Automating NICE CXone Outbound Campaign Pause and Resume Triggers with Python
  • A Python service that polls an external weather alert API, matches severe weather regions to campaign geographic attributes, and automatically pauses or resumes CXone outbound campaigns via PATCH requests.
  • This implementation uses the NICE CXone Outbound Campaigns REST API and standard OAuth 2.0 Client Credentials authentication.
  • The tutorial covers Python 3.9+ with requests, structured audit logging, pagination handling, and explicit 409 conflict resolution.
  • OAuth Client Type: Confidential client with outbound:campaign:read and outbound:campaign:write scopes
  • API Version: CXone /api/v2/outbound/campaigns
  • Runtime: Python 3.9 or newer
  • Dependencies: requests>=2.31.0, pydantic>=2.0.0 (optional for validation, not used here to keep dependencies minimal)
  • External Weather API: Any REST endpoint returning structured alert data (example uses a standard JSON alert format)
CXone uses the standard OAuth 2.0 Client Credentials flow. The token endpoint lives at https://{organization}.niceincontact.com/oauth2/token. You must cache the access token and implement a refresh buffer to avoid unnecessary authentication calls.
import requests
from typing import Optional
class CXoneAuth:
    def __init__(self, org_url: str, client_id: str, client_secret: str):
        self.org_url = org_url.rstrip("/")
        self.client_id = client_id
        self.token_url = f"{self.org_url}/oauth2/token"
        self.session = requests.Session()
        self.session.timeout = (10, 20)
    def get_token(self) -> str:
        """Fetches or returns cached OAuth token with a 300-second safety buffer."""
        if time.time() < self.token_expiry and self.access_token:
            return self.access_token
        payload = {
            "client_id": self.client_id,
            response = self.session.post(self.token_url, data=payload, headers=headers)
            response.raise_for_status()
        except requests.exceptions.HTTPError as exc:
                raise ValueError("Invalid client credentials or incorrect grant type.") from exc
            if response.status_code == 403:
                raise ValueError("Client lacks authorization for the requested scope.") from exc
            raise
        token_data = response.json()
        self.token_expiry = time.time() + token_data["expires_in"] - 300
    def get_authenticated_headers(self) -> dict:
            "Authorization": f"Bearer {self.get_token()}",
            "Accept": "application/json"
HTTP Cycle: Token Request
POST /oauth2/token HTTP/1.1
Host: {organization}.niceincontact.com
grant_type=client_credentials&client_id=YOUR_CLIENT_ID&client_secret=YOUR_CLIENT_SECRET
Expected Response:
  "access_token": "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9...",
  "token_type": "Bearer",
  "expires_in": 3600,
  "scope": "outbound:campaign:read outbound:campaign:write"
Step 1: Campaign Discovery and Region Matching
CXone returns campaign lists with pagination. You must iterate through pages to evaluate all active campaigns. Each campaign object contains a custom_attributes map where you store geographic identifiers. The service compares these identifiers against weather alert regions.
import logging
logger = logging.getLogger("weather_campaign_service")
def fetch_all_campaigns(auth: CXoneAuth, page_size: int = 50) -> List[Dict[str, Any]]:
    """Paginates through /api/v2/outbound/campaigns to collect all campaigns."""
    campaigns = []
    page = 1
    base_url = f"{auth.org_url}/api/v2/outbound/campaigns"
    headers = auth.get_authenticated_headers()
    while True:
        params = {"page": page, "pageSize": page_size}
        response = requests.get(base_url, headers=headers, params=params, timeout=15)
        campaigns.extend(data.get("entities", []))
        if page >= data.get("pageCount", 1):
            break
        page += 1
    return campaigns
HTTP Cycle: Campaign List Request
GET /api/v2/outbound/campaigns?page=1&pageSize=50 HTTP/1.1
Authorization: Bearer {access_token}
Accept: application/json
Expected Response:
  "page": 1,
  "pageSize": 50,
  "count": 2,
  "total": 2,
  "pageCount": 1,
  "entities": [
      "id": "camp-a1b2c3d4-e5f6-7890-abcd-ef1234567890",
      "name": "Northeast Outreach Q3",
      "status": "running",
      "custom_attributes": {
        "region": "US-NE",
        "timezone": "America/New_York"
The weather alert parser extracts affected regions. You must normalize region codes to match your campaign custom_attributes.region values.
def fetch_weather_alerts(weather_url: str) -> List[Dict[str, Any]]:
    """Polls external weather API for active severe alerts."""
    response = requests.get(weather_url, timeout=10)
    # Adapts to common alert structures; adjust keys to match your provider
    return data.get("alerts", [])
def match_campaigns_to_alerts(
    campaigns: List[Dict[str, Any]],
    alerts: List[Dict[str, Any]]
) -> Dict[str, List[str]]:
    """Returns a mapping of campaign IDs to matching alert regions."""
    affected_campaigns: Dict[str, List[str]] = {}
    alert_regions = set()
    for alert in alerts:
        # Weather APIs vary; this example assumes a 'regions' array in each alert
        regions = alert.get("regions", [])
        alert_regions.update(regions)
    for campaign in campaigns:
        region = campaign.get("custom_attributes", {}).get("region")
        if region and region in alert_regions:
            affected_campaigns[campaign["id"]] = [region]
    return affected_campaigns
Step 2: Status Verification and 409 Conflict Resolution
CXone returns HTTP 409 Conflict when a campaign cannot transition to the requested state. This occurs when you attempt to pause an already paused campaign, resume a completed campaign, or modify a draft. The service must verify the current phase before retrying or logging a state mismatch.
def verify_campaign_status(auth: CXoneAuth, campaign_id: str) -> str:
    """Fetches current campaign status to resolve 409 conflicts."""
    url = f"{auth.org_url}/api/v2/outbound/campaigns/{campaign_id}"
    response = requests.get(url, headers=headers, timeout=10)
    return response.json().get("status", "unknown")
HTTP Cycle: Single Campaign GET
GET /api/v2/outbound/campaigns/camp-a1b2c3d4-e5f6-7890-abcd-ef1234567890 HTTP/1.1
Expected Response:
    "region": "US-NE"
Step 3: PATCH Execution and Audit Logging
The PATCH request toggles the campaign status. You must include the exact status string expected by CXone (paused or running). The service implements exponential backoff for 429 rate limits and structured JSON logging for operational auditing.
import json
import logging
from logging.handlers import RotatingFileHandler
def setup_audit_logger(log_file: str = "campaign_interventions.log") -> logging.Logger:
    logger.setLevel(logging.INFO)
    handler = RotatingFileHandler(log_file, maxBytes=10_000_000, backupCount=5)
    handler.setFormatter(logging.Formatter("%(message)s"))
    logger.addHandler(handler)
    return logger
def patch_campaign_status(
    auth: CXoneAuth,
    campaign_id: str,
    target_status: str,
    logger: logging.Logger,
    max_retries: int = 3
) -> bool:
    """Sends PATCH to toggle campaign status with 409 verification and 429 retry logic."""
    payload = {"status": target_status}
    for attempt in range(1, max_retries + 1):
            response = requests.patch(url, headers=headers, json=payload, timeout=15)
            if response.status_code == 200:
                logger.info(json.dumps({
                    "event": "status_change_success",
                    "campaign_id": campaign_id,
                    "new_status": target_status,
                    "attempt": attempt
                return True
            if response.status_code == 409:
                current_status = verify_campaign_status(auth, campaign_id)
                logger.warning(json.dumps({
                    "event": "status_conflict_resolved",
                    "requested_status": target_status,
                    "actual_status": current_status,
                    "action": "skip" if current_status == target_status else "retry"
                if current_status == target_status:
                    return True  # Already in desired state
                return False  # Incompatible state, do not force
                wait_time = 2 ** attempt
                    "event": "rate_limited",
                    "retry_in_seconds": wait_time
                time.sleep(wait_time)
        except requests.exceptions.RequestException as exc:
            logger.error(json.dumps({
                "event": "api_error",
                "error": str(exc),
                "attempt": attempt
            if attempt == max_retries:
                return False
            time.sleep(1)
    return False
HTTP Cycle: Campaign Status PATCH
PATCH /api/v2/outbound/campaigns/camp-a1b2c3d4-e5f6-7890-abcd-ef1234567890 HTTP/1.1
{"status": "paused"}
Expected Response:
  "status": "paused",
    "region": "US-NE"
This script combines authentication, polling, region matching, conflict resolution, and audit logging into a single executable service. Replace the placeholder credentials and weather URL before execution.
import os
import json
import logging
import requests
from typing import List, Dict, Any, Optional
class CXoneAuth:
        payload = {
        self.access_token = data["access_token"]
        self.token_expiry = time.time() + data["expires_in"] - 300
def setup_audit_logger() -> logging.Logger:
    handler = logging.StreamHandler()
    return logger
    campaigns = []
    page = 1
    while True:
            break
        page += 1
    return campaigns
    return response.json().get("alerts", [])
def match_campaigns_to_alerts(campaigns: List[Dict[str, Any]], alerts: List[Dict[str, Any]]) -> Dict[str, List[str]]:
def patch_campaign_status(auth: CXoneAuth, campaign_id: str, target_status: str, logger: logging.Logger, max_retries: int = 3) -> bool:
                logger.info(json.dumps({"event": "status_change_success", "campaign_id": campaign_id, "new_status": target_status, "attempt": attempt}))
                return True
                logger.warning(json.dumps({"event": "status_conflict_resolved", "campaign_id": campaign_id, "requested_status": target_status, "actual_status": current_status, "action": "skip" if current_status == target_status else "retry"}))
                return current_status == target_status
                logger.warning(json.dumps({"event": "rate_limited", "campaign_id": campaign_id, "retry_in_seconds": wait_time}))
            logger.error(json.dumps({"event": "api_error", "campaign_id": campaign_id, "error": str(exc), "attempt": attempt}))
                return False
            time.sleep(1)
    return False
def run_weather_campaign_controller(
    org_url: str,
    client_id: str,
    client_secret: str,
    weather_api_url: str,
    poll_interval_seconds: int = 300
    auth = CXoneAuth(org_url, client_id, client_secret)
    logger = setup_audit_logger()
    logger.info(json.dumps({"event": "service_started", "org": org_url, "poll_interval": poll_interval_seconds}))
    while True:
            logger.info(json.dumps({"event": "poll_cycle_start"}))
            campaigns = fetch_all_campaigns(auth)
            alerts = fetch_weather_alerts(weather_api_url)
            affected = match_campaigns_to_alerts(campaigns, alerts)
            logger.info(json.dumps({"event": "region_match_complete", "affected_campaign_count": len(affected)}))
            for campaign_id, regions in affected.items():
                target_status = "paused"
                logger.info(json.dumps({"event": "weather_intervention_triggered", "campaign_id": campaign_id, "regions": regions, "target_status": target_status}))
                patch_campaign_status(auth, campaign_id, target_status, logger)
        except Exception as exc:
            logger.error(json.dumps({"event": "unhandled_error", "error": str(exc), "traceback": "check logs"}))
        time.sleep(poll_interval_seconds)
        org_url=os.getenv("CXONE_ORG_URL", "https://your-org.niceincontact.com"),
        client_id=os.getenv("CXONE_CLIENT_ID", "your_client_id"),
        client_secret=os.getenv("CXONE_CLIENT_SECRET", "your_client_secret"),
        weather_api_url=os.getenv("WEATHER_API_URL", "https://api.weather.example.com/v1/alerts"),
        poll_interval_seconds=300
Error: HTTP 401 Unauthorized
  • Cause: Expired access token, invalid client credentials, or missing outbound:campaign:read scope on the OAuth application.
  • Fix: Verify the client ID and secret match a CXone OAuth application with the correct scopes. Ensure the token refresh buffer does not exceed expires_in. The get_token method automatically refreshes, but initial 401 failures indicate credential mismatch.
  • Code Fix: Check that grant_type=client_credentials is sent as form data, not JSON. CXone rejects JSON payloads for token requests.
Error: HTTP 403 Forbidden
  • Cause: The OAuth client lacks outbound:campaign:write scope, or the campaign belongs to a contact center where the client lacks permissions.
  • Fix: Add outbound:campaign:write to the OAuth application scopes in the CXone admin console. Reauthenticate after scope changes.
  • Code Fix: Inspect the token response scope field to confirm write permissions are granted.
Error: HTTP 409 Conflict
  • Cause: Attempting to pause a campaign already in paused state, or modifying a campaign in draft or completed phase.
  • Fix: The service calls verify_campaign_status on 409. If the campaign is already in the target state, the service logs a skip. If the campaign is in an incompatible state, the service logs a warning and proceeds to the next campaign.
  • Code Fix: Ensure your business logic accounts for campaigns that finish or fail during the poll interval. The verification step prevents infinite retry loops.
  • Cause: Exceeding CXone rate limits (typically 100 requests per second globally, with lower limits per endpoint).
  • Fix: The implementation uses exponential backoff (2 ** attempt). For production workloads, distribute requests across multiple poll cycles or implement a token bucket algorithm.
  • Code Fix: Monitor Retry-After headers if CXone returns them. The current fallback sleeps for 2, 4, or 8 seconds depending on the attempt count.
Error: HTTP 5xx Server Errors
  • Cause: CXone platform maintenance, database locks, or transient network failures.
  • Fix: Implement circuit breaker logic for extended outages. The current script retries up to 3 times with linear backoff. If all retries fail, the error logs to the audit file for manual review.
  • Code Fix: Wrap the poll loop in a try-except block that catches requests.exceptions.ConnectionError and requests.exceptions.Timeout. Log the failure and continue to the next poll cycle rather than crashing the service.
