Audio Toaster
Another question with toaster popup, is it possible to play audio when toaster popup. Any parameter to enable it?
genesys.wwe.service.system.popupToast({
title: “Alert Message”,
iconUrl: msgURL,
subject: “Testing”,
message: “Click Yes/No”,
buttons: buttonName,
buttonShowDismiss: false
}, succeeded, failed);
Kumar
You could just do it through javascript itself.
After you call the popupToast method:
                        title: "Alert Message",
                        iconUrl: msgURL,
                        subject: "Testing",
                        message: "Click Yes/No",
// Here you place a code to play the audio, for example:
new Audio('https://www.your-domain.com/your-audio-file.mp3').play();
