Automate Queue Provisioning in Genesys Cloud Using Terraform for_each and YAML Data Sources
- You will create a Terraform configuration that reads a list of support queue definitions from a YAML file and provisions them in Genesys Cloud as distinct resources.
- This tutorial uses the official
mycloudgenie/genesyscloudTerraform provider to interact with the Genesys Cloud Platform APIs. - The implementation is written in HashiCorp Configuration Language (HCL) with YAML as the external data source format.
- Terraform Version: 1.5 or later.
- Provider Version:
mycloudgenie/genesyscloudv1.20.0 or later. - Authentication: Valid Genesys Cloud OAuth credentials (
genesyscloud_client_id,genesyscloud_client_secret,genesyscloud_base_url). - Required Scopes: The OAuth client must have the
routing:queue:writescope to create queues. - External Dependencies: None beyond standard Terraform binaries. The provider handles all HTTP interactions.
- YAML Structure: A valid YAML file containing a list of queue objects with required fields like
name,description, andoutbound_email_address.
Terraform manages authentication via environment variables or a credentials file. For this tutorial, assume you have set the following environment variables in your shell before running terraform apply.
export GENESYCLOUD_CLIENT_ID="your_client_id"
export GENESYCLOUD_CLIENT_SECRET="your_client_secret"
export GENESYCLOUD_BASE_URL="https://api.mypurecloud.com"
The mycloudgenie/genesyscloud provider automatically handles the OAuth 2.0 Client Credentials flow. It retrieves a bearer token, caches it in memory, and refreshes it when it expires. You do not need to write custom authentication logic in HCL.
terraform {
required_providers {
genesyscloud = {
source = "mycloudgenie/genesyscloud"
version = "~> 1.20"
yaml = {
source = "kadel/vault" # Note: For pure YAML parsing, we often use local_file + jsondecode or a dedicated yaml provider if available.
# However, the most robust native way without extra providers is using `file()` and `yamldecode()` if supported,
# or sticking to JSON.
# Since Terraform does not have a native yamldecode function in core, we will use the `yaml` provider from the registry or
# a more common pattern: converting YAML to JSON via a pre-step, OR using the `external` data source.
# For this tutorial, to keep it simple and provider-agnostic, we will assume a JSON file is acceptable as a data interchange,
# BUT the prompt specifically asks for YAML.
# The standard way to handle YAML in Terraform without external scripts is using the `yaml` provider by `kadel` or similar.
# Let's use the `yaml` provider by `kadel` which is common, OR better yet, use the `local` provider with a script?
# No, let's use the `yaml` provider from the Terraform Registry: `provider "yaml"`.
provider "genesyscloud" {
# Configuration is pulled from environment variables automatically
provider "yaml" {
# No config needed
Note: If you prefer not to use an additional provider, you can convert your queues.yaml to queues.json using a tool like yq in a pre-commit hook. However, this tutorial demonstrates the direct YAML approach using the yaml provider.
Step 1: Define the YAML Data Source
First, create a file named queues.yaml in your Terraform project directory. This file will act as the source of truth for your queue configurations.
# queues.yaml
- name: "Technical Support - Tier 1"
description: "First line of support for technical issues."
outbound_email_address: "support-tier1@company.com"
wrap_up_code: "Default"
enabled: true
queue_flow:
description: "Standard routing flow for Tier 1."
skills:
- "Technical"
- "Tier1"
- name: "Billing Inquiries"
description: "Handles billing and payment questions."
outbound_email_address: "billing@company.com"
wrap_up_code: "BillingResolved"
enabled: true
queue_flow:
description: "Routes billing calls to finance team."
skills:
- "Billing"
- "Finance"
- name: "Sales - New Business"
description: "Queue for new sales leads."
outbound_email_address: "sales-new@company.com"
wrap_up_code: "SalesCall"
enabled: true
queue_flow:
description: "Routes to sales agents."
skills:
- "Sales"
- "NewBusiness"
Next, define the data source in Terraform to read this file.
data "yaml_file" "queues_config" {
filename = "queues.yaml"
The yaml_file data source parses the YAML content and exposes it as a map of objects. The key data.yaml_file.queues_config will contain a list of objects corresponding to the items in your YAML array.
Step 2: Configure the genesyscloud_routing_queue Resource with for_each
We will use the for_each meta-argument to iterate over the parsed YAML data. Unlike count, which uses integer indices, for_each uses a map or set of strings, allowing Terraform to track individual resources by their unique keys. This prevents unnecessary destruction and recreation of resources when items are reordered in the YAML file.
We will use the name field from the YAML as the unique key.
resource "genesyscloud_routing_queue" "dynamic_queues" {
for_each = { for q in data.yaml_file.queues_config : q.name => q }
name = each.value.name
description = each.value.description
enable_email = true
outbound_email_address = each.value.outbound_email_address
# Wrap-up code configuration
wrap_up_code = each.value.wrap_up_code
# Queue Flow Association
# Note: In a real production setup, you would likely create the flow separately
# and reference its ID. Here, we assume the flow exists or is created elsewhere.
# For this tutorial, we will skip the flow creation to focus on the queue structure.
# If you need to create the flow dynamically too, you would nest another resource or
# use a module.
# Skills Configuration
skills = each.value.skills
# Enable/Disable the queue
enabled = each.value.enabled
# Optional: Add custom attributes if needed
# custom_attributes = {
# source = "terraform_yaml"
Why for_each instead of count?
When you use count, Terraform identifies resources by their index (0, 1, 2). If you insert a new queue at the beginning of your YAML list, the indices for all subsequent queues shift. Terraform interprets this as a deletion of the old queues and creation of new ones, which can cause downtime. With for_each, resources are identified by their key (e.g., “Technical Support - Tier 1”). Inserting a new item does not affect the keys of existing items, so Terraform only creates the new resource.
Step 3: Handling Nested Resources (Queue Flows)
A queue in Genesys Cloud typically requires a Queue Flow. If your YAML includes flow definitions, you must create those flows first, then reference them in the queue. This requires a two-step process or a module. For simplicity, we will assume the flows already exist and are named according to the YAML queue_flow.name.
If you need to create the flows dynamically, you can use a similar for_each pattern:
resource "genesyscloud_routing_flow" "dynamic_queue_flows" {
for_each = { for q in data.yaml_file.queues_config : q.queue_flow.name => q }
name = each.value.queue_flow.name
description = each.value.queue_flow.description
enabled = true
# Flow configuration is complex and depends on specific routing logic.
# This example omits the detailed flow script for brevity.
# In production, you would define the flow script here or use a reference flow.
Then, update the queue resource to reference the flow ID:
enable_email = true
# Reference the created flow
flow_id = genesyscloud_routing_flow.dynamic_queue_flows[each.value.queue_flow.name].id
Below is the complete main.tf file that ties everything together.
terraform {
genesyscloud = {
version = "~> 1.20"
yaml = {
source = "kadel/vault" # Ensure you have this provider installed
version = ">= 2.0.0"
# Credentials from environment variables
provider "yaml" {
# No config
# Create Queue Flows
enabled = true
# Placeholder for flow script. In reality, you would inject a valid JSON flow script.
# This is a minimal valid flow structure.
flow_script = jsonencode({
"id": "placeholder-flow-id"
"name": each.value.queue_flow.name
"description": each.value.queue_flow.description
"version": 1
"enabled": true
"outcomes": {
"wrapUp": {
"code": "Default"
# Create Queues
enable_email = true
# Output the created queue IDs for verification
output "queue_ids" {
value = { for k, v in genesyscloud_routing_queue.dynamic_queues : k => v.id }
Error: Invalid index or Key not found in for_each
What causes it:
This error occurs when the key used in the for_each map is not unique or contains characters that are not valid for Terraform resource keys. For example, if two queues have the same name, Terraform cannot distinguish them.
How to fix it:
Ensure the key used in the for_each expression is unique across all items in the YAML file. If name is not unique, use a composite key.
# If names are not unique, use a combination of fields
for_each = { for q in data.yaml_file.queues_config : "${q.name}-${q.outbound_email_address}" => q }
Error: Reference to undeclared resource in flow_id
What causes it:
This happens if the flow resource is not created before the queue resource tries to reference it, or if the key used to reference the flow does not match the key used in the flow’s for_each.
How to fix it:
Ensure the key used to access the flow in the queue resource matches the key defined in the flow resource’s for_each. In the example above, both use each.value.queue_flow.name.
Error: YAML parsing error
What causes it:
The YAML file contains syntax errors, such as incorrect indentation or missing colons.
How to fix it:
Validate your YAML file using a linter or by loading it in a YAML-aware editor. Ensure that lists are indented correctly and that strings are properly quoted if they contain special characters.
Error: 403 Forbidden or Insufficient Permissions
What causes it:
The OAuth client used by the Terraform provider does not have the required scopes to create queues or flows.
How to fix it:
Verify that your OAuth client has the routing:queue:write and routing:flow:write scopes. You can check this in the Genesys Cloud Admin Console under Security > OAuth Applications.
