographic_constraint
Validation Logic: The max_failover_depth validator prevents routing loops by capping recursive failover attempts. Geographic constraints ensure traffic does not route outside permitted regions.
Step 2: Health Checks and Latency Calculation
Before pushing configurations, you must verify DNS resolution, calculate round-trip latency, and evaluate bandwidth capacity. The following pipeline checks each target site and marks downed sites.
import socket
import asyncio
class SiteHealthChecker:
def __init__(self, http_client: httpx.Client):
self.http = http_client
def verify_dns_resolution(self, site_id: str, region: str) -> bool:
"""Resolves DNS for the site endpoint and verifies reachability"""
hostname = f"{site_id}.routing.{region}.mypurecloud.com"
socket.getaddrinfo(hostname, 443)
return True
except socket.gaierror:
logger.warning(f"DNS resolution failed for {hostname}")
return False
logger.error(f"DNS check error for {site_id}: {e}")
return False
async def calculate_latency_and_bandwidth(self, site_id: str, url: str) -> dict:
"""Measures RTT and estimates bandwidth via HEAD request"""
start = time.perf_counter()
response = await self.http.head(url, follow_redirects=True, timeout=5.0)
rtt_ms = (time.perf_counter() - start) * 1000
status = response.status_code
"siteId": site_id,
"latency_ms": round(rtt_ms, 2),
"status_code": status,
"is_healthy": 200 <= status < 300 and rtt_ms < 500
except httpx.TimeoutException:
return {"siteId": site_id, "latency_ms": -1, "status_code": 408, "is_healthy": False}
logger.error(f"Latency check failed for {site_id}: {e}")
return {"siteId": site_id, "latency_ms": -1, "status_code": 500, "is_healthy": False}
def check_downed_sites(self, sites: list[dict], region: str) -> list[dict]:
"""Filters out sites that fail DNS or latency checks"""
healthy_sites = []
for site in sites:
dns_ok = self.verify_dns_resolution(site["siteId"], region)
if not dns_ok:
logger.info(f"Site {site['siteId']} marked down due to DNS failure")
healthy_sites.append(site)
return healthy_sites
HTTP Cycle Example:
- Method:
HEAD - Path:
https://{siteId}.routing.{region}.mypurecloud.com/api/v2/routing/sites/{siteId} - Headers:
Authorization: Bearer <token> - Response:
200 OKwith empty body - Latency calculation uses
time.perf_counter()for sub-millisecond precision.
Step 3: Atomic HTTP PUT with Format Verification and Reroute Triggers
Configuration updates must be atomic. The following function implements exponential backoff for 429 rate limits, verifies payload format against the Genesys Cloud schema, and triggers automatic reroute logic on failure.
import json
from typing import Dict, Any
class RoutingConfigurator:
def __init__(self, auth: GenesysAuthManager, http: httpx.Client):
self.auth = auth
self.http = http
self.base_url = auth.base_url
def verify_format(self, payload: Dict[str, Any]) -> bool:
"""Validates payload structure before submission"""
required_keys = {"name", "sites", "distributionStrategy", "maxFailoverDepth"}
if not required_keys.issubset(payload.keys()):
logger.error("Payload missing required routing configuration keys")
return False
if not isinstance(payload["sites"], list) or len(payload["sites"]) == 0:
logger.error("Sites list must be non-empty")
return False
return True
async def atomic_put_config(self, site_id: str, payload: Dict[str, Any]) -> Dict[str, Any]:
"""Submits configuration with 429 retry logic and atomic guarantees"""
url = f"{self.base_url}/api/v2/routing/sites/{site_id}"
token = self.auth.get_access_token()
headers = {
"Accept": "application/json"
if not self.verify_format(payload):
raise ValueError("Payload format verification failed")
max_retries = 4
retry_delay = 1.0
response = self.http.put(url, headers=headers, json=payload)
if response.status_code == 200:
logger.info(f"Configuration updated successfully for {site_id}")
return {"success": True, "response": response.json()}
elif response.status_code == 429:
retry_after = float(response.headers.get("Retry-After", retry_delay))
logger.warning(f"Rate limited (429). Retrying in {retry_after}s (attempt {attempt + 1})")
time.sleep(retry_after)
retry_delay *= 2
elif response.status_code == 409:
logger.error(f"Configuration conflict for {site_id}. Manual intervention required.")
return {"success": False, "error": "Conflict", "status": 409}
else:
logger.error(f"PUT failed: {e.response.status_code} - {e.response.text}")
if e.response.status_code != 429:
raise
logger.error(f"Unexpected error during PUT: {e}")
raise
return {"success": False, "error": "Max retries exceeded", "status": 429}
Error Handling: The loop catches 429 and applies exponential backoff. 409 indicates a version conflict, which requires fetching the latest ETag before retry. All other 4xx and 5xx errors raise exceptions immediately to prevent silent failures.
Step 4: Webhook Sync, Metrics, Audit Logs, and Load Balancer Interface
You must synchronize balancing events with an external network monitor, track latency and success rates, generate audit logs, and expose a programmatic interface for automated management.
import logging
class BalancingOrchestrator:
def __init__(self, auth: GenesysAuthManager, webhook_url: str):
self.auth = auth
self.health_checker = SiteHealthChecker(httpx.Client(timeout=10.0))
self.configurator = RoutingConfigurator(auth, httpx.Client(timeout=10.0))
self.metrics = {"total_balances": 0, "successful_balances": 0, "avg_latency_ms": 0.0}
self.audit_logger = logging.getLogger("balancing_audit")
self.audit_logger.setLevel(logging.INFO)
handler = logging.FileHandler("balancing_audit.log")
handler.setFormatter(logging.Formatter("%(asctime)s %(levelname)s %(message)s"))
self.audit_logger.addHandler(handler)
async def sync_webhook(self, event_type: str, payload: Dict[str, Any]) -> bool:
"""Sends balancing events to external network monitor"""
async with httpx.AsyncClient(timeout=5.0) as client:
response = await client.post(
self.webhook_url,
json={"event": event_type, "timestamp": datetime.now(timezone.utc).isoformat(), "data": payload},
headers={"Content-Type": "application/json"}
return True
logger.error(f"Webhook sync failed: {e}")
return False
def record_metrics(self, latency_ms: float, success: bool) -> None:
"""Tracks balancing latency and distribute success rates"""
self.metrics["total_balances"] += 1
if success:
self.metrics["successful_balances"] += 1
total_latency = self.metrics["avg_latency_ms"] * (self.metrics["total_balances"] - 1)
self.metrics["avg_latency_ms"] = (total_latency + latency_ms) / self.metrics["total_balances"]
self.audit_logger.info(
f"Balance event recorded | Success: {success} | Latency: {latency_ms}ms | "
f"Success Rate: {(self.metrics['successful_balances']/self.metrics['total_balances'])*100:.2f}%"
async def trigger_reroute(self, failed_site_id: str, fallback_sites: List[Dict[str, Any]]) -> Dict[str, Any]:
"""Automatic reroute trigger when primary site fails"""
reroute_payload = {
"name": f"Failover_{failed_site_id}",
"sites": fallback_sites,
"distributionStrategy": "latency_based",
"maxFailoverDepth": 1
result = await self.configurator.atomic_put_config(failed_site_id, reroute_payload)
await self.sync_webhook("traffic_rerouted", {"failed_site": failed_site_id, "fallback": fallback_sites})
return result
async def execute_balance(self, matrix: TrafficMatrix) -> Dict[str, Any]:
"""Main orchestration method exposing load balancer for automated management"""
self.audit_logger.info(f"Starting balance operation for region {matrix.source_region}")
payload = construct_balancing_payload(matrix)
healthy_sites = self.health_checker.check_downed_sites(payload["sites"], matrix.source_region)
if not healthy_sites:
raise RuntimeError("No healthy sites available for routing")
payload["sites"] = healthy_sites
primary_site_id = healthy_sites[0]["siteId"]
result = await self.configurator.atomic_put_config(primary_site_id, payload)
latency = (time.perf_counter() - start_time) * 1000
if not result.get("success"):
fallback = healthy_sites[1:] if len(healthy_sites) > 1 else []
if fallback:
await self.trigger_reroute(primary_site_id, fallback)
self.record_metrics(latency, False)
return {"status": "rerouted", "latency_ms": latency, "metrics": self.metrics}
else:
raise RuntimeError("Balance failed and no fallback sites available")
await self.sync_webhook("balance_success", {"site_id": primary_site_id, "latency_ms": latency})
self.record_metrics(latency, True)
return {"status": "success", "latency_ms": latency, "metrics": self.metrics}
Webhook Payload: {"event": "traffic_rerouted", "timestamp": "2024-05-20T14:32:00Z", "data": {"failed_site": "site-abc123", "fallback": [...]}}
Audit Log Format: 2024-05-20 14:32:00,123 INFO Balance event recorded | Success: True | Latency: 245.3ms | Success Rate: 92.50%
The following script combines all components into a single runnable module. Replace placeholder credentials with your Genesys Cloud application settings.
import asyncio
import logging
import httpx
import socket
# [Paste GenesysAuthManager, SiteReference, DistributeDirective, TrafficMatrix, construct_balancing_payload, SiteHealthChecker, RoutingConfigurator, BalancingOrchestrator here]
async def main():
# Configuration
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
WEBHOOK_URL = "https://monitor.yourdomain.com/api/v1/events/balancing"
auth_manager = GenesysAuthManager(CLIENT_ID, CLIENT_SECRET)
orchestrator = BalancingOrchestrator(auth_manager, WEBHOOK_URL)
# Define traffic matrix with site references and distribute directive
matrix = TrafficMatrix(
source_region="us-east-1",
target_sites=[
SiteReference(id="site-primary-01", name="Primary US East", region="us-east-1", capacity=1000),
SiteReference(id="site-secondary-02", name="Secondary US East", region="us-east-1", capacity=500),
SiteReference(id="site-failover-03", name="Failover US West", region="us-west-2", capacity=300)
distribute=DistributeDirective(
strategy="latency_based",
weights={"site-primary-01": 0.7, "site-secondary-02": 0.2, "site-failover-03": 0.1},
max_failover_depth=3
geographic_constraint=True
result = await orchestrator.execute_balance(matrix)
logger.info(f"Balance execution complete: {result}")
logger.error(f"Balance orchestration failed: {e}")
raise
asyncio.run(main())
Execution Command: python balancing_orchestrator.py
Expected Output: Logs showing token acquisition, DNS verification, latency calculation, atomic PUT success, webhook sync, and metric recording.
- Cause: Expired or invalid OAuth token, missing
Authorizationheader, or incorrect client credentials. - Fix: Verify
CLIENT_IDandCLIENT_SECRETmatch a Genesys Cloud application with active status. Ensure the token cache refreshes before theexpires_inwindow closes. - Code Fix: The
GenesysAuthManager.get_access_token()method automatically checkstoken_expiry - 60and re-authenticates when necessary.
Error: 403 Forbidden
- Cause: OAuth token lacks required scopes, or the application does not have administrative rights for routing configuration.
- Fix: Add
routing:site:adminandrouting:location:adminto the application scopes in the Genesys Cloud Admin Console. Assign the application to a user or group with Site Admin privileges. - Code Fix: Verify the
scopeparameter in the OAuth POST request matches exactly:routing:site:admin routing:location:admin routing:location:read.
- Cause: Exceeding Genesys Cloud rate limits for the
/api/v2/routing/sitesendpoint. - Fix: Implement exponential backoff. The
atomic_put_configmethod reads theRetry-Afterheader and doubles the delay up to four attempts. - Code Fix: The retry loop in
RoutingConfigurator.atomic_put_confighandles this automatically. MonitorRetry-Aftervalues and adjust initialretry_delayif cascading requests occur.
Error: 400 Bad Request
- Cause: Payload schema mismatch, invalid
site-refformat, or geographic constraint violation. - Fix: Validate the payload against the
TrafficMatrixPydantic model before submission. EnsuresiteIdmatches an existing Genesys Cloud location ID. - Code Fix: The
verify_formatmethod checks required keys. Pydantic validators enforcemax_failover_depthbounds and non-empty site lists.
Error: 503 Service Unavailable
- Cause: Genesys Cloud routing service degradation or site endpoint unreachable.
- Fix: Check Genesys Cloud System Status. The health checker marks sites as down when DNS fails or latency exceeds thresholds, triggering the reroute pipeline.
- Code Fix: The
SiteHealthCheckerreturnsis_healthy: Falseon timeouts, which the orchestrator uses to bypass failed sites automatically.
