Auditing NICE CXone Pure Connect Station Firmware Versions via Pure Connect APIs with Python
A Python module that queries Pure Connect stations, validates firmware versions against a hardware compatibility matrix, verifies cryptographic checksums and signatures, triggers maintenance windows, syncs audit results to external IT asset managers via webhooks, and tracks latency and success metrics. This tutorial uses the Pure Connect REST API and Python 3.9+.
  • Pure Connect REST API access with OAuth2 client credentials
  • Required scopes: station:read, firmware:read, audit:execute, maintenance:write, webhook:write
  • Python 3.9 or higher
  • External dependencies: pip install requests pydantic
  • Network access to the Pure Connect REST API base URL and your external IT asset manager webhook endpoint
Pure Connect uses an OAuth2 client credentials flow. The following code establishes a session, caches the access token, and implements exponential backoff for 429 rate-limit responses.
import requests
from typing import Optional
class PureConnectAuth:
    def __init__(self, base_url: str, client_id: str, client_secret: str):
        self.client_id = client_id
        self.session = requests.Session()
        self.session.headers.update({
            "Accept": "application/json"
    def _get_token(self) -> str:
        if self.token and time.time() < self.token_expiry:
            return self.token
        payload = {
            "client_id": self.client_id,
        response = self.session.post(
            f"{self.base_url}/oauth/token",
            json=payload
        response.raise_for_status()
        data = response.json()
        self.token = data["access_token"]
        self.token_expiry = time.time() + data["expires_in"] - 30
        return self.token
    def get_session(self) -> requests.Session:
        self.session.headers["Authorization"] = f"Bearer {self._get_token()}"
        return self.session
OAuth Scope: station:read (required for subsequent station queries)
Step 1: Retrieve Stations and Construct Audit Payloads
The Pure Connect API returns station lists with pagination. You must construct an audit payload containing firmware references, a version matrix, and an inspect directive. The payload is validated against telephony constraints and maximum version skew limits.
import logging
from pydantic import BaseModel, Field, validator
class FirmwareConstraint(BaseModel):
    max_version_skew: int = Field(ge=1, le=10)
    supported_hardware_ids: List[str]
    min_firmware_version: str
class AuditPayload(BaseModel):
    firmware_reference: str
    version_matrix: Dict[str, str]
    inspect_directive: str = Field(pattern=r"^(VERIFY|ROLLBACK|DEPLOY)$")
    @validator("version_matrix")
    def validate_skew(cls, v, values):
        # Placeholder for skew validation against constraint
        return v
def fetch_stations(session: requests.Session, base_url: str, page: int = 1, limit: int = 100) -> Dict[str, Any]:
    """Fetch paginated station list with 429 retry logic."""
    max_retries = 3
        response = session.get(
            f"{base_url}/api/v1/stations",
            params={"page": page, "limit": limit}
            wait_time = 2 ** attempt
            logger.warning("Rate limited (429). Retrying in %d seconds.", wait_time)
            time.sleep(wait_time)
        return response.json()
    raise requests.exceptions.TooManyRequests("Exceeded maximum retry attempts for 429.")
def build_audit_payload(stations: List[Dict], constraint: FirmwareConstraint) -> List[Dict[str, Any]]:
    """Construct auditing payloads with firmware references and version matrix."""
    payloads = []
    for station in stations:
        current_fw = station.get("firmware_version", "0.0.0")
        hardware_id = station.get("hardware_id")
        # Hardware compatibility check
        if hardware_id not in constraint.supported_hardware_ids:
            logger.warning("Station %s hardware %s is not in supported list. Skipping.", station["id"], hardware_id)
        payload = {
            "station_id": station["id"],
            "firmware_reference": f"PC-FW-{hardware_id}-{current_fw}",
            "version_matrix": {
                "current": current_fw,
                "target": constraint.min_firmware_version,
                "architecture": station.get("architecture", "x86_64")
            "inspect_directive": "VERIFY"
        payloads.append(payload)
    return payloads
OAuth Scope: station:read, firmware:read
HTTP Cycle:
  • Method: GET
  • Path: /api/v1/stations?page=1&limit=100
  • Headers: Authorization: Bearer <token>, Accept: application/json
  • Response: {"stations": [{"id": "STN-001", "firmware_version": "14.2.1", "hardware_id": "PC-6800"}], "pagination": {"next_page": 2}}
Step 2: Execute Inspect Directive with Checksum and Rollback State Preservation
The audit process must perform atomic GET operations to fetch the current firmware checksum and rollback state. You verify the signature pipeline and validate the format before proceeding.
import hashlib
import json
def inspect_station_firmware(session: requests.Session, base_url: str, payload: Dict[str, Any]) -> Dict[str, Any]:
    """Execute inspect directive and validate checksum/rollback state."""
    station_id = payload["station_id"]
    # Atomic GET for state preservation
    state_response = session.get(f"{base_url}/api/v1/stations/{station_id}/state")
    state_response.raise_for_status()
    state_data = state_response.json()
    current_checksum = state_data.get("firmware_checksum")
    rollback_preserved = state_data.get("rollback_state", "NONE")
    # Signature verification pipeline
    expected_checksum = hashlib.sha256(
        f"{payload['firmware_reference']}{payload['version_matrix']['current']}".encode()
    ).hexdigest()
    signature_valid = current_checksum == expected_checksum
    if not signature_valid:
        logger.error("Checksum mismatch for station %s. Audit halted.", station_id)
        return {"station_id": station_id, "status": "CHECKSUM_FAILURE", "rollback_state": rollback_preserved}
    # Inspect directive execution
    inspect_response = session.post(
        f"{base_url}/api/v1/audit/inspect",
        json=payload
    inspect_response.raise_for_status()
    return inspect_response.json()
OAuth Scope: audit:execute
HTTP Cycle:
  • Method: POST
  • Path: /api/v1/audit/inspect
  • Body: {"station_id": "STN-001", "firmware_reference": "PC-FW-PC-6800-14.2.1", "version_matrix": {"current": "14.2.1", "target": "14.3.0", "architecture": "x86_64"}, "inspect_directive": "VERIFY"}
  • Response: {"audit_id": "AUD-9921", "status": "COMPLETED", "verified": true}
Step 3: Trigger Maintenance Windows and Sync to External IT Asset Managers
After successful inspection, the system triggers automatic maintenance windows for safe audit iteration. Results are synchronized to an external IT asset manager via webhooks. Latency and success rates are tracked.
class AuditMetrics:
    def __init__(self):
        self.total_inspected = 0
        self.successful = 0
        self.failed = 0
        self.total_latency_ms = 0.0
    def record(self, success: bool, latency_ms: float):
        self.total_inspected += 1
        self.total_latency_ms += latency_ms
        if success:
            self.successful += 1
        else:
            self.failed += 1
    def get_summary(self) -> Dict[str, Any]:
            "total": self.total_inspected,
            "success_rate": self.successful / self.total_inspected if self.total_inspected > 0 else 0.0,
            "avg_latency_ms": self.total_latency_ms / self.total_inspected if self.total_inspected > 0 else 0.0
def trigger_maintenance_window(session: requests.Session, base_url: str, station_id: str) -> bool:
    """Create automatic maintenance window for safe audit iteration."""
    window_payload = {
        "start_time": (datetime.utcnow() + timedelta(minutes=5)).isoformat() + "Z",
        "duration_minutes": 30,
        "reason": "Firmware audit and verification"
        response = session.post(f"{base_url}/api/v1/maintenance/windows", json=window_payload)
        return True
        logger.error("Failed to trigger maintenance window for %s: %s", station_id, e)
        return False
def sync_to_ita_manager(webhook_url: str, audit_result: Dict[str, Any], metrics: AuditMetrics) -> None:
    """Synchronize auditing events with external IT asset managers via webhooks."""
    webhook_payload = {
        "event_type": "FIRMWARE_AUDIT_COMPLETED",
        "timestamp": datetime.utcnow().isoformat() + "Z",
        "audit_data": audit_result,
        "metrics": metrics.get_summary()
        requests.post(webhook_url, json=webhook_payload, timeout=10)
        logger.info("Webhook synced for audit %s.", audit_result.get("audit_id"))
        logger.error("Webhook delivery failed: %s", e)
OAuth Scope: maintenance:write, webhook:write
HTTP Cycle:
  • Method: POST
  • Path: /api/v1/maintenance/windows
  • Body: {"station_id": "STN-001", "start_time": "2024-06-15T10:05:00Z", "duration_minutes": 30, "reason": "Firmware audit and verification"}
  • Response: {"window_id": "MW-4412", "status": "SCHEDULED"}
The following script combines authentication, pagination, payload construction, inspection, maintenance triggering, webhook synchronization, and metric tracking into a single executable module.
import requests
import logging
import hashlib
from typing import List, Dict, Any, Optional
class AuditMetrics:
    def __init__(self):
        self.successful = 0
        self.failed = 0
        if success:
        else:
            self.failed += 1
class PureConnectFirmwareAuditor:
    def __init__(self, base_url: str, client_id: str, client_secret: str, ita_webhook_url: str, constraint: FirmwareConstraint):
        self.ita_webhook_url = ita_webhook_url
        self.constraint = constraint
        self.session.headers.update({"Content-Type": "application/json", "Accept": "application/json"})
        self.metrics = AuditMetrics()
            return self.token
        payload = {"grant_type": "client_credentials", "client_id": self.client_id, "client_secret": self.client_secret}
        response = self.session.post(f"{self.base_url}/oauth/token", json=payload)
        return self.token
    def _request_with_retry(self, method: str, url: str, **kwargs) -> requests.Response:
        max_retries = 3
            response = self.session.request(method, url, **kwargs)
            return response
    def fetch_all_stations(self) -> List[Dict[str, Any]]:
        stations = []
        page = 1
        while True:
            resp = self._request_with_retry("GET", f"{self.base_url}/api/v1/stations", params={"page": page, "limit": 100})
            resp.raise_for_status()
            data = resp.json()
            stations.extend(data.get("stations", []))
            if not data.get("pagination", {}).get("next_page"):
                break
            page = data["pagination"]["next_page"]
        return stations
    def run_audit(self) -> AuditMetrics:
        logger.info("Fetching stations...")
        stations = self.fetch_all_stations()
        logger.info("Found %d stations.", len(stations))
        payloads = []
            if hardware_id not in self.constraint.supported_hardware_ids:
                logger.warning("Station %s hardware %s unsupported. Skipping.", station["id"], hardware_id)
            payloads.append({
                "firmware_reference": f"PC-FW-{hardware_id}-{station['firmware_version']}",
                "version_matrix": {
                    "current": station["firmware_version"],
                    "target": self.constraint.min_firmware_version,
        logger.info("Executing audit cycle for %d stations.", len(payloads))
        for payload in payloads:
                state_resp = self._request_with_retry("GET", f"{self.base_url}/api/v1/stations/{payload['station_id']}/state")
                state_resp.raise_for_status()
                state_data = state_resp.json()
                ).hexdigest()
                if state_data.get("firmware_checksum") != expected_checksum:
                    logger.error("Checksum mismatch for %s.", payload["station_id"])
                    self.metrics.record(False, (time.perf_counter() - start_time) * 1000)
                inspect_resp = self._request_with_retry("POST", f"{self.base_url}/api/v1/audit/inspect", json=payload)
                inspect_resp.raise_for_status()
                audit_result = inspect_resp.json()
                trigger_maint = self._request_with_retry("POST", f"{self.base_url}/api/v1/maintenance/windows", json={
                    "station_id": payload["station_id"],
                trigger_maint.raise_for_status()
                self.metrics.record(True, (time.perf_counter() - start_time) * 1000)
                logger.info("Audit completed for %s. ID: %s", payload["station_id"], audit_result.get("audit_id"))
                requests.post(self.ita_webhook_url, json={
                    "metrics": self.metrics.get_summary()
                }, timeout=10)
                logger.error("Audit failed for %s: %s", payload["station_id"], e)
        logger.info("Audit cycle complete. Summary: %s", self.metrics.get_summary())
        return self.metrics
    CONSTRAINT = FirmwareConstraint(
        max_version_skew=3,
        supported_hardware_ids=["PC-6800", "PC-7500", "PC-9200"],
        min_firmware_version="14.3.0"
    auditor = PureConnectFirmwareAuditor(
        base_url="https://your-tenant.pureconnect.com",
        client_id="your_client_id",
        client_secret="your_client_secret",
        ita_webhook_url="https://your-ita-manager.com/api/webhooks/firmware",
        constraint=CONSTRAINT
    auditor.run_audit()
  • What causes it: The OAuth token has expired, the client credentials are incorrect, or the scope lacks station:read or audit:execute.
  • How to fix it: Verify the client_id and client_secret. Ensure the token refresh logic runs before each request. Check the Pure Connect admin console to confirm the OAuth client has the required scopes.
  • Code showing the fix: The _get_token method automatically refreshes when time.time() >= self.token_expiry. If credentials are wrong, catch requests.exceptions.HTTPError and log the response body.
Error: 403 Forbidden
  • What causes it: The authenticated user lacks permission to access the /api/v1/audit/inspect or /api/v1/maintenance/windows endpoints.
  • How to fix it: Assign the Telephony Administrator or Firmware Manager role to the OAuth client service account. Verify the inspect_directive value matches allowed values (VERIFY, ROLLBACK, DEPLOY).
  • Code showing the fix: Add scope validation before execution: if "audit:execute" not in granted_scopes: raise PermissionError("Missing audit:execute scope").
  • What causes it: The audit loop exceeds Pure Connect API rate limits during pagination or inspection calls.
  • How to fix it: The _request_with_retry method implements exponential backoff. Ensure you do not spawn parallel threads for station inspection. Process stations sequentially or use a bounded semaphore.
  • Code showing the fix: The retry loop sleeps for 2 ** attempt seconds and caps at 3 attempts before raising TooManyRequests.
Error: Checksum Mismatch During Signature Verification
  • What causes it: The firmware binary on the station does not match the expected SHA256 hash derived from the firmware reference and version matrix. This indicates corruption or an unauthorized firmware flash.
  • How to fix it: Halt the audit for that station. Trigger a rollback state preservation via the /api/v1/stations/{id}/state endpoint. Manually verify the station hardware or redeploy the verified firmware package.
  • Code showing the fix: The script compares state_data.get("firmware_checksum") against hashlib.sha256(...). On mismatch, it logs the error, records a failure metric, and skips maintenance window creation.
