Automating the Deactivation and Offboarding Process for Genesys Agents
This guide details the architectural implementation of a fully automated agent deactivation workflow within Genesys Cloud CX, triggered by HR system events via the Genesys Cloud API. You will build a secure, idempotent process that revokes telephony access, suspends user accounts, removes queue assignments, and archives interaction history without manual intervention.
- Licensing Tier: CX 1 or higher (User Management API access is standard, but WEM add-on required if suspending WEM licenses explicitly).
- Granular Permissions:
user:manage(to update user status),routing:queue:edit(to remove members),routing:skillgroup:edit(to remove members),admin:securityrole:read(for audit logging). - OAuth Scopes:
user:write,routing:edit,admin:edit(for the service account executing the automation). - External Dependencies: HRIS system (Workday, SAP, BambooHR) capable of webhooks or scheduled exports, or a middleware platform (MuleSoft, Boomi) acting as the integration orchestrator.
- Service Account: A dedicated Genesys Cloud User with
System Administratoror a custom security role possessing the exact permissions listed above. This account must not be a standard end-user.
1. Designing the Idempotent Deactivation Payload
The foundation of any enterprise offboarding process is idempotency. If the HR system retries the webhook due to a network timeout, your automation must not throw errors or attempt to deactivate an already deactivated user. You must design a single API call or a tightly scoped transaction that handles the full lifecycle.
Genesys Cloud does not provide a single “Delete User” endpoint that handles all downstream routing dependencies. Deleting a user while they are still a member of a queue or skill group will fail or leave orphaned references in the routing engine. Therefore, the architecture requires a sequential update strategy.
The Trap: Attempting to use the PATCH /api/v2/users/{userId} endpoint to set the user status to DEACTIVATED without first removing the user from all routing entities (Queues, Skill Groups, Wrap-up Codes, etc.). The Genesys API will return a 400 Bad Request with a validation error stating that the user cannot be deactivated while still assigned to active routing resources. This causes the automation to fail, leaving the user active in the system but flagged as “error” in your HRIS, creating a security gap.
Architectural Reasoning: We use a two-phase commit pattern within our integration middleware. Phase 1 strips all routing assignments. Phase 2 deactivates the user. If Phase 2 fails, Phase 1 is already complete, which is acceptable because a user with no routing assignments cannot receive calls. This is a safe failure state.
API Payload Construction:
First, retrieve the user’s current assignments to ensure we are not removing them from entities they are not in (which would cause API errors).
GET /api/v2/users/{userId}?exp=queues,skillGroups,wrapUpCodes,skills
Authorization: Bearer {access_token}
Response snippet:
"id": "a1b2c3d4-...",
"queues": [
"id": "queue-xyz-123",
"name": "General Support"
"skillGroups": [],
"wrapUpCodes": [],
"skills": []
Next, iterate through the queues array and remove the user.
PATCH /api/v2/routing/queues/{queueId}
"member": {
"remove": [
"type": "user"
Repeat this PATCH operation for any skillGroups returned in the initial query. Note that you must remove the user from skill groups explicitly, even if they are not directly assigned to queues, because skill groups can be used in Architect flows or routing strategies.
The Trap: Ignoring wrapUpCodes. While removing a user from wrap-up codes is not strictly required for deactivation (the API allows deactivation with wrap-up code assignments), it is a critical security and data integrity step. If you leave wrap-up code assignments, and that user is later reactivated or their account is compromised, they retain the ability to close interactions with specific dispositions. More importantly, if you are auditing who used which wrap-up codes, orphaned assignments create noise in your analytics. Best practice is to remove them.
"wrapUpCodes": {
"remove": [
"id": "wrapup-code-id-1"
2. Executing the User Deactivation
Once all routing dependencies are cleared, you can safely deactivate the user. The deactivation process in Genesys Cloud does not delete the user record. It changes the user’s status to DEACTIVATED. This is crucial for compliance. Deactivated users retain their interaction history, which is required for PCI-DSS, HIPAA, and general audit trails.
API Endpoint:
"status": "DEACTIVATED"
Architectural Reasoning: We use PATCH instead of PUT because PUT requires the entire user object. If you use PUT, you risk overwriting fields that were updated by other processes (e.g., WFM schedule updates, skill assignments from a separate provisioning pipeline). PATCH ensures atomic updates to only the status field.
The Trap: Assuming DEACTIVATED stops all access immediately. While DEACTIVATED prevents the user from logging into the Genesys Cloud UI or making/receiving calls, it does not revoke OAuth tokens already issued to that user’s sessions. If an agent has an active browser session or a mobile app token, they may retain access for the duration of that token’s expiry (typically 24 hours for Genesys Cloud). For high-security environments (finance, healthcare), you must implement a second step: force token revocation.
Forcing Token Revocation:
Genesys Cloud does not have a direct “Revoke All Tokens for User” API endpoint. However, you can achieve this by changing the user’s password or, more effectively, by leveraging the admin:securityrole to remove their access roles before deactivation. But the most robust method for immediate termination of active sessions is to update the user’s authentication settings.
Actually, the most reliable method in the current Genesys Cloud API set is to update the user’s authentication settings to force a re-authentication, but since the user is deactivated, they cannot re-authenticate. A more practical approach for high-security offboarding is to ensure the HRIS webhook triggers immediately upon termination, and you accept the token expiry window. If you need immediate revocation, you must use the PATCH /api/v2/users/{userId} to update the password field, which invalidates existing session cookies in many SSO configurations, but this is not guaranteed for OAuth2 bearer tokens.
Correct High-Security Approach:
Before deactivating, remove all security roles from the user. This ensures that even if a token persists, the user has no permissions to execute any API call or UI action.
"securityRoles": {
"remove": [
"id": "role-id-1",
"type": "role"
"id": "role-id-2",
"type": "role"
Only after removing security roles do you set the status to DEACTIVATED.
3. Archiving and Data Retention Configuration
Deactivating the user is only half the battle. You must ensure that the user’s interaction history is preserved according to your data retention policy. Genesys Cloud automatically retains interaction data for deactivated users, but you must configure the Data Retention Settings to ensure that the data is not purged prematurely.
Architectural Reasoning: Genesys Cloud uses a tiered storage model. Recent interactions are stored in hot storage (fast query), and older interactions are moved to cold storage (archival). If your retention policy is 7 years (common for finance), you must ensure that the cold storage retention period is set to at least 7 years. This is configured at the organization level, not the user level.
The Trap: Assuming that deactivating a user deletes their interaction data. It does not. However, if you have configured Automated Data Purging in the Genesys Cloud Admin Console, ensure that the purging schedule does not conflict with your legal hold requirements. If you have a legal hold on a specific agent’s interactions, you must apply a Legal Hold to the user’s interactions before deactivation.
Applying a Legal Hold:
POST /api/v2/analytics/legalholds
"name": "Offboarding Legal Hold - {userId}",
"description": "Legal hold for terminated employee {userId}",
"holdCriteria": {
"filter": {
"type": "user",
"id": "{userId}"
This ensures that no matter what the global data retention policy is, this user’s data is never deleted until the legal hold is released.
4. Integrating with HRIS via Webhooks
The automation is triggered by the HRIS. You must configure a webhook endpoint in your middleware (or Genesys Cloud Architect, though middleware is preferred for complex logic) that accepts the termination event.
Webhook Payload from HRIS:
"eventType": "user.terminated",
"timestamp": "2023-10-27T10:00:00Z",
"data": {
"userId": "a1b2c3d4-...",
"email": "agent@example.com",
"terminationDate": "2023-10-27"
Middleware Logic:
- Validate the webhook signature to ensure it came from the HRIS.
- Query Genesys Cloud to confirm the user exists and is currently
ACTIVE. - If active, execute the Phase 1 (remove routing assignments) and Phase 2 (remove security roles, deactivate user) logic.
- If the user is already
DEACTIVATED, log a warning and return a200 OKto the HRIS to prevent retry loops. - Return a
200 OKwith a JSON body confirming the deactivation status.
The Trap: Not handling the case where the user is already deactivated. If the HRIS retries the webhook, and your middleware attempts to remove routing assignments from a user who is already deactivated, the API will succeed (idempotent removal), but if the logic is not carefully written, you might attempt to remove security roles that were already removed, causing errors. Always check the current state of the user before making changes.
Architectural Reasoning: Use a message queue (e.g., AWS SQS, Azure Service Bus) between the HRIS webhook and the Genesys Cloud API calls. This decouples the HRIS from the Genesys Cloud API latency. If Genesys Cloud is slow or under maintenance, the message queue holds the termination event, and your middleware processes it when the API is available. This ensures that no termination event is lost.
5. Audit Logging and Compliance Reporting
Every deactivation event must be logged for audit purposes. You must log the following:
- The
userIdof the deactivated user. - The timestamp of the deactivation.
- The identity of the service account that performed the deactivation.
- The source of the trigger (HRIS webhook ID).
- The result of each API call (success/failure).
API Endpoint for Audit Logs:
GET /api/v2/analytics/details?filter=entityName:user&filter=entityId:{userId}&filter=action:deactivate
You can also use the Event Streams API to subscribe to real-time audit events.
GET /api/v2/analytics/eventstreams?filter=entityName:user&filter=action:deactivate
The Trap: Relying solely on Genesys Cloud’s internal audit logs. While Genesys Cloud provides audit logs, they are not always sufficient for external compliance audits (e.g., PCI-DSS). You must export these logs to a secure, immutable storage system (e.g., AWS S3 with Object Lock, Azure Blob Storage with Immutable Blob) to ensure they cannot be tampered with by internal administrators.
Edge Case 1: The “Orphaned Queue Member” Failure
- The Failure Condition: The API returns a
400 Bad Requestwith the message “User cannot be deactivated while still assigned to routing resources.” - The Root Cause: The user was assigned to a queue or skill group after the initial query but before the deactivation command was issued. This is a race condition in high-concurrency environments.
- The Solution: Implement a retry loop with exponential backoff. Before each retry, re-query the user’s routing assignments. If new assignments are found, remove them. If the error persists after 3 retries, log a critical alert and escalate to a human administrator. This indicates a systemic issue with the routing assignment process.
Edge Case 2: The “Active Session” Persistence
- The Failure Condition: The user is deactivated, but they can still access the Genesys Cloud UI or make API calls using an existing OAuth token.
- The Root Cause: The OAuth token has not expired, and the user was not removed from their security roles before deactivation.
- The Solution: Ensure that security roles are removed before the user status is set to
DEACTIVATED. This ensures that even if the token is valid, the user has no permissions to perform any action. For immediate revocation of all sessions, consider using a SSO provider that supports forced logout (e.g., Okta, Azure AD) and trigger a logout from the SSO provider as part of the offboarding workflow.
Edge Case 3: The “Reactivated User” Conflict
- The Failure Condition: A user is reactivated within 24 hours of deactivation, but their routing assignments are not restored.
- The Root Cause: The deactivation process removed all routing assignments, but the reactivation process did not restore them.
- The Solution: Do not remove routing assignments during deactivation if you anticipate a high rate of reactivations (e.g., temporary contractors). Instead, use a “Suspend” status in your HRIS and only deactivate users who are permanently terminated. If you must remove assignments, store the user’s routing assignments in a database before deactivation, so they can be restored upon reactivation.
Edge Case 4: The “WEM License” Leak
- The Failure Condition: The user is deactivated, but the WEM (Workforce Engagement Management) license remains assigned, costing the organization money.
- The Root Cause: WEM licenses are managed separately from CX licenses. Deactivating the CX user does not automatically release the WEM license.
- The Solution: Include a step in the automation to remove the user from the WEM license pool. This requires the
wem:license:editpermission.
PATCH /api/v2/wem/licenses/{licenseId}
"userId": null
