Automating Group Membership Synchronization Between Azure AD and Genesys Cloud Using SCIM 2.0 PUT Operations and a Python Scheduler With Idempotency Keys
  • A Python automation script that reads group membership assignments from Microsoft Graph, transforms them into SCIM 2.0 compliant payloads, and pushes deterministic updates to Genesys Cloud using PUT requests.
  • This implementation targets the Genesys Cloud SCIM 2.0 REST API at /api/v2/scim/v2/Groups/{id} and uses the requests library for HTTP transport.
  • The solution runs in Python 3.9+ with a cron-style scheduler, exponential backoff for rate limits, and cryptographic idempotency keys to guarantee exactly once execution.
  • Genesys Cloud OAuth 2.0 confidential client with the Provisioning:Scim scope granted
  • Microsoft Entra ID (Azure AD) application registration with Group.Read.All and Directory.Read.All delegated or application permissions
  • Python 3.9 or newer runtime environment
  • External packages: requests>=2.31.0, schedule>=1.2.0, msal>=1.24.0
  • Genesys Cloud environment ID and client credentials stored in environment variables or a secure vault
  • Target Genesys Cloud groups must already exist in the Genesys tenant before membership sync begins
Both Genesys Cloud and Microsoft Graph require OAuth 2.0 client credentials flow. You must cache tokens and refresh them before expiration. The following implementation uses a time-to-live cache pattern that validates token expiry headers before issuing new requests.
import os
import requests
import msal
from datetime import datetime, timezone, timedelta
from typing import Dict, Optional
GENESYS_OAUTH_URL = "https://api.mypurecloud.com/oauth/token"
GRAPH_CLIENT_ID = os.environ["GRAPH_CLIENT_ID"]
GRAPH_CLIENT_SECRET = os.environ["GRAPH_CLIENT_SECRET"]
GRAPH_TENANT_ID = os.environ["GRAPH_TENANT_ID"]
GENESYS_CLIENT_ID = os.environ["GENESYS_CLIENT_ID"]
GENESYS_CLIENT_SECRET = os.environ["GENESYS_CLIENT_SECRET"]
GENESYS_SUBDOMAIN = os.environ["GENESYS_SUBDOMAIN"]
class TokenCache:
    def __init__(self) -> None:
        self._tokens: Dict[str, Dict] = {}
    def get(self, key: str) -> Optional[str]:
        entry = self._tokens.get(key)
        if not entry:
            return None
        if datetime.now(timezone.utc) > entry["expires_at"]:
            return None
        return entry["token"]
    def set(self, key: str, token: str, expires_in_seconds: int) -> None:
        self._tokens[key] = {
            "token": token,
            "expires_at": datetime.now(timezone.utc) + timedelta(seconds=expires_in_seconds - 30)
cache = TokenCache()
def get_genesys_token() -> str:
    cached = cache.get("genesys")
    if cached:
        return cached
    response = requests.post(
        GENESYS_OAUTH_URL,
        headers={"Content-Type": "application/x-www-form-urlencoded"},
        data={
            "client_id": GENESYS_CLIENT_ID,
            "client_secret": GENESYS_CLIENT_SECRET,
            "scope": "Provisioning:Scim"
        timeout=10
    response.raise_for_status()
    payload = response.json()
    cache.set("genesys", payload["access_token"], payload["expires_in"])
    return payload["access_token"]
def get_graph_token() -> str:
    cached = cache.get("graph")
    if cached:
        return cached
    app = msal.ConfidentialClientApplication(
        GRAPH_CLIENT_ID,
        authority=f"https://login.microsoftonline.com/{GRAPH_TENANT_ID}",
        client_credential=GRAPH_CLIENT_SECRET
    result = app.acquire_token_for_client(scopes=["https://graph.microsoft.com/.default"])
    if "access_token" not in result:
        raise RuntimeError("Graph token acquisition failed: " + str(result.get("error_description")))
    cache.set("graph", result["access_token"], result["expires_in"])
    return result["access_token"]
The Genesys endpoint requires the Provisioning:Scim scope. The Microsoft Graph endpoint requires the default application scope. Both responses include an expires_in field that drives the cache TTL. The implementation subtracts thirty seconds from the TTL to prevent edge-case expiration during active requests.
Step 1: Fetch Azure AD Group Members via Microsoft Graph
Microsoft Graph returns group members in paginated responses. You must iterate through @odata.nextLink until the list is complete. The following function retrieves all user object IDs assigned to a specific group.
import requests
from typing import List
GRAPH_BASE = "https://graph.microsoft.com/v1.0"
def fetch_graph_members(group_id: str, token: str) -> List[str]:
    members: List[str] = []
    url = f"{GRAPH_BASE}/groups/{group_id}/members/microsoft.graph.user?$select=id"
    while url:
        response = requests.get(
            url,
            headers={"Authorization": f"Bearer {token}"},
            timeout=15
            retry_after = int(response.headers.get("Retry-After", 5))
            time.sleep(retry_after)
        data = response.json()
        for user in data.get("value", []):
            members.append(user["id"])
        url = data.get("@odata.nextLink")
    return members
The request targets /groups/{id}/members/microsoft.graph.user. The $select=id parameter reduces payload size. The loop handles pagination automatically. A 429 response triggers a pause using the Retry-After header before retrying.
Step 2: Map Members to SCIM 2.0 Format and Calculate Idempotency Keys
Genesys Cloud SCIM 2.0 expects group resources to conform to RFC 7643. The PUT operation replaces the entire group resource. You must include the members array with value fields matching Genesys user identifiers. The idempotency key prevents duplicate mutations when the scheduler retries or overlaps.
import hashlib
import json
from typing import Dict, List
def build_scim_payload(group_display_name: str, member_ids: List[str]) -> Dict:
    members = [{"value": uid, "displayName": f"user-{uid}"} for uid in member_ids]
        "schemas": ["urn:ietf:params:scim:schemas:core:2.0:Group"],
        "displayName": group_display_name,
        "members": members
def generate_idempotency_key(group_id: str, member_ids: List[str]) -> str:
    normalized = sorted(member_ids)
    payload_str = json.dumps(normalized, sort_keys=True)
    hash_input = f"{group_id}:{payload_str}"
    return hashlib.sha256(hash_input.encode("utf-8")).hexdigest()
The value field must match an existing Genesys Cloud user ID or email address. If users are not yet provisioned, Genesys returns a 404. The idempotency key derives from a sorted list of member IDs, ensuring that identical membership states produce identical keys across scheduler runs.
Step 3: Execute Idempotent PUT Operations Against Genesys Cloud SCIM API
The PUT request targets /api/v2/scim/v2/Groups/{id}. You must include the Idempotency-Key header and set Content-Type to application/scim+json. The implementation includes exponential backoff for 429 responses and explicit error mapping for common SCIM failures.
import requests
GENESYS_SCIM_BASE = f"https://{GENESYS_SUBDOMAIN}.mypurecloud.com/api/v2/scim/v2"
def sync_group_to_genesys(
    group_id: str,
    payload: Dict,
    idempotency_key: str,
    token: str,
    max_retries: int = 3
) -> None:
    url = f"{GENESYS_SCIM_BASE}/Groups/{group_id}"
    headers = {
        "Content-Type": "application/scim+json",
        "Idempotency-Key": idempotency_key,
        "Accept": "application/json"
    retry_count = 0
    base_delay = 2
    while retry_count < max_retries:
        response = requests.put(url, json=payload, headers=headers, timeout=20)
            retry_count += 1
            delay = base_delay ** retry_count
            print(f"Rate limited. Retrying in {delay}s (attempt {retry_count}/{max_retries})")
            time.sleep(delay)
        if response.status_code in (200, 201):
            print(f"Successfully synced group {group_id}")
            return
        if response.status_code == 409:
            print(f"Conflict on group {group_id}. Resource version mismatch or duplicate operation.")
            return
        if response.status_code == 404:
            raise RuntimeError(f"Group {group_id} not found in Genesys Cloud SCIM.")
    raise RuntimeError(f"Failed to sync group {group_id} after {max_retries} retries.")
The HTTP request cycle follows this pattern:
  • Method: PUT
  • Path: /api/v2/scim/v2/Groups/{groupId}
  • Headers: Authorization: Bearer <token>, Content-Type: application/scim+json, Idempotency-Key: <sha256>
  • Request Body: SCIM 2.0 Group resource with members array
  • Success Response: 200 OK with updated group resource or 201 Created if the group did not exist
  • Rate Limit Response: 429 Too Many Requests with Retry-After header
The exponential backoff multiplies the delay by two on each 429 response. The idempotency key ensures that identical PUT payloads do not create duplicate mutations if the scheduler runs concurrently.
Step 4: Implement the Scheduler and Orchestration Loop
The scheduler iterates through a predefined list of Azure AD group IDs, fetches memberships, transforms payloads, and pushes updates. The implementation catches token expiration and refreshes automatically.
import schedule
TARGET_GROUPS = [
    {"aad_id": "a1b2c3d4-e5f6-7890-abcd-ef1234567890", "genesys_id": "g1h2i3j4-k5l6-7890-mnop-qr1234567890", "name": "Support_Tier1"},
    {"aad_id": "b2c3d4e5-f6a7-8901-bcde-f12345678901", "genesys_id": "h2i3j4k5-l6m7-8901-nopq-r12345678901", "name": "Support_Tier2"}
def run_sync_job() -> None:
    print(f"Starting sync job at {datetime.now(timezone.utc).isoformat()}")
    graph_token = get_graph_token()
    genesys_token = get_genesys_token()
    for group in TARGET_GROUPS:
            members = fetch_graph_members(group["aad_id"], graph_token)
            payload = build_scim_payload(group["name"], members)
            idem_key = generate_idempotency_key(group["genesys_id"], members)
            sync_group_to_genesys(group["genesys_id"], payload, idem_key, genesys_token)
        except Exception as exc:
            print(f"Failed to process group {group['genesys_id']}: {exc}")
    print("Sync job completed.")
    schedule.every(15).minutes.do(run_sync_job)
    print("Scheduler started. Press Ctrl+C to exit.")
        while True:
            schedule.run_pending()
            time.sleep(1)
    except KeyboardInterrupt:
        print("Scheduler stopped.")
The loop runs every fifteen minutes. Each iteration refreshes tokens if necessary, processes each group independently, and isolates failures so that one group error does not halt the entire batch.
The following script combines all components into a single executable module. Replace the environment variables and group mappings before execution.
import os
import json
import hashlib
import requests
import schedule
import msal
from typing import Dict, List, Optional
# Configuration
TARGET_GROUPS = [
class TokenCache:
        if not entry:
            return None
            return None
            "token": token,
    if cached:
        return cached
        GENESYS_OAUTH_URL,
        data={
        timeout=10
    if cached:
        return cached
        GRAPH_CLIENT_ID,
    while url:
        response = requests.get(url, headers={"Authorization": f"Bearer {token}"}, timeout=15)
    return members
        "members": members
def sync_group_to_genesys(group_id: str, payload: Dict, idempotency_key: str, token: str, max_retries: int = 3) -> None:
    headers = {
    retry_count = 0
    base_delay = 2
            retry_count += 1
            time.sleep(delay)
            return
            return
        while True:
            time.sleep(1)
  • Cause: Expired OAuth token or missing scope. Genesys rejects requests without Provisioning:Scim. Graph rejects requests without valid application permissions.
  • Fix: Verify the token cache logic refreshes before expiry. Confirm the OAuth client in Genesys Cloud has the exact scope string. Check Entra ID app registration for Group.Read.All and Directory.Read.All with admin consent.
  • Code Adjustment: The TokenCache class automatically invalidates tokens before the expires_in threshold. If 401 persists, force cache invalidation by calling cache._tokens.clear() during debugging.
Error: 409 Conflict
  • Cause: SCIM resource version mismatch or duplicate idempotency key processing. Genesys returns 409 when a PUT attempts to overwrite a group with a newer ETag, or when the idempotency key is reused outside its validity window.
  • Fix: Regenerate the idempotency key only when the member list changes. The generate_idempotency_key function hashes the sorted member array, so identical states produce identical keys. If the group structure changed externally, fetch the current Genesys group state first and merge before PUT.
  • Code Adjustment: Add a GET request to /api/v2/scim/v2/Groups/{id} to retrieve the current members array. Compare it to the Graph payload. Skip PUT if arrays match exactly.
  • Cause: Exceeding Genesys Cloud SCIM rate limits or Microsoft Graph throttling thresholds.
  • Fix: The implementation includes exponential backoff. Increase base_delay to 4 or 8 if throttling persists. Stagger group processing with time.sleep(1) between PUT calls to distribute load.
  • Code Adjustment: Add time.sleep(1) inside the TARGET_GROUPS loop after each successful sync.
Error: 5xx Server Errors
  • Cause: Genesys Cloud platform outage or transient routing failure.
  • Fix: Implement circuit breaker logic for production deployments. The current retry loop handles transient 500/502/503 responses by treating them as retryable. Log the response body for support tickets.
  • Code Adjustment: Modify the retry condition to if response.status_code in (429, 500, 502, 503): and extend max_retries to 5 for production workloads.
