Automate Genesys Cloud Infrastructure with Terraform in GitHub Actions
- A GitHub Actions workflow that runs
terraform planon every pull request to validate infrastructure changes against your Genesys Cloud CX environment. - The same workflow executes
terraform applyautomatically when the pull request is merged into themainbranch, provisioning or updating resources like users, skill groups, or queues. - The implementation uses Python for credential handling and shell scripts for Terraform execution within a GitHub-hosted runner.
- Genesys Cloud OAuth Client: You need a Genesys Cloud OAuth client with the
Client Credentialsgrant type. The client must have scopes matching the resources you manage (e.g.,user:read,user:write,routing:skillgroup:write). - Terraform Provider: This tutorial uses the official
genesyscloudTerraform provider. Ensure yourmain.tfreferences a version >=1.0.0. - GitHub Repository: A repository containing your Terraform code.
- GitHub Secrets: You must store the following secrets in your GitHub repository settings:
GENESYS_CLOUD_REGION: e.g.,us-east-1ormypurecloud.com.GENESYS_CLOUD_CLIENT_ID: Your OAuth Client ID.GENESYS_CLOUD_CLIENT_SECRET: Your OAuth Client Secret.
- Terraform State Backend: A remote backend (such as AWS S3, Azure Blob Storage, or Genesys Cloud’s own state storage if applicable) configured in your
backend.tf. Local state is not suitable for CI/CD.
Genesys Cloud APIs use OAuth 2.0. For CI/CD pipelines, the Client Credentials Flow is the standard mechanism because it does not require a human user to interact with a login prompt. The pipeline exchanges your CLIENT_ID and CLIENT_SECRET for an access token.
This token has a limited lifespan (typically 5 minutes). The Terraform provider handles token refresh internally, but initial authentication requires a valid token or the provider must be configured to fetch one automatically using the client credentials.
The genesyscloud Terraform provider supports passing client_id and client_secret directly in the provider block. This is the most robust method for CI/CD as it offloads the OAuth handshake to the provider SDK.
# provider.tf
terraform {
required_providers {
genesyscloud = {
source = "mygenesys/genesyscloud"
version = "~> 1.0"
provider "genesyscloud" {
# These values will be injected by GitHub Actions via environment variables
client_id = var.genesys_cloud_client_id
client_secret = var.genesys_cloud_client_secret
region = var.genesys_cloud_region
In your GitHub Actions workflow, you will pass these values as environment variables to the Terraform step. The provider will use the underlying SDK (written in Go) to perform the OAuth handshake.
Step 1: Define the GitHub Actions Workflow File
Create a file named .github/workflows/terraform.yml in your repository. This file defines the triggers, the environment, and the steps for planning and applying changes.
We use actions/checkout to retrieve the code and hashicorp/setup-terraform to install the correct version of Terraform. We then use env blocks to inject secrets securely.
on:
pull_request:
branches:
- main
paths:
- '**.tf'
- '.github/workflows/terraform.yml'
push:
branches:
- main
paths:
- '**.tf'
permissions:
contents: read
id-token: write # Required for OIDC if using AWS/Azure login, optional for pure Genesys OAuth
jobs:
terraform:
name: 'Terraform Plan and Apply'
runs-on: ubuntu-latest
env:
# Inject Genesys Cloud Credentials from GitHub Secrets
GENESYS_CLOUD_CLIENT_ID: ${{ secrets.GENESYS_CLOUD_CLIENT_ID }}
GENESYS_CLOUD_CLIENT_SECRET: ${{ secrets.GENESYS_CLOUD_CLIENT_SECRET }}
GENESYS_CLOUD_REGION: ${{ secrets.GENESYS_CLOUD_REGION }}
# Ensure that only one concurrent workflow runs per branch to prevent state conflicts
concurrency:
group: terraform-${{ github.ref }}
cancel-in-progress: true
steps:
- name: Checkout Code
uses: actions/checkout@v4
- name: Setup Terraform
uses: hashicorp/setup-terraform@v3
with:
terraform_version: 1.5.0
- name: Terraform Init
run: terraform init
env:
# Pass secrets as environment variables for Terraform to consume
TF_VAR_genesys_cloud_client_id: ${{ secrets.GENESYS_CLOUD_CLIENT_ID }}
TF_VAR_genesys_cloud_client_secret: ${{ secrets.GENESYS_CLOUD_CLIENT_SECRET }}
TF_VAR_genesys_cloud_region: ${{ secrets.GENESYS_CLOUD_REGION }}
- name: Terraform Format Check
run: terraform fmt -check -diff
- name: Terraform Validate
run: terraform validate -no-color
- name: Terraform Plan
if: github.event_name == 'pull_request'
run: |
terraform plan -no-color \
-var="genesys_cloud_client_id=${{ secrets.GENESYS_CLOUD_CLIENT_ID }}" \
-var="genesys_cloud_client_secret=${{ secrets.GENESYS_CLOUD_CLIENT_SECRET }}" \
-var="genesys_cloud_region=${{ secrets.GENESYS_CLOUD_REGION }}" \
-out=tfplan
continue-on-error: false
- name: Update Pull Request
uses: actions/github-script@v6
with:
github-token: ${{ secrets.GITHUB_TOKEN }}
script: |
const output = `#### Terraform Plan Format
${{ steps.plan.outputs.stdout }}
github.rest.pulls.createReview({
pull_number: context.issue.number,
owner: context.repo.owner,
repo: context.repo.repo,
body: output
- name: Terraform Apply
if: github.event_name == 'push' && github.ref == 'refs/heads/main'
run: |
terraform apply -auto-approve -no-color \
Key Configuration Details:
concurrency: This is critical. Without it, two simultaneous pushes tomaincould cause race conditions when locking the Terraform state. This ensures only one workflow runs per branch at a time.ifconditions: Theplanstep only runs onpull_requestevents. Theapplystep only runs onpushevents to themainbranch. This separates validation from execution.-out=tfplan: In the plan step, we save the plan output to a file. While we do not upload this file for apply in this simple example (since apply happens in a different job context on merge), saving it allows you to inspect the exact changes that would occur. For a more advanced setup, you might uploadtfplanas an artifact and download it during apply, but for most Genesys Cloud use cases, re-planning on apply is acceptable and safer to ensure the state is current.
Step 2: Configure Terraform Variables and Backend
Your variables.tf must define the inputs used in the workflow.
variable "genesys_cloud_client_id" {
description = "The OAuth Client ID for Genesys Cloud"
type = string
sensitive = true
variable "genesys_cloud_client_secret" {
description = "The OAuth Client Secret for Genesys Cloud"
type = string
sensitive = true
variable "genesys_cloud_region" {
description = "The Genesys Cloud region (e.g., us-east-1)"
type = string
default = "mypurecloud.com"
Your backend.tf must point to a remote state storage. For this example, we assume an AWS S3 backend, which is the industry standard for Terraform state.
terraform {
backend "s3" {
bucket = "my-company-terraform-state"
key = "genesys-cx/infrastructure/terraform.tfstate"
region = "us-east-1"
dynamodb_table = "terraform-locks"
encrypt = true
Why DynamoDB?
The dynamodb_table parameter enables state locking. When terraform plan or terraform apply runs, it acquires a lock in DynamoDB. If another process tries to modify the state simultaneously, it fails immediately. This prevents the “split-brain” scenario where two pipelines update the same Genesys Cloud resource concurrently, leading to inconsistent state or API conflicts (409 errors).
Step 3: Example Genesys Cloud Resource
To verify the pipeline works, create a simple resource. Here is an example of creating a User in Genesys Cloud.
resource "genesyscloud_user" "demo_user" {
name = "Terraform Demo User"
email = "terraform.demo@example.com"
division_id = null # Uses default division
# Assign a default routing email address if needed
routing_email_addresses {
address = "terraform.demo@example.com"
When you push this to a branch and open a Pull Request, the workflow will trigger. The terraform plan step will attempt to authenticate with Genesys Cloud using the secrets. If the credentials are valid and the scopes are sufficient, it will output a plan showing the creation of the user.
Below is the complete set of files required to run this pipeline.
1. .github/workflows/terraform.yml
on:
pull_request:
branches:
- main
paths:
- '**.tf'
push:
branches:
- main
paths:
- '**.tf'
permissions:
contents: read
jobs:
terraform:
env:
concurrency:
steps:
with:
run: terraform init
env:
run: |
-out=tfplan
- name: Update Pull Request with Plan
with:
script: |
const output = `#### Terraform Plan Output
body: output
run: |
2. main.tf
terraform {
genesyscloud = {
version = "~> 1.0"
type = string
sensitive = true
type = string
sensitive = true
type = string
resource "genesyscloud_user" "ci_test_user" {
name = "CI Test User"
email = "ci.test.user@example.com"
3. backend.tf
terraform {
backend "s3" {
bucket = "my-terraform-state-bucket"
key = "genesys/terraform.tfstate"
encrypt = true
Cause: The OAuth token generated by the Client ID and Secret is invalid. This usually means the Client ID/Secret are incorrect, or the OAuth client in Genesys Cloud is disabled.
Fix:
- Log into Genesys Cloud Admin Portal.
- Navigate to Platform > Integrations > OAuth Client Applications.
- Verify the Client ID matches your GitHub Secret.
- Ensure the client is Enabled.
- If you recently rotated the secret, update the GitHub Secret immediately.
Error: 403 Forbidden
Cause: The OAuth client does not have the required scopes for the resource being modified. For example, creating a user requires user:write.
Fix:
- In the Genesys Cloud Admin Portal, edit the OAuth client.
- Add the necessary scopes. For the
genesyscloud_userresource, ensureuser:readanduser:writeare selected. - Save the client. Note: Scope changes may require a new token, which Terraform will fetch automatically on the next run.
Cause: Genesys Cloud APIs enforce rate limits. If your Terraform configuration creates many resources in parallel (default parallelism = 10), you may hit the API rate limit.
Fix:
Reduce the parallelism in your Terraform configuration or in the workflow command.
run: |
terraform apply -auto-approve -parallelism=5 -no-color \
Alternatively, configure retry logic in the provider if supported, or add a sleep between large batches of resources.
Error: State Lock Timeout
Cause: Another process holds the DynamoDB lock. This happens if a previous run crashed or was cancelled without releasing the lock.
Fix:
You can force-unlock the state using the Terraform CLI locally or in a separate manual workflow step.
terraform force-unlock <LOCK_ID>
Find the <LOCK_ID> in the error message output from the failed GitHub Actions run. Use this command with the same backend configuration and credentials.
