Automating Cognigy.AI Model Versioning with Drift Detection, Statistical Validation, and Rollback-Safe Promotion
A Python automation script that monitors utterance distribution drift, triggers Cognigy.AI model retraining, statistically validates performance improvements against a baseline, and promotes the superior version to production with automatic rollback hooks. This tutorial uses the Cognigy.AI v2 REST API with httpx and scipy. It covers Python 3.9+.
- OAuth 2.0 Client Credentials grant configured in the Cognigy.AI tenant
- Required scopes:
model:read,model:write,train:execute,version:manage - Python 3.9 or newer
- External dependencies:
httpx>=0.25.0,scipy>=1.11.0,numpy>=1.24.0,pandas>=2.0.0 - Install dependencies:
pip install httpx scipy numpy pandas
Cognigy.AI uses OAuth 2.0 for all API access. The client credentials flow requires exchanging a client ID and secret for a bearer token. You must cache the token and handle expiration gracefully. The following setup configures an httpx client with automatic retry logic for rate limits and a token refresh wrapper.
import os
import httpx
from httpx import Auth, Request, Response
from dataclasses import dataclass
from typing import Optional
@dataclass
class CognigyAuth:
tenant: str
client_id: str
client_secret: str
token_url: str = "https://auth.cognigy.ai/oauth/token"
def __post_init__(self):
self._expires_at: float = 0.0
self._client = httpx.Client(
base_url=f"https://{self.tenant}.cognigy.ai/api/v2",
timeout=30.0,
transport=httpx.HTTPTransport(retries=3)
def _fetch_token(self) -> str:
payload = {
"client_id": self.client_id,
"scope": "model:read model:write train:execute version:manage"
response = httpx.post(self.token_url, data=payload)
response.raise_for_status()
data = response.json()
self._token = data["access_token"]
self._expires_at = time.time() + data["expires_in"] - 300
return self._token
def get_token(self) -> str:
if not self._token or time.time() >= self._expires_at:
return self._fetch_token()
return self._token
def request(self, method: str, path: str, **kwargs) -> Response:
headers = kwargs.pop("headers", {})
headers["Authorization"] = f"Bearer {self.get_token()}"
headers["Content-Type"] = "application/json"
return self._client.request(method, path, headers=headers, **kwargs)
The CognigyAuth class handles token lifecycle management. The request method injects the bearer token into every call. The httpx.HTTPTransport(retries=3) configuration automatically retries transient network failures. You must handle HTTP 429 responses explicitly for API rate limits.
Step 1: Detect Data Drift in Utterance Distributions
Data drift occurs when the distribution of incoming utterances diverges from the distribution used during the last training cycle. You measure drift using the Kullback-Leibler (KL) divergence between the baseline distribution and the current distribution. The Cognigy.AI API exposes utterance distribution analytics through the model analytics endpoint.
import numpy as np
from scipy.spatial.distance import kl
from typing import Dict, List
def detect_drift(auth: CognigyAuth, model_id: str, baseline_dist: List[float], threshold: float = 0.15) -> bool:
Fetches current utterance distribution and compares it to the baseline.
Returns True if drift exceeds the threshold.
response = auth.request("GET", f"/models/{model_id}/analytics/utterance-distribution")
# Extract current distribution from response
current_dist = [intent["count"] for intent in data.get("distribution", [])]
# Normalize distributions to probability mass functions
current_pdf = np.array(current_dist) / sum(current_dist)
baseline_pdf = np.array(baseline_dist) / sum(baseline_dist)
# Add epsilon to avoid log(0)
epsilon = 1e-10
current_pdf += epsilon
baseline_pdf += epsilon
current_pdf /= current_pdf.sum()
baseline_pdf /= baseline_pdf.sum()
divergence = kl(baseline_pdf, current_pdf)
print(f"KL Divergence: {divergence:.4f} (Threshold: {threshold})")
return divergence > threshold
The detect_drift function fetches the current distribution, normalizes both distributions to probability vectors, and computes KL divergence. A threshold of 0.15 is a standard operational cutoff. If divergence exceeds the threshold, the script proceeds to retraining. You must handle HTTP 403 errors if the model:read scope is missing.
Step 2: Trigger Retraining and Monitor Job Status
Once drift is confirmed, you trigger a synchronous or asynchronous training job. Cognigy.AI returns a training job identifier immediately. You must poll the job status endpoint until the job completes or fails. The following implementation includes exponential backoff for 429 rate limit responses.
def trigger_and_monitor_training(auth: CognigyAuth, model_id: str) -> str:
Triggers model training and polls until completion.
Returns the new version ID.
# Trigger training
response = auth.request("POST", f"/models/{model_id}/train")
print("Rate limit exceeded. Retrying in 5 seconds...")
time.sleep(5)
job_data = response.json()
job_id = job_data["id"]
print(f"Training job {job_id} initiated. Monitoring status...")
# Poll training job status
max_retries = 60
retry_delay = 10
for _ in range(max_retries):
status_response = auth.request("GET", f"/training-jobs/{job_id}")
status_response.raise_for_status()
status_data = status_response.json()
status = status_data.get("status")
if status == "COMPLETED":
return status_data.get("versionId", "")
elif status == "FAILED":
raise RuntimeError(f"Training failed: {status_data.get('errorMessage')}")
elif status == "RUNNING" or status == "QUEUED":
time.sleep(retry_delay)
retry_delay = min(retry_delay * 1.5, 60) # Exponential backoff cap at 60s
raise TimeoutError("Training job did not complete within expected timeframe.")
The POST /models/{modelId}/train endpoint requires the train:execute scope. The polling loop uses exponential backoff to respect API rate limits. If the job fails, the function raises a RuntimeError with the vendor error message. You must handle HTTP 503 responses if the training queue is saturated.
Step 3: Compare Evaluation Metrics Using Statistical Significance Testing
After training completes, you compare the new version against the baseline version. Cognigy.AI returns evaluation metrics per intent. You aggregate F1 scores across intents and run Welch’s t-test to determine if the improvement is statistically significant. This prevents promoting models that improve only by random variance.
import pandas as pd
from scipy import stats
def evaluate_version_metrics(auth: CognigyAuth, model_id: str, version_id: str) -> List[float]:
Fetches evaluation metrics for a specific version.
Returns a list of F1 scores per intent.
response = auth.request("GET", f"/models/{model_id}/versions/{version_id}")
version_data = response.json()
metrics = version_data.get("evaluationMetrics", {})
intents = metrics.get("intents", [])
f1_scores = [intent["f1Score"] for intent in intents if "f1Score" in intent]
return f1_scores
def compare_versions_statistically(
auth: CognigyAuth,
model_id: str,
baseline_version_id: str,
new_version_id: str,
alpha: float = 0.05
) -> bool:
Runs Welch's t-test comparing F1 scores between baseline and new version.
Returns True if the new version is significantly better.
baseline_scores = evaluate_version_metrics(auth, model_id, baseline_version_id)
new_scores = evaluate_version_metrics(auth, model_id, new_version_id)
if len(baseline_scores) < 3 or len(new_scores) < 3:
raise ValueError("Insufficient intent metrics for statistical testing. Minimum 3 intents required.")
# Welch's t-test (does not assume equal variance)
t_stat, p_value = stats.ttest_ind(new_scores, baseline_scores, equal_var=False)
print(f"T-statistic: {t_stat:.4f}, P-value: {p_value:.6f}")
# One-tailed test: we want to know if new > baseline
# scipy returns two-tailed p-value, so we divide by 2 for one-tailed
one_tailed_p = p_value / 2 if t_stat > 0 else 1 - (p_value / 2)
is_significant = one_tailed_p < alpha and t_stat > 0
print(f"Statistically significant improvement: {is_significant}")
return is_significant
The compare_versions_statistically function fetches F1 scores for both versions, validates sample size, and executes a one-tailed Welch’s t-test. The alpha parameter controls the false positive rate. A p-value below 0.05 with a positive t-statistic confirms the new version outperforms the baseline beyond random chance. You must handle HTTP 404 errors if version IDs are invalid.
Step 4: Promote Superior Model with Rollback Hooks
Promotion changes the production routing target. You must store the current production version ID before promotion to enable automatic rollback if post-promotion validation fails. The promotion endpoint is idempotent, but concurrent promotions can cause conflicts.
def promote_version_with_rollback(
auth: CognigyAuth,
model_id: str,
target_version_id: str,
validation_callback=None
) -> Dict:
Promotes a version to production with automatic rollback capability.
Returns promotion result and rollback version ID.
# Fetch current production version
versions_response = auth.request("GET", f"/models/{model_id}/versions")
versions_response.raise_for_status()
versions = versions_response.json().get("versions", [])
production_version = next((v for v in versions if v.get("environment") == "PRODUCTION"), None)
rollback_version_id = production_version["id"] if production_version else None
print(f"Promoting version {target_version_id} to production. Rollback target: {rollback_version_id}")
# Trigger promotion
promote_response = auth.request("POST", f"/models/{model_id}/versions/{target_version_id}/promote")
promote_response.raise_for_status()
promotion_result = promote_response.json()
# Optional post-promotion validation
if validation_callback:
validation_callback(auth, model_id, target_version_id)
print(f"Post-promotion validation failed: {e}. Initiating rollback...")
if rollback_version_id:
rollback_response = auth.request("POST", f"/models/{model_id}/versions/{rollback_version_id}/promote")
rollback_response.raise_for_status()
print(f"Rollback successful. Version {rollback_version_id} is now production.")
raise RuntimeError("Promotion rolled back due to validation failure.")
"promoted_version": target_version_id,
"rollback_version": rollback_version_id,
"promotion_status": promotion_result.get("status")
The promote_version_with_rollback function identifies the current production version, stores it as the rollback target, executes the promotion, and optionally runs a validation callback. If validation fails, the script automatically re-promotes the previous version. The version:manage scope is required for this operation. You must handle HTTP 409 conflicts if another process modifies the model during execution.
The following script integrates all components into a production-ready orchestration module. You must configure environment variables for credentials and model identifiers.
import os
import sys
def main():
# Configuration
tenant = os.getenv("COGNIGY_TENANT")
client_id = os.getenv("COGNIGY_CLIENT_ID")
client_secret = os.getenv("COGNIGY_CLIENT_SECRET")
model_id = os.getenv("COGNIGY_MODEL_ID")
baseline_version_id = os.getenv("COGNIGY_BASELINE_VERSION_ID")
drift_threshold = float(os.getenv("DRIFT_THRESHOLD", "0.15"))
if not all([tenant, client_id, client_secret, model_id, baseline_version_id]):
print("Missing required environment variables. Check documentation.")
sys.exit(1)
auth = CognigyAuth(tenant, client_id, client_secret)
# Step 1: Drift Detection
# Baseline distribution should be loaded from persistent storage in production
baseline_distribution = [0.25, 0.30, 0.20, 0.15, 0.10] # Example probability distribution
has_drift = detect_drift(auth, model_id, baseline_distribution, drift_threshold)
if not has_drift:
print("No significant drift detected. Skipping retraining.")
return
# Step 2: Trigger Retraining
new_version_id = trigger_and_monitor_training(auth, model_id)
print(f"Training failed: {e}")
return
print(f"Training completed. New version ID: {new_version_id}")
# Step 3: Statistical Comparison
is_better = compare_versions_statistically(
auth, model_id, baseline_version_id, new_version_id, alpha=0.05
print(f"Statistical comparison failed: {e}")
return
if not is_better:
print("New version does not show statistically significant improvement. Aborting promotion.")
return
# Step 4: Promotion with Rollback
def post_promotion_check(auth_obj: CognigyAuth, mid: str, vid: str):
# Example validation: fetch version status and verify routing is active
resp = auth_obj.request("GET", f"/models/{mid}/versions/{vid}")
resp.raise_for_status()
data = resp.json()
if data.get("status") != "ACTIVE":
raise RuntimeError("Version is not active after promotion.")
result = promote_version_with_rollback(
auth, model_id, new_version_id, validation_callback=post_promotion_check
print(f"Promotion successful. Result: {result}")
print(f"Promotion process failed: {e}")
return
main()
This script runs sequentially through drift detection, training, statistical validation, and promotion. It includes environment variable validation, exception handling, and a post-promotion validation callback. You must persist the baseline distribution and baseline version ID in a database or configuration store for production use.
Error: HTTP 401 Unauthorized
- Cause: The OAuth token has expired or the client credentials are invalid.
- Fix: Verify the
client_idandclient_secretmatch the Cognigy.AI application configuration. Ensure the token cache refreshes before expiration. TheCognigyAuthclass handles automatic refresh, but network timeouts during token exchange can cause failures. Implement a retry wrapper around_fetch_tokenif your environment experiences intermittent auth service latency.
Error: HTTP 403 Forbidden
- Cause: Missing required OAuth scopes.
- Fix: Update the client credentials grant in the Cognigy.AI admin console to include
model:read,model:write,train:execute, andversion:manage. The token endpoint returns scopes in the response payload. Verify thescopeclaim matches your requirements.
- Cause: API rate limit exceeded. Cognigy.AI enforces per-tenant and per-endpoint rate limits.
- Fix: The
httpx.HTTPTransport(retries=3)configuration handles automatic retries for network errors, but you must explicitly handle 429 responses. Implement exponential backoff in polling loops. Thetrigger_and_monitor_trainingfunction demonstrates a retry pattern. Increaseretry_delayif your tenant enforces strict limits.
Error: HTTP 503 Service Unavailable
- Cause: Training queue is saturated or the model service is undergoing maintenance.
- Fix: Poll the training job status with longer intervals. Implement a circuit breaker pattern if consecutive 503 responses occur. Check Cognigy.AI status pages for scheduled maintenance windows.
Error: Statistical Test Fails with Insufficient Data
- Cause: Fewer than three intents with evaluation metrics exist in the version.
- Fix: Ensure your model has sufficient intent coverage. The
compare_versions_statisticallyfunction raises aValueErrorif sample size is too small. Add a fallback metric comparison using accuracy or precision if F1 scores are unavailable.
