Auditing and Reporting in Genesys Cloud CX: A Complete Guide to System Logs, Event Data Export, and Security Monitoring
This guide details configuring comprehensive auditing and reporting within Genesys Cloud CX, focusing on system log access, event data export to external SIEM solutions, and leveraging data for security monitoring. The end result will be a robust, auditable system providing visibility into user actions, system events, and security-relevant activity, allowing for proactive threat detection and compliance reporting.
- Licensing Tier: Genesys Cloud CX Enterprise or higher is required for full access to all auditing and reporting features. Data Connect is required for exporting event data.
- Permissions: The following granular permissions are essential:
Administration > System Configuration > ViewAdministration > System Configuration > EditReporting > Historical Reports > ViewReporting > Historical Reports > EditData Connect > Data Connections > ViewData Connect > Data Connections > CreateAdministration > Security > Audit Log > ViewAdministration > Security > Audit Log > Export
- OAuth Scopes (for API access):
gc_data_connect_read,gc_audit_log_read - External Dependencies: A SIEM solution (Splunk, Sumo Logic, Azure Sentinel, etc.) and a data pipeline or connector to ingest data from Genesys Cloud CX Data Connect.
1. Configuring Audit Log Retention and Access
Genesys Cloud CX’s audit log captures a wealth of information regarding user activity, system changes, and security events. The default retention period is 30 days. Increasing this retention is crucial for longer-term investigations and compliance requirements.
Navigate to Administration > Security > Audit Log. Here you can adjust the Retention Period (Days). The maximum retention is 90 days. Be mindful of the storage cost implications of longer retention periods.
The Trap: Setting the retention period to the maximum without considering storage costs. Unexpectedly high monthly bills can occur. Monitor storage usage within Administration > System Configuration > Storage Usage.
Architecturally, the audit log is designed for forensic analysis, not real-time monitoring. It’s a historical record of events. Relying on it for immediate threat detection is unreliable due to processing latency.
2. Exporting Event Data via Data Connect
The most effective method for continuous monitoring and integration with a SIEM is leveraging the Data Connect feature. This allows for near real-time streaming of event data to an external destination.
First, create a Data Connection. Navigate to Admin > Data Connect > Data Connections > Add. Choose the desired destination type (e.g., Amazon Kinesis, Azure Event Hub, HTTP Webhook). Configure the connection details, including authentication credentials and endpoint URL.
Next, create a Data Export. Navigate to Admin > Data Connect > Data Exports > Add.
- Name: Give your export a descriptive name (e.g., “CXone Audit Log to Splunk”).
- Data Connection: Select the Data Connection created in the previous step.
- Data Type: Select “Audit Log”.
- Filters: This is where you can selectively export events based on criteria like user ID, event type, or timestamp. Filters are applied before data is sent, reducing noise and cost.
- Frequency: Choose the desired export frequency. The options are Real-Time (immediate streaming) and Hourly (batch export). Real-Time is preferable for security monitoring.
Here’s an example JSON payload for creating a Data Export via API:
"name": "CXone Audit Log to Splunk",
"dataConnectionId": "a1b2c3d4-e5f6-7890-1234-567890abcdef",
"dataType": "AUDIT_LOG",
"frequency": "REAL_TIME",
"filters": [
"field": "eventType",
"operator": "IN",
"values": ["user_login", "user_logout", "system_change"]
API Endpoint: POST /api/v1/dataexports
OAuth Scope: gc_data_connect_read
The Trap: Forgetting to configure filters on the Data Export. This results in all audit log events being exported, overwhelming your SIEM and incurring unnecessary costs.
3. Utilizing Historical Reports for Compliance and Trend Analysis
While Data Connect is ideal for real-time monitoring, Genesys Cloud CX’s built-in historical reporting capabilities are valuable for compliance and trend analysis.
Navigate to Reporting > Historical Reports. You can create custom reports based on various data sources, including audit log data. Focus on the “Audit” category.
The Trap: Assuming that Historical Reports provide the same level of granularity and real-time accuracy as Data Connect. Historical reports are designed for aggregated analysis, not detailed forensic investigations.
You can filter reports by date range, user, event type, and other criteria. The reports can be scheduled to be delivered automatically via email.
4. Customizing Audit Log Event Types
Genesys Cloud CX allows you to define custom event types to be audited, providing greater control over the information collected. This is particularly useful for tracking specific business processes or configurations.
Navigate to Admin > System Configuration > Audit Log > Custom Events. Here, you can define custom event types and associate them with specific API calls or actions within Genesys Cloud CX. This requires a technical understanding of the Genesys Cloud CX API.
The Trap: Defining overly broad custom event types that generate excessive logging and impact performance. Carefully scope the custom events to only include the actions that are genuinely critical to audit.
Edge Case 1: Data Connect Export Failure – Authentication Error
The failure condition: The Data Export status shows as “Failed” with an error message indicating an authentication failure.
The root cause: Incorrect credentials configured in the Data Connection or insufficient permissions on the destination system.
The solution: Verify the credentials in the Data Connection. Test the connection independently using a tool like Postman or curl to ensure the credentials are valid. Confirm that the user account used in the Data Connection has the necessary permissions on the destination system.
Edge Case 2: Audit Log Data Missing in SIEM – Filtering Issue
The failure condition: Expected audit log events are not appearing in the SIEM, despite the Data Export showing as “Active”.
The root cause: A filter in the Data Export is unintentionally excluding the relevant events.
The solution: Review the filters configured in the Data Export. Temporarily remove all filters to confirm that the events are being exported correctly. Then, re-add the filters one by one, testing after each addition to identify the problematic filter.
Edge Case 3: Historical Report Data Inconsistency
The failure condition: Data in a Historical Report does not match data observed in the live system.
The root cause: Data latency or aggregation issues within the reporting system.
The solution: Verify the time range of the report. Be aware that Historical Reports are not always real-time. If the discrepancy persists, contact Genesys Cloud CX support.
