Automate Token Refresh for Long-Running Batch Jobs in Genesys Cloud
  • A Python script that executes a long-running batch query against Genesys Cloud Analytics and automatically refreshes its OAuth access token when it expires.
  • This solution uses the Genesys Cloud Python SDK (genesyscloud) with custom middleware to intercept 401 Unauthorized responses.
  • The implementation covers Python 3.9+ with asyncio for non-blocking token refresh during high-throughput data processing.
  • OAuth Client Type: Confidential Client (Client Credentials Grant). This is the standard for server-to-server integrations.
  • Required Scopes: analytics:conversation:read (for the example query), login:all (implicit in client credentials).
  • SDK Version: genesyscloud >= 3.0.0 (PyPI).
  • Runtime: Python 3.9 or higher.
  • Dependencies:
    pip install genesyscloud requests aiohttp
The core challenge in batch processing is that the default Genesys Cloud Python SDK initializes a single PureCloudPlatformClientV2 instance with a static token. When that token expires (typically after 1 hour for Client Credentials, though it can vary based on policy), subsequent API calls fail with HTTP 401 Unauthorized.
The solution is not to manually refresh the token before every call. Instead, we implement a Reactive Refresh Pattern. We allow the API call to fail, catch the 401 error, trigger a token refresh in the background, and retry the original request.
Below is the base configuration for the SDK client. Note that we do not pass the token directly to the client constructor in the final implementation; we inject it via the authentication mechanism.
import os
from genesyscloud.configuration import Configuration
from genesyscloud.platform_client import PlatformClient
from genesyscloud.analytics_api import AnalyticsApi
def create_initial_client() -> PlatformClient:
    Initializes the Genesys Cloud Platform Client with configuration.
    Does not authenticate yet. Authentication is handled by the refresh logic.
    # Load environment variables
    client_id = os.environ.get('GENESYS_CLIENT_ID')
    client_secret = os.environ.get('GENESYS_CLIENT_SECRET')
    env_name = os.environ.get('GENESYS_ENVIRONMENT', 'mypurecloud.com')
        raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set")
    configuration = Configuration(
        base_url=f"https://{env_name}",
        client_id=client_id,
        client_secret=client_secret
    # The platform client manages the session
    platform_client = PlatformClient(configuration)
    # Initial authentication to get the first token
    platform_client.authenticate()
    return platform_client
Step 1: Implement the Token Refresh Mechanism
The Genesys Cloud Python SDK provides an Authentication class that can be customized. However, for robust batch jobs, it is often safer to wrap the API calls in a utility that handles the retry logic explicitly. This ensures that if the refresh token endpoint itself fails (e.g., network timeout), your batch job does not crash silently.
We will create a helper class GenesysBatchClient that wraps the AnalyticsApi. This class will maintain a reference to the PlatformClient and handle the 401 retry loop.
import logging
from typing import Callable, Any, Optional
class GenesysBatchClient:
    def __init__(self, platform_client: PlatformClient):
        self.platform_client = platform_client
        self.analytics_api = AnalyticsApi(platform_client)
    def execute_with_retry(self, api_call_func: Callable, *args, **kwargs) -> Any:
        Executes an API call. If it fails with a 401 Unauthorized, it refreshes the token
        and retries the call once.
        :param api_call_func: The API method to call (e.g., self.analytics_api.post_analytics_conversations_details_query)
        :param args: Positional arguments for the API call
        :param kwargs: Keyword arguments for the API call
        :return: The response body from the API
        max_retries = 2  # Initial attempt + 1 retry
                logger.info(f"Executing API call (Attempt {attempt + 1})...")
                response = api_call_func(*args, **kwargs)
                return response
            except ApiException as e:
                if e.status == 401 and attempt < max_retries - 1:
                    logger.warning("Received 401 Unauthorized. Refreshing access token...")
                        # Trigger token refresh
                        self.platform_client.refresh_token()
                        logger.info("Token refreshed successfully. Retrying...")
                        # Continue to next iteration (retry)
                    except Exception as refresh_error:
                        logger.error(f"Failed to refresh token: {refresh_error}")
                        raise refresh_error
                else:
                    logger.error(f"API call failed with status {e.status}: {e.body}")
                    raise e
                logger.error(f"Unexpected error during API call: {e}")
                raise e
        raise RuntimeError("Max retries exceeded for API call")
Step 2: Define the Batch Query Payload
We need a realistic analytics query that takes time to process. A common pattern is querying conversation details for a specific date range. This endpoint supports pagination via nextPageUri.
The request body must conform to the ConversationDetailsQuery schema.
  "view": "DEFAULT",
  "dateRange": {
    "from": "2023-10-01T00:00:00Z",
    "to": "2023-10-01T23:59:59Z"
  "size": 100,
  "filter": [
      "type": "channel",
      "value": "voice"
In Python, we construct this object using the SDK models to ensure type safety.
from genesyscloud.models import ConversationDetailsQuery, DateRange, Filter
def create_query_payload() -> ConversationDetailsQuery:
    Creates a standard analytics query for voice conversations.
    date_range = DateRange(
        from_time="2023-10-01T00:00:00Z",
        to_time="2023-10-01T23:59:59Z"
    channel_filter = Filter(
        type="channel",
        value="voice"
    query = ConversationDetailsQuery(
        view="DEFAULT",
        date_range=date_range,
        size=100,
        filter=[channel_filter]
    return query
Step 3: Process Paginated Results with Resilience
The critical part of the batch job is the pagination loop. If the token expires between page 10 and page 11, the standard SDK call will throw a 401. Our execute_with_retry wrapper handles this transparently.
We also need to handle Rate Limiting (429). While the prompt focuses on token refresh, production code must handle 429s to avoid cascading failures. We will add a simple exponential backoff for 429s.
import random
class GenesysBatchProcessor:
    def __init__(self, client: GenesysBatchClient):
        self.client = client
    def process_batch(self, query: ConversationDetailsQuery) -> list:
        Iterates through all pages of an analytics query, handling token refresh
        and rate limiting automatically.
        all_conversations = []
        next_page_uri = None
        page_count = 0
        while True:
            page_count += 1
            logger.info(f"Fetching page {page_count}...")
                if next_page_uri:
                    # Use the next page URI for subsequent calls
                    response = self.client.execute_with_retry(
                        self.client.analytics_api.post_analytics_conversations_details_query,
                        body=query, # Note: Some endpoints accept body + uri, others just uri.
                                    # For details query, we often pass the query body and the SDK handles pagination via headers or URI.
                                    # Actually, for /details/query, the SDK method usually takes the body.
                                    # Pagination is often handled by the 'nextPageUri' in the response.
                                    # Let's use the standard SDK pagination helper if available, or manual URI handling.
                                    # The Genesys SDK Python helper `get_paginated_data` is robust but let's implement manual
                                    # to show the token refresh in action.
                else:
                        body=query
                # Extract conversations from response
                if response.conversations:
                    all_conversations.extend(response.conversations)
                    logger.info(f"Retrieved {len(response.conversations)} conversations on page {page_count}")
                # Check for next page
                if response.next_page_uri:
                    next_page_uri = response.next_page_uri
                    # Small delay to be polite to the API, even if not rate limited
                    time.sleep(0.5)
                else:
                    logger.info("No more pages. Batch complete.")
                    break
                if e.status == 429:
                    # Rate Limited. Implement exponential backoff.
                    retry_after = e.headers.get('Retry-After')
                    if retry_after:
                        wait_time = int(retry_after)
                    else:
                        wait_time = 5 * (2 ** (page_count - 1)) # Exponential backoff
                    # Add jitter to prevent thundering herd
                    jitter = random.uniform(0, 1)
                    wait_time += jitter
                    logger.warning(f"Rate limited (429). Waiting {wait_time:.2f} seconds...")
                    time.sleep(wait_time)
                else:
                    # Re-raise 401s if they weren't handled by execute_with_retry (shouldn't happen)
                    # or other errors
                    raise e
                logger.error(f"Unexpected error in batch processing: {e}")
                raise e
        return all_conversations
Correction on Pagination Logic: The post_analytics_conversations_details_query endpoint in the Python SDK returns a ConversationDetailsResponse. The nextPageUri is a string. To fetch the next page, you typically make a GET request to that URI. However, the SDK’s post_ method is for the initial query. For subsequent pages, you should use a generic get request or the SDK’s get_analytics_conversations_details_query if it exists, but usually, the POST initiates the job and returns a job ID or direct data.
For Details Query, it is a direct query (not an async job). The standard pattern for pagination in Genesys Cloud Python SDK is:
# Corrected Pagination Approach
def fetch_page(self, uri: str, body: ConversationDetailsQuery = None) -> Any:
    if uri:
        # If we have a URI, we use the generic GET request via the platform client
        # Or use the SDK's specific GET endpoint if available.
        # The AnalyticsApi has get_analytics_conversations_details_query(uri)
        return self.client.execute_with_retry(
            self.client.analytics_api.get_analytics_conversations_details_query,
            uri
    else:
        # Initial POST
            body=body
Let’s refine the GenesysBatchProcessor to use this corrected logic.
        page_count = 0
        while True:
            page_count += 1
                if next_page_uri:
                    # Subsequent pages use GET with the nextPageUri
                        uri=next_page_uri
                else:
                    # First page uses POST with the query body
                        body=query
                    logger.info(f"Page {page_count}: Retrieved {len(response.conversations)} items.")
                    time.sleep(0.1) # Small delay between requests
                else:
                    break
                if e.status == 429:
                    wait_time = int(e.headers.get('Retry-After', 5))
                    logger.warning(f"Rate limited. Waiting {wait_time}s...")
                else:
                    raise e
                logger.error(f"Batch processing error: {e}")
                raise e
Below is the full, copy-pasteable Python script. It combines the configuration, the retry logic, and the batch processor into a single executable module.
import os
import sys
import logging
import random
from typing import Any, Callable
# Genesys Cloud SDK Imports
# Configure Logging
    level=logging.INFO,
    format='%(asctime)s - %(name)s - %(levelname)s - %(message)s'
    Wrapper around Genesys Cloud Analytics API to handle automatic token refresh
    on 401 Unauthorized errors.
        max_retries = 2  # 1 initial attempt + 1 retry after refresh
                logger.debug(f"API Call Attempt {attempt + 1}")
                return response
                    logger.warning("Access Token expired (401). Refreshing...")
                        logger.info("Token refreshed. Retrying request...")
                    except Exception as refresh_err:
                        logger.error(f"Token refresh failed: {refresh_err}")
                        raise refresh_err
                else:
                    logger.error(f"API Error {e.status}: {e.body}")
                    raise e
                logger.error(f"Unexpected error: {e}")
                raise e
        raise RuntimeError("Max retries exceeded")
def create_genesis_client() -> PlatformClient:
    environment = os.environ.get('GENESYS_ENVIRONMENT', 'mypurecloud.com')
        raise ValueError("Environment variables GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET are required.")
    config = Configuration(
        base_url=f"https://{environment}",
    platform_client = PlatformClient(config)
def run_batch_job():
        # 1. Initialize Client
        logger.info("Initializing Genesys Cloud Client...")
        platform_client = create_genesis_client()
        batch_client = GenesysBatchClient(platform_client)
        # 2. Define Query
        logger.info("Defining Analytics Query...")
            to_time="2023-10-01T01:00:00Z" # Small range for testing
            view="DEFAULT",
            size=50,
            filter=[Filter(type="channel", value="voice")]
        # 3. Process Batch
        logger.info("Starting Batch Processing...")
        processor = GenesysBatchProcessor(batch_client)
        conversations = processor.process_batch(query)
        logger.info(f"Batch Complete. Total Conversations Retrieved: {len(conversations)}")
        # 4. Output Sample Data
        if conversations:
            logger.info("Sample Conversation ID: %s", conversations[0].id)
        logger.error(f"Job Failed: {e}")
        sys.exit(1)
        page_count = 0
        while True:
            page_count += 1
            logger.info(f"Fetching Page {page_count}...")
                if next_page_uri:
                        uri=next_page_uri
                else:
                        body=query
                    logger.info(f"Page {page_count}: Added {len(response.conversations)} conversations.")
                    time.sleep(0.2) # Rate limiting courtesy delay
                else:
                    logger.info("End of data reached.")
                    break
                if e.status == 429:
                    retry_after = int(e.headers.get('Retry-After', 5))
                    logger.warning(f"Rate Limited (429). Waiting {retry_after}s...")
                    time.sleep(retry_after)
                else:
                    raise e
                logger.error(f"Processing error: {e}")
                raise e
    run_batch_job()
Error: 401 Unauthorized persists after refresh
Cause: The refresh_token() method failed silently or the new token was not applied to the current session object correctly. In some older SDK versions, the PlatformClient might not update the header interceptor immediately.
Fix: Ensure you are using the latest genesyscloud SDK. If the issue persists, force a re-initialization of the API client instance after refresh:
# Inside execute_with_retry catch block
# Re-initialize the API wrapper to pick up new headers
self.analytics_api = AnalyticsApi(self.platform_client)
Cause: Your batch job is sending requests faster than the Genesys Cloud API allows. The default rate limit for Analytics endpoints is often 10 requests per second per organization.
Fix: Implement exponential backoff with jitter, as shown in the GenesysBatchProcessor. Always check the Retry-After header. Do not ignore 429s; continuing to hammer the API will result in a temporary IP ban.
Error: 403 Forbidden
Cause: The OAuth client does not have the required scope (analytics:conversation:read) or the user associated with the client credentials does not have permission to view the specific data (e.g., restricted by role or data governance).
Fix: Verify the scopes in the Genesys Cloud Admin Console under Platform AppsOAuth 2.0 Clients. Ensure the client has analytics:conversation:read.
Error: ApiException: 500 Internal Server Error
Cause: The Genesys Cloud backend encountered an error processing the query. This is rare but can happen with complex filters or large date ranges.
Fix: Reduce the date range of the query. Break the batch job into smaller chunks (e.g., 1 hour instead of 1 day). If the error persists, contact Genesys Cloud Support with the x-correlation-id from the response headers.
