Authenticate Against NICE CXone Using Client Credentials
  • A script that exchanges a client ID and secret for a valid OAuth 2.0 access token.
  • A mechanism to persist that token and handle expiration automatically.
  • Python and JavaScript implementations using the official NICE CXone SDKs.
  • OAuth Client Type: Confidential Client (Server-to-Server).
  • Required Scopes: default or specific scopes granted to your API key (e.g., agent:read, interaction:write).
  • SDK Version: NICE CXone Python SDK (cxone-api-client) or JavaScript SDK (@nice-dcv/cxone-client).
  • Runtime: Python 3.8+ or Node.js 16+.
  • Dependencies:
    • Python: pip install cxone-api-client
    • JavaScript: npm install @nice-dcv/cxone-client
NICE CXone uses OAuth 2.0 for all API interactions. The client_credentials grant is the standard method for service-to-service communication where no human user is involved. This flow exchanges a Client ID and Client Secret for a short-lived access token.
The token endpoint is always:
https://{your-subdomain}.api.nice.incontact.com/oauth2/token
You must configure your API Key in the CXone Admin Console to allow “Server-to-Server” access and assign the necessary permissions.
Step 1: Obtain the Access Token (Python)
The Python SDK handles the underlying HTTP requests, but you must initialize the configuration correctly. The SDK uses a Configuration object that stores the credentials and the OAuth2 client instance.
import sys
import os
from cxone_api_client import Configuration, ApiClient
from cxone_api_client.rest import ApiException
def get_cxone_client(subdomain: str, client_id: str, client_secret: str) -> ApiClient:
    Configures and returns an authenticated CXone ApiClient instance.
    # 1. Define the OAuth2 Configuration
    # The CXone SDK uses a specific OAuth2Client wrapper internally.
    # We must pass the subdomain, client_id, and client_secret.
        configuration = Configuration(
            host=f"https://{subdomain}.api.nice.incontact.com",
            client_id=client_id,
            client_secret=client_secret
        # 2. Initialize the ApiClient
        # This client will automatically handle token acquisition and refresh.
        api_client = ApiClient(configuration)
        return api_client
        print(f"Failed to initialize CXone client: {e}", file=sys.stderr)
        raise
def test_authentication(api_client: ApiClient):
    Validates the token by making a simple API call.
    We use the 'Who Am I' endpoint to verify scope and identity.
    from cxone_api_client.api import platform_api
    platform_instance = platform_api.PlatformApi(api_client)
        # The 'whoami' endpoint requires no body, just valid auth.
        # It returns the user identity associated with the API key.
        response = platform_instance.get_platform_whoami()
        print(f"Authentication Successful.")
        print(f"User ID: {response.id}")
        print(f"User Name: {response.name}")
        print(f"Scopes: {response.scopes}")
    except ApiException as e:
        if e.status == 401:
            print("Authentication failed. Check Client ID, Secret, or Subdomain.")
        elif e.status == 403:
            print("Forbidden. The API key may lack required permissions.")
        else:
            print(f"API Error {e.status}: {e.body}")
        raise
    # Load credentials from environment variables
    SUBDOMAIN = os.getenv("CXONE_SUBDOMAIN")
    CLIENT_ID = os.getenv("CXONE_CLIENT_ID")
    CLIENT_SECRET = os.getenv("CXONE_CLIENT_SECRET")
    if not all([SUBDOMAIN, CLIENT_ID, CLIENT_SECRET]):
        print("Missing environment variables: CXONE_SUBDOMAIN, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET")
        sys.exit(1)
    client = get_cxone_client(SUBDOMAIN, CLIENT_ID, CLIENT_SECRET)
    test_authentication(client)
Expected Response from get_platform_whoami:
  "id": "550e8400-e29b-41d4-a716-446655440000",
  "name": "Service Account API Key",
  "email": "service-account@nice.com",
  "scopes": ["default"],
  "siteId": "123456"
Step 2: Obtain the Access Token (JavaScript)
In Node.js, the @nice-dcv/cxone-client package provides a Promise-based API. You must configure the client before making any requests.
const { CXoneClient } = require('@nice-dcv/cxone-client');
const { PlatformApi } = require('@nice-dcv/cxone-client');
async function initializeCXoneClient(subdomain, clientId, clientSecret) {
        // 1. Create the CXoneClient instance
        const cxoneClient = new CXoneClient({
            host: `https://${subdomain}.api.nice.incontact.com`,
            clientId: clientId,
            clientSecret: clientSecret
        // 2. The client automatically handles the OAuth2 flow.
        // No explicit token fetch is required for SDK usage.
        return cxoneClient;
    } catch (error) {
        console.error("Failed to initialize CXone Client:", error.message);
        throw error;
async function validateToken(cxoneClient) {
        // Initialize the PlatformApi with the configured client
        const platformApi = new PlatformApi(cxoneClient);
        // Call 'Who Am I' to verify authentication
        const response = await platformApi.getPlatformWhoami();
        console.log("Authentication Successful.");
        console.log("User ID:", response.body.id);
        console.log("User Name:", response.body.name);
        console.log("Scopes:", response.body.scopes);
        return response.body;
    } catch (error) {
        if (error.response && error.response.status === 401) {
            console.error("401 Unauthorized. Check credentials.");
        } else if (error.response && error.response.status === 403) {
            console.error("403 Forbidden. Check API key permissions.");
        } else {
            console.error("API Error:", error.message);
        throw error;
async function main() {
    const subdomain = process.env.CXONE_SUBDOMAIN;
    const clientId = process.env.CXONE_CLIENT_ID;
    const clientSecret = process.env.CXONE_CLIENT_SECRET;
    if (!subdomain || !clientId || !clientSecret) {
        console.error("Missing environment variables.");
        process.exit(1);
    const client = await initializeCXoneClient(subdomain, clientId, clientSecret);
    await validateToken(client);
main();
Step 3: Manual Token Management (Raw HTTP)
If you are not using the SDK and need to manage tokens manually (e.g., in a serverless function where you want to cache the token in Redis), you must hit the OAuth endpoint directly.
Endpoint: POST https://{subdomain}.api.nice.incontact.com/oauth2/token
Headers:
  • Content-Type: application/x-www-form-urlencoded
  • Authorization: Basic {Base64(ClientId:ClientSecret)} (Optional if sent in body)
Body:
grant_type=client_credentials&scope=default
import requests
import base64
class ManualTokenManager:
    def __init__(self, subdomain, client_id, client_secret):
        self.subdomain = subdomain
        self.client_id = client_id
        self.token_url = f"https://{subdomain}.api.nice.incontact.com/oauth2/token"
        self.access_token = None
        self.token_expiry = 0
    def get_token(self):
        Returns a valid access token. Handles refresh if expired.
        # Check if current token is still valid (add 30s buffer)
        if self.access_token and time.time() < (self.token_expiry - 30):
            return self.access_token
        # Fetch new token
        payload = {
            'grant_type': 'client_credentials',
            'scope': 'default'
        # Basic Auth header for Client ID and Secret
        credentials = f"{self.client_id}:{self.client_secret}"
        encoded_credentials = base64.b64encode(credentials.encode()).decode()
        headers = {
            'Content-Type': 'application/x-www-form-urlencoded',
            'Authorization': f'Basic {encoded_credentials}'
            response = requests.post(self.token_url, data=payload, headers=headers)
            response.raise_for_status()
            token_data = response.json()
            self.access_token = token_data['access_token']
            # CXone tokens typically expire in 1 hour (3600 seconds)
            self.token_expiry = time.time() + token_data.get('expires_in', 3600)
                raise Exception("Invalid Client ID or Secret.")
            elif response.status_code == 400:
                raise Exception("Invalid grant_type or scope.")
            else:
                raise Exception(f"OAuth Error: {response.text}")
# Usage
# manager = ManualTokenManager('mydomain', 'my_client_id', 'my_secret')
# token = manager.get_token()
# headers = {'Authorization': f'Bearer {token}'}
Below is a complete Python module that demonstrates authentication, token caching, and a subsequent API call to list agents. This example uses the SDK but includes a wrapper to demonstrate robust error handling.
import os
import sys
from cxone_api_client.api import analytics_conversations_api
class CXoneService:
        self.api_client = None
        self._init_client()
    def _init_client(self):
        """Initializes the CXone SDK client."""
            self.config = Configuration(
                host=f"https://{self.subdomain}.api.nice.incontact.com",
                client_id=self.client_id,
                client_secret=self.client_secret
            self.api_client = ApiClient(self.config)
            raise RuntimeError(f"Failed to initialize CXone Client: {e}")
    def get_current_time(self):
        Helper to get current time for API queries.
        return time.strftime("%Y-%m-%dT%H:%M:%S.000Z", time.gmtime())
    def fetch_recent_conversations(self, limit=5):
        Fetches recent conversation summaries.
        Requires scope: analytics:read
        analytics_api = analytics_conversations_api.AnalyticsConversationsApi(self.api_client)
        # Define the query body
        # Note: The 'interval' must be in ISO 8601 format
        current_time = self.get_current_time()
        # Look back 1 hour
        past_time = time.strftime("%Y-%m-%dT%H:%M:%S.000Z", time.gmtime(time.time() - 3600))
        query_body = {
            "interval": f"{past_time}/{current_time}",
            "groupBy": ["interactionType"],
            "metrics": ["conversationCount"],
            "filter": {
                "type": "and",
                "clauses": [
                        "type": "equals",
                        "path": "interactionType",
                        "value": "voice"
            "size": limit
            # The SDK handles pagination via 'nextPage' if available
            response = analytics_api.post_analytics_conversations_summary_query(
                body=query_body,
                retry_after_seconds=5 # Default retry behavior
            return response
            self._handle_api_error(e)
            raise
    def _handle_api_error(self, e):
        """Centralized error handling for API exceptions."""
        error_body = e.body
        if e.status == 401:
            print("ERROR: Unauthorized. Token is invalid or expired.")
            print("ERROR: Forbidden. API Key lacks 'analytics:read' scope.")
        elif e.status == 429:
            print("ERROR: Rate Limited. Too many requests.")
        else:
            print(f"ERROR: HTTP {e.status} - {error_body}")
def main():
    # Configuration
        print("Set CXONE_SUBDOMAIN, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET env vars.")
        sys.exit(1)
        # 1. Initialize Service
        service = CXoneService(SUBDOMAIN, CLIENT_ID, CLIENT_SECRET)
        # 2. Perform API Action
        print("Fetching recent voice conversations...")
        result = service.fetch_recent_conversations(limit=3)
        if result and result.entities:
            for entity in result.entities:
                print(f"Type: {entity.group}, Count: {entity.conversationCount}")
        else:
            print("No conversations found in the last hour.")
        print(f"Application Error: {e}")
        sys.exit(1)
    main()
Cause: The Client ID or Client Secret is incorrect, or the API Key is disabled.
Fix:
  1. Verify the Client ID and Secret in the CXone Admin Console under Settings > Integrations > API Keys.
  2. Ensure the API Key is “Active”.
  3. Check that the subdomain in your code matches the one in the Admin Console exactly (case-sensitive).
Error: 403 Forbidden
Cause: The API Key does not have the required permissions (scopes) for the endpoint you are calling.
Fix:
  1. Go to Settings > Integrations > API Keys.
  2. Click on your API Key.
  3. Under “Permissions”, ensure the relevant module (e.g., Analytics, Agents, Interactions) is checked.
  4. Note: Changes to permissions may take up to 15 minutes to propagate.
Cause: You have exceeded the rate limit for your API Key or tenant.
Fix:
  1. Implement exponential backoff in your retry logic.
  2. Check the Retry-After header in the response.
  3. In the Python SDK, you can configure retry behavior:
# Enable automatic retries for 429s
configuration.retries = 3
configuration.retry_after_seconds = 5
Error: 400 Bad Request (OAuth)
Cause: The grant_type is incorrect or missing.
Fix: Ensure your POST body contains grant_type=client_credentials. If using Basic Auth, ensure the header is Authorization: Basic {base64(client_id:client_secret)}.
