Authenticate with Genesys Cloud CX Using OAuth2 Client Credentials in Python
- A Python script that authenticates against the Genesys Cloud CX authorization server using the OAuth2 Client Credentials grant type.
- This tutorial uses the
requestslibrary to handle the HTTP POST request to the/oauth/tokenendpoint. - The code is written in Python 3.8+ and demonstrates proper error handling, token caching, and environment variable management.
- OAuth Client Type: You must have a Genesys Cloud CX Application created in the Developer Portal. The application type must be Machine to Machine (or Confidential Client).
- Required Scopes: For this specific authentication step, no specific business scope is required. However, the token returned will be used for subsequent API calls. Ensure your Application has the necessary scopes (e.g.,
analytics:conversation:view,user:read) added in the Developer Portal for the APIs you plan to call later. - SDK/API Version: This tutorial uses the raw REST API via
requests. It is compatible with Genesys Cloud CX API v2. - Language/Runtime: Python 3.8 or higher.
- External Dependencies:
requests: For making HTTP calls.python-dotenv: For securely managing environment variables (optional but recommended).
Install dependencies via pip:
pip install requests python-dotenv
The Genesys Cloud CX authorization server supports the OAuth2 Client Credentials flow. This flow is ideal for server-to-server communication where there is no user interaction. It exchanges a client ID and client secret for an access token.
Step 1: Prepare Credentials and Environment Variables
Hardcoding credentials is a security risk. Use environment variables to store your Client ID and Client Secret.
Create a .env file in your project root:
GENESYS_CLIENT_ID=your_client_id_here
GENESYS_CLIENT_SECRET=your_client_secret_here
GENESYS_REGION=us
Note: The GENESYS_REGION determines the base URL. Common values are us, eu, au, jp, ca, in, br, sg, kr, ae, za.
Load these variables in your Python script:
import os
# Load environment variables from .env file
load_dotenv()
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
REGION = os.getenv("GENESYS_REGION", "us")
if not CLIENT_ID or not CLIENT_SECRET:
raise ValueError("Missing GENESYS_CLIENT_ID or GENESYS_CLIENT_SECRET in environment variables.")
Step 2: Construct the Authorization URL
The authorization endpoint varies slightly by region but follows a consistent pattern.
- US:
https://api.mypurecloud.com/oauth/token - EU:
https://api.eu.mypurecloud.com/oauth/token - Other Regions:
https://api.[region].mypurecloud.com/oauth/token
Construct the base URL dynamically:
def get_auth_url(region: str) -> str:
Constructs the OAuth token endpoint URL based on the region.
if region == "us":
base = "https://api.mypurecloud.com"
else:
base = f"https://api.{region}.mypurecloud.com"
return f"{base}/oauth/token"
Step 3: Execute the OAuth Request
The Client Credentials grant requires a POST request to the token endpoint with the following parameters in the body (application/x-www-form-urlencoded):
grant_type: Must be set toclient_credentials.client_id: Your applicationâs Client ID.client_secret: Your applicationâs Client Secret.scope: A space-delimited list of scopes. While you can request specific scopes here, it is often easier to request all scopes assigned to the application or a broad set. If omitted, the server may return an error or default behavior depending on configuration. It is best practice to specify the scopes you need.
Code Implementation:
import requests
import json
from typing import Optional, Dict, Any
def get_access_token(
client_id: str,
client_secret: str,
region: str,
scopes: Optional[str] = None
) -> Dict[str, Any]:
Authenticates with Genesys Cloud CX using Client Credentials flow.
Args:
client_id: The OAuth Client ID.
client_secret: The OAuth Client Secret.
region: The Genesys Cloud region (e.g., 'us', 'eu').
scopes: Optional space-delimited string of OAuth scopes.
If None, it requests the default scope associated with the client.
Returns:
A dictionary containing the access token and metadata.
Raises:
requests.exceptions.HTTPError: If the HTTP request returns an error status.
ValueError: If the response does not contain an access token.
url = get_auth_url(region)
# Prepare the payload
payload = {
"client_id": client_id,
"client_secret": client_secret
# Add scopes if provided
if scopes:
payload["scope"] = scopes
# Set headers
# Note: Content-Type is application/x-www-form-urlencoded by default
# when passing a dict to data= in requests.
headers = {
# Make the POST request
response = requests.post(
url,
data=payload, # Use 'data' for form-encoded, not 'json'
headers=headers,
timeout=10
# Raise an exception for 4xx/5xx status codes
response.raise_for_status()
# Parse the JSON response
token_data = response.json()
# Validate that we received an access token
if "access_token" not in token_data:
raise ValueError("Response did not contain an 'access_token'.")
return token_data
except requests.exceptions.HTTPError as http_err:
# Handle specific HTTP errors
status_code = response.status_code
error_body = response.text
if status_code == 401:
raise ValueError(f"Authentication failed (401). Check your Client ID and Secret. Details: {error_body}")
elif status_code == 403:
raise ValueError(f"Access forbidden (403). The client may not have permission to request these scopes. Details: {error_body}")
elif status_code == 429:
raise ValueError(f"Rate limited (429). Too many requests. Details: {error_body}")
else:
raise ValueError(f"HTTP Error {status_code}: {error_body}") from http_err
except requests.exceptions.RequestException as req_err:
raise ValueError(f"Network error occurred: {req_err}")
# Example Usage
# Request common scopes for testing
# In production, only request the scopes you strictly need
requested_scopes = "analytics:conversation:view user:read"
token_response = get_access_token(
client_id=CLIENT_ID,
client_secret=CLIENT_SECRET,
region=REGION,
scopes=requested_scopes
print("Authentication Successful!")
print(f"Access Token: {token_response['access_token'][:20]}...")
print(f"Token Type: {token_response['token_type']}")
print(f"Expires In: {token_response['expires_in']} seconds")
print(f"Scope Granted: {token_response['scope']}")
except ValueError as e:
print(f"Error: {e}")
Step 4: Understanding the Response
A successful response returns a JSON object with the following structure:
"token_type": "Bearer",
"expires_in": 3600,
"scope": "analytics:conversation:view user:read"
access_token: The JWT token used to authorize subsequent API calls.token_type: AlwaysBearerfor Genesys Cloud.expires_in: The lifetime of the token in seconds. Typically 3600 (1 hour).scope: The list of scopes granted. This may be a subset of what you requested if the application does not have permission for certain scopes.
Below is the complete, runnable script. Save this as auth_genesis.py.
import os
import sys
import requests
load_dotenv()
if region == "us":
else:
client_id: str,
client_secret: str,
region: str,
payload = {
if scopes:
headers = {
url,
data=payload,
headers=headers,
timeout=10
return token_data
raise ValueError(f"Authentication failed (401). Check Client ID/Secret. Details: {error_body}")
raise ValueError(f"Access forbidden (403). Check application scopes. Details: {error_body}")
raise ValueError(f"Rate limited (429). Details: {error_body}")
else:
def main():
region = os.getenv("GENESYS_REGION", "us")
print("Error: GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set in environment variables.")
sys.exit(1)
# Define scopes you need.
# You can find a list of scopes in the Genesys Cloud Developer Portal documentation.
client_id=client_id,
client_secret=client_secret,
region=region,
scopes=scopes
print("=== Authentication Successful ===")
print(f"Token Type: {token_response.get('token_type')}")
print(f"Expires In: {token_response.get('expires_in')} seconds")
print(f"Scopes: {token_response.get('scope')}")
print(f"Access Token (first 30 chars): {token_response['access_token'][:30]}...")
# Store the token for use in other parts of your application
# In a real app, you might cache this in memory or a secure store
access_token = token_response["access_token"]
# Example: Verify the token works by calling a simple API
# This demonstrates using the token in a subsequent request
verify_token(access_token, region)
print(f"Authentication Error: {e}")
sys.exit(1)
def verify_token(access_token: str, region: str):
Demonstrates using the obtained token to call a Genesys Cloud API.
Calls /api/v2/users/me to verify the token is valid and has user:read scope.
if region == "us":
base_url = "https://api.mypurecloud.com"
else:
base_url = f"https://api.{region}.mypurecloud.com"
endpoint = f"{base_url}/api/v2/users/me"
headers = {
"Authorization": f"Bearer {access_token}",
response = requests.get(endpoint, headers=headers, timeout=10)
user_data = response.json()
print("\n=== Token Verification Successful ===")
print(f"Authenticated User ID: {user_data.get('id')}")
print(f"User Name: {user_data.get('name')}")
print("\nToken Verification Failed: Unauthorized. The token may be invalid or expired.")
elif response.status_code == 403:
print("\nToken Verification Failed: Forbidden. The token lacks the 'user:read' scope.")
else:
print(f"\nToken Verification Error: {e}")
print(f"\nUnexpected error during verification: {e}")
main()
What causes it:
- The
client_idorclient_secretis incorrect. - The application is not active or has been deleted.
- The client secret was rotated in the Developer Portal, and your code is using the old secret.
How to fix it:
- Go to the Genesys Cloud Developer Portal.
- Navigate to Applications.
- Select your application.
- Verify the Client ID matches exactly.
- Regenerate the Client Secret if you suspect it is compromised or old, and update your
.envfile. - Ensure the application status is Active.
Error: 403 Forbidden
What causes it:
- The application does not have the requested scopes assigned.
- The organization has restricted OAuth access for that application.
How to fix it:
- In the Developer Portal, select your application.
- Go to the Scopes tab.
- Add the scopes you are requesting in the
scopeparameter of your request. - Save the changes. Note that scope changes may take a few minutes to propagate.
What causes it:
- You are requesting tokens too frequently. Genesys Cloud has rate limits on the OAuth endpoint.
- Your code is not caching the token and is requesting a new one on every API call.
How to fix it:
- Implement token caching. Tokens are valid for 1 hour (3600 seconds). Request a new token only when the current one expires or is close to expiring (e.g., 5 minutes before expiry).
- Use a library like
cachetoolsor a simple in-memory variable with a timestamp.
class TokenCache:
def __init__(self):
self.token = None
self.expiry_time = 0
def get_token(self, client_id, client_secret, region, scopes):
# Check if we have a valid token
if self.token and time.time() < self.expiry_time:
return self.token
# Fetch new token
token_data = get_access_token(client_id, client_secret, region, scopes)
self.token = token_data["access_token"]
# Set expiry to 5 minutes before actual expiry to be safe
self.expiry_time = time.time() + (token_data["expires_in"] - 300)
return self.token
Error: ValueError: Response did not contain an âaccess_tokenâ
What causes it:
- The request succeeded (200 OK), but the JSON structure is unexpected.
- This is rare but can happen if the API behavior changes or if a proxy interferes.
How to fix it:
- Print the raw
response.textto debug. - Ensure you are not accidentally sending JSON in the body instead of form-urlencoded data. Use
data=payloadnotjson=payloadinrequests.post.
