Automate Genesys Cloud Infrastructure: Terraform Plan on PR and Apply on Merge
- A GitHub Actions pipeline that executes
terraform planon every pull request to validate infrastructure changes without applying them. - A workflow that executes
terraform applyautomatically when a pull request is merged into themainbranch. - A secure authentication mechanism using Genesys Cloud OAuth2 Client Credentials flow to generate short-lived tokens for Terraform providers.
- GitHub Repository: A repository containing Terraform configuration files (
.tf) for Genesys Cloud resources. - Genesys Cloud Organization: An admin account to create an OAuth2 Client.
- OAuth2 Client: A “Public” or “Confidential” client registered in Genesys Cloud with the scope
admin:infrastructure:write(or specific scopes likeadmin:users:writedepending on your Terraform resources). - GitHub Secrets:
GENESYS_CLIENT_ID: The OAuth Client ID.GENESYS_CLIENT_SECRET: The OAuth Client Secret.GENESYS_REGION: The Genesys region (e.g.,us-east-1,eu-west-1).
- Terraform Version: 1.5+ installed in the GitHub Actions runner environment.
- Provider:
myntra/genesyscloudorgenesys/genesyscloud(depending on the specific provider fork used in yourversions.tf).
Genesys Cloud does not support static long-lived API keys for Terraform providers in a secure manner. The standard pattern is to generate a token at runtime using the Client Credentials flow. This ensures that the token expires after 1 hour, reducing the blast radius if a token is leaked.
We will create a shell script to handle the token generation. This script will be called by the GitHub Actions workflow before Terraform initializes.
Create a file named get-token.sh in your repository root:
#!/bin/bash
# Exit immediately if a command exits with a non-zero status.
set -e
# Check for required environment variables
if [ -z "$GENESYS_CLIENT_ID" ] || [ -z "$GENESYS_CLIENT_SECRET" ] || [ -z "$GENESYS_REGION" ]; then
echo "Error: Missing required environment variables GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, or GENESYS_REGION"
exit 1
fi
# Determine the OAuth endpoint based on region
if [ "$GENESYS_REGION" == "us-east-1" ]; then
OAUTH_ENDPOINT="https://api.mypurecloud.com"
elif [ "$GENESYS_REGION" == "eu-west-1" ]; then
OAUTH_ENDPOINT="https://api.eu.pure.cloud"
elif [ "$GENESYS_REGION" == "ap-southeast-2" ]; then
OAUTH_ENDPOINT="https://api.au.pure.cloud"
else
fi
echo "Requesting OAuth token from ${OAUTH_ENDPOINT}..."
# Request the token
TOKEN_RESPONSE=$(curl -s -X POST "${OAUTH_ENDPOINT}/oauth/token" \
-H "Content-Type: application/x-www-form-urlencoded" \
-d "grant_type=client_credentials" \
-d "client_id=${GENESYS_CLIENT_ID}" \
-d "client_secret=${GENESYS_CLIENT_SECRET}")
# Extract the access token using jq (installed in GitHub Actions runners)
ACCESS_TOKEN=$(echo "$TOKEN_RESPONSE" | jq -r '.access_token')
# Verify token extraction was successful
if [ -z "$ACCESS_TOKEN" ] || [ "$ACCESS_TOKEN" == "null" ]; then
echo "Error: Failed to retrieve access token. Response:"
exit 1
fi
# Export the token for use by subsequent steps
export GENESYS_ACCESS_TOKEN="$ACCESS_TOKEN"
echo "OAuth token retrieved successfully."
Make the script executable locally, though GitHub Actions will handle permissions. In your Terraform provider configuration (main.tf), reference the environment variable:
provider "genesyscloud" {
access_token = var.genesys_access_token
region = var.genesys_region
And in your variables.tf:
variable "genesys_access_token" {
description = "Genesys Cloud OAuth Access Token"
type = string
sensitive = true
variable "genesys_region" {
description = "Genesys Cloud Region"
type = string
default = "us-east-1"
Step 1: Define the GitHub Actions Workflow Structure
Create a new file at .github/workflows/terraform-genesis.yml. This file defines two distinct jobs: one for planning (triggered on PRs) and one for applying (triggered on merges to main).
The workflow uses actions/checkout to fetch code and hashicorp/setup-terraform to install the Terraform binary. Crucially, it uses the actions/cache to store the .terraform directory and state files, ensuring faster initialization and consistent state locking behavior.
name: Genesys Cloud Terraform CI/CD
on:
pull_request:
branches: [ main ]
paths:
- '**.tf'
- '.github/workflows/terraform-genesis.yml'
push:
branches: [ main ]
paths:
- '**.tf'
env:
TF_IN_AUTOMATION: 1
GENESYS_REGION: ${{ secrets.GENESYS_REGION }}
jobs:
terraform-plan:
runs-on: ubuntu-latest
if: github.event_name == 'pull_request'
steps:
- name: Checkout Code
uses: actions/checkout@v4
- name: Setup Terraform
uses: hashicorp/setup-terraform@v3
with:
terraform_version: 1.5.0
- name: Generate Genesys Token
run: |
chmod +x get-token.sh
export GENESYS_ACCESS_TOKEN=$(/bin/bash get-token.sh)
echo "::add-mask::$GENESYS_ACCESS_TOKEN"
echo "GENESYS_ACCESS_TOKEN=$GENESYS_ACCESS_TOKEN" >> $GITHUB_ENV
- name: Terraform Init
run: terraform init -backend-config="bucket=${{ secrets.S3_BUCKET_NAME }}" -backend-config="key=genesys/terraform.tfstate" -backend-config="region=${{ secrets.AWS_REGION }}"
- name: Terraform Plan
run: |
terraform plan -var="genesys_access_token=${{ env.GENESYS_ACCESS_TOKEN }}" \
-var="genesys_region=${{ env.GENESYS_REGION }}" \
-out=tfplan
continue-on-error: true
- name: Save Plan Output
if: always()
run: |
mkdir -p plan-output
terraform show -json tfplan > plan-output/plan.json
cat plan-output/plan.json
- name: Post Plan Summary
if: always()
run: |
echo "## Terraform Plan Summary" >> $GITHUB_STEP_SUMMARY
echo "" >> $GITHUB_STEP_SUMMARY
echo '```json' >> $GITHUB_STEP_SUMMARY
cat plan-output/plan.json | jq '.resource_changes' >> $GITHUB_STEP_SUMMARY
echo '```' >> $GITHUB_STEP_SUMMARY
terraform-apply:
if: github.event_name == 'push' && github.ref == 'refs/heads/main'
needs: terraform-plan
steps:
with:
run: |
- name: Terraform Apply
run: |
terraform apply -var="genesys_access_token=${{ env.GENESYS_ACCESS_TOKEN }}" \
-auto-approve -input=false
Step 2: Configure Remote State Backend
Terraform requires a remote state backend for team collaboration and state locking. AWS S3 with DynamoDB is the industry standard. You must configure this in your backend.tf or pass it via CLI arguments as shown in the workflow above.
If you prefer defining the backend in code, use backend.tf:
terraform {
backend "s3" {
bucket = "my-genesis-terraform-state"
key = "genesys/terraform.tfstate"
region = "us-east-1"
dynamodb_table = "terraform-locks"
encrypt = true
Note that the GitHub Actions workflow passes -backend-config arguments. This allows you to keep the S3 bucket name and AWS region in GitHub Secrets rather than hardcoding them in the repository. This is a critical security practice.
Step 3: Handle State Locking and Concurrency
Genesys Cloud APIs have rate limits. If multiple pipelines run simultaneously, you may encounter 429 Too Many Requests errors. The hashicorp/setup-terraform action does not handle rate limiting automatically. You must rely on the DynamoDB lock to prevent concurrent apply operations.
However, plan operations are read-only and can run in parallel. The workflow above ensures apply only runs on push to main, and plan only runs on pull requests. This naturally serializes the apply operations.
To handle potential transient 429 errors during the apply phase, you can configure the Genesys Cloud provider to retry requests. Add this to your provider block:
# Provider-specific retry configuration if supported by the specific provider version
# Note: The official genesys/genesyscloud provider handles retries internally.
# If you encounter 429s, ensure your OAuth client has sufficient rate limit capacity.
Below is the complete set of files required to run this pipeline.
1. main.tf
terraform {
required_version = ">= 1.5.0"
required_providers {
genesyscloud = {
source = "genesys/genesyscloud"
version = "~> 1.0.0"
# Example Resource: Create a Queue
resource "genesyscloud_routing_queue" "support_queue" {
name = "Terraform Support Queue"
description = "Managed by Terraform"
enabled = true
wrap_up_policy {
type = "OPTIONAL"
outbound_email {
enabled = false
acd_skill {
enabled = true
2. variables.tf
type = string
sensitive = true
type = string
3. outputs.tf
output "queue_id" {
value = genesyscloud_routing_queue.support_queue.id
description = "The ID of the created queue"
4. .github/workflows/terraform-genesis.yml
(See the full YAML block in Step 1 above).
5. get-token.sh
(See the full Bash script in the Authentication Setup section above).
Cause: The OAuth token is invalid, expired, or missing scopes.
Fix:
- Verify that
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETare correctly set in GitHub Secrets. - Check the Genesys Cloud Admin console to ensure the OAuth Client is active.
- Ensure the OAuth Client has the necessary scopes. For creating queues, you need
admin:infrastructure:write. For users, you needadmin:users:write. - Inspect the
get-token.shoutput in the GitHub Actions logs. If the token request fails, the script will print the error response.
Error: 403 Forbidden
Cause: The OAuth Client lacks permissions to perform the specific action, or the user associated with the client does not have the required roles.
Fix:
- In Genesys Cloud, navigate to Admin > Platform > OAuth2 Clients.
- Edit the client and verify the “Scopes” section.
- Ensure the user linked to the OAuth Client has the “System Administrator” or specific “Infrastructure Administrator” role.
Cause: Genesys Cloud API rate limits have been exceeded. This is common during terraform apply when creating many resources.
Fix:
- The Genesys Cloud Terraform provider includes built-in retry logic for 429 errors. However, if you are creating hundreds of resources, consider breaking them into smaller modules.
- Increase the rate limit capacity of your OAuth Client in the Genesys Cloud Admin console if you have an enterprise agreement that allows it.
- Add a
sleepcommand between resource creation blocks if you are using custom scripts, though Terraform handles this internally.
Error: State Lock Timeout
Cause: Another process is holding the DynamoDB lock.
Fix:
- Check if another GitHub Actions run is in progress.
- If the lock is stale, you may need to manually release it using
terraform force-unlock <LOCK_ID>. - Ensure that only one
applyoperation runs at a time. The workflow configuration prevents this by only allowingapplyon push to main.
