Authenticate with Genesys Cloud Using OAuth2 Client Credentials in Python
  • A Python script that authenticates against the Genesys Cloud OAuth2 endpoint using the Client Credentials grant type.
  • The script retrieves a valid JWT access token and decodes the payload to verify scopes and expiration.
  • The tutorial uses the requests library for HTTP interactions and jwt (PyJWT) for token inspection.
  • OAuth Client Type: Confidential Client (Machine-to-Machine). You must have a registered OAuth Client in the Genesys Cloud Admin Console.
  • Required Scopes: admin:conversation:read, admin:user:read, or any specific scopes your integration requires. For this tutorial, we will request admin:conversation:read.
  • SDK/API Version: PureCloudPlatformClientV2 (Python SDK) or raw REST API. This tutorial focuses on the raw REST API via requests to demonstrate the underlying mechanics, which applies to all SDK versions.
  • Language/Runtime: Python 3.8+.
  • External Dependencies:
    • requests: For HTTP requests.
    • pyjwt: For decoding the JWT token payload.
Install dependencies via pip:
pip install requests pyjwt
The Genesys Cloud OAuth2 endpoint uses the standard RFC 6749 Client Credentials flow. This flow is designed for server-to-server communication where no user interaction is involved. The client authenticates itself using a Client ID and Client Secret, and requests an access token with specific scopes.
You must obtain the following from the Genesys Cloud Admin Console under Users > Integrations > OAuth Clients:
  1. Client ID: A unique identifier for your application.
  2. Client Secret: A confidential string known only to your application and Genesys Cloud.
  3. Environment URL: The base URL for your environment (e.g., https://api.mypurecloud.com for US1).
The token endpoint is always located at:
https://login.mypurecloud.com/oauth/token
Note that the login domain (login.mypurecloud.com) is consistent across all Genesys Cloud environments, even if your API base URL differs.
Step 1: Construct the Authentication Request
The OAuth2 token endpoint expects a POST request with application/x-www-form-urlencoded content. The body must contain the grant_type, client_id, client_secret, and scope parameters.
Critical Detail: The client_secret must be included in the body, not in the HTTP Basic Auth header, unless you have explicitly configured your OAuth client to support Basic Auth authentication in the Genesys Cloud Admin Console. The default and most robust method is to pass it in the body.
Here is the code to construct and send the request.
import requests
import jwt
from typing import Dict, Optional
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, environment: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        # The login domain is always login.mypurecloud.com regardless of the API environment
        self.token_url = "https://login.mypurecloud.com/oauth/token"
        self.base_url = environment
    def get_access_token(self, scopes: list[str]) -> Dict[str, any]:
        Requests an OAuth2 access token using the Client Credentials flow.
        Args:
            scopes: A list of OAuth scopes required for the API calls.
        Returns:
            A dictionary containing the access token and related metadata.
        # Prepare the form data
        # The scope parameter must be a space-separated string
        scope_string = " ".join(scopes)
        payload = {
            "client_id": self.client_id,
            "scope": scope_string
            # Send the POST request
            response = requests.post(
                self.token_url,
                data=payload,
                timeout=10
            # Raise an exception for 4xx and 5xx status codes
            response.raise_for_status()
            return response.json()
        except requests.exceptions.HTTPError as http_err:
            print(f"HTTP error occurred: {http_err}")
            print(f"Response body: {response.text}")
            raise
        except requests.exceptions.ConnectionError:
            print("Error: Could not connect to the Genesys Cloud login server.")
            raise
        except requests.exceptions.Timeout:
            print("Error: The request to the login server timed out.")
            raise
        except requests.exceptions.RequestException as err:
            print(f"An error occurred: {err}")
            raise
# Usage Example
    # Replace with your actual credentials
    CLIENT_ID = "your_client_id_here"
    CLIENT_SECRET = "your_client_secret_here"
    auth_client = GenesysAuth(CLIENT_ID, CLIENT_SECRET)
        token_data = auth_client.get_access_token(["admin:conversation:read"])
        print("Authentication successful.")
        print(f"Access Token: {token_data['access_token'][:20]}...")
        print(f"Authentication failed: {e}")
Step 2: Handle Token Response and Expiration
The response from the OAuth2 endpoint is a JSON object. If successful, it contains the access_token, token_type, expires_in, and scope.
Expected Response Body:
  "token_type": "Bearer",
  "expires_in": 3600,
  "scope": "admin:conversation:read"
The expires_in field indicates the lifetime of the token in seconds. For Client Credentials grants, this is typically 3600 seconds (1 hour). You must implement logic to cache the token and request a new one before expiration to avoid unnecessary latency in your application.
Here is how to decode the token and verify its validity.
    def decode_token(self, token: str) -> Dict[str, any]:
        Decodes the JWT access token to inspect claims without verification.
        Note: In production, you should verify the signature using the JWKS endpoint.
        For simple tutorials, unverified decoding allows inspection of scopes and expiry.
        Args:
            token: The JWT access token string.
        Returns:
            A dictionary of the token's payload claims.
            # Decode without verification for inspection purposes
            # In production, use jwt.decode(token, options={"verify_signature": True}, audience="...", algorithms=["RS256"])
            payload = jwt.decode(token, options={"verify_signature": False})
            return payload
        except jwt.ExpiredSignatureError:
            print("Error: The token has expired.")
            raise
        except jwt.InvalidTokenError as e:
            print(f"Error: Invalid token - {e}")
            raise
    def is_token_valid(self, token: str, buffer_seconds: int = 300) -> bool:
        Checks if the token is still valid, considering a buffer time.
        Args:
            buffer_seconds: Seconds before actual expiration to consider the token invalid.
        Returns:
            True if valid, False otherwise.
            payload = self.decode_token(token)
            exp = payload.get('exp')
            if exp is None:
                return False
            current_time = time.time()
            return exp > (current_time + buffer_seconds)
        except Exception:
            return False
Step 3: Integrate Token Management into API Calls
To use the access token, you must include it in the Authorization header of subsequent API requests. The format is Bearer <access_token>.
Here is a complete example that authenticates, caches the token, and makes a simple API call to retrieve the current user’s profile (if the scope allows) or list conversations.
    def api_request(self, method: str, endpoint: str, token: str, headers: Optional[Dict] = None) -> requests.Response:
        Makes an authenticated API request to Genesys Cloud.
        Args:
            method: HTTP method (GET, POST, etc.).
            endpoint: The API endpoint path (e.g., '/api/v2/conversations').
            token: The active Bearer token.
            headers: Additional headers if needed.
        Returns:
            The requests.Response object.
        url = f"{self.base_url}{endpoint}"
        auth_headers = {
        if headers:
            auth_headers.update(headers)
            response = requests.request(
                method=method,
                url=url,
                headers=auth_headers,
                timeout=30
            return response
            print(f"API Request failed: {e}")
            raise
# Updated Usage Example with API Call
        # Step 1: Get Token
        access_token = token_data['access_token']
        # Step 2: Verify Token
        if not auth_client.is_token_valid(access_token):
            print("Token is expired or invalid.")
        else:
            print("Token is valid.")
            # Step 3: Make an API Call
            # Example: Get list of conversations (requires admin:conversation:read)
            endpoint = "/api/v2/conversations"
            params = {
                "pageSize": 10,
                "filter": "type:voice"
            response = auth_client.api_request("GET", endpoint, access_token)
            if response.status_code == 200:
                conversations = response.json()
                print(f"Retrieved {len(conversations.get('entities', []))} conversations.")
                # Print first conversation ID if available
                if conversations.get('entities'):
                    print(f"First Conversation ID: {conversations['entities'][0]['id']}")
            else:
                print(f"API Error: {response.status_code} - {response.text}")
        print(f"Critical Failure: {e}")
Below is the full, copy-pasteable script. It includes a simple token cache mechanism to avoid re-authenticating on every run within the token’s lifetime.
import requests
import jwt
import os
class GenesysCloudClient:
        # Internal cache for token
        self._cached_token: Optional[str] = None
        self._token_expiry: float = 0
    def _get_token(self, scopes: list[str]) -> str:
        Retrieves a new access token.
        payload = {
        response = requests.post(self.token_url, data=payload, timeout=10)
        data = response.json()
        return data['access_token'], data['expires_in']
    def get_valid_token(self, scopes: list[str]) -> str:
        Returns a valid access token, caching it until it expires.
        # Check if we have a cached token and if it is still valid (with 5 min buffer)
        if self._cached_token and current_time < (self._token_expiry - 300):
            return self._cached_token
        # If not, get a new one
        print("Authenticating with Genesys Cloud...")
        token, expires_in = self._get_token(scopes)
        self._cached_token = token
        self._token_expiry = current_time + expires_in
        return token
    def make_api_request(self, method: str, endpoint: str, scopes: list[str], params: Optional[Dict] = None) -> Dict:
        High-level method to make an API request with automatic authentication.
        token = self.get_valid_token(scopes)
        headers = {
            method=method,
            url=url,
            headers=headers,
            params=params,
            timeout=30
# Example Usage
    # Load credentials from environment variables for security
    CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
    CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
    if not CLIENT_ID or not CLIENT_SECRET:
        raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables must be set.")
    client = GenesysCloudClient(CLIENT_ID, CLIENT_SECRET)
        # Example: List recent voice conversations
        data = client.make_api_request(
            method="GET",
            endpoint="/api/v2/conversations",
            scopes=["admin:conversation:read"],
            params={"pageSize": 5, "filter": "type:voice"}
        entities = data.get("entities", [])
        print(f"Found {len(entities)} conversations.")
        for conv in entities:
            print(f"ID: {conv['id']}, Type: {conv['type']}, State: {conv['state']}")
        print(f"HTTP Error: {e.response.status_code} - {e.response.text}")
        print(f"Error: {e}")
  • Cause: The Client ID or Client Secret is incorrect, or the OAuth Client is disabled in the Admin Console.
  • Fix: Verify the credentials in the Genesys Cloud Admin Console. Ensure the “Enabled” checkbox is selected for the OAuth Client. Check for trailing spaces in your secret string.
Error: 403 Forbidden
  • Cause: The requested scopes are not granted to the OAuth Client, or the client does not have permission to access the specific resource.
  • Fix: In the Admin Console, navigate to Users > Integrations > OAuth Clients, select your client, and ensure the required scopes (e.g., admin:conversation:read) are checked. Also, verify that the OAuth Client has been assigned to a user or group that has the necessary permissions for those scopes.
  • Cause: You have exceeded the rate limit for the OAuth endpoint or the API endpoint.
  • Fix: Implement exponential backoff in your retry logic. For the OAuth endpoint, this is rare unless you are requesting tokens too frequently. For API endpoints, check the Retry-After header in the response.
Error: Token Expired
  • Cause: The access token has passed its expires_in duration.
  • Fix: Implement token caching as shown in the complete example. Always check the exp claim in the JWT or track the expiration time in your application memory. Do not store tokens in long-term storage without expiration checks.
