Audit Log Granularity Gaps for BYOC Trunk Credential Rotation
No idea why this is happening, the Genesys Cloud Admin Console audit logs lack sufficient granularity for compliance verification during bulk BYOC trunk credential rotations.
  • Managing 15 BYOC trunks across APAC regions requires strict adherence to security protocols, specifically regarding SIP credential updates and failover logic validation.
  • Recent internal audits highlighted a critical gap: the standard audit logs only record the high-level event of ‘Trunk Configuration Updated’ without detailing which specific fields were modified.
  • This lack of detail makes it impossible to distinguish between a routine SIP credential refresh and a potentially malicious alteration of outbound routing rules or carrier failover priorities.
  • The current logging behavior obscures the exact timestamp and user action for changes to sensitive fields like ‘SIP Username’, ‘SIP Password’, and ‘Failover Strategy’.
  • Attempts to retrieve more detailed metadata via the audit query API endpoints have proven insufficient, as the payload structure remains generic for trunk configuration changes.
  • The JSON response from the API endpoint provides a ‘changes’ object, but it often aggregates multiple field updates into a single entry, lacking the atomicity required for forensic analysis.
  • For example, when rotating credentials for the Singapore primary trunk, the log entry groups the password change with a minor update to the ‘Description’ field, making it difficult to isolate the security-critical action.
  • This aggregation issue complicates the generation of compliance reports for SOC 2 Type II audits, where specific evidence of who changed what and when is mandatory.
  • The environment involves complex SIP registration logic with carrier-specific quirks, necessitating precise tracking of configuration drift and credential lifecycle events.
  • Is there a known limitation in the current Genesys Cloud version regarding audit log depth for BYOC trunk configurations?
  • Or is there an alternative API endpoint or webhook mechanism that can capture these granular changes in real-time?
  • The goal is to ensure that every credential rotation and routing change is individually logged with full context for security review purposes.
