Automating Routing Capacity and Queue Scaling via Genesys Cloud Python SDK
- A Python module that programmatically adjusts routing queue capacity, validates license entitlements, synchronizes changes via webhooks, and tracks provisioning metrics using the Genesys Cloud CX Python SDK.
- This uses the
genesyscloudSDK and real routing, webhook, analytics, and audit endpoints. - The programming language covered is Python 3.10+.
- OAuth client type: Service Account (Client Credentials Grant)
- Required scopes:
routing:queue:read,routing:queue:write,platform:webhook:create,platform:auditlog:read,analytics:report:run,user:read - SDK version:
genesyscloud>=2.0.0 - Language/runtime: Python 3.10+
- External dependencies:
httpx>=0.25.0,pydantic>=2.0.0
Genesys Cloud CX uses OAuth 2.0 Client Credentials flow for service accounts. The Python SDK handles token acquisition and automatic refresh. You must store credentials securely in environment variables.
import os
from genesyscloud import PureCloudPlatformClientV2
from genesyscloud.auth import OAuthClientCredentialsConfig
def initialize_client() -> PureCloudPlatformClientV2:
"""Initialize the Genesys Cloud SDK client with service account authentication."""
client = PureCloudPlatformClientV2()
client.set_base_url(os.getenv("GENESYS_CLOUD_BASE_URL", "https://api.mypurecloud.com"))
oauth_config = OAuthClientCredentialsConfig(
client_id=os.getenv("GENESYS_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLIENT_SECRET"),
oauth_host_url="https://login.mypurecloud.com"
client.set_oauth_client_credentials_config(oauth_config)
# Trigger initial token fetch
client.login()
return client
HTTP Equivalent:
- Method:
POST - Path:
https://login.mypurecloud.com/oauth/token - Headers:
Content-Type: application/x-www-form-urlencoded - Body:
grant_type=client_credentials&client_id={CLIENT_ID}&client_secret={CLIENT_SECRET} - Scopes: Passed as
scope=routing:queue:read+routing:queue:write+platform:webhook:create+platform:auditlog:read+analytics:report:run+user:read
Expected Response:
"token_type": "Bearer",
"expires_in": 3599,
"scope": "routing:queue:read routing:queue:write platform:webhook:create platform:auditlog:read analytics:report:run user:read"
The SDK caches the token and automatically refreshes before expiration. You do not need to implement manual refresh logic when using set_oauth_client_credentials_config.
Step 1: Validate License Entitlements and Capacity Constraints
Genesys Cloud CX is a fully managed SaaS platform. Infrastructure scaling is handled automatically by the platform. Developer-controlled capacity scaling occurs through routing queues and agent assignments. Before modifying queue capacity, you must verify that the organization holds sufficient user licenses and that the queue configuration complies with platform constraints.
from genesyscloud import PlatformApi, UserApi, RoutingApi
def validate_entitlements_and_constraints(
platform_api: PlatformApi,
user_api: UserApi,
target_agents: List[str],
max_agents: int = 1000
) -> Dict[str, Any]:
"""Verify license counts and queue capacity constraints before scaling."""
validation_result = {
"valid": True,
"errors": [],
"entitled_users": 0,
"target_count": len(target_agents)
# Retrieve licensed user count
user_response = user_api.post_users_query(
body={"query": "status:active", "pageSize": 1, "pageNumber": 1}
validation_result["entitled_users"] = user_response.total
if len(target_agents) > max_agents:
validation_result["valid"] = False
validation_result["errors"].append(
f"Target agent count {len(target_agents)} exceeds maximum node limit {max_agents}"
if len(target_agents) > validation_result["entitled_users"]:
f"Insufficient licenses. Requested {len(target_agents)}, available {validation_result['entitled_users']}"
except ApiException as e:
validation_result["errors"].append(f"Entitlement validation failed: {e.status} {e.reason}")
return validation_result
HTTP Equivalent:
- Method:
POST - Path:
/api/v2/users/query - Headers:
Authorization: Bearer {ACCESS_TOKEN},Content-Type: application/json - Body:
{"query": "status:active", "pageSize": 1, "pageNumber": 1} - Scopes:
user:read
Expected Response:
"total": 450,
"pageCount": 450,
"pageSize": 1,
"page": 1,
"order": "asc",
"divisionId": null,
"entities": []
The validation pipeline checks license availability against the target agent list. It enforces a hard maximum node count to prevent configuration rejection by the routing engine.
Step 2: Construct Scale Payload and Execute Atomic PATCH
Capacity adjustments use atomic PATCH operations on the queue resource. The payload must include updated member references, service level targets, and overflow rules. The SDK validates schema compliance before transmission.
from genesyscloud import RoutingQueueEntity, RoutingQueueWrapupcodeEntity
def build_scale_payload(
queue_id: str,
agent_ids: List[str],
service_level_percent: float = 80.0,
service_level_sec: int = 20
"""Construct a validated queue scaling payload."""
"id": queue_id,
"name": f"ScaleQueue-{queue_id[:8]}",
"description": "Automatically scaled routing capacity",
"enabled": True,
"outboundEnabled": False,
"memberIds": agent_ids,
"serviceLevel": {
"enabled": True,
"percent": service_level_percent,
"threshold": service_level_sec
"overflowSettings": {
"enabled": True,
"waitTime": 30,
"threshold": 90,
"overflowTarget": {
"id": None,
"type": "queue"
"wrapUpCodes": []
def apply_scale_patch(
routing_api: RoutingApi,
queue_id: str,
payload: Dict[str, Any],
retry_count: int = 3
"""Execute atomic PATCH with 429 retry logic and format verification."""
for attempt in range(retry_count):
# SDK automatically serializes dict to RoutingQueueEntity
response = routing_api.patch_routing_queue(
queue_id=queue_id,
body=payload
"success": True,
"status": 200,
"queue_id": response.id,
"member_count": len(response.memberIds or []),
"attempt": attempt + 1
if e.status == 429 and attempt < retry_count - 1:
wait_time = 2 ** attempt
time.sleep(wait_time)
elif e.status == 400:
"success": False,
"status": 400,
"error": f"Schema validation failed: {e.body}",
else:
"success": False,
"status": e.status,
"error": f"PATCH failed: {e.reason}",
"success": False,
"status": 429,
"error": "Exhausted retry attempts due to rate limiting",
"attempt": retry_count
HTTP Equivalent:
- Method:
PATCH - Path:
/api/v2/routing/queues/{queueId} - Headers:
"name": "ScaleQueue-a1b2c3d4",
"enabled": true,
"outboundEnabled": false,
"memberIds": ["agent-uuid-1", "agent-uuid-2", "agent-uuid-3"],
"serviceLevel": {
"enabled": true,
"percent": 80.0,
"threshold": 20
"enabled": true,
"waitTime": 30,
"threshold": 90,
"overflowTarget": {
"id": null,
"type": "queue"
"wrapUpCodes": []
- Scopes:
routing:queue:write
Expected Response:
"enabled": true,
"serviceLevel": {
"enabled": true,
"percent": 80.0,
"threshold": 20
"enabled": true,
"waitTime": 30,
"threshold": 90,
"overflowTarget": {
"id": null,
"type": "queue"
"wrapUpCodes": [],
"selfUri": "/api/v2/routing/queues/a1b2c3d4-e5f6-7890-abcd-ef1234567890"
The PATCH operation replaces the entire resource representation. The retry loop handles 429 responses with exponential backoff. Schema validation failures return 400 with detailed field errors.
Step 3: Register Webhook Callbacks and Synchronize Events
You must synchronize scaling events with external cloud managers. Webhooks deliver real-time notifications for queue updates, member changes, and health check triggers.
from genesyscloud import PlatformApi, WebhookEntity
from typing import Dict, Any
def register_scale_webhook(
queue_id: str,
callback_url: str,
webhook_name: str = "QueueScaleSync"
"""Create webhook for routing queue event synchronization."""
webhook_config = {
"name": webhook_name,
"description": "Synchronizes queue scaling events with external cloud manager",
"enabled": True,
"apiVersion": "V2",
"filter": f"queueId eq '{queue_id}'",
"url": callback_url,
"event": "routing.queue.updated",
"contentType": "application/json",
"headers": {
"X-Webhook-Source": "GenesysCloudScaler"
"secret": None
response = platform_api.post_platform_webhooks(body=webhook_config)
"success": True,
"webhook_id": response.id,
"event": response.event,
"filter": response.filter,
"url": response.url
"success": False,
"status": e.status,
"error": f"Webhook registration failed: {e.reason}"
HTTP Equivalent:
- Method:
POST - Path:
/api/v2/platform/webhooks - Headers:
"name": "QueueScaleSync",
"enabled": true,
"apiVersion": "V2",
"filter": "queueId eq 'a1b2c3d4-e5f6-7890-abcd-ef1234567890'",
"url": "https://cloud-manager.example.com/api/v1/sync/genesys/queue",
"headers": {
"secret": null
- Scopes:
Expected Response:
"id": "wh-98765432-abcd-ef01-2345-6789abcdef01",
"enabled": true,
"apiVersion": "V2",
"headers": {
"secret": null,
"selfUri": "/api/v2/platform/webhooks/wh-98765432-abcd-ef01-2345-6789abcdef01"
The webhook filter restricts notifications to the specific queue. The platform triggers automatic health check validations after successful PATCH operations. You receive the updated queue state in the webhook payload.
Step 4: Track Provisioning Metrics and Generate Audit Logs
You must measure scaling latency, instance provision success rates, and maintain audit trails for governance. The Analytics API provides queue performance data. The Audit API records configuration changes.
from genesyscloud import AnalyticsApi, PlatformApi
def track_scaling_metrics(
analytics_api: AnalyticsApi,
queue_id: str,
start_time: float
"""Query queue metrics and calculate provisioning latency."""
end_time = time.time()
latency_seconds = end_time - start_time
query_body = {
"dateFrom": (datetime.utcnow() - timedelta(hours=1)).isoformat(),
"dateTo": datetime.utcnow().isoformat(),
"interval": "PT1H",
"groupBy": ["queue.id"],
"filter": f"queue.id eq '{queue_id}'",
"metrics": [
"conversation/offerCount",
"conversation/acceptedCount",
"conversation/serviceLevel"
response = analytics_api.post_analytics_queues_details_query(body=query_body)
total_offers = sum(entity.metrics.get("conversation/offerCount", 0) for entity in response.entities)
total_accepted = sum(entity.metrics.get("conversation/acceptedCount", 0) for entity in response.entities)
success_rate = (total_accepted / total_offers * 100) if total_offers > 0 else 0.0
"latency_seconds": round(latency_seconds, 3),
"total_offers": total_offers,
"total_accepted": total_accepted,
"success_rate_percent": round(success_rate, 2),
"query_status": "completed"
"query_status": "failed",
"error": f"Analytics query failed: {e.status} {e.reason}"
def generate_audit_log(
queue_id: str,
scale_result: Dict[str, Any]
"""Retrieve audit logs for governance and compliance tracking."""
query_body = {
"query": f"targetEntityId eq '{queue_id}'",
"pageSize": 5,
"pageNumber": 1
response = platform_api.post_platform_auditlogs_query(body=query_body)
audit_entries = [
"id": entry.id,
"eventType": entry.eventType,
"timestamp": entry.timestamp,
"initiatingUser": entry.initiatingUser.id if entry.initiatingUser else "SYSTEM",
"targetEntity": entry.targetEntity.id,
"summary": entry.summary
for entry in response.entities
"success": True,
"audit_count": len(audit_entries),
"entries": audit_entries
"success": False,
"status": e.status,
"error": f"Audit log retrieval failed: {e.reason}"
HTTP Equivalent (Analytics):
- Method:
POST - Path:
/api/v2/analytics/queues/details/query - Headers:
"dateFrom": "2024-01-15T10:00:00Z",
"dateTo": "2024-01-15T11:00:00Z",
"interval": "PT1H",
"filter": "queue.id eq 'a1b2c3d4-e5f6-7890-abcd-ef1234567890'",
"metrics": [
- Scopes:
HTTP Equivalent (Audit):
- Method:
POST - Path:
/api/v2/platform/auditlogs/query - Headers:
{"query": "targetEntityId eq 'a1b2c3d4-e5f6-7890-abcd-ef1234567890'", "pageSize": 5, "pageNumber": 1} - Scopes:
The analytics query returns aggregated metrics for the target queue. The audit log query retrieves configuration change history. Both endpoints support pagination via nextPage tokens in the response.
import os
from genesyscloud import PureCloudPlatformClientV2, OAuthClientCredentialsConfig
from genesyscloud import RoutingApi, PlatformApi, UserApi, AnalyticsApi
class QueueCapacityScaler:
"""Automated routing capacity scaler with validation, synchronization, and audit tracking."""
def __init__(self, client: PureCloudPlatformClientV2):
self.routing_api = RoutingApi(client)
self.platform_api = PlatformApi(client)
self.user_api = UserApi(client)
self.analytics_api = AnalyticsApi(client)
def execute_scale_operation(
self,
queue_id: str,
callback_url: str,
"""Orchestrate the complete scaling pipeline."""
operation_log = {
"queue_id": queue_id,
"target_agents": len(agent_ids),
"steps": {}
# Step 1: Validate entitlements
start_time = time.time()
validation = self._validate_entitlements(agent_ids, max_agents)
operation_log["steps"]["validation"] = validation
if not validation["valid"]:
operation_log["status"] = "failed_validation"
return operation_log
# Step 2: Construct and apply PATCH
payload = self._build_scale_payload(queue_id, agent_ids)
patch_result = self._apply_scale_patch(queue_id, payload)
operation_log["steps"]["patch"] = patch_result
if not patch_result["success"]:
operation_log["status"] = "failed_patch"
# Step 3: Register webhook
webhook_result = self._register_scale_webhook(queue_id, callback_url)
operation_log["steps"]["webhook"] = webhook_result
# Step 4: Track metrics and audit
metrics = self._track_scaling_metrics(queue_id, start_time)
audit = self._generate_audit_log(queue_id)
operation_log["steps"]["metrics"] = metrics
operation_log["steps"]["audit"] = audit
operation_log["status"] = "completed"
def _validate_entitlements(self, target_agents: List[str], max_agents: int) -> Dict[str, Any]:
user_response = self.user_api.post_users_query(
entitled = user_response.total
valid = len(target_agents) <= max_agents and len(target_agents) <= entitled
"valid": valid,
"entitled_users": entitled,
"errors": [] if valid else [
f"Exceeded limit" if len(target_agents) > max_agents else "Insufficient licenses"
return {"valid": False, "entitled_users": 0, "errors": [f"API Error: {e.status}"]}
def _build_scale_payload(self, queue_id: str, agent_ids: List[str]) -> Dict[str, Any]:
"id": queue_id,
"enabled": True,
"serviceLevel": {"enabled": True, "percent": 80.0, "threshold": 20},
"enabled": True,
"waitTime": 30,
"threshold": 90,
"overflowTarget": {"id": None, "type": "queue"}
"wrapUpCodes": []
def _apply_scale_patch(self, queue_id: str, payload: Dict[str, Any], retry_count: int = 3) -> Dict[str, Any]:
response = self.routing_api.patch_routing_queue(queue_id=queue_id, body=payload)
return {"success": True, "status": 200, "queue_id": response.id, "attempt": attempt + 1}
time.sleep(2 ** attempt)
return {"success": False, "status": e.status, "error": str(e), "attempt": attempt + 1}
return {"success": False, "status": 429, "error": "Rate limit exhausted", "attempt": retry_count}
def _register_scale_webhook(self, queue_id: str, callback_url: str) -> Dict[str, Any]:
response = self.platform_api.post_platform_webhooks(body={
"enabled": True,
"apiVersion": "V2",
"headers": {"X-Webhook-Source": "GenesysCloudScaler"},
"secret": None
return {"success": True, "webhook_id": response.id}
return {"success": False, "status": e.status, "error": str(e)}
def _track_scaling_metrics(self, queue_id: str, start_time: float) -> Dict[str, Any]:
latency = time.time() - start_time
response = self.analytics_api.post_analytics_queues_details_query(body={
"interval": "PT1H",
"metrics": ["conversation/offerCount", "conversation/acceptedCount"]
offers = sum(e.metrics.get("conversation/offerCount", 0) for e in response.entities)
accepted = sum(e.metrics.get("conversation/acceptedCount", 0) for e in response.entities)
"latency_seconds": round(latency, 3),
"success_rate_percent": round((accepted / offers * 100) if offers > 0 else 0, 2),
"status": "completed"
return {"latency_seconds": round(latency, 3), "status": "failed", "error": str(e)}
def _generate_audit_log(self, queue_id: str) -> Dict[str, Any]:
response = self.platform_api.post_platform_auditlogs_query(
body={"query": f"targetEntityId eq '{queue_id}'", "pageSize": 5, "pageNumber": 1}
return {"success": True, "count": len(response.entities)}
client.set_oauth_client_credentials_config(OAuthClientCredentialsConfig(
client.login()
scaler = QueueCapacityScaler(client)
result = scaler.execute_scale_operation(
queue_id="a1b2c3d4-e5f6-7890-abcd-ef1234567890",
agent_ids=["agent-uuid-1", "agent-uuid-2", "agent-uuid-3"],
callback_url="https://cloud-manager.example.com/api/v1/sync/genesys/queue"
print(result)
Error: 403 Forbidden
- Cause: The service account lacks the required OAuth scopes or the queue division does not match the account’s division access.
- Fix: Verify the client credentials grant includes
routing:queue:write. Ensure the account has write permissions on the queue’s division. Update the scope string during token acquisition. - Code Fix: Add missing scopes to
OAuthClientCredentialsConfigor assign the service account to the correct division in the admin console.
Error: 400 Bad Request
- Cause: The PATCH payload violates schema constraints. Common issues include invalid UUID formats in
memberIds, negative service level thresholds, or circular overflow references. - Fix: Validate all UUIDs before transmission. Ensure
serviceLevel.thresholdis positive. VerifyoverflowTarget.idreferences a different queue. - Code Fix: Implement pre-flight validation using
uuid.UUID()parsing and range checks before callingpatch_routing_queue.
- Cause: The routing engine enforces per-tenant rate limits. Rapid scaling iterations or concurrent webhook registrations trigger throttling.
- Fix: Implement exponential backoff. Space out PATCH operations by at least 500 milliseconds. Batch webhook creation if scaling multiple queues.
- Code Fix: The
_apply_scale_patchmethod includes a retry loop withtime.sleep(2 ** attempt). Increaseretry_countfor production workloads.
Error: 404 Not Found
- Cause: The queue ID does not exist in the target environment or the account lacks visibility due to division restrictions.
- Fix: Verify the queue ID using
get_routing_queue. Confirm division alignment between the service account and the queue resource. - Code Fix: Add a pre-check call to
routing_api.get_routing_queue(queue_id)before executing the PATCH operation.
