Automating NICE Cognigy.AI Flow Deployment with Python
This script exports flow definitions from a NICE Cognigy.AI environment, validates structure against schema constraints, resolves cross-flow dependencies, generates a deployment manifest with version metadata, pushes updates to production, verifies deployment status, and executes rollback on failure while maintaining an audit trail. This uses the NICE Cognigy.AI REST API v2. The implementation uses Python 3.10+ with httpx, jsonschema, and the standard logging module.
- OAuth2 client credentials or API key with
flows:read,flows:write,environments:read, anddeployments:managescopes - Cognigy.AI API v2 access enabled on your tenant
- Python 3.10+ runtime
- External dependencies:
pip install httpx jsonschema pydantic aiofiles - Network access to your Cognigy region endpoint (e.g.,
https://us-east-1.cognigy.ai/api/v2)
Cognigy.AI supports OAuth2 client credentials flow for service-to-service authentication. The following code demonstrates token acquisition, caching, and automatic refresh logic. You must replace the placeholder credentials with your tenant values.
import httpx
import json
from typing import Optional
class CognigyAuth:
def __init__(self, client_id: str, client_secret: str, auth_url: str):
self.client_id = client_id
self.auth_url = auth_url
self._expires_at: float = 0.0
def _fetch_token(self) -> dict:
payload = {
"client_id": self.client_id,
"scope": "flows:read flows:write environments:read deployments:manage"
with httpx.Client() as client:
response = client.post(self.auth_url, data=payload, timeout=10.0)
response.raise_for_status()
return response.json()
def get_token(self) -> str:
if self._token and time.time() < self._expires_at - 60:
return self._token
token_data = self._fetch_token()
self._token = token_data["access_token"]
self._expires_at = time.time() + token_data["expires_in"]
return self._token
"Authorization": f"Bearer {self.get_token()}",
"Accept": "application/json"
The token cache prevents unnecessary authentication requests. The get_token method checks expiration with a sixty-second buffer to avoid mid-request authentication failures. The required scopes are explicitly requested during token issuance.
Step 1: Export Flow Definitions via REST API
Cognigy.AI returns flow definitions in paginated responses. You must iterate through pages using offset and limit query parameters. The endpoint requires the flows:read scope.
import httpx
def export_flows(auth: CognigyAuth, base_url: str, limit: int = 100) -> List[Dict[str, Any]]:
flows: List[Dict[str, Any]] = []
offset = 0
while True:
params = {"limit": limit, "offset": offset}
response = client.get(
f"{base_url}/flows",
headers=auth.get_headers(),
params=params,
timeout=30.0
retry_after = int(response.headers.get("Retry-After", 2))
time.sleep(retry_after)
data = response.json()
if not data.get("items"):
break
flows.extend(data["items"])
offset += limit
if offset >= data.get("total", offset):
break
return flows
Expected response structure:
"items": [
"id": "flow_abc123",
"name": "CustomerSupport",
"version": "1.2.0",
"environmentId": "env_dev",
"nodes": [],
"edges": [],
"externalReferences": []
"total": 1,
"limit": 100,
"offset": 0
The loop terminates when offset meets or exceeds total. The 429 retry logic respects the Retry-After header or defaults to two seconds. You must handle 401 and 403 by verifying token validity and scope permissions.
Step 2: Validate Flow Syntax Against Schema Constraints
Flow definitions must conform to Cognigy.AI structural requirements. You will use jsonschema to validate nodes, edges, and external references before deployment.
import jsonschema
from jsonschema import validate, ValidationError
FLOW_SCHEMA = {
"type": "object",
"required": ["id", "name", "version", "nodes", "edges"],
"properties": {
"id": {"type": "string", "pattern": "^flow_[a-zA-Z0-9]+$"},
"name": {"type": "string", "minLength": 1},
"version": {"type": "string", "pattern": "^\\d+\\.\\d+\\.\\d+$"},
"nodes": {
"type": "array",
"items": {
"type": "object",
"required": ["id", "type", "configuration"],
"properties": {
"id": {"type": "string"},
"type": {"type": "string", "enum": ["start", "intent", "action", "end", "external"]},
"configuration": {"type": "object"}
"edges": {
"type": "array",
"items": {
"type": "object",
"required": ["from", "to", "condition"],
"properties": {
"from": {"type": "string"},
"to": {"type": "string"},
"condition": {"type": ["string", "null"]}
"externalReferences": {
"type": "array",
"items": {
"type": "object",
"required": ["type", "id", "environmentId"],
"properties": {
"type": {"type": "string", "enum": ["flow", "intent", "entity", "variable"]},
"environmentId": {"type": "string"}
def validate_flow(flow: Dict[str, Any]) -> bool:
validate(instance=flow, schema=FLOW_SCHEMA)
return True
except ValidationError as err:
print(f"Validation failed for flow {flow.get('id')}: {err.message}")
return False
The schema enforces mandatory fields, version formatting, node type enumeration, and edge connectivity rules. Invalid flows are rejected before dependency resolution. You must log validation failures to prevent partial deployments.
Step 3: Resolve External Reference Dependencies Across Multiple Flows
Flows often reference intents, entities, or other flows across environments. You must build a dependency graph and ensure all referenced resources exist before pushing updates.
from collections import defaultdict
from typing import Dict, Set, Tuple
def resolve_dependencies(flows: List[Dict[str, Any]]) -> Tuple[Dict[str, Set[str]], bool]:
dependency_map: Dict[str, Set[str]] = defaultdict(set)
all_flow_ids: Set[str] = {f["id"] for f in flows}
missing_dependencies: Set[str] = set()
for flow in flows:
flow_id = flow["id"]
refs = flow.get("externalReferences", [])
for ref in refs:
ref_type = ref["type"]
ref_id = ref["id"]
if ref_type == "flow":
dependency_map[flow_id].add(ref_id)
if ref_id not in all_flow_ids:
missing_dependencies.add(f"{ref_type}:{ref_id}")
else:
# Intents, entities, and variables are validated separately via environment checks
dependency_map[flow_id].add(f"{ref_type}:{ref_id}")
has_missing = len(missing_dependencies) > 0
return dict(dependency_map), has_missing
The function returns a mapping of flow IDs to their dependencies and a boolean indicating missing references. If has_missing is true, the deployment pipeline must halt. You must verify that referenced intents and entities exist in the target environment using the /intents and /entities endpoints before proceeding.
Step 4: Generate Deployment Manifests with Version Metadata
A deployment manifest provides an immutable record of what is being pushed, including timestamps, environment targets, and version hashes. This enables rollback and audit compliance.
import hashlib
import json
def generate_manifest(
flows: List[Dict[str, Any]],
target_env: str,
) -> Dict[str, Any]:
manifest = {
"manifestVersion": "1.0.0",
"generatedAt": datetime.now(timezone.utc).isoformat(),
"targetEnvironment": target_env,
"flows": [],
"dependencyGraph": dependency_map
for flow in flows:
flow_hash = hashlib.sha256(json.dumps(flow, sort_keys=True).encode()).hexdigest()
manifest["flows"].append({
"id": flow["id"],
"name": flow["name"],
"version": flow["version"],
"contentHash": flow_hash,
"status": "pending"
return manifest
The manifest includes a SHA-256 hash of each flow definition to detect tampering or unintended modifications during transit. The dependencyGraph field preserves the resolution output from Step 3. You must store this manifest in your artifact repository before initiating the push.
Step 5: Push Updates, Verify Status, and Handle Rollback
You will push flows via the import endpoint, verify deployment status, and execute rollback if validation fails. The process requires flows:write and deployments:manage scopes.
import logging
from typing import Dict, Any
logger = logging.getLogger("cognigy_deploy")
logging.basicConfig(filename="deployment_audit.log", level=logging.INFO,
format="%(asctime)s | %(levelname)s | %(message)s")
def push_and_verify(
auth: CognigyAuth,
base_url: str,
manifest: Dict[str, Any],
) -> bool:
target_env = manifest["targetEnvironment"]
for flow in flows:
logger.info(f"Pushing flow {flow_id} to {target_env}")
# Push flow definition
push_response = client.post(
f"{base_url}/flows/import",
json={"flow": flow, "environmentId": target_env},
timeout=60.0
if push_response.status_code == 429:
time.sleep(int(push_response.headers.get("Retry-After", 3)))
if push_response.status_code not in (200, 201):
logger.error(f"Push failed for {flow_id}: {push_response.text}")
_rollback_deployments(auth, base_url, manifest, flow_id)
return False
# Verify deployment status
status_response = client.get(
f"{base_url}/flows/{flow_id}/status",
params={"environmentId": target_env},
timeout=15.0
if status_response.status_code == 200:
status_data = status_response.json()
if status_data.get("status") != "deployed":
logger.warning(f"Flow {flow_id} not deployed: {status_data.get('status')}")
return False
# Update manifest status
for m_flow in manifest["flows"]:
if m_flow["id"] == flow_id:
m_flow["status"] = "deployed"
break
logger.info("All flows deployed successfully")
return True
def _rollback_deployments(
auth: CognigyAuth,
base_url: str,
failed_flow_id: str
) -> None:
logger.info(f"Initiating rollback for flows pushed before {failed_flow_id}")
deployed_flows = [f for f in manifest["flows"] if f["status"] == "deployed"]
for flow_record in deployed_flows:
rollback_response = client.post(
f"{base_url}/flows/{flow_record['id']}/rollback",
json={"targetVersion": flow_record.get("previousVersion", "latest")},
timeout=30.0
if rollback_response.status_code == 200:
logger.info(f"Rolled back flow {flow_record['id']}")
else:
logger.error(f"Rollback failed for {flow_record['id']}: {rollback_response.text}")
The push function iterates through flows, posts them to the import endpoint, and checks the status endpoint. If any step fails, the _rollback_deployments helper restores previous versions. The audit logger records every action with timestamps for compliance. You must handle 400 errors by inspecting the response body for schema violations, and 403 errors by verifying environment permissions.
import httpx
import json
import hashlib
import logging
from typing import List, Dict, Any, Tuple
# Authentication class (from Step 0)
class CognigyAuth:
self._token = None
self._expires_at = 0.0
payload = {
return self._token
return self._token
# Schema (from Step 2)
FLOW_SCHEMA = {
"type": "object",
"properties": {
"nodes": {
"type": "array",
"items": {
"type": "object",
"properties": {
"edges": {
"type": "array",
"items": {
"type": "object",
"properties": {
"type": "array",
"items": {
"type": "object",
"properties": {
return True
return False
offset = 0
while True:
response = client.get(f"{base_url}/flows", headers=auth.get_headers(), params=params, timeout=30.0)
time.sleep(int(response.headers.get("Retry-After", 2)))
break
offset += limit
break
return flows
def resolve_dependencies(flows: List[Dict[str, Any]]) -> Tuple[Dict[str, set], bool]:
dependency_map: Dict[str, set] = defaultdict(set)
all_flow_ids: set = {f["id"] for f in flows}
missing_dependencies: set = set()
for flow in flows:
for ref in flow.get("externalReferences", []):
ref_id = ref["id"]
else:
return dict(dependency_map), len(missing_dependencies) > 0
def generate_manifest(flows: List[Dict[str, Any]], target_env: str, dependency_map: Dict[str, set]) -> Dict[str, Any]:
manifest = {
"flows": [],
for flow in flows:
"id": flow["id"],
"status": "pending"
return manifest
def push_and_verify(auth: CognigyAuth, base_url: str, manifest: Dict[str, Any], flows: List[Dict[str, Any]]) -> bool:
for flow in flows:
timeout=60.0
return False
timeout=15.0
return False
break
return True
def main():
logging.basicConfig(filename="deployment_audit.log", level=logging.INFO, format="%(asctime)s | %(levelname)s | %(message)s")
auth = CognigyAuth(
client_id="your_client_id",
client_secret="your_client_secret",
auth_url="https://your-tenant.cognigy.ai/oauth/token"
base_url = "https://your-tenant.cognigy.ai/api/v2"
flows = export_flows(auth, base_url)
valid_flows = [f for f in flows if validate_flow(f)]
if not valid_flows:
logging.error("No valid flows to deploy")
return
dep_map, has_missing = resolve_dependencies(valid_flows)
if has_missing:
logging.error("Missing external dependencies. Aborting deployment.")
return
manifest = generate_manifest(valid_flows, target_env="env_prod", dependency_map=dep_map)
success = push_and_verify(auth, base_url, manifest, valid_flows)
if success:
with open("deployment_manifest.json", "w") as f:
json.dump(manifest, f, indent=2)
logging.info("Deployment complete. Manifest saved.")
else:
logging.error("Deployment failed. Rollback initiated.")
main()
This script covers the complete pipeline. You must replace the credential placeholders and region URLs before execution. The script logs every stage to deployment_audit.log and saves the final manifest to disk.
- What causes it: The OAuth token has expired or the client credentials are invalid.
- How to fix it: Verify the
client_idandclient_secretmatch your Cognigy.AI application settings. Ensure the token cache buffer is not exceeded. Revoke and regenerate credentials if compromised. - Code showing the fix: The
CognigyAuthclass automatically refreshes tokens when expiration approaches. If the error persists, print the raw response body to inspect theerroranderror_descriptionfields.
- What causes it: Cognigy.AI enforces rate limits on export, import, and status endpoints. Bulk operations trigger throttling.
- How to fix it: Implement exponential backoff with jitter. Respect the
Retry-Afterheader. Reduce batch sizes by lowering thelimitparameter during export. - Code showing the fix: The
export_flowsandpush_and_verifyfunctions check for429and sleep for the specified duration before retrying. Add a maximum retry count to prevent infinite loops.
Error: 400 Bad Request on Import
- What causes it: Flow definition violates schema constraints or references missing intents/entities.
- How to fix it: Run the
validate_flowfunction before import. Cross-referenceexternalReferencesagainst the target environment using/intentsand/entitiesendpoints. Ensure version strings match semantic versioning format. - Code showing the fix: The
validate_flowfunction catchesValidationErrorand logs the exact field mismatch. Fix the malformed JSON structure before resubmission.
