Audio file corrupt when using g729
I have problems with calls made with the IWS as calls are recorded corrupt however with eyebeam if recorded properly.
I edit the file Edpoint.config to ensure that the g729 codec use and if it does .
someone has already encountered this case ?, I would appreciate if you can guide me about it.
Best regards.
It also depends on SIP server codec configuration. What say logs? what about SIP signalization - what do you see there, in SDP?
