Automating NICE Cognigy Flow Deployments via CI/CD with a Java Gradle Plugin
- A Gradle plugin that extracts Cognigy flow definitions from a staging tenant, validates JSON structure against a custom linter, resolves cross-flow dependencies via a manifest file, deploys the artifacts to a production tenant using the Cognigy REST API, and verifies runtime health after deployment.
- The implementation uses the Cognigy Platform API v2.
- The code is written in Java 17 and follows standard Gradle plugin development conventions.
- Cognigy tenant credentials for staging and production environments with
flow:read,flow:write, andproject:readpermissions - Cognigy API v2 base URLs for both environments
- Java 17+ runtime and Gradle 8.x
- External dependencies:
com.fasterxml.jackson.core:jackson-databind:2.15.2,com.fasterxml.jackson.datatype:jackson-datatype-jsr310:2.15.2 - A
manifest.jsonfile in the repository root defining flow dependencies
Cognigy uses a token-based authentication flow. You must POST credentials to /api/v2/auth/login to receive a JWT token. The token is cached in memory and reused for subsequent requests. The following Java implementation handles token acquisition, caching, and automatic refresh when a 401 response occurs.
import java.net.URI;
import java.time.Instant;
public class CognigyAuthManager {
private final String baseUrl;
private final String username;
private final String password;
private final ConcurrentHashMap<String, AuthToken> tokenCache = new ConcurrentHashMap<>();
private final HttpClient httpClient;
public CognigyAuthManager(String baseUrl, String username, String password) {
this.baseUrl = baseUrl.endsWith("/") ? baseUrl.substring(0, baseUrl.length() - 1) : baseUrl;
this.username = username;
this.password = password;
this.httpClient = HttpClient.newBuilder()
.version(HttpClient.Version.HTTP_2)
.build();
public String getAccessToken() throws Exception {
String cacheKey = username;
AuthToken cached = tokenCache.get(cacheKey);
if (cached != null && Instant.now().isBefore(cached.expiresAt)) {
return cached.token;
String loginPayload = String.format(
"{\"username\": \"%s\", \"password\": \"%s\"}", username, password);
.uri(URI.create(baseUrl + "/api/v2/auth/login"))
.POST(HttpRequest.BodyPublishers.ofString(loginPayload))
.build();
throw new RuntimeException("Authentication failed with status " + response.statusCode() + ": " + response.body());
// Expected response: {"token": "eyJhbGci...", "expiresIn": 3600}
JsonNode root = new ObjectMapper().readTree(response.body());
String token = root.get("token").asText();
long expiresIn = root.get("expiresIn").asLong();
AuthToken newToken = new AuthToken(token, Instant.now().plusSeconds(expiresIn - 60));
tokenCache.put(cacheKey, newToken);
return token;
private static class AuthToken {
final String token;
final Instant expiresAt;
AuthToken(String token, Instant expiresAt) {
this.token = token;
this.expiresAt = expiresAt;
Step 1: Gradle Plugin Structure and Task Definition
You must register the plugin and define a task that exposes configuration properties for staging, production, and manifest paths. The task action orchestrates the export, validation, resolution, deployment, and health check phases.
// build.gradle (Plugin Project)
plugins {
id 'java-gradle-plugin'
id 'java-library'
repositories {
mavenCentral()
dependencies {
implementation 'com.fasterxml.jackson.core:jackson-databind:2.15.2'
implementation 'com.fasterxml.jackson.datatype:jackson-datatype-jsr310:2.15.2'
gradlePlugin {
plugins {
cognigyDeploy {
id = 'com.example.cognigy-deploy'
implementationClass = 'com.example.gradle.CognigyDeployPlugin'
// src/main/java/com/example/gradle/CognigyDeployPlugin.java
package com.example.gradle;
import org.gradle.api.Plugin;
import org.gradle.api.Project;
public class CognigyDeployPlugin implements Plugin<Project> {
@Override
public void apply(Project project) {
project.getTasks().register("deployCognigyFlows", CognigyDeployTask.class);
Step 2: API Client with Token Caching and 429 Retry Logic
The HTTP client must handle pagination for flow exports, implement exponential backoff for 429 rate limits, and attach the Bearer token automatically. The following class centralizes request execution.
import java.net.http.*;
import java.util.List;
import java.util.Map;
import java.util.stream.Collectors;
public class CognigyApiClient {
private final CognigyAuthManager authManager;
private final ObjectMapper mapper;
public CognigyApiClient(String baseUrl, CognigyAuthManager authManager) {
this.authManager = authManager;
.connectTimeout(java.time.Duration.ofSeconds(10))
.build();
this.mapper = new ObjectMapper();
public List<Map<String, Object>> getFlowsPaginated(String projectId, int limit) throws Exception {
List<Map<String, Object>> allFlows = new java.util.ArrayList<>();
int offset = 0;
while (true) {
String token = authManager.getAccessToken();
String url = String.format("%s/api/v2/projects/%s/flows?limit=%d&offset=%d",
baseUrl, projectId, limit, offset);
.uri(URI.create(url))
.header("Accept", "application/json")
.GET()
.build();
HttpResponse<String> response = executeWithRetry(request);
if (response.statusCode() == 401) {
authManager.invalidateCache(); // Force refresh
return getFlowsPaginated(projectId, limit);
JsonNode root = mapper.readTree(response.body());
JsonNode data = root.get("data");
if (data == null || !data.isArray() || data.isEmpty()) break;
for (JsonNode node : data) {
allFlows.add(mapper.convertValue(node, Map.class));
if (data.size() < limit) break;
offset += limit;
return allFlows;
public Map<String, Object> getFlowById(String projectId, String flowId) throws Exception {
.uri(URI.create(String.format("%s/api/v2/projects/%s/flows/%s", baseUrl, projectId, flowId)))
.GET()
.build();
if (response.statusCode() == 401) throw new RuntimeException("Token expired during flow fetch");
if (response.statusCode() != 200) throw new RuntimeException("Failed to fetch flow: " + response.statusCode());
return mapper.convertValue(root.get("data"), Map.class);
public void deployFlow(String projectId, String flowId, Map<String, Object> flowPayload) throws Exception {
String jsonPayload = mapper.writeValueAsString(flowPayload);
.PUT(HttpRequest.BodyPublishers.ofString(jsonPayload))
.build();
if (response.statusCode() == 401) throw new RuntimeException("Token expired during deployment");
if (response.statusCode() != 200 && response.statusCode() != 202) {
throw new RuntimeException("Deployment failed: " + response.statusCode() + " " + response.body());
private HttpResponse<String> executeWithRetry(HttpRequest request) throws Exception {
int maxRetries = 5;
long baseDelayMs = 500;
Exception lastException = null;
for (int attempt = 0; attempt < maxRetries; attempt++) {
return httpClient.send(request, HttpResponse.BodyHandlers.ofString());
} catch (HttpRetryException e) {
if (e.getStatusCode() == 429) {
long delay = baseDelayMs * (long) Math.pow(2, attempt) + (long) (Math.random() * 100);
Thread.sleep(delay);
continue;
throw e;
throw lastException;
Step 3: Export Flow Definitions from Staging
The export phase retrieves all flows from the staging project using pagination. You must store the raw JSON definitions for later validation and deployment.
// Inside CognigyDeployTask.java
@TaskAction
public void execute() throws Exception {
CognigyAuthManager stagingAuth = new CognigyAuthManager(stagingUrl.get(), stagingUser.get(), stagingPass.get());
CognigyApiClient stagingClient = new CognigyApiClient(stagingUrl.get(), stagingAuth);
getLogger().lifecycle("Exporting flows from staging project: " + stagingProjectId.get());
List<Map<String, Object>> exportedFlows = stagingClient.getFlowsPaginated(stagingProjectId.get(), 50);
if (exportedFlows.isEmpty()) {
throw new GradleException("No flows found in staging environment");
getLogger().quiet("Exported " + exportedFlows.size() + " flow definitions");
// Proceed to validation and dependency resolution
Step 4: Custom Linter Validation and Dependency Resolution
You must validate each flow JSON against structural requirements and resolve execution order using a manifest file. The linter checks for required fields and valid node references. The resolver builds a topological sort based on the manifest.
import java.io.File;
import java.util.*;
public class FlowLinter {
public static void validateFlowDefinition(Map<String, Object> flow) {
if (!flow.containsKey("id") || !flow.containsKey("name") || !flow.containsKey("nodes")) {
throw new IllegalArgumentException("Invalid flow structure: missing id, name, or nodes");
List<?> nodes = (List<?>) flow.get("nodes");
Set<String> nodeIds = nodes.stream()
.map(n -> ((Map<?, ?>) n).get("id"))
.filter(Objects::nonNull)
.map(Object::toString)
.collect(Collectors.toSet());
if (nodeIds.size() != nodes.size()) {
throw new IllegalArgumentException("Flow contains duplicate or missing node IDs");
public class DependencyResolver {
private final ObjectMapper mapper = new ObjectMapper();
public List<String> resolveOrder(File manifestPath, List<Map<String, Object>> flows) throws Exception {
JsonNode manifest = mapper.readTree(manifestPath);
Map<String, List<String>> dependencies = new HashMap<>();
// Build dependency graph from manifest
for (Map<String, Object> flow : flows) {
String flowId = flow.get("id").toString();
JsonNode depNode = manifest.get(flowId);
if (depNode != null && depNode.isArray()) {
List<String> deps = new ArrayList<>();
for (JsonNode d : depNode) deps.add(d.asText());
dependencies.put(flowId, deps);
} else {
dependencies.put(flowId, Collections.emptyList());
// Topological sort
List<String> ordered = new ArrayList<>();
Set<String> visited = new HashSet<>();
Set<String> inStack = new HashSet<>();
for (String flowId : dependencies.keySet()) {
if (!visited.contains(flowId)) {
dfs(flowId, dependencies, visited, inStack, ordered);
return ordered;
private void dfs(String node, Map<String, List<String>> graph, Set<String> visited,
Set<String> inStack, List<String> result) {
if (inStack.contains(node)) throw new IllegalArgumentException("Circular dependency detected: " + node);
if (visited.contains(node)) return;
inStack.add(node);
for (String dep : graph.getOrDefault(node, Collections.emptyList())) {
dfs(dep, graph, visited, inStack, result);
inStack.remove(node);
visited.add(node);
result.add(node);
Step 5: Production Deployment and Health Check Verification
After validation and ordering, you push each flow to production using the PUT endpoint. You must verify deployment health by polling the flow status until the runtime reports a successful state.
// Continuation of CognigyDeployTask.java @TaskAction
CognigyAuthManager prodAuth = new CognigyAuthManager(prodUrl.get(), prodUser.get(), prodPass.get());
CognigyApiClient prodClient = new CognigyApiClient(prodUrl.get(), prodAuth);
File manifestFile = new File(manifestPath.get());
DependencyResolver resolver = new DependencyResolver();
List<String> orderedFlowIds = resolver.resolveOrder(manifestFile, exportedFlows);
Map<String, Map<String, Object>> flowMap = exportedFlows.stream()
.collect(Collectors.toMap(f -> f.get("id").toString(), f -> f));
for (String flowId : orderedFlowIds) {
Map<String, Object> flowDef = flowMap.get(flowId);
FlowLinter.validateFlowDefinition(flowDef);
getLogger().lifecycle("Deploying flow: " + flowId);
prodClient.deployFlow(prodProjectId.get(), flowId, flowDef);
// Health check verification
boolean healthy = waitForHealthyState(prodClient, prodProjectId.get(), flowId, 30);
if (!healthy) {
throw new GradleException("Flow " + flowId + " failed health check post-deployment");
getLogger().quiet("Flow " + flowId + " deployed and verified healthy");
private boolean waitForHealthyState(CognigyApiClient client, String projectId, String flowId, int maxPolls) throws Exception {
for (int i = 0; i < maxPolls; i++) {
Thread.sleep(2000);
Map<String, Object> status = client.getFlowById(projectId, flowId);
String state = (String) status.get("status");
if ("DEPLOYED".equalsIgnoreCase(state) || "ACTIVE".equalsIgnoreCase(state)) {
return true;
return false;
The following file contains the complete Gradle task implementation. Place it in src/main/java/com/example/gradle/CognigyDeployTask.java within your plugin project.
import org.gradle.api.DefaultTask;
import org.gradle.api.GradleException;
import org.gradle.api.tasks.TaskAction;
import org.gradle.api.tasks.Input;
import org.gradle.api.tasks.InputFile;
import org.gradle.api.tasks.Optional;
import org.gradle.api.tasks.Internal;
public class CognigyDeployTask extends DefaultTask {
@Input
private String stagingUrl;
@Input
private String stagingUser;
@Input
private String stagingPass;
@Input
private String stagingProjectId;
@Input
private String prodUrl;
@Input
private String prodUser;
@Input
private String prodPass;
@Input
private String prodProjectId;
@InputFile
@Optional
private File manifestPath;
public void setStagingUrl(String stagingUrl) { this.stagingUrl = stagingUrl; }
public void setStagingUser(String stagingUser) { this.stagingUser = stagingUser; }
public void setStagingPass(String stagingPass) { this.stagingPass = stagingPass; }
public void setStagingProjectId(String stagingProjectId) { this.stagingProjectId = stagingProjectId; }
public void setProdUrl(String prodUrl) { this.prodUrl = prodUrl; }
public void setProdUser(String prodUser) { this.prodUser = prodUser; }
public void setProdPass(String prodPass) { this.prodPass = prodPass; }
public void setProdProjectId(String prodProjectId) { this.prodProjectId = prodProjectId; }
public void setManifestPath(File manifestPath) { this.manifestPath = manifestPath; }
@TaskAction
getLogger().lifecycle("Starting Cognigy Flow Deployment Pipeline");
CognigyAuthManager stagingAuth = new CognigyAuthManager(stagingUrl, stagingUser, stagingPass);
CognigyApiClient stagingClient = new CognigyApiClient(stagingUrl, stagingAuth);
getLogger().lifecycle("Exporting flows from staging project: " + stagingProjectId);
List<Map<String, Object>> exportedFlows = stagingClient.getFlowsPaginated(stagingProjectId, 50);
CognigyAuthManager prodAuth = new CognigyAuthManager(prodUrl, prodUser, prodPass);
CognigyApiClient prodClient = new CognigyApiClient(prodUrl, prodAuth);
File manifestFile = manifestPath != null ? manifestPath : new File("manifest.json");
if (flowDef == null) {
getLogger().warn("Skipping flow " + flowId + " as it was not exported from staging");
continue;
prodClient.deployFlow(prodProjectId, flowId, flowDef);
boolean healthy = waitForHealthyState(prodClient, prodProjectId, flowId, 15);
if (!healthy) {
getLogger().lifecycle("Deployment pipeline completed successfully");
Thread.sleep(2000);
return true;
} catch (Exception e) {
getLogger().warn("Health check poll " + (i + 1) + " failed: " + e.getMessage());
return false;
To run the plugin in your CI/CD pipeline, add the following to your project build.gradle:
plugins {
id 'com.example.cognigy-deploy'
deployCognigyFlows {
stagingUrl = System.getenv("COGNIGY_STAGING_URL")
stagingUser = System.getenv("COGNIGY_STAGING_USER")
stagingPass = System.getenv("COGNIGY_STAGING_PASS")
stagingProjectId = System.getenv("COGNIGY_STAGING_PROJECT_ID")
prodUrl = System.getenv("COGNIGY_PROD_URL")
prodUser = System.getenv("COGNIGY_PROD_USER")
prodPass = System.getenv("COGNIGY_PROD_PASS")
prodProjectId = System.getenv("COGNIGY_PROD_PROJECT_ID")
manifestPath = file("manifest.json")
- Cause: The JWT token has expired or the credentials are incorrect. Cognigy tokens typically expire after one hour.
- Fix: The
CognigyAuthManagerautomatically refreshes tokens on 401. If the error persists, verify that the username and password match a Cognigy account with API access enabled. Ensure the account is not locked due to failed login attempts.
Error: 403 Forbidden
- Cause: The authenticated user lacks the required
flow:readorflow:writescopes for the target project. - Fix: Navigate to the Cognigy Admin Console, locate the user or service account, and assign the
Flow ManagerorProject Adminrole. Verify that the project ID matches the environment where the user holds permissions.
- Cause: The Cognigy API rate limiter has throttled the deployment pipeline due to rapid sequential requests.
- Fix: The
executeWithRetrymethod implements exponential backoff with jitter. If deployments still fail, reduce the paginationlimitparameter or add a static delay between flow deployments in the task loop.
Error: 502 Bad Gateway or 503 Service Unavailable
- Cause: The Cognigy runtime is temporarily unavailable or the deployment payload is too large for the current gateway configuration.
- Fix: Verify the staging environment is reachable. If the error occurs during health checks, increase the
maxPollsparameter inwaitForHealthyState. Split large flows into smaller modular components if the payload exceeds Cognigy gateway limits.
Error: Circular Dependency Detected
- Cause: The
manifest.jsoncontains a dependency loop (Flow A depends on Flow B, which depends on Flow A). - Fix: Review the manifest structure and remove circular references. Cognigy flows must be deployed in a strictly acyclic order. The
DependencyResolverwill throw an explicit exception with the offending node ID.
