Automating Resource Distribution and Routing Rebalancing in Genesys Cloud via Python SDK
- This script distributes routing capacity across queues, validates configuration limits, applies atomic updates, and synchronizes events with external systems.
- This implementation uses the Genesys Cloud Routing API, Integrations API, and Analytics API with the official Python HTTP client.
- The tutorial covers Python 3.10+ with production-grade error handling, retry logic, and structured audit logging.
- OAuth 2.0 Client Credentials grant configured in the Genesys Cloud admin console
- Required scopes:
routing:queue:write,routing:queue:read,integration:write,analytics:query,user:read - Genesys Cloud API v2 endpoints (
/api/v2/...) - Python 3.10 or higher
- External dependencies:
pip install httpx pydantic python-dotenv structlog
Genesys Cloud uses OAuth 2.0 for all API access. The client credentials flow returns an access token that expires after 3600 seconds. You must cache the token and request a new one before expiration to avoid 401 interruptions.
import os
import httpx
from typing import Optional
class GenesysAuth:
def __init__(self, env: str, client_id: str, client_secret: str):
self.base_url = f"https://{env}.mygenesys.cloud"
self.client_id = client_id
self.token_expiry: float = 0
def get_token(self) -> str:
if self.token and time.time() < (self.token_expiry - 60):
return self.token
with httpx.Client(timeout=15) as client:
response = client.post(
f"{self.base_url}/oauth/token",
data={
"client_id": self.client_id,
"scope": "routing:queue:write routing:queue:read integration:write analytics:query user:read"
response.raise_for_status()
payload = response.json()
self.token = payload["access_token"]
self.token_expiry = time.time() + payload["expires_in"]
return self.token
The get_token method checks the local cache first. If the token is valid for more than 60 seconds, it returns the cached value. Otherwise it performs a POST to /oauth/token with the required scopes. The expiration timestamp is stored to prevent repeated network calls.
Step 1: Validate Distribution Payloads Against Topology Constraints
Genesys Cloud enforces capacity and assignment limits at the queue level. You must validate the node matrix (agent assignments) and distribute directive (routing strategy) before sending a PATCH request. The validation checks maximum concurrent capacity, skill assignment conflicts, and ensures no orphaned references exist.
import pydantic
class DistributionPayload(pydantic.BaseModel):
queue_id: str
capacity: int
members: List[str]
routing_strategy: str
max_per_zone: int = 50
@pydantic.validator("capacity")
def validate_capacity(cls, v: int) -> int:
if v < 1 or v > 1000:
raise ValueError("Capacity must be between 1 and 1000")
return v
@pydantic.validator("routing_strategy")
def validate_strategy(cls, v: str) -> str:
allowed = ["longest_idle_agent", "most_available", "fewest_conversations", "random", "longest_available_agent"]
if v not in allowed:
raise ValueError(f"Invalid routing strategy: {v}")
return v
def validate_topology(self, user_ids: List[str]) -> List[str]:
orphaned = [uid for uid in self.members if uid not in user_ids]
if len(self.members) > self.max_per_zone:
raise ValueError(f"Assignment exceeds maximum per zone limit: {self.max_per_zone}")
return orphaned
The DistributionPayload model enforces schema validation at the Python level. The validate_topology method returns orphaned user IDs that do not exist in the provided user matrix. You call this method before constructing the HTTP PATCH body. The max_per_zone parameter prevents cluster fragmentation by capping assignments per logical zone.
Step 2: Execute Atomic Routing Configuration Updates via HTTP PATCH
You apply distribution changes using atomic PATCH operations against /api/v2/routing/queues/{queueId}. The request must include the If-Match header with the current ETag to prevent race conditions. You must also implement 429 retry logic with exponential backoff.
import logging
from typing import Dict, Any
logger = logging.getLogger("rebalancer")
class QueueRebalancer:
def __init__(self, auth: GenesysAuth):
self.auth = auth
self.base_url = auth.base_url
def _retry_request(self, method: str, url: str, headers: Dict[str, str], json: Dict[str, Any]) -> httpx.Response:
max_retries = 3
token = self.auth.get_token()
headers["Authorization"] = f"Bearer {token}"
with httpx.Client(timeout=30) as client:
response = client.request(method, url, headers=headers, json=json)
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
logger.warning("Rate limited. Retrying in %d seconds", retry_after)
time.sleep(retry_after)
return response
raise RuntimeError("Max retries exceeded for 429 response")
def apply_distribution(self, payload: DistributionPayload, etag: str) -> Dict[str, Any]:
patch_body = {
"capacity": payload.capacity,
"routingStrategy": payload.routing_strategy,
"memberIds": payload.members,
"wrapUpCodeRequired": False,
"skillsRequired": []
headers = {
"If-Match": etag
response = self._retry_request(
"PATCH",
f"{self.base_url}/api/v2/routing/queues/{payload.queue_id}",
headers=headers,
json=patch_body
return response.json()
The apply_distribution method constructs a minimal PATCH body. You must supply the current ETag to ensure atomic updates. The _retry_request helper handles 429 responses by reading the Retry-After header and applying exponential backoff. The method returns the updated queue object for downstream processing.
Step 3: Implement Orphaned Resource Checking and Webhook Certificate Verification
Before triggering external synchronization, you verify that all assigned users are active and that the target webhook endpoint presents a valid certificate chain. This step prevents cluster fragmentation and ensures high availability.
import ssl
import socket
def verify_user_matrix(auth: GenesysAuth, user_ids: List[str]) -> List[str]:
token = auth.get_token()
active_users = []
for uid in user_ids:
response = client.get(
f"{auth.base_url}/api/v2/users/{uid}",
headers={"Authorization": f"Bearer {token}"}
if response.status_code == 200:
data = response.json()
if data.get("status") == "active":
active_users.append(uid)
return active_users
def verify_webhook_certificate(host: str, port: int = 443) -> bool:
context = ssl.create_default_context()
with socket.create_connection((host, port), timeout=10) as sock:
with context.wrap_socket(sock, server_hostname=host) as ssock:
cert = ssock.getpeercert()
if not cert:
return False
return True
except (ssl.SSLError, socket.timeout, ConnectionError):
return False
The verify_user_matrix function iterates through assigned user IDs and checks their status via /api/v2/users/{id}. Only active users are returned for inclusion in the PATCH payload. The verify_webhook_certificate function performs a TLS handshake against the external endpoint to validate the certificate chain. You call this before registering or triggering the webhook integration.
Step 4: Synchronize Events with External Systems and Track Latency/Metrics
You register a webhook integration to notify external Kubernetes clusters or orchestration systems. You also query the Analytics API to track distribution success rates and rebalancing latency. Pagination is handled via the nextPage token.
import json
import structlog
audit_logger = structlog.get_logger("audit")
def register_webhook(auth: GenesysAuth, target_url: str) -> str:
payload = {
"name": "Cluster Rebalance Sync",
"integrationType": "webhook",
"configuration": {
"url": target_url,
"method": "POST",
"headers": {
"X-Source": "Genesys-Rebalancer"
"eventSubscriptions": [
"routing:queue:updated"
f"{auth.base_url}/api/v2/integrations/webhooks",
headers={"Authorization": f"Bearer {token}"},
json=payload
return response.json()["id"]
def query_rebalancing_metrics(auth: GenesysAuth, queue_id: str, start_time: str, end_time: str) -> List[Dict[str, Any]]:
query_payload = {
"interval": "PT1H",
"dateFrom": start_time,
"dateTo": end_time,
"viewId": "default",
"query": {
"type": "queue",
"selector": {"type": "id", "ids": [queue_id]},
"filter": {
"type": "or",
"clauses": [{"type": "metric", "metric": "offerCount", "operator": ">", "value": 0}]
"metrics": ["offerCount", "acceptCount", "abandonCount"],
"groupings": [{"type": "queue", "property": "id"}]
results = []
next_page = None
while True:
params = {"nextPage": next_page} if next_page else {}
f"{auth.base_url}/api/v2/analytics/queues/details/query",
headers=headers,
json=query_payload,
params=params
results.extend(data.get("entities", []))
next_page = data.get("nextPage")
if not next_page:
break
return results
The register_webhook function creates a webhook integration subscribed to routing:queue:updated events. The query_rebalancing_metrics function retrieves queue analytics with pagination support. You calculate distribute success rates by dividing acceptCount by offerCount across the returned entities. Latency is tracked by recording timestamps before and after each PATCH operation.
The following script combines all components into a single runnable module. You must set environment variables for credentials and configuration.
import os
import logging
import structlog
from datetime import datetime, timezone, timedelta
audit = structlog.get_logger("rebalance_audit")
def main():
env = os.getenv("GENESYS_ENV", "mypurecloud")
queue_id = os.getenv("TARGET_QUEUE_ID")
etag = os.getenv("QUEUE_ETAG")
target_url = os.getenv("EXTERNAL_WEBHOOK_URL", "https://hooks.example.com/rebalance")
user_ids = os.getenv("ASSIGNED_USER_IDS", "").split(",")
if not all([client_id, client_secret, queue_id, etag]):
raise ValueError("Missing required environment variables")
auth = GenesysAuth(env, client_id, client_secret)
# Step 1: Validate topology
active_users = verify_user_matrix(auth, user_ids)
payload = DistributionPayload(
queue_id=queue_id,
capacity=int(os.getenv("QUEUE_CAPACITY", "50")),
members=active_users,
routing_strategy=os.getenv("ROUTING_STRATEGY", "longest_idle_agent"),
max_per_zone=int(os.getenv("MAX_PER_ZONE", "50"))
orphaned = payload.validate_topology(active_users)
if orphaned:
audit.warning("orphaned_users_found", orphaned=orphaned)
# Step 2: Verify external endpoint
host = target_url.replace("https://", "").split("/")[0]
if not verify_webhook_certificate(host):
raise ConnectionError("Webhook certificate verification failed")
# Step 3: Register webhook
webhook_id = register_webhook(auth, target_url)
audit.info("webhook_registered", id=webhook_id)
# Step 4: Apply distribution with latency tracking
start = time.perf_counter()
result = QueueRebalancer(auth).apply_distribution(payload, etag)
latency = time.perf_counter() - start
audit.info("distribution_applied", queue_id=queue_id, latency_ms=round(latency * 1000, 2))
# Step 5: Query metrics for success rate calculation
now = datetime.now(timezone.utc)
entities = query_rebalancing_metrics(auth, queue_id, (now - timedelta(hours=1)).isoformat(), now.isoformat())
total_offers = sum(e.get("metrics", {}).get("offerCount", {}).get("value", 0) for e in entities)
total_accepts = sum(e.get("metrics", {}).get("acceptCount", {}).get("value", 0) for e in entities)
success_rate = (total_accepts / total_offers * 100) if total_offers > 0 else 0
audit.info("rebalance_metrics", success_rate=round(success_rate, 2), total_offers=total_offers)
print("Rebalancing cycle completed successfully.")
main()
The script loads configuration from environment variables, validates the user matrix, verifies the webhook certificate, registers the integration, applies the PATCH update, tracks latency, and queries analytics for success rates. All operations include structured audit logging for governance compliance.
- What causes it: The OAuth token has expired or the client credentials are incorrect.
- How to fix it: Verify
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETin the environment. Ensure theGenesysAuthclass refreshes the token before expiration. - Code showing the fix: The
get_tokenmethod checksself.token_expiryand requests a new token when the remaining lifetime falls below 60 seconds.
Error: 403 Forbidden
- What causes it: The OAuth client lacks the required scopes or the queue belongs to a different organization environment.
- How to fix it: Add
routing:queue:writeandintegration:writeto the client credentials grant in the admin console. Verify the environment URL matches the token issuer. - Code showing the fix: The token request explicitly includes all required scopes in the
scopeparameter.
- What causes it: You exceeded the API rate limit for routing or analytics endpoints.
- How to fix it: Implement exponential backoff and respect the
Retry-Afterheader. - Code showing the fix: The
_retry_requestmethod captures 429 responses, readsRetry-After, sleeps, and retries up to three times before raising an exception.
Error: 400 Bad Request
- What causes it: The PATCH payload contains invalid capacity values, unsupported routing strategies, or missing required fields.
- How to fix it: Use the
DistributionPayloadPydantic model to validate inputs before sending. EnsureIf-Matchcontains a valid ETag from a prior GET request. - Code showing the fix: The
validate_capacityandvalidate_strategymethods reject out-of-range values and unsupported strategies before HTTP transmission.
